R E V I S I O N
REV.
DRAWN BY
1
M BOYER
2
M BOYER
2.1
SXX-301210
3" DONGLE
MOLD USING 2 SHORT ENDS
INCLUDES 4 #4 x 3/8" ASSEMBLY SCREWS
ECO No
DESCRIPTION
DATE
APPROVED
PRELIMINARY RELEASE
09-Apr-08
D.C.
2408
UPDATE TO AS BUILT AND B.O.M. INFORMATION
17-Jul-08
D.C.
M BOYER
0710
UPDATE FORMAT
05-Mar-10
D.C.
3.0
M BOYER
1610
REMOVE EXTRA ASSEMBLY SCREW HOLES
01-Jun-10
D.C.
4.0
M BOYER
3110
INCREASE HEIGHT OF RETAINING RIBS ON BASE
26-Aug-10
D.C.
5.0
M BOYER
5410
INCREASE DRAFT ON END OF BASE TO 2°
14-Dec-10
D.C.
5.1
M BOYER
3712
MODIFY NOTE ON PG 5
22-Oct-12
D.C.
5.2
M BOYER
2013
UPDATE AS-BUILT TEXTURE INFORMATION
22-Apr-13
D.C.
S(X)01210 CONFIGURATIONS
SXX-401210
3"
4" DONGLE
SCALE 1.000
S301210
S301210
S401210
S401210
S501210
S501210
#4 HiLo
MOLD USING 1 SHORT & 1 LONG END
NOTES:
COVER
BASE
COVER
BASE
COVER
BASE
SCREW .375"
4"
5"
1
1
1
1
4
1
1
4
4
UNLESS OTHERWISE SPECIFIED
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11020.
SXX-501210
SCALE 1.000
5" DONGLE
MOLD USING 2 LONG ENDS
3. INTERIOR SURFACE TEXTURE TO BE: NONE.
4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX,
UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF
THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT
THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED.
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
7. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM
MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION
OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH O.E.M.
9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED.
ARE UNNESESSARY WITH PCB CAPTURE DESIGN.
MOUNTING SCREWS
10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED
BY THE SOLID MODEL FILE.
SCALE 1.000
11. ALLOWABLE FLASH: 0.010 MAX.
THIS ENCLOSURE IS MOLDED WITH A "SHORT" OR "LONG"
END ON EITHER HALF. THE DETAILS ON THE FOLLOWING
SHEET SHOW THE 4" VERSION SINCE IT'S MOLDED
WITH ONE LONG END AND ONE SHORT END.
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
4
X01210 COVER - STANDARD
ABS
BLACK or WHITE
1
3
X01210 BASE - STANDARD
ABS
BLACK or WHITE
1
2
HiLo #4 x 3/8"
STEEL
.375" LONG
4
1
X01210 PCB
REFERENCE ONLY
.062" THICK
1
ITEM
DESCRIPTION
MATERIAL
COLOR
QTY.
BILL OF MATERIALS
THIRD ANGLE PROJECTION
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2012
4330 Santa Fe Road
ph. (805) 595-1310
APPROVAL
BY
STANDARD - DONGLE
SXX-X01210 ASSEMBLY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
SIZE
09-Apr-08
San Luis Obispo, CA. 93401
fax (805) 595-1024
www.newageenclosures.com
Customer's Part No: (X)01210
DRAWING NAME
A SX01210_R5_2
SHEET
1 OF 6
REV.DOC
5.2
2.500
1.500
1.110
1.110
LONG | SHORT
.030
R1.280
.710
(.655)
CLEAR
1.000
SCALE 1.000
.270
(.133)
CLEAR
SECTION P-P
1.330 x2
.000
2.305 x2
1.249
.440 x2
.400
.000
.400
.440 x2
NOTE:
4" DONGLE SHOWN TO REPRESENT
1 LONG END & 1 SHORT END CONFIGURATION.
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
APPROVAL
FOR THE 3" & 5" VERSIONS,
MATCHING ENDS SHOULD BE USED.
4330 Santa Fe Road
ph. (805) 595-1310
BY
STANDARD - DONGLE
SXX-X01210 ASSEMBLY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
SIZE
09-Apr-08
fax (805) 595-1024
DRAWING NAME
A SX01210_R5_2
SHEET
2 OF 6
REV.DOC
5.2
1.0°
SECTION Y-Y
4.000
.030
1.274
Y
Y
R1.280
SCALE 1.000
30.0°
.010
P
.075
3.0°
.760
.050
P
SECTION P-P
.440
2.500
2.305
1.330
1.125
.000
1.125
1.330
1.500
.030
.400
SHORT | LONG
.000
X.XXX = .010
X.X° = 1°
.400
.440
NEW AGE ENCLOSURES
4330 Santa Fe Road
ph. (805) 595-1310
.188
.092
APPROVAL
BY
STANDARD - DONGLE
SXX-X01210 ASSEMBLY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
SIZE
09-Apr-08
fax (805) 595-1024
DRAWING NAME
A SX01210_R5_2
SHEET
3 OF 6
REV.DOC
5.2
1.499
2.499
S
.030
(.133)
.062
1.274
DETAIL B
SCALE 4.000
.035
.025
.501 TO CL
SEE DETAIL B
S
.270
3.0°
16.0°
SECTION S-S
.075
.035
(.120)
SEE DETAIL A
.192
.125
.143
2.499
2.305 x2
1.125
.875 x2
.250 x2
.000
.250 x2
.875 x2
1.125
1.330 x2
1.499
SECTION F-F
.032
.030
.440
.466
SHORT | LONG
.400
F
.000
DETAIL A
SCALE 4.000
F
.466
.440
.400
SCALE 1.000
.260
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
4330 Santa Fe Road
ph. (805) 595-1310
APPROVAL
2.0°
BY
STANDARD - DONGLE
SXX-X01210 ASSEMBLY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
SIZE
09-Apr-08
fax (805) 595-1024
DRAWING NAME
A SX01210_R5_2
SHEET
4 OF 6
REV.DOC
5.2
2.400
2.240
1.190
.000
1.190
1.400
.380
(X)01210 PCB - CUSTOMER SUPPLIED
SIZES AND VERIFICATION OF IT'S FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
.500
.380
.335
SHORT | LONG
PROPOSED PCB SIZE
.000
.335
.380
.500
.380
R.062 TYP.
45° TYP.
2.305 x2
1.330 x2
.000
1.330 x2
.062
.440 x2
.400
TOP - KEEP OUT ZONES
.000
.400
.440 x2
2.305 x2
1.330 x2
.875 x2
.000
.875 x2
.207 6 PLACES
KEEP OUT
1.330 x2
SCALE 1.000
.440 x2
.400
SCALE 1.500
BOTTOM - KEEP OUT ZONES
.000
.400
.440 x2
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
.040
.050
.280 6 PLACES
KEEP OUT
4330 Santa Fe Road
ph. (805) 595-1310
APPROVAL
BY
STANDARD - DONGLE
SXX-X01210 ASSEMBLY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
SIZE
09-Apr-08
fax (805) 595-1024
DRAWING NAME
A SX01210_R5_2
SHEET
5 OF 6
REV.DOC
5.2
2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
SCALE 1.000
X.XXX = .010
X.X° = 1°
SXX-X01210-XXX
COVER
NEW AGE ENCLOSURES
ABS, BLACK
4330 Santa Fe Road
ph. (805) 595-1310
STEP NO
DESCRIPTION
CUTTER
FIXTURE
ORIENTATION
1
2
3
T2 = .062" EM
T2 = .062" EM
T2 = .062" EM
178
178
178
PROGRAM
APPROVAL
BY
STANDARD - DONGLE
SXX-X01210 ASSEMBLY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
SIZE
09-Apr-08
fax (805) 595-1024
DRAWING NAME
A SX01210_R5_2
SHEET
6 OF 6
REV.DOC
5.2
很抱歉,暂时无法提供与“S3A-401210”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+55.704631+6.96976
- 5+47.613925+5.95745
- 10+44.4946710+5.56717
- 25+40.6991125+5.09227
- 50+38.0405850+4.75963
- 100+35.55570100+4.44873
- 250+32.51821250+4.06868
- 500+30.63464500+3.83300
