669333 BK001
669333 BK001
    ALPHAWIRE(阿尔法电线)
    4(2 对双绞线) 芯 多线对,Cat5e 线缆 黑色 24 AWG 箔,编织线 50.00'(15.24m)
669333 BK001 数据手册
ALPHA WIRE Part Number: 669333 Page 1 of 2 Pages A. Construction 1) Component 1 a) Conductor b) Insulation (1) Color(s) Pair 1 c) Color BLU - WHT/BLU Pair (1) Lay Length: d) 2) 3) B. C. D. E. Cabling (1) Twists: e) Jacket (1) Color(s) Shield: a) Foil Direction b) Braid Jacket a) Color(s) b) Print Applicable Specifications 1) UL a) Component 1 b) Overall 2) TIA Environmental Compliance 1) CE: CUSTOMER PRODUCT SPECIFICATION Issue: Issue Date: Effective Date: 5 7/7/2014 7/9/2014 Diameters (In) 1 X 2 PAIR 24 (7/32) AWG BC 0.011" Wall, Nom. Polypropylene(PP) Pair 2 Color ORG - WHT/ORG 0.024 0.045 Pair Color 2/Cond Cabled Together BLU – WHT/BLU: 0.415" LH Lay ORG – WHT/ORG: 0.549” LH Lay 2 PAIR Cabled 4.0 Twists/foot (min) 0.020" Wall, Nom.,PVC BLACK Alum/Mylar Tape, 25% Overlap, Min. Foil Facing Out TC,90% Coverage, Min. 0.033" Wall, Nom.,TPE BLACK ALPHA WIRE-* P/N 669333 2PR 24 AWG RU AWM 20626 80C 300V CAT5E PATCH ROHS (SEQUENTIAL #) FT * = Factory Code AWM/STYLE 10152 AWM/STYLE 20626 TIA-568-C.2 Category 5e 0.200 (0.210 Max.) 0.310 (0.320 Max.) 80°C / 300 VRMS 80°C / 300 VRMS EU Directive 2011/65/EU(RoHS2): All materials used in the manufacture and packaging of this part must meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. 2) REACH Regulation (EC 1907/2006): This product may not contain any of the substances listed in the latest issue European Union's REACH Substance of Very High Concern (SVHC) candidate list in excess of 0.1% mass of the item. Physical & Mechanical Properties 1) Temperature Range -50 to 105°C 2) Bend Radius 8X Cable Diameter 3) Pull Tension 20.7 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 300 VRMS 2) Characteristic Impedance 100 Ω +/- 15 3) Mutual Capacitance 5.6 nF/100m Max 4) Velocity of Propagation 70 % Nom. 5) Conductor DCR 9.38 Ω/100m Max 6) Skew 45 ns/100m Max 7) Pair to Ground Unbalance 330 pF/100m Max 8) Transfer Impedance 100 mΩ/m Max 9) DC Unbalance of a Pair 5% Max 10) Insertion Loss 2.4 (Max dB/100m ) @ 1 MHz Although Alpha Wire Company ("Alpha") makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. 711 Lidgerwood Ave Elizabeth, NJ 07207-0711 Toll Free 1-800-52 ALPHA • T: 1-908-925-8000 • F: 908-925-5411 • Email: info@alphawire.com www.alphawire.com ALPHA WIRE Part Number: 669333 Page 2 of 2 Pages CUSTOMER PRODUCT SPECIFICATION Issue: Issue Date: Effective Date: 5 7/7/2014 7/9/2014 4.9 (Max dB/100m ) @ 4 MHz 6.9 (Max dB/100m ) @ 8 MHz 7.8 (Max dB/100m ) @ 10 MHz 9.9 (Max dB/100m ) @ 16 MHz 11.1 (Max dB/100m ) @ 20 MHz 12.5 (Max dB/100m ) @ 25 MHz 14.1 (Max dB/100m ) @ 31.25 MHz 20.4 (Max dB/100m ) @ 62.5 MHz 26.4 (Max dB/100m ) @ 100 MHz F. Other 1) Packaging a) 1000 FT b) Bulk Ft. Flange x Traverse x Barrel (inches) 16 x 11 x 8 Continuous length 16 x 11 x 8 Continuous length, 400 ft. Min, 1200 ft. Max This Design is custom, Made-To-Order & once accepted, the order is NON-CANCELLABLE & NON-RETURNABLE. Accepted By: Date: Company: Title: Although Alpha Wire Company ("Alpha") makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. 711 Lidgerwood Ave Elizabeth, NJ 07207-0711 Toll Free 1-800-52 ALPHA • T: 1-908-925-8000 • F: 908-925-5411 • Email: info@alphawire.com www.alphawire.com
669333 BK001 价格&库存
很抱歉,暂时无法提供与“669333 BK001”相匹配的价格&库存,您可以联系我们找货
