Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207
Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com
Customer Specification
PART NO. 5776
Construction
Diameters (In)
1) Component 1
1 X 1 COND
a) Conductor
24 (SOLID) AWG CHROMEL
0.020
b) Insulation
0.004" Wall, Nom. Impregnated Fiberglass
0.028
Cond
Cond
(1) Color(s)
Cond
Color
1
YELLOW
Color
2) Component 2
1 X 1 COND
a) Conductor
24 (SOLID) AWG ALUMEL
0.020
b) Insulation
0.028
Cond
Cond
Color
(1) Color(s)
Cond
Color
1
RED
Color
3) Cable Assembly
2 Components run parallel under jacket.
4) Jacket
0.006" Wall, Nom.,Impregnated Fiberglass
0.040X0.068
(0.044X0.074 Max.)
a) Color(s)
BROWN with Yellow tracer
Applicable Specifications
1) Other
ANSI MC96.1 Type K
ASTM E230
Environmental
Properties
510°C
Color
Physical & Mechanical Properties
1) Temperature Range
0 to 510°C continuous, single exposure to 650°C
2) Bend Radius
10X Cable Diameter
3) Pull Tension
6.3 Lbs, Maximum
Electrical Properties
(For Engineering purposes only)
1) Voltage Rating
NOT SPECIFIED
2) Component 1
a) Inductance
0.16 µH/ft, Nominal
b) Conductor DCR
1053 Ω/1000ft @20°C, Nominal
3) Component 2
a) Inductance
0.16 µH/ft, Nominal
b) Conductor DCR
438 Ω/1000ft @20°C, Nominal
Other
Packaging
Flange x Traverse x Barrel (inches)
a) Bulk(Made-to-order)
Notes:
a) Impregnation maintained to 200C.
www.alphawire.com
Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications
described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not
ensure product availability.
Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or
implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever,
even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out
of or in connection with the use, or inability to use, the information or specifications described herein.
ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY
Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE,
and is merely on loan and subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges and
agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be
copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In the case of conflicting contractual provisions, this notice shall
govern the status of this document. ©2013 ALPHA WIRE - all rights reserved.
EU/China ROHS CERTIFICATE OF COMPLIANCE
To Whom It May Concern:
Alpha Wire Part Number: 5776
5776 , RoHS-Compliant Commencing With 11/1/2005 Production
This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European
Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of
electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions
are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this
Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope. Additionally, Alpha certifies that
the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006.
Substance
Maximum Control Value
Lead
0.1% by weight (1000 ppm)
Mercury
Cadmium
0.01% by weight (100 ppm)
Hexavalent Chromium
0.1% by weight (1000 ppm )
Polybrominated Biphenyls (PBB)
Polybrominated Diphenyl Ethers (PBDE) ,
Including Deca-BDE
The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its
release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or
the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is
for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual
usage of the product.
Authorized Signatory for the Alpha Wire Company:
Dave Watson, Director of Engineering & QA
4/25/2013
很抱歉,暂时无法提供与“5776 BR001”相匹配的价格&库存,您可以联系我们找货
