172419 WH013
172419 WH013
    ALPHAWIRE(阿尔法电线)
    24 AWG 电子线 电线 19/36 白色 300V 5000'(1524.0m)
172419 WH013 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. 172419 Construction Diameters (In) 1) Component 1 1 X 1 HOOKUP a) Conductor 24 (19/36) AWG TC b) Insulation 0.010" Wall, Nom. PVC (1) Color(s) WHITE, BLACK, RED, GREEN, YELLOW, BLUE, BROWN ORANGE, SLATE, VIOLET 0.045+/- 0.002 Applicable Specifications 1) UL VW-1 2) Military MIL-W-16878E/1 105°C / 300 VRMS Environmental 1) EU Directive 2002/95/EC(RoHS): All materials used in the manufacture of this part are in compliance with EU Directive 2002/95/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Consult Alpha Wire's web site for compliance Date of Manufacture. 2) California Proposition 65: The outer surface materials used in the manufacture of this part meet the requirements of California Proposition 65. Properties Physical &Mechanical Properties 1) Temperature Range -55 to 105°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 3.7 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 600 VRMS 2) Inductance 0.05 µH/ft, Nominal 3) Conductor DCR 23.9 /1000ft @20°C, Nominal Other 1) Packaging a) 5000 FT b) 1000 FT c) 500 FT d) 100 FT e) Bulk(Made-to-order) www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com RoHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number:172419 172419 , RoHS-Compliant Commencing With7/1/2005Production This document certifies that the Alpha part numbers cited above are manufactured in accordance with Directive 2002/95/EC of the European Parliament and of the Council of 27 January 2003, better known as the RoHS Directives, with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. The reader is referred to these Directives for the specific definitions and extents of these Directives. No Exemptions are required for RoHS Compliance on this item. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.1% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm) Polybrominated Biphenyls (PBB) Polybrominated Diphenyl Ethers (PBDE) 0.1% by weight (1000 ppm) Including Deca-BDE 0.1% by weight (1000 ppm) The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire Company: Dave Watson, Director of Engineering &QA 1/24/2011
172419 WH013
物料型号:172419
器件简介:Alpha Wire公司生产的线缆,具有多种颜色选择。
引脚分配:文档中未提及引脚分配,因为这是关于线缆的文档。
参数特性: - 导体规格:24(19/36)AWG TC - 绝缘材料:0.010"壁厚,标称PVC - 颜色:白色、黑色、红色、绿色、黄色、蓝色、棕色、橙色、石板色、紫色
功能详解: - 温度范围:-55至105°C - 弯曲半径:10倍电缆直径 - 拉力:最大3.7磅 - 电压等级:600VRMS - 电感:0.05 H/英尺,标称 - 导体直流电阻:23.9欧姆/1000英尺 @20°C,标称
应用信息:文档中未明确提及应用信息,但根据其物理和电气特性,这种线缆适用于需要一定温度范围和电气性能的应用。
封装信息:提供多种包装长度选项,包括5000英尺、1000英尺、500英尺和100英尺,以及按订单制作的散装包装。
172419 WH013 价格&库存
很抱歉,暂时无法提供与“172419 WH013”相匹配的价格&库存,您可以联系我们找货
172419 WH013
  • 1+2500.747011+321.80914
