S1A-784114
S1A-784114
    NEWAGE
    LARGE HANDHELD
S1A-784114 数据手册
NOTES: UNLESS OTHERWISE SPECIFIED R E V I S I O N DESCRIPTION PRELIMINARY RELEASE DATE 08-Jul-04 APPROVED D.C. M BOYER RELEASED 09-Jul-04 D.C. M BOYER MODIFIED BATTERY COMPARTMENT 06-Aug-04 D.C. 0208 UPDATE FORMAT 15-May-08 D.C. M BOYER 4209 REDUCE SIZE OF ASSEMBLY SCREW HOLE ON BASE 04-Nov-09 D.C. M BOYER 0710 UPDATE FORMAT 26-Mar-10 D.C. 13-Feb-12 D.C. REV. 1 DRAWN BY M BOYER 2 3 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4 M BOYER 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5 5.1 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11010. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. ECO No 5.2 M BOYER 0412 ADD NYLON WASHER TO BOM 5.3 M BOYER 04715 CHANGE ASSY SCREW FROM #6x.250 TO #4x.500 2015-Nov-04 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 5 9. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE UPON REQUEST FOR QUOTE. 2 10. ASSEMBLY SCREWS PROVIDED. PCB SCREWS AND BATTERY CONTACTS ARE SOLD SEPERATELY. 11. BATTERY CLIPS AVAILABLE. 4 ASK REP. FOR DETAILS 12. HARDWARE CALLOUT: a) ASSY BOSS 4ea .500" #4 HI-LOW SCREW b) PCB BOSS 4ea .187" #4 HI-LOW SCREW (Not Included) c) BATTERY HATCH - 1ea 4-40 BRASS INSERT 1ea 4-40 FLATHEAD SCREW 1ea #2 RETAINER WASHER 10 9 8 11 6 11 WASHER_91755A2 WASHER NYLON RETAINING #2 NYLON WHITE 1 10 BATTERY_AA BATTERY - CUSTOMER SUPPLIED SIZE "AA" REFERENCE 4 9 SM_CLIP ACC-AACLIP-209 STEEL NICKEL PLATED 2 8 LG_CLIP ACC-AACLIP-210 STEEL NICKEL PLATED 3 7 SCREW_HILO-NO4X500 #4 HiLo x .500" SCREW ZINK PLATED INCLUDED 4 6 784114_HATCH 784114 HATCH - STANDARD ABS BLACK or WHITE 1 5 784114_COVER 784114 COVER - STANDARD ABS BLACK or WHITE 1 4 784114_BASE 784114 BASE - STANDARD ABS BLACK or WHITE 1 3 4-40_INSERT PEM STKB-440-8 STK SERIES INSERT 4-40 x .250" 1 2 784114_PCB 784114 PCB - REFERENCE CUSTOMER SUPPLIED .062" THICK 1 1 4-40_FLAT-HEAD-SCREW 4-40 FLAT HEAD 4-40 FH x .312" - 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS EXPLODED VIEW SCALE 0.500 1 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 784114 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 LRG HANDHELD - STANDARD SXX-784114-XXX SIZE 2004-Jul-08 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 784114_R5_3 SHEET 1 OF 7 REV.DOC 5.3 COVER LABEL AREA AVAILABLE FOR CUSTOM TOOLING 6.58" x 3.15" 4.100 3.250 BASE LABEL AREA AVAILABLE FOR CUSTOM TOOLING 3.25" X 3.25" 3.150 1.625 A R.188 .755 .320 3.250 7.875 .250 6.575 .830 2.760 SECTION A-A SCALE 0.500 A 2.505 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .990 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 1.477 NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 784114 DATE CHECK ENG. .465 SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 LRG HANDHELD - STANDARD SXX-784114-XXX SIZE 2004-Jul-08 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 784114_R5_3 SHEET 2 OF 7 REV.DOC 5.3 784114 COVER A .249 .100 .990 .078 3.400 7.875 3.400 SECTION A-A A 1.600 1.600 SCALE 0.500 LABEL AREA RECESS AVAILABLE .020 DEEP TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES 4.100 Customer's Part No: APPROVAL BY 784114 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 LRG HANDHELD - STANDARD SXX-784114-XXX SIZE 2004-Jul-08 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 784114_R5_3 SHEET 3 OF 7 REV.DOC 5.3 4-40 BRASS INSERT 784114 BASE .125 .855 1.600 4X .311 P .465 1.600 A 2.310 .100 P 2.315 3.400 .025 2.245 .249 4x .093 (4X .320) 3.400 2X 3.025 .100 SECTION A-A 3.100 OPTIONAL LABEL RECESS x .020 DEEP (R.188) A SCALE 0.500 BRASS INSERTS AVAILABLE AT PCB STANDOFFS ASK REP FOR DETAILS TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .200 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 784114 DATE CHECK SECTION P-P ENG. .270 -4° DRAFT/SIDE SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 LRG HANDHELD - STANDARD SXX-784114-XXX SIZE 2004-Jul-08 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 784114_R5_3 SHEET 4 OF 7 REV.DOC 5.3 784114 BATTERY HATCH 2.495 .750 .050 .290 1.375 2.750 .075 3.035 SCALE 1.000 .150 .187 1.250 R.693 .145 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 784114 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 LRG HANDHELD - STANDARD SXX-784114-XXX SIZE 2004-Jul-08 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 784114_R5_3 SHEET 5 OF 7 REV.DOC 5.3 784114 PCB - CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 5.950 .062 2.319 1.674 2x 1.869 .000 1.326 2x 2.319 3.631 4.638 1.825 1.550 2x 1.375 1.156 R.070 4x .000 EXTENDED LEGS NOT NESSESARY DESIGNERS OPTION 1.156 1.375 1.550 2x 1.825 SCALE 1.000 .120 4x TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 784114 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 LRG HANDHELD - STANDARD SXX-784114-XXX SIZE 2004-Jul-08 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 784114_R5_3 SHEET 6 OF 7 REV.DOC 5.3 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" SCALE 0.500 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° SXX-784114X-XXX COVER - ABS, BLACK NEW AGE ENCLOSURES Customer's Part No: STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 3-C-C3 SIDE SIDE SIDE T2 = .062" EM T2 = .062" EM T2 = .062" EM 118 118 118 SINGLE - - APPROVAL BY 784114 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 LRG HANDHELD - STANDARD SXX-784114-XXX SIZE 2004-Jul-08 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 784114_R5_3 SHEET 7 OF 7 REV.DOC 5.3
S1A-784114 价格&库存
很抱歉,暂时无法提供与“S1A-784114”相匹配的价格&库存,您可以联系我们找货
