Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207
Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com
Customer Specification
PART NO. 882260
Construction
Diameters (In)
1) Component 1
60 X 1 COND
a) Conductor
22 (7/30) AWG TC
0.030
b) Insulation
0.010" Wall, Nom. PVC, Semi Rigid
0.050
(1) Color Code
Alpha Wire Color Code F
Cond
Color
Cond
Color
Cond
Color
1
BLACK
21
ORANGE/GREEN
41
GREEN/WHITE/BLUE
2
WHITE
22
BLACK/WHITE/RED
42
ORANGE/RED/GREE
N
3
RED
23
WHITE/BLACK/RED
43
BLUE/RED/GREEN
4
GREEN
24
RED/BLACK/WHITE
44
BLACK/WHITE/BLUE
5
ORANGE
25
GREEN/BLACK/WHIT 45
E
WHITE/BLACK/BLUE
6
BLUE
26
ORANGE/BLACK/WHI 46
TE
RED/WHITE/BLUE
7
WHITE/BLACK
27
BLUE/BLACK/WHITE 47
GREEN/ORANGE/RE
D
8
RED/BLACK
28
BLACK/RED/GREEN 48
ORANGE/RED/BLUE
9
GREEN/BLACK
29
WHITE/RED/GREEN
BLUE/RED/ORANGE
10
ORANGE/BLACK
30
RED/BLACK/GREEN 50
BLACK/ORANGE/RE
D
11
BLUE/BLACK
31
GREEN/BLACK/ORA
NGE
51
WHITE/BLACK/ORAN
GE
12
BLACK/WHITE
32
ORANGE/BLACK/GR
EEN
52
RED/ORANGE/BLAC
K
13
RED/WHITE
33
BLUE/WHITE/ORANG 53
E
GREEN/RED/BLUE
14
GREEN/WHITE
34
BLACK/WHITE/ORAN 54
GE
ORANGE/BLACK/BLU
E
15
BLUE/WHITE
35
55
BLUE/BLACK/ORANG
E
16
BLACK/RED
36
ORANGE/WHITE/BLU 56
E
BLACK/ORANGE/GR
EEN
17
WHITE/RED
37
WHITE/RED/BLUE
57
WHITE/ORANGE/GR
EEN
18
ORANGE/RED
38
BLACK/WHITE/GREE 58
N
RED/ORANGE/GREE
N
19
BLUE/RED
39
WHITE/BLACK/GREE 59
N
GREEN/BLACK/BLUE
RED/GREEN
40
RED/WHITE/GREEN
2) Cable Assembly
60 Components Cabled
WHITE/RED/ORANGE
49
60
ORANGE/GREEN/BL
UE
a) Twists:
1.8 Twists/foot (min)
3) Jacket
0.035" Wall, Nom.,PVC
a) Color(s)
SLATE
b) Print
ALPHA WIRE-* P/N 882260 60C 22 AWG
(UL) TYPE CL2 90C OR AWM 2464 80C 300V
C(RU) AWM II A/B 105C 300V FT4
CE ROHS
* = Factory Code
0.520 (0.547 Max.)
Applicable Specifications
1) UL
2) CSA International
AWM/STYLE 2464
80°C / 300 VRMS
CL2
90°C
C(RU) AWM II A/B
105°C / 300 VRMS
FT4
3) CE:
EU Low Voltage Directive 2006/95/EC
Environmental
1) CE: EU Directive 2011/65/EU(RoHS2):
This product complies with European Directive 2011/65/EU (RoHS Directive) of the European
Parliament and of the Council of 8 June 2011. No Exemptions are required for RoHS
Compliance on this item. Consult Alpha Wire's web site for RoHS C of C.
2) REACH Regulation (EC 1907/2006):
This product does not contain Substances of Very High Concern (SVHC) listed on the European
Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information,
please see Alpha's REACH SVHC Declaration.
Properties
Physical & Mechanical Properties
1) Temperature Range
-20 to 105°C
2) Bend Radius
10X Cable Diameter
3) Pull Tension
330 Lbs, Maximum
Electrical Properties
(For Engineering purposes only)
1) Voltage Rating
300 VRMS
2) Capacitance
23.5 pf/ft @1 kHz, Nominal Conductor to Conductor
3) Inductance
0.18 µH/ft, Nominal
4) Conductor DCR
16.5 Ω/1000ft @20°C, Nominal
Other
Packaging
Flange x Traverse x Barrel (inches)
a) 1000 FT
30 x 14 x 12 Continuous length
b) 500 FT
20 x 11 x 8 Continuous length
c) 100 FT
16 x 11 x 8 Continuous length
d) Bulk(Made-to-order)
[Spool dimensions may vary slightly]
www.alphawire.com
Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications
described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not
ensure product availability.
Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or
implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever,
even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out
of or in connection with the use, or inability to use, the information or specifications described herein.
ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY
Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE,
and is merely on loan and subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges and
agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be
copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In the case of conflicting contractual provisions, this notice shall
govern the status of this document. ©2013 ALPHA WIRE - all rights reserved.
EU/China ROHS CERTIFICATE OF COMPLIANCE
To Whom It May Concern:
Alpha Wire Part Number: 882260
882260 , RoHS-Compliant Commencing With 7/1/2005 Production
This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European
Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of
electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions
are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this
Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope. Additionally, Alpha certifies that
the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006.
Substance
Maximum Control Value
Lead
0.1% by weight (1000 ppm)
Mercury
Cadmium
0.01% by weight (100 ppm)
Hexavalent Chromium
0.1% by weight (1000 ppm )
Polybrominated Biphenyls (PBB)
Polybrominated Diphenyl Ethers (PBDE) ,
Including Deca-BDE
The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its
release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or
the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is
for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual
usage of the product.
Authorized Signatory for the Alpha Wire Company:
Dave Watson, Director of Engineering & QA
4/30/2013
很抱歉,暂时无法提供与“882260 SL002”相匹配的价格&库存,您可以联系我们找货
