NOTES:
UNLESS OTHERWISE SPECIFIED
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
V
I
S
I
O
N
DATE
APPROVE
A
M BOYER
PRELIMINARY RELEASE
2017-May-30
D.C.
B
M BOYER
REVISE SIZE
2017-May-31
D.C.
C
M BOYER
REVISE SIZE FOR ETHERNET
2017-Jun-02
D.C.
D
R CRUZ
REVISE ENVELOPE DIMENSIONS
2017-Jun-06
D.C.
E
R CRUZ
REVISE ENCLOSURE NAME
2017-Jul-25
D.C.
1.0
M BOYER
UPDATE SHEETS AND RELEASE TO REV 1 PER CUSTOMER
2017-Jul-28
D.C.
2.0
R CRUZ
UPDATE TO AS-BUILT DIMENSIONS
2019-Jun-26
3. INTERIOR SURFACE TEXTURE TO BE: NONE.
4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED.
01919
DESCRIPTION
E
DRAWN BY
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVALENT TO MT-11010. TEXTURE ON ENCLOSURE
WILL VARY FROM TIME TO TIME AS THE TOOL WEARS AND
IT BECOMES NESSESARY TO REAPPLY.
ECO No
R
REV.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE
LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED
BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
7. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
ALTERNATE RESINS HAVE DIFFERENT SHRINK RATES, AND WILL EFFECT
DIMENSIONS.
2
8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION
OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER.
9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED.
FOR THE PCB ARE SOLD SEPARATELY.
MOUNTING SCREWS
10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED
BY THE SOLID MODEL FILE.
11. ALLOWABLE FLASH: 0.010 MAX.
4
12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH,
PROTRUDING OR BELOW FLUSH.
13. TRIM GATE WITHIN 0.030" OF FLUSH.
5
3
1
SCALE 1.000
6
SCALE 1.000
6
SCREW_HILO-NO4X375
#4 HiLo SCREW x .375"
ZINC PLATED
INCLUDED
4
5
SCREW_HILO-NO4X250
#4 HiLo SCREW x .250"
ZINC PLATED
CUSTOMER SUPPLIED
8
4
332010_PCB-TOP
332010 TOP PCB - REFERENCE
.062" THICK
CUSTOMER SUPPLIED
1
3
332010_PCB-BOT
332010 BOTTOM PCB - REFERENCE
.062" THICK
CUSTOMER SUPPLIED
1
2
332010_COVER
332010 COVER - STANDARD
ABS
BLACK or WHITE
1
1
332010_BASE
332010 BASE - STANDARD
ABS
BLACK or WHITE
1
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
BILL OF MATERIALS
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2017
Customer's Part No:
APPROVAL
BY
332010
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
2240 South Thornburg Street
ph. (805) 595-1310
UTILITY BAR - STANDARD
SXX-332010-XXX
SIZE
2017-May-30
Santa Maria, CA. 93455
fax (805) 595-1024
www.newageenclosures.com
A
DRAWING NAME
332010_R2_0
SHEET
1 OF 6
REV.DOC
2.0
332010 ASSEMBLY
3.250
2.000
R.400
R5.970
SCALE 1.000
.561
.226
X
.690
1.030
X
SECTION X-X
.320
.153
.488
R.105
1.020
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
332010
DATE
CHECK
2.050
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-332010-XXX
SIZE
2017-May-30
fax (805) 595-1024
A
DRAWING NAME
332010_R2_0
SHEET
2 OF 6
REV.DOC
2.0
332010 COVER
1.351
P
X
X
3.161 -5°
DRAFT/SIDE
2.450
1.750
4X
SCALE 1.000
4X
P
SECTION P-P
.090
.090
SEE DETAIL A
.385
.007
1.911 -5°
DRAFT/SIDE
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
332010
DATE
CHECK
SECTION X-X
ENG.
DETAIL A
SCALE 2.000
.070
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-332010-XXX
SIZE
2017-May-30
fax (805) 595-1024
A
DRAWING NAME
332010_R2_0
SHEET
3 OF 6
REV.DOC
2.0
332010 BASE
.320
P
4X
X
X
RECESS .015"
SCALE 1.000
.090
4X
P
.137
SECTION P-P
SEE DETAIL B
.090
.012
SECTION X-X
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
DETAIL B
SCALE 2.000
BY
332010
DATE
CHECK
ENG.
.050
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-332010-XXX
SIZE
2017-May-30
fax (805) 595-1024
A
DRAWING NAME
332010_R2_0
SHEET
4 OF 6
REV.DOC
2.0
332010 PCB
.880
.550
.675 2x
.000
.675 2x
.550
.880
SIZES AND VERIFICATION OF ITS FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
.062
1.490
1.100
.875 2x
.800 2x
.000
R.063
.800 2x
.875 2x
.125 4x
1.100
.215 4x
KEEP OUT ZONE
1.490
R.125 4x
332010 PCB
SCALE 1.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
332010
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-332010-XXX
SIZE
2017-May-30
fax (805) 595-1024
A
DRAWING NAME
332010_R2_0
SHEET
5 OF 6
REV.DOC
2.0
332010 2nd OPERATION
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
332010 COVER
SCALE 1.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
SXX-332010-XXX
COVER
Customer's Part No:
ABS, BLACK
APPROVAL
STEP
DESCRIPTION
CUTTER
FIXTURE
ORIENTATION
PROGRAM
1-C-C1
2-C-C2
T2 = .062" EM
T2 = .062" EM
424
424
o1001
o1002
BY
332010
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-332010-XXX
SIZE
2017-May-30
fax (805) 595-1024
A
DRAWING NAME
332010_R2_0
SHEET
6 OF 6
REV.DOC
2.0
很抱歉,暂时无法提供与“S3A-332010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+77.354141+9.67854
- 5+66.093775+8.26964
- 10+61.7794810+7.72984
- 25+56.5074125+7.07020
- 50+52.8156850+6.60829
- 100+49.36606100+6.17668
- 250+45.14774250+5.64888
- 500+44.30067500+5.54290
