882260 SL001
882260 SL001
    ALPHAWIRE(阿尔法电线)
    CABLE 60COND 22AWG SLATE 1000'
882260 SL001 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. 882260 Construction Diameters (In) 1) Component 1 60 X 1 COND a) Conductor 22 (7/30) AWG TC 0.030 b) Insulation 0.010" Wall, Nom. PVC, Semi Rigid 0.050 (1) Color Code Alpha Wire Color Code F Cond Color Cond Color Cond Color 1 BLACK 21 ORANGE/GREEN 41 GREEN/WHITE/BLUE 2 WHITE 22 BLACK/WHITE/RED 42 ORANGE/RED/GREE N 3 RED 23 WHITE/BLACK/RED 43 BLUE/RED/GREEN 4 GREEN 24 RED/BLACK/WHITE 44 BLACK/WHITE/BLUE 5 ORANGE 25 GREEN/BLACK/WHIT 45 E WHITE/BLACK/BLUE 6 BLUE 26 ORANGE/BLACK/WHI 46 TE RED/WHITE/BLUE 7 WHITE/BLACK 27 BLUE/BLACK/WHITE 47 GREEN/ORANGE/RE D 8 RED/BLACK 28 BLACK/RED/GREEN 48 ORANGE/RED/BLUE 9 GREEN/BLACK 29 WHITE/RED/GREEN BLUE/RED/ORANGE 10 ORANGE/BLACK 30 RED/BLACK/GREEN 50 BLACK/ORANGE/RE D 11 BLUE/BLACK 31 GREEN/BLACK/ORA NGE 51 WHITE/BLACK/ORAN GE 12 BLACK/WHITE 32 ORANGE/BLACK/GR EEN 52 RED/ORANGE/BLAC K 13 RED/WHITE 33 BLUE/WHITE/ORANG 53 E GREEN/RED/BLUE 14 GREEN/WHITE 34 BLACK/WHITE/ORAN 54 GE ORANGE/BLACK/BLU E 15 BLUE/WHITE 35 55 BLUE/BLACK/ORANG E 16 BLACK/RED 36 ORANGE/WHITE/BLU 56 E BLACK/ORANGE/GR EEN 17 WHITE/RED 37 WHITE/RED/BLUE 57 WHITE/ORANGE/GR EEN 18 ORANGE/RED 38 BLACK/WHITE/GREE 58 N RED/ORANGE/GREE N 19 BLUE/RED 39 WHITE/BLACK/GREE 59 N GREEN/BLACK/BLUE 20 RED/GREEN 40 RED/WHITE/GREEN 2) Cable Assembly 60 Components Cabled WHITE/RED/ORANGE 49 60 ORANGE/GREEN/BL UE a) Twists: 1.8 Twists/foot (min) 3) Jacket 0.035" Wall, Nom.,PVC a) Color(s) SLATE b) Print ALPHA WIRE-* P/N 882260 60C 22 AWG (UL) TYPE CL2 90C OR AWM 2464 80C 300V C(RU) AWM II A/B 105C 300V FT4 CE ROHS * = Factory Code 0.520 (0.547 Max.) Applicable Specifications 1) UL 2) CSA International AWM/STYLE 2464 80°C / 300 VRMS CL2 90°C C(RU) AWM II A/B 105°C / 300 VRMS FT4 3) CE: EU Low Voltage Directive 2006/95/EC Environmental 1) CE: EU Directive 2011/65/EU(RoHS2): This product complies with European Directive 2011/65/EU (RoHS Directive) of the European Parliament and of the Council of 8 June 2011. No Exemptions are required for RoHS Compliance on this item. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. Properties Physical & Mechanical Properties 1) Temperature Range -20 to 105°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 330 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 300 VRMS 2) Capacitance 23.5 pf/ft @1 kHz, Nominal Conductor to Conductor 3) Inductance 0.18 µH/ft, Nominal 4) Conductor DCR 16.5 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 1000 FT 30 x 14 x 12 Continuous length b) 500 FT 20 x 11 x 8 Continuous length c) 100 FT 16 x 11 x 8 Continuous length d) Bulk(Made-to-order) [Spool dimensions may vary slightly] www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time.  By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE.  In the case of conflicting contractual provisions, this notice shall govern the status of this document.  ©2013 ALPHA WIRE - all rights reserved. EU/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: 882260 882260 , RoHS-Compliant Commencing With 7/1/2005 Production This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope.  Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire Company: Dave Watson, Director of Engineering & QA 4/30/2013
882260 SL001 价格&库存
很抱歉,暂时无法提供与“882260 SL001”相匹配的价格&库存,您可以联系我们找货
