Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207
Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com
Customer Specification
PART NO. 172001
Construction
Diameters (In)
1) Component 1
1 X 1 HOOKUP
a) Conductor
20 (SOLID) AWG TC
0.032
b) Insulation
0.010" Wall, Nom. PVC
0.052+/- 0.002
(1) Color(s)
WHITE, BLACK, RED, GREEN, YELLOW, BLUE, BROWN
ORANGE, SLATE, VIOLET
Applicable Specifications
1) Military
105°C / 600 VRMS
MIL-W-16878E/1
Environmental
1) EU Directive 2002/95/EC(RoHS):
All materials used in the manufacture of this part are in compliance with EU Directive
2002/95/EU regarding the restriction of use of certain hazardous substances in electrical and
electronic equipment. Consult Alpha Wire's web site for compliance Date of Manufacture.
2) California Proposition 65:
The outer surface materials used in the manufacture of this part meet the requirements of
California Proposition 65.
Properties
Physical & Mechanical Properties
1) Temperature Range
-55 to 105°C
2) Bend Radius
10X Cable Diameter
3) Pull Tension
8 Lbs, Maximum
Electrical Properties
(For Engineering purposes only)
1) Voltage Rating
600 VRMS
2) Inductance
0.04 µH/ft, Nominal
3) Conductor DCR
10.5 /1000ft @20°C, Nominal
Other
Packaging
Flange x Traverse x Barrel (inches)
a) 55DR75000
24 x 14 x 12 Max. 8 separate pieces; Min length/piece 1000 FT.
b) 37DR50000
18 x 12 x 8 Max. 10 separate pieces; Min length/piece 1000 FT.
c) 55DR50000
d) 37DR25000
12 x 12 x 3.5 Max. 10 separate pieces; Min length/piece 1000 FT.
e) 37DR20000
12 x 10 x 5 Max. 10 separate pieces; Min length/piece 1000 FT.
f) 37DR15000
12 x 10 x 5 Max. 8 separate pieces; Min length/piece 1000 FT.
g) 37DR10000
12 x 4.5 x 3.5 Max. 8 separate pieces; Min length/piece 1000 FT.
h) 5000 FT
10 x 4 x 3.5 Continuous length
i) 2500 FT
6.5 x 4 x 2.5 Continuous length
j) 1000 FT
6.5 x 2 x 1.9 Continuous length
k) Bulk(Made-to-order)
[Spool dimensions may vary slightly]
Notes:
a) Not all colors available in all put-ups
b) Splice Method is Square Knots on multiple piece put-ups
www.alphawire.com
Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication, information and specifications
described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not
ensure product availability.
Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or
implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever,
even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out
of or in connection with the use, or inability to use, the information or specifications described herein.
RoHS CERTIFICATE OF COMPLIANCE
To Whom It May Concern:
Alpha Wire Part Number:172001
172001 , RoHS-Compliant Commencing With7/1/2005Production
This document certifies that the Alpha part numbers cited above are manufactured in accordancewith Directive 2002/95/EC of the European
Parliament and of the Council of 27 January 2003,better known as the RoHS Directives, with regards to restrictions of the use of certain
hazardoussubstances used in the manufacture of electrical and electronic equipment. The reader is referredto these Directives for the specific
definitions and extents of these Directives. No Exemptions arerequired for RoHS Compliance on this item.
Substance
Maximum Control Value
Lead
0.1% by weight (1000 ppm)
Mercury
Cadmium
0.01% by weight (100 ppm)
Hexavalent Chromium
Polybrominated Biphenyls (PBB)
Polybrominated Diphenyl Ethers (PBDE)
Including Deca-BDE
The information provided in this document and disclosure is correct to the best of Alpha Wire'sknowledge, information and belief at the date of its
release. The information provided is designedonly as a general guide for the safe handling, storage, and any other operation of the productitself or
the one that it will become part of. The intent of this document is not to be considered awarranty or quality specification. Regulatory information is
for guidance purposes only. Productusers are responsible for determining the applicability of legislation and regulations based ontheir individual
usage of the product.
Authorized Signatory for the Alpha Wire Company:
Dave Watson, Director of Engineering & QA
10/31/2012
很抱歉,暂时无法提供与“172001 RD013”相匹配的价格&库存,您可以联系我们找货
