S1A-401210
S1A-401210
    NEWAGE
    4 INCH DONGLE
S1A-401210 数据手册
R E V I S I O N REV. DRAWN BY 1 M BOYER 2 M BOYER 2.1 SXX-301210 3" DONGLE MOLD USING 2 SHORT ENDS INCLUDES 4 #4 x 3/8" ASSEMBLY SCREWS ECO No DESCRIPTION DATE APPROVED PRELIMINARY RELEASE 09-Apr-08 D.C. 2408 UPDATE TO AS BUILT AND B.O.M. INFORMATION 17-Jul-08 D.C. M BOYER 0710 UPDATE FORMAT 05-Mar-10 D.C. 3.0 M BOYER 1610 REMOVE EXTRA ASSEMBLY SCREW HOLES 01-Jun-10 D.C. 4.0 M BOYER 3110 INCREASE HEIGHT OF RETAINING RIBS ON BASE 26-Aug-10 D.C. 5.0 M BOYER 5410 INCREASE DRAFT ON END OF BASE TO 2° 14-Dec-10 D.C. 5.1 M BOYER 3712 MODIFY NOTE ON PG 5 22-Oct-12 D.C. 5.2 M BOYER 2013 UPDATE AS-BUILT TEXTURE INFORMATION 22-Apr-13 D.C. S(X)01210 CONFIGURATIONS SXX-401210 3" 4" DONGLE SCALE 1.000 S301210 S301210 S401210 S401210 S501210 S501210 #4 HiLo MOLD USING 1 SHORT & 1 LONG END INCLUDES 4 #4 x 3/8" ASSEMBLY SCREWS NOTES: COVER BASE COVER BASE COVER BASE SCREW .375" 4" 5" 1 1 1 1 4 1 1 4 4 UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11020. SXX-501210 SCALE 1.000 5" DONGLE MOLD USING 2 LONG ENDS INCLUDES 4 #4 x 3/8" ASSEMBLY SCREWS 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX, UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH O.E.M. 9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. ARE UNNESESSARY WITH PCB CAPTURE DESIGN. MOUNTING SCREWS 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. SCALE 1.000 11. ALLOWABLE FLASH: 0.010 MAX. THIS ENCLOSURE IS MOLDED WITH A "SHORT" OR "LONG" END ON EITHER HALF. THE DETAILS ON THE FOLLOWING SHEET SHOW THE 4" VERSION SINCE IT'S MOLDED WITH ONE LONG END AND ONE SHORT END. TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 4 X01210 COVER - STANDARD ABS BLACK or WHITE 1 3 X01210 BASE - STANDARD ABS BLACK or WHITE 1 2 HiLo #4 x 3/8" STEEL .375" LONG 4 1 X01210 PCB REFERENCE ONLY .062" THICK 1 ITEM DESCRIPTION MATERIAL COLOR QTY. BILL OF MATERIALS THIRD ANGLE PROJECTION NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2012 4330 Santa Fe Road ph. (805) 595-1310 APPROVAL BY STANDARD - DONGLE SXX-X01210 ASSEMBLY DATE CHECK ENG. SCALE DRAWN BY M BOYER SIZE 09-Apr-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: (X)01210 DRAWING NAME A SX01210_R5_2 SHEET 1 OF 6 REV.DOC 5.2 2.500 1.500 1.110 1.110 LONG | SHORT .030 R1.280 .710 (.655) CLEAR 1.000 SCALE 1.000 .270 (.133) CLEAR SECTION P-P 1.330 x2 .000 2.305 x2 1.249 .440 x2 .400 .000 .400 .440 x2 NOTE: 4" DONGLE SHOWN TO REPRESENT 1 LONG END & 1 SHORT END CONFIGURATION. TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES APPROVAL FOR THE 3" & 5" VERSIONS, MATCHING ENDS SHOULD BE USED. 4330 Santa Fe Road ph. (805) 595-1310 BY STANDARD - DONGLE SXX-X01210 ASSEMBLY DATE CHECK ENG. SCALE DRAWN BY M BOYER SIZE 09-Apr-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: (X)01210 DRAWING NAME A SX01210_R5_2 SHEET 2 OF 6 REV.DOC 5.2 1.0° SECTION Y-Y 4.000 .030 1.274 Y Y R1.280 SCALE 1.000 30.0° .010 P .075 3.0° .760 .050 P SECTION P-P .440 2.500 2.305 1.330 1.125 .000 1.125 1.330 1.500 .030 .400 SHORT | LONG .000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° .400 .440 NEW AGE ENCLOSURES 4330 Santa Fe Road ph. (805) 595-1310 .188 .092 APPROVAL BY STANDARD - DONGLE SXX-X01210 ASSEMBLY DATE CHECK ENG. SCALE DRAWN BY M BOYER SIZE 09-Apr-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: (X)01210 DRAWING NAME A SX01210_R5_2 SHEET 3 OF 6 REV.DOC 5.2 1.499 2.499 S .030 (.133) .062 1.274 DETAIL B SCALE 4.000 .035 .025 .501 TO CL SEE DETAIL B S .270 3.0° 16.0° SECTION S-S .075 .035 (.120) SEE DETAIL A .192 .125 .143 2.499 2.305 x2 1.125 .875 x2 .250 x2 .000 .250 x2 .875 x2 1.125 1.330 x2 1.499 SECTION F-F .032 .030 .440 .466 SHORT | LONG .400 F .000 DETAIL A SCALE 4.000 F .466 .440 .400 SCALE 1.000 .260 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES 4330 Santa Fe Road ph. (805) 595-1310 APPROVAL 2.0° BY STANDARD - DONGLE SXX-X01210 ASSEMBLY DATE CHECK ENG. SCALE DRAWN BY M BOYER SIZE 09-Apr-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: (X)01210 DRAWING NAME A SX01210_R5_2 SHEET 4 OF 6 REV.DOC 5.2 2.400 2.240 1.190 .000 1.190 1.400 .380 (X)01210 PCB - CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .500 .380 .335 SHORT | LONG PROPOSED PCB SIZE .000 .335 .380 .500 .380 R.062 TYP. 45° TYP. 2.305 x2 1.330 x2 .000 1.330 x2 .062 .440 x2 .400 TOP - KEEP OUT ZONES .000 .400 .440 x2 2.305 x2 1.330 x2 .875 x2 .000 .875 x2 .207 6 PLACES KEEP OUT 1.330 x2 SCALE 1.000 .440 x2 .400 SCALE 1.500 BOTTOM - KEEP OUT ZONES .000 .400 .440 x2 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES .040 .050 .280 6 PLACES KEEP OUT 4330 Santa Fe Road ph. (805) 595-1310 APPROVAL BY STANDARD - DONGLE SXX-X01210 ASSEMBLY DATE CHECK ENG. SCALE DRAWN BY M BOYER SIZE 09-Apr-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: (X)01210 DRAWING NAME A SX01210_R5_2 SHEET 5 OF 6 REV.DOC 5.2 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° SXX-X01210-XXX COVER - NEW AGE ENCLOSURES ABS, BLACK 4330 Santa Fe Road ph. (805) 595-1310 STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION 1 2 3 - T2 = .062" EM T2 = .062" EM T2 = .062" EM 178 178 178 - PROGRAM APPROVAL BY STANDARD - DONGLE SXX-X01210 ASSEMBLY DATE CHECK ENG. SCALE DRAWN BY M BOYER SIZE 09-Apr-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: (X)01210 DRAWING NAME A SX01210_R5_2 SHEET 6 OF 6 REV.DOC 5.2
S1A-401210 价格&库存
很抱歉,暂时无法提供与“S1A-401210”相匹配的价格&库存,您可以联系我们找货
