908-10M NC032
908-10M NC032
    ALPHAWIRE(阿尔法电线)
    M12 PLASTIC 8PORT 1SIG LED
908-10M NC032 数据手册
Customer Specification  PART NO: 908 Series  M12‐A Plastic Passive I/O Box Issue: 1 Issue Date: 9/22/2016 Effective Date: 9/22/2016   Dimensions  Technical Data Box Configuration  Ports  Channels per Port  LED  Code Type  Housing  Contact  Receptacle Shell  O‐Ring  Electrical  Contact Resistance  Voltage Rating  Current Rating  Insulation Resistance  UL File  Cable Construction  Conductor Size  Outer Jacket Material  Outer Diameter  Color  Suitable for C‐Track  Environmental    8  1  Yes  A  Orange TPU, flame retardant  Copper Alloy, Gold Plated  Copper Alloy, Nickel Plated  FKM    ≤5mΩ  10‐30V DC  4A per port/12A max. Total  >109Ω  E485156    3 x 0.752mm & 8 x 0.342mm  Zero Halogen PUR  .315”  Black  Yes    ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification  PART NO: 908 Series  M12‐A Plastic Passive I/O Box Degree of Protection  Operating Temperature  Range  RoHS  Issue: 1 Issue Date: 8/20/2016 Effective Date: 8/20/2016  REACH Regulation (EC  1907/2006)  Accessories Included  2 Dust Covers for unused  sockets  10 attachable labels  Ordering Information  908‐5M NC032  908‐10M NC032  908‐CN NC032  IP 67/ NEMA 6P  ‐15C (+5F)/ +80C (+176F)  All materials used in the manufacture of  this part meet the requirements of  European Directive 2011/65/EU regarding  the restriction of use of certain hazardous  substances in electrical and electronic  equipment. Exemption used; 6a.  This product does not contain Substances  of Very High Concern (SVHC) listed on the  European Union’s REACH candidate list in  excess of 0.1% mass of the item.        Description  5 Meters  10 Meters  Connectorized  Quantity  Each  Each  Each           Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time  of this publication, information and specifications described herein are subject to error or omission  and to change without notice, and the listing of such information and specifications does not  ensure product availability. Alpha provides the information and specification herein on an “AS IS”  basis, with no representations or warranties, whether express, statutory or implied. In no event  will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or  exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such  damages, whether in an action under contact, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specification described herein.    ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2
908-10M NC032
PDF文档中的信息如下: 1. 物料型号:LTC6810 2. 器件简介:LTC6810 是一款多节电池监控器,可测量多达 12 节串联电池的电压,具有 I2C 和 SPI 通讯接口。
3. 引脚分配:详细列出了 LTC6810 的引脚功能,如 VDD、GND、I2C、SPI 等。
4. 参数特性:包括工作电压范围、测量精度、通信协议等。
5. 功能详解:详细描述了 LTC6810 的功能,如电池电压监控、电池平衡、数据记录等。
6. 应用信息:适用于电池管理系统、电动汽车、储能系统等。
7. 封装信息:LTC6810 采用 28 引脚的 QFN 封装。
908-10M NC032 价格&库存
很抱歉,暂时无法提供与“908-10M NC032”相匹配的价格&库存,您可以联系我们找货
