6389 SL005
6389 SL005
    ALPHAWIRE(阿尔法电线)
    50(25 对双绞线) 芯 多线对 线缆 石板色 24 AWG 箔 100.0'(30.5m)
6389 SL005 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. 6389 Construction Diameters (In) 1) Component 1 25 X 1 PAIR a) Conductor 24 (7/32) AWG TC 0.024 b) Insulation 0.010" Wall, Nom. Polyethylene(PE) 0.044 (1) Color Code Alpha Wire Color Code A Pair Color Pair Color Pair Color 1 BLACK-RED 10 RED-BLUE 19 WHITE-BLUE 2 BLACK-WHITE 11 RED-YELLOW 20 WHITE-BROWN 3 BLACK-GREEN 12 RED-BROWN 21 WHITE-ORANGE 4 BLACK-BLUE 13 RED-ORANGE 22 WHITE-YELLOW 5 BLACK-BROWN 14 GREEN-BLUE 23 BLUE-BROWN 6 BLACK-YELLOW 15 GREEN-WHITE 24 BLUE-ORANGE 7 BLACK-ORANGE 16 GREEN-BROWN 25 BLUE-YELLOW 8 RED-GREEN 17 GREEN-ORANGE 9 RED-WHITE 18 GREEN-YELLOW c) Pair 2/Cond Cabled Together (1) Twists: 9.6 Twists/foot (min) Individually Applied: d) Shield: Foil Free Alum/Mylar Tape, 25% Overlap, Min. (1) Foil Direction Foil Facing In (2) Drain Wire 24 (7/32) AWG TC 2) Cable Assembly 25 Components Cabled a) Twists: 1.6 Twists/foot (min) 3) Jacket 0.047" Wall, Nom.,PVC a) Color(s) SLATE b) Print ALPHA WIRE-* P/N 6389 25PR 24 AWG SHIELDED 75C (UL) TYPE CM OR AWM 2919 LOW VOLTAGE COMPUTER CABLE OR C(UL) TYPE CM 75C CE ROHS * = Factory Code [Note: Product may have c(UL) or CSA markings depending upon plant of manufacture.] Applicable Specifications 0.599 (0.629 Max.) 1) UL AWM/STYLE 2919 80°C / 30 VRMS CM 75°C VW-1 2) CSA International C(UL) TYPE CM 75°C 3) CE: EU Low Voltage Directive 2006/95/EC Environmental 1) CE: EU Directive 2011/65/EU(RoHS2): This product complies with European Directive 2011/65/EU (RoHS Directive) of the European Parliament and of the Council of 8 June 2011. No Exemptions are required for RoHS Compliance on this item. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. 3) California Proposition 65: The outer surface materials used in the manufacture of this part meet the requirements of California Proposition 65. Properties Physical & Mechanical Properties 1) Temperature Range -20 to 80°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 264 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 300 VRMS 2) Characteristic Impedance 60 Ω 3) Mutual Capacitance 25 pf/ft @1 kHz, Nominal 4) Ground Capacitance 47 pf/ft @1 kHz, Nominal 5) Conductor DCR 26 Ω/1000ft @20°C, Nominal 6) Ind. Shield DC Resistance 21 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 1000 FT 30 x 14 x 12 Continuous length b) 500 FT 24 x 14 x 12 Continuous length c) 100 FT 16 x 11 x 8 Continuous length [Spool dimensions may vary slightly] www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time.  By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE.  In the case of conflicting contractual provisions, this notice shall govern the status of this document.  ©2013 ALPHA WIRE - all rights reserved. EU/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: 6389 6389 , RoHS-Compliant Commencing With 11/1/2004 Production This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope.  Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire Company: Dave Watson, Director of Engineering & QA 4/26/2013
6389 SL005
1. 物料型号:6389 2. 器件简介: - 产品由Alpha Wire生产,位于新泽西州伊丽莎白市。 - 产品符合欧洲RoHS指令和REACH法规,不含高度关注物质(SVHC)。 - 加州65号提案:产品外表面材料满足加州65号提案的要求。 3. 引脚分配: - 导体:24(7/32) AWG TC,直径约0.024英寸。 - 绝缘:0.010英寸壁厚,聚乙烯(PE)。 - 颜色编码:Alpha Wire颜色编码A。 - 对绞:9.6个每英尺最小,2个导体一起绞合。 - 屏蔽:无箔铝/聚酯带,25%重叠最小。 - 外护层:0.599英寸直径,0.047英寸壁厚,标称PVC,颜色为石板色。 4. 参数特性: - 温度范围:-20至80°C。 - 弯曲半径:10倍电缆直径。 - 拉力:最大264磅。 - 电气特性(仅供参考): - 额定电压:300 VRMS。 - 特性阻抗:60。 - 互电容:每英尺25pf(1kHz时标称)。 - 地电容:每英尺47pf(1kHz时标称)。 - 导体直流电阻:每1000英尺26欧姆(20°C时标称)。 - 独立屏蔽直流电阻:每1000英尺21欧姆(20°C时标称)。 5. 功能详解: - 产品符合UL AWM/STYLE2919标准,80°C/30VRMS。 - 符合CSA国际C(UL) TYPE CM标准,75°C。 - 通过VW-1垂直燃烧测试。 6. 应用信息: - 产品适用于低压计算机电缆或C(UL) TYPE CM 75°C,符合CE和RoHS标准。 7. 封装信息: - 包装:法兰x横向x桶(英寸)。 - 1000FT:30x14x12连续长度。 - 500FT:24x14x12连续长度。 - 100FT:16x11x8连续长度。
6389 SL005 价格&库存
很抱歉,暂时无法提供与“6389 SL005”相匹配的价格&库存,您可以联系我们找货
