891626 BK013
891626 BK013
    ALPHAWIRE(阿尔法电线)
    16 AWG 电子线 电线 26/30 黑色 300V 5000'(1524.0m)
891626 BK013 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. 891626 Construction Diameters (In) 1) Component 1 1 X 1 HOOKUP a) Conductor 16 (26/30) AWG TC b) Insulation 0.016" Wall, Nom. PVC (1) Print 16 AWG EXXXXX RU AWM STYLE 1569 105C 300V VW-1 OR AWM 1007 LLXXXXX CSA AWM I A/B 105C 300V FT1 OR TR64 90C [Note: Product may have c(UL) or CSA markings depending upon plant of manufacture.] (2) Color(s) WHITE, BLACK, RED, GREEN, YELLOW, BLUE, BROWN ORANGE, SLATE, VIOLET 0.092+/- 0.002 Applicable Specifications 1) UL AWM/STYLE 1569 105°C / 300 VRMS VW-1 2) CSA International AWM/STYLE 1007 80C°C / 300 VRMS AWM I A/B 105°C / 300 VRMS FT1 TR-64 90C°C Environmental 1) EU Directive 2002/95/EC(RoHS): All materials used in the manufacture of this part are in compliance with EU Directive 2002/95/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Consult Alpha Wire's web site for compliance Date of Manufacture. 2) California Proposition 65: The outer surface materials used in the manufacture of this part meet the requirements of California Proposition 65. Properties Physical &Mechanical Properties 1) Temperature Range -20 to 105°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 20.4 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 300 VRMS 2) Inductance 0.04 µH/ft, Nominal 3) Conductor DCR 4.4 /1000ft @20°C, Nominal Other 1) Packaging a) 5000 FT b) 2500 FT c) 1000 FT d) 500 FT e) 100 FT f) Bulk(Made-to-order) www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com RoHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number:891626 891626 , RoHS-Compliant Commencing With1/29/2007Production This document certifies that the Alpha part numbers cited above are manufactured in accordance with Directive 2002/95/EC of the European Parliament and of the Council of 27 January 2003, better known as the RoHS Directives, with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. The reader is referred to these Directives for the specific definitions and extents of these Directives. No Exemptions are required for RoHS Compliance on this item. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.1% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm) Polybrominated Biphenyls (PBB) Polybrominated Diphenyl Ethers (PBDE) 0.1% by weight (1000 ppm) Including Deca-BDE 0.1% by weight (1000 ppm) The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire Company: Dave Watson, Director of Engineering &QA 1/24/2011
891626 BK013
物料型号:891626
器件简介:文档描述了Alpha Wire公司的一种导线产品,包括其构造、适用规格、环境合规性、物理和机械属性、电气属性以及其他信息。
引脚分配:文档中没有提及引脚分配,因为它是关于导线而非电子元件。
参数特性: - 温度范围:-20至105°C - 弯曲半径:10倍电缆直径 - 拉力:最大20.4磅 - 电压等级:300VBMS - 电感:0.04微亨/英尺(名义值) - 导体直流电阻(DCR):在20°C下,每1000英尺4.4欧姆(名义值)
功能详解:文档提供了导线的详细物理和电气属性,以及环境合规性声明,包括符合欧盟RoHS指令和加州65号提案。
应用信息:文档没有提供具体的应用案例,但Alpha Wire的产品通常用于各种工业和电子应用。
封装信息:文档提供了不同长度的包装选项,包括5000英尺、2500英尺、1000英尺、500英尺、100英尺和定制的散装包装。
891626 BK013 价格&库存
很抱歉,暂时无法提供与“891626 BK013”相匹配的价格&库存,您可以联系我们找货
