3590/26 SL005
3590/26 SL005
    ALPHAWIRE(阿尔法电线)
    扁平带状电缆 灰色 26 导线 0.050"(1.27mm) 扁平缆线,扁平套管 100.0'(30.48m)
3590/26 SL005 数据手册
Communication, Control, and Industrial Cable Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 291 Get control of demanding applications T he broad range of communication and control cables from Alpha Wire means you can find the right cable for your application. Our cables meet special needs, such as lowcapacitance cables for extended transmission of digital signals, such as the extra flexibility of rubber insulation and jackets, or excellent shielding for electrically noisy environments. Our communication and control line includes six main categories: • Solar cable: a full range of solar cables for power and control. We combine a wide range of insulation materials, shielding variations, conductor counts and gauges, as well as other options to create cables suited to any application. From traditional RS-232 connections to high-speed telemetry and data recording to high-fidelity microphone systems, our experience in materials and expertise in manufacturing means cable built to perform electrically, mechanically, and environmentally. • C  ommunication and control: round multiconductor and multipair cable in configurations suited to nearly any application. 292 • Industrial automation cable: cable for common automation protocols such as ControlNet, DeviceNet, and PROFIBUS. • F  lexible motor supply cable: four-conductor double-shielded cable suited for light-duty flexing. • L  ow-smoke, zero-halogen cable: minimizes the effects from smoke and harmful corrosive gases in the event of combustion. • F  lat cable: planar multiconductor cable used primarily inside cabinets or equipment. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Solar Cable F rom residential rooftops to solar farms harvesting energy, our solar cables and photovoltaic wire are designed for the harsh environments of solar energy applications—the hot and cold of climate extremes, ozone and UV radiation, moisture, oil, and direct burial. Our specially formulated PVC jackets provide years of reliable service by withstanding the potential environments without failing or degrading. A full range for power and control No matter what your need in connecting solar power to the grid, we have wire and cable in a range of gauges and conductor counts to satisfy it. Our cables meet regulatory and industry requirements for photovoltaic applications. Applications • Panel monitoring and control • Panel to junction box • Panel to collector • Collector to inverter • Grounding • Motor supply Photovoltaic Wire For single-conductor needs, see page 417 for our line of photovoltaic wires. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 293 Cable > Communication, Control and Industrial > Multiconductor > Braid Shield > 1000 V Solar Cable 1000 V Braid Shield, Multiconductor, PVC/Nylon, PVC 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.12 mm) nylon UL TC-ER UL WTTC (1000 V) UL MTW CSA AWM I/II A/B FT1 Operating Temperature • -40°C to +90°C (static) • -30°C to +90°C (dynamic) • +105°C (CSA) Conductor Color Coding • Chart F (page 532) Materials • Stranded bare copper conductors • PVC/nylon insulation • Clear polyester wrap • Tinned copper braid shield, 85% coverage • Green PVC jacket Features • UL Sunlight Resistant • UL Oil Res. I • UL Direct Burial • Suitable for use in Class I, Division 2 locations per Article 501 of the National Electric Code Conductors SPM1803CY SPM1804CY SPM1805CY SPM1807CY SPM1809CY 3 4 5 7 9 Nominal Diameter Inch mm 0.329 8.36 0.354 8.99 0.381 9.68 0.409 10.39 0.466 11.84 Jacket Thickness Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 16 AWG (1.32 mm2) Stranding: 26/30 (26 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.12 mm) nylon Part No. Conductors SPM1603CY SPM1604CY SPM1605CY SPM1607CY SPM1609CY 3 4 5 7 9 Nominal Diameter Inch mm 0.351 8.92 0.378 9.60 0.408 10.36 0.439 11.15 0.509 12.93 Jacket Thickness Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 14 AWG (2.08 mm2) Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.12 mm) nylon Part No. Conductors SPM1403CY SPM1404CY SPM1405CY SPM1407CY SPM1409CY 3 4 5 7 9 Nominal Diameter Inch mm 0.381 9.68 0.412 10.46 0.446 11.33 0.481 12.22 0.590 14.99 Jacket Thickness Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.065 1.65 12 AWG (3.29 mm2) Stranding: 65/30 (65 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.12 mm) nylon Availability Bulk, cut to length FIT® Tubing Recommendations • FIT-260: Cross-linked polyolefin for ground identification • FIT-300: Dual-wall polyolefin with meltable inner wall • FIT-750: Bonding adhesive-lined cross-linked polyolefin 294 Part No. Part No. Conductors SPM1203CY SPM1204CY SPM1205CY SPM1207CY SPM1209CY 3 4 5 7 9 Nominal Diameter Inch mm 0.422 10.72 0.458 11.63 0.497 12.62 0.574 14.58 0.659 16.74 Jacket Thickness Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.065 1.65 0.065 1.65 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Unshielded > 1000 V Solar Cable 1000 V Unshielded, Multiconductor, PVC/Nylon, PVC 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.12 mm) nylon UL TC-ER UL WTTC (1000 V) UL MTW CSA AWM I/II A/B FT1 Operating Temperature • -40°C to +90°C (static) • -30°C to +90°C (dynamic) • +105°C (CSA) Conductor Color Coding • Chart F (page 532) Materials • Stranded bare copper conductors • PVC/nylon insulation • Clear polyester wrap • Green PVC jacket Features • UL Sunlight Resistant • UL Oil Res. I • UL Direct Burial • Suitable for use in Class I, Division 2 locations per Article 501 of the National Electric Code Part No. Conductors SPM1803 SPM1804 SPM1805 SPM1807 SPM1809 3 4 5 7 9 Jacket Thickness Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 16 AWG (1.32 mm2) Stranding: 26/30 (26 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.12 mm) nylon Part No. Conductors SPM1603 SPM1604 SPM1605 SPM1607 SPM1609 3 4 5 7 9 Nominal Diameter Inch mm 0.323 8.20 0.350 8.89 0.380 9.65 0.411 10.44 0.475 12.07 Jacket Thickness Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 14 AWG (2.08 mm2) Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.12 mm) nylon Part No. Conductors SPM1403 SPM1404 SPM1405 SPM1407 SPM1409 3 4 5 7 9 Availability Bulk, cut to length FIT® Tubing Recommendations • FIT-260: Cross-linked polyolefin for ground identification • FIT-300: Dual-wall polyolefin with meltable inner wall • FIT-750: Bonding adhesive-lined cross-linked polyolefin Nominal Diameter Inch mm 0.301 7.65 0.326 8.28 0.353 8.97 0.381 9.68 0.438 11.13 Nominal Diameter Inch mm 0.353 8.97 0.384 9.75 0.418 10.62 0.453 11.51 0.556 14.12 Jacket Thickness Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.065 1.65 12 AWG (3.29 mm2) Stranding: 65/30 (65 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.12 mm) nylon Part No. Conductors SPM1203 SPM1204 SPM1205 SPM1207 SPM1209 3 4 5 7 9 Nominal Diameter Inch mm 0.394 10.01 0.430 10.92 0.469 11.91 0.510 12.95 0.625 15.88 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.065 1.65 295 Industrial Automation Cable Seamless communication for robust industrial environments W hether you are designing a device for error proofing to increase quality or motion sensing to improve safety, trust Alpha Wire for all your Industrial Automation needs. RS-485 As industrial automation systems continue to increase in complexity, we understand the challenges that engineers and manufacturers face in designing and interconnecting system components from sensors to top-level controllers. Our range of industrial automation cables combines the industryleading quality and exceptional reliability you expect with Alpha Wire with the performance to meet the rigorous requirements of the major automation communication architectures. DeviceNet™ Meeting ODVA thick and thin specifications, the cables comply with Allen-Bradley 1485 CPI-A and 1485 CPI-C, and support high data rates (500 kb/s at 100 m and 125 kb/s at 500 m). Fieldbus and PROFIBUS® A complete family meets ruggedness, performance, and quality requirements of almost any fieldbus and PROFIBUS application environment. Industrial Twinax ControlNet™ Low-loss RG-6/U coax designed to meet the high-speed, timecritical requirements of modern ControlNet factory-floor automation systems. 296 Bringing proven data transmission protocol to the factory floor, rugged RS-485 cables reduce electrical noise sensitivity to keep reliability and performance at world-class levels. A robust physical media for the transmission of PLC/DCS signals in real-time, high-throughput applications, including AllenBradley Data Highway networks. The cables may be installed in the same tray or conduit as 600-volt power cable. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Double Braid and Foil Shielded > 300 V ControlNet 300 V, RG-6/U Coaxial Cable, Double Braid and Foil Shielded Nominal Diameter Inch mm 0.298 7.57 Part No. 6458 Center Conductor AWG mm2 18 0.82 Nominal Impedance (ohms) 75 Nominal Attenuation Frequency (MHz) UL CL2R UL CMR CSA CMG FT4 Operating Temperature • -30°C to +75°C Materials • S  olid bare Copperweld conductor • Foam polyethylene insulation • Shielding: double braid and foil Foil +60% aluminum braid + foil +40% aluminum braid • Black PVC jacket 1 2 5 10 20 50 100 200 300 400 Attenuation, Nom. dB/100 ft 0.35 0.38 0.45 0.59 0.86 1.37 1.97 2.82 3.48 4.04 dB/100 m 1.1 1.2 1.5 1.9 2.8 4.5 6.5 9.3 11.4 13.3 Features • • • • UL Sunlight Resistant 75-ohm nominal impedance 82% velocity of propagation 16.2 pF/ft (53.1 pF/m) nominal capacitance Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) FIT® Tubing Recommendations • F  IT-221: General-purpose, cross-linked polyolefin • FIT-321: Medium-wall, adhesivelined, cross-linked polyolefin Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 297 Cable > Communication, Control and Industrial > Foil Shielded, Individual Pairs > Braid Shield Overall > 300 V DeviceNet 300 V Power and Data, Class 2, ODVA Thick and Thin Trunks Part No. UL CMG UL PLTC-ER (Thick) UL CL2 (Thin) CSA CMG FT4 CSA AWM I/II A/B FT4 Type 6451 Thick 6452 Thin Pairs 1 Power: 15 AWG (1.75 mm2), 19/0.0135 (19 x 0.35 mm) stranding 1 Data: 18 AWG (0.96 mm2), 19/30 (19 x 0.25 mm) stranding 1 Power: 22 AWG (0.38 mm2), 19/34 (19 x 0.16 mm) stranding 1 Data: 24 AWG (0.24 mm2), 19/36 (19 x 0.13 mm) stranding Nominal Diameter Inch mm 0.480 12.19 0.280 7.11 Operating Temperature • -20°C to +75°C (static) • 0°C to +80°C (dynamic) Conductor Color Coding • Black-red power • Blue-white data Materials • Tinned copper conductors • Each pair individually foil shielded • PVC insulation (power pair) • Foam HDPE insulation (data pair) • 65% tinned copper braid overall • Slate PVC jacket Features • Oil resistant • UL Sunlight Resistant • 120-ohm nominal impedance (data pair) • Compliant with Allen-Bradley part numbers 1485 CPI-A and 1485 CPI-C Availability FIT® Tubing Recommendations 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) • F  IT-221: General-purpose, cross-linked polyolefin • FIT-321: Medium-wall, adhesivelined, cross-linked polyolefin 298 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Single-Pair > Foil Shielded > 300 V Fieldbus 300 V Single-Pair Cable, Fieldbus Types A and B Part No. Fieldbus Type Pairs 6459 6460 A B 1 1 Conductor AWG mm2 18 0.90 22 0.33 Stranding AWG mm 7/26 7 x 0.40 7/0.0096 7 x 0.24 Nominal Diameter Inch mm 0.253 6.43 0.196 4.97 UL PLTC-ER UL CM UL ITC CSA CM Operating Temperature • -30°C to +105°C Conductor Color Coding • Blue-orange Materials • • • • Tinned copper conductors Polyolefin insulation Foil shield Orange PVC jacket Features • UL Sunlight Resistant • 100-ohm nominal impedance Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) FIT® Tubing Recommendations • F  IT-221: General-purpose, cross-linked polyolefin • FIT-321: Medium-wall, adhesivelined, cross-linked polyolefin Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 299 Cable > Communication, Control and Industrial > Single-Pair > Foil Shielded > 300 V High-Speed Fieldbus 300 V Single-Pair Cable Part No. Pairs 6461 1 Conductor AWG mm2 22 0.35 Stranding AWG mm 7/30 7 x 0.25 Nominal Diameter Inch mm 0.351 8.92 UL PLTC UL CM CSA CM Operating Temperature • -40°C to +75°C Conductor Color Coding • Blue-orange Materials • Tinned copper conductors • Foam high-density polyethylene insulation • Foil shield • Orange PVC jacket Features • UL Sunlight Resistant • 150-ohm nominal impedance Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) FIT® Tubing Recommendations • F  IT-221: General-purpose, cross-linked polyolefin • FIT-321: Medium-wall, adhesivelined, cross-linked polyolefin 300 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Single-Pair > Foil + Braid Shield > 300 V PROFIBUS-DP 300 V Single-Pair Cable Part No. Pairs 6462 6463 1 1 Conductor AWG mm2 22 0.32 22 0.35 Stranding AWG mm Solid 7/30 7 x 0.25 Nominal Diameter Inch mm 0.315 8.00 0.315 8.00 UL AWM 20201 (6462 only) UL PLTC UL CMG CSA CMG FT4 Operating Temperature • -30°C to +75°C (PLTC, CMG) • -30°C to +60°C (AWM) Conductor Color Coding • Red-green Materials • T  inned solid or stranded copper conductors • Foam high-density polyethylene insulation • Foil + 65% tinned copper braid shield • Purple PVC jacket Features • UL Sunlight Resistant • 150-ohm nominal impedance Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) FIT® Tubing Recommendations • F  IT-221: General-purpose, cross-linked polyolefin • FIT-321: Medium-wall, adhesivelined, cross-linked polyolefin Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 301 Cable > Communication, Control and Industrial > Multipair > Foil + Braid > 300 V RS-485 Cable 300 V Foil + Braid, Multipair 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) UL CM, CMG UL TC, PLTC CSA CM, CMG FT1 Part No. Pairs 6453 6454* 6455 6456 6457 1 1.5 2 3 4 Nominal Diameter Inch mm 0.284 7.21 0.300 7.62 0.408 10.36 0.414 10.52 0.448 11.38 Insulation Thickness Inch mm 0.028 0.71 0.032 0.81 0.024 0.61 0.022 0.56 0.022 0.56 Jacket Thickness Inch mm 0.042 1.07 0.042 1.07 0.053 1.35 0.053 1.35 0.053 1.35 *Conductor color coding: white/orange-orange/white pair, white-blue single conductor. Operating Temperature • -20°C to +60°C Conductor Color Coding • C  hart M (page 530), except 6454 Materials • T  inned copper conductors • Foam high-density polyethylene insulation • Foil + 65% tinned copper braid shield • Black PVC jacket Features • UL Sunlight Resistant • 120-ohm nominal impedance Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) FIT® Tubing Recommendations • F  IT-221: General-purpose, cross-linked polyolefin • FIT-321: Medium-wall, adhesivelined, cross-linked polyolefin 302 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Single Pair > Foil + Braid Shield > 600 V Industrial Twinax 600 V Foil + Braid Shield, Single Pair Part No. Pairs 6450 1 Conductor AWG mm2 18 0.90 Stranding AWG mm 7/26 7 x 0.40 Nominal Diameter Inch mm 0.324 8.23 UL TC, PLTC, ITC UL CMG CSA CMG FT4 Operating Temperature • -40°C to +75°C Conductor Color Coding • Blue-white Materials • T  inned stranded copper conductors • Flame-resistant polypropylene insulation • Foil + 55% tinned copper braid shield • Blue PVC jacket Features • UL Sunlight Resistant • 78-ohm nominal impedance • Meets the requirements of AllenBradley Data Highway Networks Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) FIT® Tubing Recommendations • F  IT-221: General-purpose, cross-linked polyolefin • FIT-321: Medium-wall, adhesivelined, cross-linked polyolefin Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 303 Cable > Communication, Control and Industrial > Motor Supply > Shielded > 600 V Flexible Motor Supply Cable Light Duty Flexing 600 V Foil/Braid, Four Conductor UL TC-ER UL MTW UL WTTC CSA AWM l/ll A/B FT4 CE Operating Temperature Conductor Color Coding • One yellow/green and three numbered black Voltage Materials Availability • F  inely stranded bare copper conductors • PVC/nylon insulation • Foil + braid shield Aluminum/polyester/aluminum foil shield, with 25% overlap and four tinned copper drain wires Tinned copper braid with 70% coverage • Black PVC jacket Bulk, cut to length • 6  00 V (UL TC-ER, MTW) • 1000 V (UL WTTC) FIT® Tubing Recommendations • F  IT-321: Medium-wall, adhesivelined, cross-linked polyolefin • FIT-600: Highly flexible, cross-linked elastomer • - 5°C to +90°C (flexing) • -20°C to +90°C (stationary) 16 to 6 AWG (1.49 to 5.33 mm2) Part No. Conductors 5660 5661 5662 5663 5664 5665 4 4 4 4 4 4 304 Wire Size AWG mm2 16 1.32 14 2.08 12 3.30 10 5.32 8 8.52 6 13.49 Stranding AWG mm 26/30 26 x 0.25 41/30 41 x 0.25 65/30 65 x 0.25 105/30 105 x 0.25 168/30 168 x 0.25 266/30 266 x 0.25 Nominal Diameter Inch mm 0.381 9.67 0.418 10.61 0.464 11.78 0.579 14.70 0.760 19.30 0.901 22.88 Jacket Thickness Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.063 1.60 0.063 1.60 0.083 2.10 Insulation Thickness Inch mm 0.016 0.40 0.016 0.40 0.016 0.40 0.022 0.55 0.032 0.81 0.032 0.81 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. A Full Range of Communication and Control O ur line-up of standard communication and control cables gives you maximum choice and fewer tradeoffs. By offering you a comprehensive collection of insulation/jacketing materials, shielding options, and conductor counts, you can easily select the cable that meets your most demanding needs. We have cables that go beyond the ordinary to satisfy rigorous requirements of EMI performance, transmission distances, flexibility, and temperature extremes. Communication and control typical applications: • Audio systems: speakers, microphones, intercoms • Broadcast and studio • Data transmission: RS-232, 422, 485 • CAD/CAM • Computer peripherals • Business machines • Security systems: alarms, cameras, sensors • Control systems • Instrumentation systems • Point-of-sale systems • Banking systems Flexible shielding options: • Unshielded • Overall foil shield • Overall foil/braid • Individual foil-shielded pairs • Individual foil-shielded pairs with overall foil/braid Communication and control key features: • 1 – 50 conductors, 1 – 50 pairs • Wide range of insulation/ jacket materials: • PVC • Irradiated PVC • Plenum-rated PVC • Semirigid PVC • Rubber • Polyethylene • Polypropylene • Foam PP and PE • PTFE/FEP • LSZH • Low-capacitance cables for improved transmission distances and signal integrity Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 305 Cable > Communication, Control and Industrial > Low-Smoke, Zero-Halogen (LSZH) Communication and Control Cable 300 V Unshielded, Multiconductor, LSZH UL CM VW-1 CSA CMG FT4 LSZH Properties Operating Temperature • -20°C to +75°C Materials Alpha Wire’s LSZH communication and control cable combines LSZH-rated insulation and jackets with the rugged performance you expect from Alpha. The specially formulated LSZH material minimizes the effects from smoke and harmful corrosive gases in the event of combustion. Low smoke means easier visibility in exiting the area and reduced danger of smoke inhalation, while low toxicity means no harm to people from halogenated gases. • L  SZH Flammability: Passes IEC 60332-1 • LSZH Acid Gas Generation: Passes IEC 60754-1 and 60754-2 • LSZH Smoke Emission: Passes IEC 61034-2 • S  tranded tinned copper conductors • LSZH insulation • Slate LSZH jacket LSZH Unshielded Multiconductor Conductor Color Coding: Chart D 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors 1172L 1173L 1174L 1175L 1176L 1177L 1178L 1179L 1180L 2 3 4 5 6 7 8 9 10 Nominal Diameter Inch mm 0.161 4.09 0.169 4.29 0.189 4.80 0.201 5.11 0.209 5.31 0.209 5.31 0.220 5.59 0.249 6.32 0.260 6.60 Jacket Thickness Inch mm 0.028 0.71 0.028 0.71 0.028 0.71 0.028 0.71 0.030 0.76 0.030 0.76 0.030 0.76 0.032 0.81 0.035 0.88 20 AWG (0.56 mm2) Stranding: 7/28 (0.32 mm) Insulation thickness: 0.016 (0.40 mm) 306 Part No. Conductors 1895L 1896L 1896/4L 1896/5L 1896/6L 2 3 4 5 6 Nominal Diameter Inch mm 0.181 4.60 0.189 4.80 0.209 5.31 0.232 5.89 0.276 7.01 Jacket Thickness Inch mm 0.018 0.45 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Low-Smoke, Zero-Halogen (LSZH) Communication and Control Cable 300 V Foil Shielded, Multipair, LSZH UL CM VW-1 CSA CMG FT4 LSZH Properties • L  SZH Flammability: Passes IEC 60332-1 • LSZH Acid Gas Generation: Passes IEC 60754-1 and 60754-2 • LSZH Smoke Emission: Passes IEC 61034-2 Operating Temperature • -20°C to +75°C Materials Alpha Wire’s LSZH communication and control cable combines LSZH-rated insulation and jackets with the rugged performance you expect from Alpha. The specially formulated LSZH material minimizes the effects from smoke and harmful corrosive gases in the event of combustion. Low smoke means easier visibility in exiting the area and reduced danger of smoke inhalation, while low toxicity means no harm to people from halogenated gases. • S  tranded tinned copper conductors • LSZH insulation (Polypropylene insulation for individually foil shielded pairs) • Aluminum/polyester shielding, with 25% overlap min. Foil facing inward Tinned copper drain wire sized the same as the conductors • Slate LSZH jacket LSZH Overall Foil Shielded Multipair Conductor Color Coding: Chart A 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Pairs 5471L 5472L 5473L 5474L 5475L 5476L 5477L 5478L 5479L 5480L 1 2 3 4 5 6 7 8 9 10 Nominal Diameter Inch mm 0.161 4.09 0.209 5.31 0.228 5.79 0.240 6.10 0.272 6.91 0.299 7.59 0.299 7.59 0.319 8.10 0.339 8.61 0.378 9.60 Jacket Thickness Inch mm 0.028 0.71 0.028 0.71 0.028 0.71 0.028 0.71 0.030 0.76 0.030 0.76 0.030 0.76 0.032 0.81 0.032 0.81 0.032 0.81 LSZH Individually Foil-Shielded Pair Conductor Color Coding: Chart A 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Pairs 2466L*† 6010L 2463L*†† 6012L 6014L 6017L 2 3 4 6 9 12 Nominal Diameter Inch mm 0.161 4.09 0.299 7.59 0.242 6.15 0.386 9.80 0.441 11.20 0.492 12.50 Jacket Thickness Inch mm 0.014 0.35 0.047 1.19 0.020 0.50 0.040 1.01 0.040 1.01 0.040 1.01 *Conductor color coding: 1 Red-Black, 2 Green-White, White/Red-White/Black, 4 White/Green-White/Yellow. †0.009 (0.23) insulation thickness. ††0.008 (0.20) insulation thickness. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 307 Cable > Communication, Control and Industrial > Multiconductor > Unshielded > 300 V Communication and Control 300 V Unshielded, Multiconductor, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2576 (150 V) VW-1 UL CM CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Conductor Color Coding • Chart D (page 531) Materials Part No. Conductors 1172C 1173C 1174C 1175C 1176C 1177C 1178C 1179C 1180C 1181C 1181/15C 1181/20C 1181/25C 1181/30C 1181/40C 1181/50C 1181/60C 2 3 4 5 6 7 8 9 10 12 15 20 25 30 40 50 60 • S  tranded or solid tinned copper conductors • PVC insulation • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 308 Nominal Diameter Inch mm 0.164 4.17 0.172 4.37 0.185 4.70 0.200 5.08 0.215 5.46 0.215 5.46 0.230 5.84 0.246 6.25 0.264 6.71 0.272 6.91 0.294 7.47 0.326 8.28 0.364 9.25 0.385 9.78 0.429 10.90 0.478 12.14 0.520 13.21 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.035 0.89 0.035 0.89 22 AWG (0.32 mm2) Stranding: Solid Insulation thickness: 0.010 (0.25 mm) Part No. Conductors 1793C 2 Nominal Diameter Inch mm 0.157 3.99 Jacket Thickness Inch mm 0.032 0.81 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Unshielded > 300 V Communication and Control 300 V Unshielded, Multiconductor, PVC, PVC 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.016 (0.41 mm) UL AWM 2509 VW-1 UL CM CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Part No. Conductors 1895C 1896C 1896/4C 1896/5C 1896/6C 1896/7C 1896/8C 1896/9C 1896/10C 1896/12C 1896/15C 2 3 4 5 6 7 8 9 10 12 15 Conductor Color Coding • S  tranded tinned copper conductors • PVC insulation • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.023 0.58 0.020 0.51 0.020 0.51 0.030 0.76 18 AWG (0.81 mm2) • Chart D (page 531) Materials Nominal Diameter Inch mm 0.180 4.57 0.191 4.85 0.209 5.31 0.230 5.84 0.251 6.38 0.251 6.38 0.273 6.93 0.301 7.65 0.320 8.13 0.331 8.41 0.382 9.70 Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors 1897C 1898C 1898/4C 1898/5C 1898/6C 1898/7C 1898/8C 1898/9C 1898/10C 1898/12C 1898/15C 1898/19C 1898/25C 2 3 4 5 6 7 8 9 10 12 15 19 25 Nominal Diameter Inch mm 0.198 5.03 0.210 5.33 0.231 5.87 0.254 6.45 0.278 7.06 0.278 7.06 0.313 7.95 0.337 8.56 0.366 9.30 0.378 9.60 0.423 10.74 0.455 11.56 0.544 13.82 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.030 0.76 0.030 0.76 0.035 0.89 16 AWG (1.32 mm2) Stranding 19/0.0117 (19 x 0.29 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors 1899C 1899/3C 1899/4C 2 3 4 Nominal Diameter Inch mm 0.222 5.64 0.236 5.99 0.260 6.60 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 309 Cable > Communication, Control and Industrial > Multiconductor > Unshielded > 300 V Communication and Control 300 V Unshielded, Multiconductor, PVC, PVC 14 AWG (2.09 mm2) Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) Part No. Conductors 1891C 1891/3C 2 3 UL CL2 VW-1 CSA AWM I/II A/B FT1 Conductor Color Coding Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 12 AWG (3.31 mm2) Stranding: 65/30 (65 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CL2) Nominal Diameter Inch mm 0.268 6.81 0.286 7.26 Part No. Conductors 1892C 1892/3C 2 3 Nominal Diameter Inch mm 0.312 7.92 0.333 8.46 Jacket Thickness Inch mm 0.023 0.58 0.023 0.58 • Chart D (page 531) Materials • S  tranded tinned copper conductors • PVC insulation • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 310 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Unshielded > 600 V Communication and Control 600 V Unshielded, Multiconductor, PVC, PVC 16 AWG (1.32 mm2) Stranding 19/0.0117 (19 x 0.29 mm) Insulation Thickness 0.032 (0.81 mm) UL AWM 2463 VW-1 Operating Temperature • -20°C to +80°C Part No. Conductors 1064 1065 1067 1069 1072 1075 1079 1085 4 5 7 9 12 15 19 25 Nominal Diameter Inch mm 0.395 10.03 0.430 10.92 0.468 11.89 0.577 14.66 0.640 16.26 0.694 17.63 0.749 19.02 0.907 23.04 Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 0.063 1.60 0.065 1.65 0.083 2.11 Conductor Color Coding • Chart F (page 532) 14 AWG (2.08 mm2) Materials • S  tranded tinned copper conductors • PVC insulation • Clear polyester wrap • Slate PVC jacket Availability Stranding (19 x 0.0147 (19 x 0.37 mm) Insulation thickness: 0.047 (1.19 mm) Part No. Conductors 1274 1275 1277 1279 1282 4 5 7 9 12 Nominal Diameter Inch mm 0.503 12.78 0.584 14.83 0.635 16.13 0.744 18.90 0.867 22.02 Jacket Thickness Inch mm 0.047 1.19 0.063 1.60 0.063 1.60 0.065 1.60 0.083 2.11 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 311 Cable > Communication, Control and Industrial > Multiconductor > Unshielded > 300 V Communication and Control 300 V Unshielded, Multiconductor, IRR PVC, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) MIL-DTL-16878/1 (Type B) UL AWM 2576 (150 V) VW-1 Part No. Conductors 6622 6623 6624 2 3 4 Conductor Color Coding • 1 White, 2 Black, 3 Red, 4 Green Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 22 AWG (0.35 mm2) Operating Temperature • -55°C to +105°C (MIL) • -55°C to +80°C (AWM) Nominal Diameter Inch mm 0.155 3.94 0.162 4.11 0.173 4.39 Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors 6632 6633 6634 2 3 4 Nominal Diameter Inch mm 0.167 4.24 0.175 4.44 0.188 4.78 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 Materials • S  tranded tinned copper conductors • Irradiated PVC insulation • Clear polyester wrap • White PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors 6642 6643 6644 2 3 4 Nominal Diameter Inch mm 0.183 4.65 0.192 4.88 0.207 5.26 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 18 AWG (0.89 mm2) Stranding: 7/26 (7 x 0.40 mm) Insulation thickness: 0.010 (0.25 mm) 312 Part No. Conductors 6652 6653 6654 2 3 4 Nominal Diameter Inch mm 0.203 5.16 0.214 5.44 0.232 5.89 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Unshielded and Braid Shield > 300 V Communication and Control 300 V Unshielded and Braid Shield, Multiconductor, PVC, PVC 22 AWG Composite Shielded and Unshielded, UL AWM 2785, UL CM, and CSA CMG 22 AWG (0.35 mm2) Stranding 7/30 (7 x 0.25 mm) Insulation Thickness 0.016 (0.41 mm) UL AWM 2785 VW-1 UL CM CSA CMG FT4 Part No. Conductors 1243 1243/4 1243/5 3 4 5 Nominal Diameter Inch mm 0.190 4.83 0.185 x 0.285 4.70 x 7.24 0.195 x 0.300 4.95 x 7.62 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 Configuration Shielded 1 2 3 Unshielded 2 2 2 Conductor Color Coding Shielded: 1 White, 2 Black, 3 Red Unshielded: 1 Black, 2 Red Operating Temperature • -20°C to +75°C (CM) • -20°C to +60°C (AWM, CMG) Conductor Color Coding See tables Materials • S  tranded tinned copper conductors • PVC insulation • Tinned copper braid shield, 80% coverage • Slate PVC jacket 22 and 18 AWG Unshielded, UL CM and CSA CMG Only 22 AWG (0.35 mm2) 18 AWG (0.81 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) 16/30 (16 x 0.25 mm) 0.018 (0.45 mm) Part No. 1826C 1827C 1828C Conductors 22 AWG 18 AWG 4 2 5 2 6 2 Nominal Diameter Inch mm 0.241 6.12 0.247 6.27 0.261 6.63 Jacket Thickness Inch mm 0.025 0.63 0.028 0.71 0.028 0.71 Conductor Color Coding 22 AWG: Chart I (page 533) 18 AWG: Chart D (page 531) Availability 100 ft (30.5 m)* 500 ft (152 m)* 1000 ft (305 m) *Parts 1243, 1243/4, and 1243/5 only Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 313 Cable > Communication, Control and Industrial > Multiconductor > Foil Shield > 300 V Communication and Control 300 V Foil Shield, Multiconductor, PE, PVC 24 AWG (0.23 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.016 (0.41 mm) 24 AWG (0.22 mm2) drain wire Part No. Conductors 2400C 2 UL AWM 2092, 2093, 2094 VW-1 UL CMG CSA CMG FT4 AWM 2092 Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) 22 AWG (0.35 mm2) drain wire Part No. Conductors • -20°C to +75°C (CMG) • -20°C to +60°C (AWM) 2401C* 2402C 2403C 2404C 2 2 3 4 • 1 Black, 2 Red, 3 Natural, 4 Green Nominal Diameter Inch mm 0.168 4.27 0.168 4.27 0.178 4.52 0.194 4.93 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 AWM 2092 2092 2093 2094 20 AWG (0.56 mm2) Materials • S  tranded tinned copper conductors • Polyethylene insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire (see table for sizes) • Slate PVC jacket Jacket Thickness Inch mm 0.020 0.51 22 AWG (0.35 mm2) Operating Temperature Conductor Color Coding Nominal Diameter Inch mm 0.156 3.96 Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.016 (0.41 mm) 20 AWG (0.50 mm2) drain wire Part No. Conductors 2411C* 2412C 2413C 2414C 2 2 3 4 Nominal Diameter Inch mm 0.184 4.67 0.184 4.67 0.195 4.95 0.213 5.41 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 AWM 2092 2092 2093 2094 18 AWG (0.81 mm2) Availability 100 ft (30.5 m) 500 ft (152 m), spool or box 1000 ft (305 m), spool or box Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) 20 AWG (0.50 mm2) drain wire Part No. Conductors 2421C* 2422C 2423C 2424C 2 2 3 4 Nominal Diameter Inch mm 0.202 5.13 0.202 5.13 0.214 5.44 0.235 5.97 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 AWM 2092 2092 2093 2094 16 AWG (1.32 mm2) Stranding: 19/0.117 (19 x 0.30 mm) Insulation thickness: 0.016 (0.41 mm) 18 AWG (0.81 mm2) drain wire Part No. Conductors 2432C 2433C 2 3 Nominal Diameter Inch mm 0.226 5.74 0.240 6.10 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 AWM 2092 2093 *Color code: 1 black, 2 natural. 314 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Foil Shield > 300 V Communication and Control 300 V Foil Shield, Multiconductor, PE, PVC 14 AWG (2.08 mm2) Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) 16 AWG (1.32 mm2) drain wire Part No. Conductors 2442C 2 UL CL2 CSA AWM I/II A/B FT4 Conductor Color Coding Jacket Thickness Inch mm 0.030 0.76 UL CL2 12 AWG (3.29 mm2) Stranding: 65/30 (65 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) 14 AWG (2.08 mm2) drain wire Operating Temperature • -20°C to +75°C (CL2) • -20°C to +60°C (AWM) Nominal Diameter Inch mm 0.292 7.42 Part No. Conductors 2444C 2 Nominal Diameter Inch mm 0.330 8.38 Jacket Thickness Inch mm 0.030 0.76 UL CL2 • 1 Black, 2 Red, 3 Natural, 4 Green Materials • S  tranded tinned copper conductors • Polyethylene insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire (see table for sizes) • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m), spool or box 1000 ft (305 m), spool or box Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 315 Cable > Communication, Control and Industrial > Multiconductor > Foil Shield > 300 V Communication and Control 300 V Foil Shield, Multiconductor, PP, PE, PVC/PVC Polypropylene Insulation 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) or solid Insulation Thickness: 0.008 (0.20 mm) UL CM VW-1 CSA CMG FT4 Part No. Conductors 2460C 2461C 2 (solid) 2 Nominal Diameter Inch mm 0.126 3.20 0.136 3.45 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 Configuration Shielded Unshielded 2 0 2 0 Polyethylene Insulation 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation Thickness: 0.014 (0.36 mm) Operating Temperature • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Conductor Color Coding • 1 White, 2 Black, 3 Red, 4 Green • 1 Black, 2 Red, 3 White, 4 Green Part No. Conductors 1243/3C 2464C 3 4 Jacket Thickness Inch mm 0.030 0.76 0.020 0.51 Configuration Shielded Unshielded 2 1 2 2 PVC Insulation 20 AWG (0.56 mm2) Materials • S  tranded tinned copper conductors (except 2460C) • PP, PE, or PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward 1243/3C: foil facing inward Stranded tinned copper drain wire (except 2460C) • Slate PVC jacket 2461C: slate or black Nominal Diameter Inch mm 0.210 5.33 0.165 4.19 Stranding: 7/28 (7 x 0.32 mm) Insulation Thickness: 0.015 (0.38 mm) Part No. Conductors 2465C 4 Nominal Diameter Inch mm 0.240 6.10 Jacket Thickness Inch mm 0.030 0.76 Configuration Shielded Unshielded 2 2 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 316 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Foil Shield > 300 V Communication and Control 300 V Foil Shield, Multiconductor, PVC, PVC 24 AWG (0.23 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2576 (150 V) VW-1 UL CM CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Conductor Color Coding • Chart D (page 531) Materials • S  tranded tinned copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Part No. Conductors 1212C 1213C 1214C 1215C 1216C 1217C 1218C 1219C 1219/10C 1219/12C 1219/15C 1219/20C 1219/25C 1219/37C 1219/40C 1219/50C 2 3 4 5 6 7 8 9 10 12 15 20 25 37 40 50 Nominal Diameter Inch mm 0.156 3.96 0.163 4.14 0.174 4.42 0.187 4.75 0.201 5.11 0.201 5.11 0.214 5.44 0.228 5.79 0.244 6.20 0.251 6.38 0.270 6.86 0.298 7.57 0.332 8.43 0.376 9.55 0.390 9.91 0.427 10.85 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors 1292C 1293C 1294C 1295C 1296C 1297C 1298C 1299C 1299/10C 1299/12C 1299/15C 1299/20C 1299/25C 1299/30C 1299/37C 1299/40C 1299/50C 2 3 4 5 6 7 8 9 10 12 15 20 25 30 37 40 50 Nominal Diameter Inch mm 0.168 4.27 0.176 4.47 0.189 4.80 0.204 5.18 0.219 5.56 0.219 5.56 0.234 5.94 0.250 6.35 0.268 6.81 0.276 7.01 0.298 7.57 0.330 8.38 0.368 9.35 0.389 9.88 0.418 10.62 0.433 11.00 0.482 12.24 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.035 0.89 317 Cable > Communication, Control and Industrial > Multiconductor > Foil Shield > 300 V Communication and Control 300 V Foil Shield, Multiconductor, SR-PVC, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2464 VW-1 UL CM CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Conductor Color Coding • Chart F (page 532) Part No. Conductors 6300/3* 6300/4* 6305 6306* 6300/8* 6300/10* 6307 6308 6309 6310 6311 6312 3 4 5 6 8 10 15 20 25 30 40 50 Nominal Diameter Inch mm 0.163 4.14 0.174 5.44 0.187 4.75 0.201 5.11 0.214 5.44 0.244 6.20 0.270 6.86 0.298 7.57 0.332 8.43 0.366 9.30 0.406 10.31 0.453 11.51 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.040 1.02 0.040 1.02 0.045 1.14 Mutual capacitance: 32 pF/ft (105 pF/m) Ground capacitance: 58 pF/ft (190 pF/m) *Color coding: 1 Black, 2 White, 3 Red, 4 Green, 5 Brown, 6 Blue, 7 Orange, 8 Yellow, 9 Violet, 10 Slate. Materials • S  tranded tinned copper conductors • Semirigid PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 318 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Spiral Shield > 300 V Communication and Control 300 V Spiral Shield, Multiconductor, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) AWM 2095 AWM 1108 (Single-conductor cables) Part No. Conductors 2254/1 2254 2254/3 2254/4 2254/6 1 2 3 4 6 Stranding: 10/30 (10 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) • -20°C to +80°C Conductor Color Coding Part No. Conductors • 1 Black, 2 Red, 3 White, 4 Green, 5 Yellow, 6 Blue 2256/1 2256 2256/3 2256/4 2256/6 1 2 3 4 6 • S  tranded tinned copper conductors • PVC insulation • Clear polyester wrap (multiconductor only) • Bare copper spiral shield, 95% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 20 AWG (0.56 mm2) Operating Temperature Materials Nominal Diameter Inch mm 0.112 2.84 0.177 4.50 0.187 4.75 0.206 5.23 0.243 6.17 Nominal Diameter Inch mm 0.119 3.02 0.191 4.85 0.202 5.13 0.223 5.66 0.264 6.71 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 18 AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors 2258/1 2258 2258/3 2258/4 1 2 3 4 Nominal Diameter Inch mm 0.129 3.28 0.214 5.44 0.226 5.74 0.247 6.27 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 16 AWG (1.32 mm2) Stranding: 26/30 (26 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors 2260 2260/3 2 3 Nominal Diameter Inch mm 0.240 6.10 0.254 6.45 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 319 Cable > Communication, Control and Industrial > Multiconductor > Braid Shield > 600 V Communication and Control 600 V Braid Shield, Multiconductor, PVC, PVC 28 AWG (0.09 mm2) Stranding: 7/36 (7 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) MIL-DTL-16878/1 (Type B) Operating Temperature • -55°C to +105°C Conductor Color Coding Part No. Conductors 3302 3303 3304 3306 3308 3310 3312 3315 3320 2 3 4 6 8 10 12 15 20 Nominal Diameter Inch mm 0.119 3.02 0.124 3.15 0.134 3.40 0.161 4.09 0.171 4.34 0.201 5.11 0.206 5.23 0.236 5.99 0.261 6.63 Jacket Thickness Inch mm 0.012 0.30 0.012 0.30 0.012 0.30 0.015 0.38 0.015 0.38 0.018 0.46 0.018 0.46 0.020 0.51 0.022 0.56 • Chart F (page 532) Materials • S  tranded tinned copper conductors • PVC insulation • Clear polyester wrap • Tinned copper braid shield, 90% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 1000 ft (305 m) 320 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Braid Shield > 600 V Communication and Control 600 V Braid Shield, Multiconductor, PVC/Nylon, PVC 26 AWG (0.14 mm2) Stranding: 7/34 (7 x 0.16 mm) Insulation thickness: 0.010 (0.25 mm) PVC/0.003 (0.08 mm) nylon MIL-DTL-16878/17 (Type B/N) Part No. Conductors 3200 3201 3202 3203 1 2 3 4 Nominal Diameter Inch mm 0.087 2.21 0.143 3.63 0.150 3.81 0.166 4.22 Jacket Thickness Inch mm 0.010 0.25 0.014 0.36 0.014 0.36 0.016 0.41 Operating Temperature • -55°C to +105°C 24 AWG (0.24 mm2) Stranding: 19/36 (19 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) PVC/0.003 (0.08 mm) nylon Conductor Color Coding • 1 White, 2 Black, 3 Red, 4 Green (unless otherwise noted) Materials • S  tranded tinned copper conductors • PVC/nylon insulation • Clear polyester wrap (multiconductor only) • Tinned copper braid shield, 90% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Part No. Conductors 3210 3211 3212 3213 1 2 3 4 Nominal Diameter Inch mm 0.093 2.36 0.159 4.04 0.167 4.24 0.182 4.62 Jacket Thickness Inch mm 0.010 0.25 0.016 0.41 0.016 0.41 0.017 0.43 22 AWG (0.38 mm2) Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.010 (0.25 mm) PVC/0.003 (0.08 mm) nylon Part No. Conductors 3220 3221 3222 3223 3335* 3336* 3337* 1 2 3 4 5 6 8 Nominal Diameter Inch mm 0.100 2.54 0.173 4.39 0.184 4.67 0.203 5.16 0.228 5.79 0.246 6.25 0.274 6.96 Jacket Thickness Inch mm 0.010 0.25 0.016 0.41 0.017 0.43 0.019 0.49 0.020 0.51 0.020 0.64 0.025 0.64 *Color code chart F. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 321 Cable > Communication, Control and Industrial > Multipair > Braid Shield > 600 V Communication and Control 600 V Braid Shield, Multipair, PVC/Nylon, PVC 20 AWG (0.61 mm2) Stranding: 19/32 (19 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) PVC/0.003 (0.08 mm) nylon MIL-DTL-16878/17 (Type B/N) Part No. Conductors 3230 3231 3232 3233 1 2 3 4 Nominal Diameter Inch mm 0.108 2.74 0.195 4.95 0.205 5.21 0.227 5.77 Jacket Thickness Inch mm 0.010 0.25 0.019 0.49 0.019 0.49 0.021 0.53 Operating Temperature • -55°C to +105°C 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) PVC/0.003 (0.08 mm) nylon Conductor Color Coding • 1 White, 2 Black, 3 Red, 4 Green (unless otherwise noted) Materials • S  tranded tinned copper conductors • PVC/nylon insulation • Clear polyester wrap (multiconductor only) • Tinned copper braid shield, 90% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 322 Part No. Conductors 3240 3241 3242 3243 1 2 3 4 Nominal Diameter Inch mm 0.122 3.10 0.219 5.56 0.233 5.92 0.261 6.63 Jacket Thickness Inch mm 0.012 0.30 0.021 0.53 0.022 0.56 0.023 0.58 16 AWG (1.23 mm2) Stranding: 19/29 (19 x 0.29 mm) Insulation thickness: 0.010 (0.25 mm) PVC/0.003 (0.08 mm) nylon Part No. Conductors 3245 3246 3247 3248 1 2 3 4 Nominal Diameter Inch mm 0.136 0.136 0.241 0.241 0.254 0.254 0.279 0.279 Jacket Thickness Inch mm 0.016 0.41 0.023 0.58 0.023 0.58 0.025 0.64 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Braid Shield > 300 V Communication and Control 300 V Braid Shield, Multiconductor, PVC, PVC 22 AWG (0.32 mm2) Stranding: Solid Insulation thickness: 0.020 (0.51 mm) UL AWM 2095 VW-1 UL AWM 1108 (Single-Conductor Cables) UL CM CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Part No. Conductors 1775C 2 Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors 1735 1736C 1737C 1738C 1 2 3 4 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Nominal Diameter Inch mm 0.124 3.15 0.189 4.80 0.199 5.05 0.215 5.46 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.016 (0.41 mm) • Chart D (page 531) • S  tranded or solid tinned copper conductors • PVC insulation • Clear polyester wrap (multiconductor only) • Bare copper braid shield, 75% coverage • Slate PVC jacket Jacket Thickness Inch mm 0.020 0.51 22 AWG (0.35 mm2) Conductor Color Coding Materials Nominal Diameter Inch mm 0.195 4.95 Part No. Conductors 1741C 1742C 1743C 2 3 4 Nominal Diameter Inch mm 0.205 5.21 0.216 5.49 0.234 5.94 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 18 AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors 1745 1746C 1747C 1747/4C 1 2 3 4 Nominal Diameter Inch mm 0.141 3.58 0.223 5.66 0.235 5.97 0.256 6.50 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 16 AWG (1.32 mm2) Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors 1748C 1749C 2 3 Nominal Diameter Inch mm 0.247 6.27 0.261 6.63 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 323 Cable > Communication, Control and Industrial > Multiconductor > Braid Shield > 450 V Communication and Control 450 V Braid Shield, Multiconductor, PVC, PVC 14 AWG (2.08 mm2) Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) Part No. Conductors 1750 1751 2 3 Nominal Diameter Inch mm 0.299 7.59 0.317 8.05 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 Operating Temperature • -20°C to +80°C 12 AWG (3.29 mm2) Stranding: 65/30 (65 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) Conductor Color Coding • Chart D (page 531) Materials • S  tranded tinned copper conductors • PVC insulation • Clear polyester wrap • Bare copper braid shield, 75% coverage • Slate PVC jacket Part No. Conductors 1760 1761 2 3 Nominal Diameter Inch mm 0.337 8.56 0.358 9.09 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 324 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Braid Shield > 600 V Communication and Control 600 V Braid Shield, Multiconductor, IRR PVC, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) MIL-DTL-16878/1 (Type B) Part No. Conductors 7622 7623 7624 2 3 4 Operating Temperature • Chart G (page 532) Materials • S  tranded tinned copper conductors • Irradiated PVC insulation • Clear polyester wrap • Tinned copper braid shield, 90% coverage • White PVC jacket Availability 1000 ft (305 m) Jacket Thickness Inch mm 0.025 0.64 0.025 0.64 0.025 0.64 22 AWG (0.35 mm2) • -55°C to +105°C Conductor Color Coding Nominal Diameter Inch mm 0.163 4.14 0.170 4.32 0.181 4.60 Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors 7631 7632 7633 7634 1 2 3 4 Nominal Diameter Inch mm 0.122 3.10 0.175 4.45 0.183 4.65 0.196 4.98 Jacket Thickness Inch mm 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors 7661 7662 7663 7664 1 2 3 4 Nominal Diameter Inch mm 0.130 3.30 0.191 4.85 0.200 5.08 0.215 5.46 Jacket Thickness Inch mm 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 18 AWG (0.89 mm2) Stranding: 7/26 (7 x 0.40 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors 7671 7672 7673 7674 1 2 3 4 Nominal Diameter Inch mm 0.140 3.56 0.211 5.35 0.222 5.64 0.240 6.09 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 325 Cable > Communication, Control and Industrial > Multiconductor > Braid Shield > 1000 V Communication and Control 1000 V Braid Shield, Multiconductor, PVC, PVC 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) MIL-DTL-16878/2 (Type C) Operating Temperature • -55°C to +105°C Part No. Conductors 3405 3408 3410 3412 3415 3420 3430 5 8 10 12 15 20 30 Conductor Color Coding Nominal Diameter Inch mm 0.303 7.70 0.364 9.25 0.429 10.90 0.442 11.23 0.488 12.40 0.550 13.97 0.667 16.94 Jacket Thickness Inch mm 0.025 0.64 0.030 0.76 0.035 0.89 0.035 0.89 0.040 1.02 0.045 1.14 0.055 1.40 16 AWG (1.23 mm2) • Chart F (page 532) Stranding: 19/29 (19 x 0.29 mm) Insulation thickness: 0.018 (0.45 mm) Materials • S  tranded tinned copper conductors • PVC insulation • Clear polyester wrap • Tinned copper braid shield, 90% coverage • Slate PVC jacket Part No. Conductors 3444 3446 3450 3452 4 6 10 12 Nominal Diameter Inch mm 0.316 8.03 0.376 9.55 0.487 12.37 0.509 12.93 Jacket Thickness Inch mm 0.031 0.79 0.034 0.86 0.044 1.12 0.048 1.22 Availability 100 ft (30.5 m) 1000 ft (305 m) 326 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Braid or Spiral Shield Communication and Control Braid or Spiral Shield, Multiconductor, PE, PVC Microphone Cable Operating Temperature • B  raided tinned copper or spiral wrapped tinned copper shield, 90% coverage (85% for part no. 1712) • Slate PVC jacket • -20°C to +60°C Conductor Color Coding • 1-White, 2-Black Availability Materials 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) • S  tranded tinned copper conductors • Polyethylene insulation • Clear polyester wrap (multiconductor only) 1-Conductor Cable for High-Impedance Microphones Part No. Voltage Rating 1706* 4000 Wire Size Nominal Diameter Stranding AWG mm2 AWG mm Inch mm 20 0.52 26/34 26 x 0.16 0.182 4.62 Shield Jacket Thickness Insulation Thickness Capacitance Inch mm Inch mm pF/ft pF/m Braid 0.030 0.76 0.031 0.79 38 125 1703 3500 24 0.20 10/34 10 x 0.16 0.146 3.71 Braid 0.030 0.76 0.020 0.50 36 118 1702** 1000 26 0.14 7/34 7 x 0.16 0.101 2.57 Spiral 0.020 0.51 0.016 0.41 35 115 1705 1000 24 0.20 10/34 10 x 0.16 0.106 2.69 Spiral 0.020 0.51 0.016 0.41 41 135 *UL AWM 1150, 300 V. **1702 has 3 strands of tinned copper and 4 strands of tinned Copperweld. 2-Conductor Cable for Low-Impedance Microphones Part No. Voltage Rating Wire Size Nominal Diameter Stranding Shield AWG mm2 AWG mm Inch mm 24 0.20 10/34 10 x 0.16 0.185 4.70 Spiral Jacket Thickness Insulation Thickness Capacitance* Inch mm Inch mm pF/ft pF/m 0.030 0.76 0.016 0.41 32 105 1709 1000 1710 1000 22 0.38 19/34 19 x 0.16 0.239 6.07 Braid 0.025 0.64 0.025 0.63 30 98 1712 600 20 0.52 26/34 26 x 0.16 0.221 5.61 Braid 0.030 0.76 0.015 0.38 44 144 *Capacitance between one conductor and remaining conductors connected to shield. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 327 Cable > Communication, Control and Industrial > Multiconductor > Braid Shield > 600 V Communication and Control 600 V Braid Shield, Multiconductor, PE, PVC Audio Cable Materials • Bare copper conductors • Polyethylene insulation • Tinned copper braid shield, 95% coverage • PVC jacket Availability Operating Temperature 100 ft (30.5 m) 1000 ft (305 m) • -20°C to +60°C Conductor Color Coding • 1 771: White, blue Black, red, or orange jacket • 1772: White, blue, white, blue Black, brown, slate, or yellow jacket Part No. Conductors 1771 1772 328 Wire Size Stranding Nominal Diameter AWG mm2 AWG mm Inch mm 2 23 0.29 60/40 60 x 0.08 0.243 6.17 4 25 0.20 40/40 40 x 0.08 0.239 6.07 Shield Jacket Thickness Insulation Thickness Capacitance Inch mm Inch mm pF/ft pF/m Braid 0.040 1.01 0.020 0.51 17.9 58.7 Braid 0.044 1.11 0.014 0.35 18 69.1 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Braid Shield > 600 V Communication and Control 600 V Multiconductor, PE, PVC Braid Shield 20 AWG (0.52 mm2) Stranding: 26/34 (26 x 0.16 mm) Insulation thickness: 0.015 (0.38 mm) Operating Temperature • -20°C to +60°C Conductor Color Coding • Chart H (page 533) Materials Part No. Conductors 1712 1713 1715 1716 1717 1719 1721 1723 1726 1728 2 3 4 5 6 8 10 12 15 20 Nominal Diameter Inch mm 0.221 5.61 0.248 6.30 0.266 6.76 0.285 7.24 0.306 7.77 0.327 8.31 0.373 9.47 0.384 9.75 0.421 10.69 0.462 11.73 Jacket Thickness Inch mm 0.030 0.76 0.035 0.88 0.035 0.88 0.035 0.88 0.035 0.88 0.035 0.88 0.035 0.88 0.035 0.88 0.035 0.88 0.035 0.88 • Stranded  tinned copper conductors • Polyethylene insulation • Clear polyester wrap • Braided tinned copper shield, 85% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 329 Cable > Communication, Control and Industrial > Multiconductor > Braid Shield > 600 V Communication and Control 600 V Multiconductor, Rubber, Polychloroprene Braid Shield 18 AWG (0.82 mm2) Stranding: 41/34 (41 x 0.16 mm) Insulation thickness: 0.020 (0.51 mm) Part No. Conductors 1450 1454 2 6 Nominal Diameter Inch mm 0.298 7.57 0.392 9.96 Jacket Thickness Inch mm 0.045 1.14 0.045 1.14 Operating Temperature • -20°C to +60°C 16AWG (1.31 mm2) Stranding: 65/34 (65 x 0.16 mm) Insulation thickness: 0.026 (0.65 mm) Conductor Color Coding • Chart H (page 533) Materials • Stranded  tinned copper conductors • EPDM rubber insulation • Clear polyester wrap • Tinned copper braid shield, 85% coverage • Black polychloroprene jacket Part No. Conductors 1450/16 1451/16 2 3 Nominal Diameter Inch mm 0.327 8.31 0.350 8.89 Jacket Thickness Inch mm 0.036 0.91 0.037 0.94 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 330 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Braid Shield > 600 V Communication and Control 600 V Multiconductor, PTFE, FEP Braid Shield 24 AWG (0.24 mm2) Stranding: 19/36 (19 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) MIL-DTL-16878/4 (Type E) NEMA HP3-EXBEE Part No. Conductors 2831 2831/2 2831/3 1 2 3 Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.009 (0.23 mm) • -55°C to +200°C • Chart G (page 532) Materials • S  tranded silver-plated copper conductors • PTFE insulation • Clear polyester wrap • Silver-plated copper braid shield, 90% coverage • White FEP jacket Availability Jacket Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 22 AWG (0.38 mm2) Operating Temperature Conductor Color Coding Nominal Diameter Inch mm 0.087 2.21 0.132 3.35 0.139 3.53 Part No. Conductors 2834 2834/2 2834/3 1 2 3 Nominal Diameter Inch mm 0.092 2.34 0.142 3.61 0.154 3.91 Jacket Thickness Inch mm 0.010 0.25 0.010 0.25 0.012 0.30 20 AWG (0.62 mm2) Stranding: 19/32 (19 x 0.20 mm) Insulation thickness: 0.009 (0.23 mm) Part No. Conductors 2837/2 2837/3 2 3 Nominal Diameter Inch mm 0.162 4.11 0.171 4.34 Jacket Thickness Inch mm 0.012 0.30 0.012 0.30 100 ft (30.5 m) 1000 ft (305 m)* *May contain multiple lengths Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 331 Cable > Communication, Control and Industrial > Multiconductor > Braid Shield > 600 V Communication and Control 600 V Multiconductor, TFE, Fiberglass Braid Shield 24 AWG (0.24 mm2) Stranding: 19/36 (19 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) MIL-DTL-16878/4 (Type E) NEMA HP3-EXBEE Part No. Conductors 2811 2811/2 2811/3 2811/4 2811/5 2811/7 1 2 3 4 5 7 Nominal Diameter Inch mm 0.100 2.54 0.145 3.68 0.152 3.86 0.164 4.17 0.177 4.50 0.191 4.85 Jacket Thickness Inch mm 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 Operating Temperature • -55°C to +200°C 22 AWG (0.38 mm2) Conductor Color Coding Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.009 (0.23 mm) • Chart G (page 532) Materials • S  tranded silver-plated copper conductors • TFE insulation • Silver-plated copper braid shield, 90% coverage • White PTFE-impregnated fiberglass jacket Availability 100 ft (30.5 m) 1000 ft (305 m)* *May contain multiple lengths 332 Part No. Conductors 2814/2 2814/4 2814/6 2 4 6 Nominal Diameter Inch mm 0.155 3.94 0.176 4.47 0.206 5.23 Jacket Thickness Inch mm 0.012 0.30 0.012 0.30 0.012 0.30 20 AWG (0.62 mm2) Stranding: 19/32 (19 x 0.20 mm) Insulation thickness: 0.009 (0.23 mm) Part No. Conductors 2817/2 2817/3 2817/4 2817/5 2817/6 2 3 4 5 6 Nominal Diameter Inch mm 0.171 4.34 0.180 4.57 0.195 4.95 0.212 5.38 0.230 5.84 Jacket Thickness Inch mm 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Braid Shield > 600 V Communication and Control 600 V Multiconductor, TFE, Fiberglass Braid Shield 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) MIL-DTL-16878/4 (Type E) NEMA HP3 Part No. Conductors 2819 2819/2 2819/3 2819/4 2819/5 1 2 3 4 5 Nominal Diameter Inch mm 0.125 3.18 0.195 4.95 0.206 5.23 0.224 5.69 0.245 6.22 Jacket Thickness Inch mm 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 Operating Temperature 16 AWG (1.32 mm2) • -55°C to +200°C Stranding: 19/29 (19 x 0.29 mm) Insulation thickness: 0.012 (0.30 mm) Conductor Color Coding • Chart G (page 532) Part No. Conductors Materials 2820 2820/2 2820/3 2820/4 1 2 3 4 • S  tranded silver-plated copper conductors • TFE insulation • Silver-plated copper braid shield, 90% coverage • White PTFE-impregnated fiberglass jacket Nominal Diameter Inch mm 0.135 3.43 0.215 5.46 0.228 5.79 0.249 6.32 Jacket Thickness Inch mm 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 14 AWG (1.23 mm2) Stranding: 19/27 (19 x 0.36 mm) Insulation thickness: 0.012 (0.30 mm) Availability Part No. Conductors 100 ft (30.5 m) 1000 ft (305 m)* 2804/2 2804/3 1 2 Nominal Diameter Inch mm 0.245 6.22 0.260 6.60 Jacket Thickness Inch mm 0.012 0.30 0.012 0.30 *May contain multiple lengths 12 AWG (3.08 mm2) Stranding: 19/25 (19 x 0.46 mm) Insulation thickness: 0.012 (0.30 mm) Part No. Conductors 2803/2 2 Nominal Diameter Inch mm 0.283 7.19 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.012 0.30 333 Cable > Communication, Control and Industrial > Multiconductor > Braid Shield > 600 V Communication and Control 600 V Multiconductor, PTFE, PTFE Tape Braid Shield 24 AWG (0.24 mm2) Stranding: 19/36 (19 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) MIL-DTL-16878/4 (Type E) NEMA HP3-EXBEE Part No. Conductors 2821 2821/2 2821/3 2821/4 2821/5 2821/6 1 2 3 4 5 6 Nominal Diameter Inch mm 0.087 2.21 0.136 3.45 0.143 3.63 0.155 3.94 0.168 4.27 0.182 4.62 Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 Operating Temperature • -55°C to +200°C 22 AWG (0.38 mm2) Conductor Color Coding Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.009 (0.23 mm) • Chart G (page 532) Materials • S  tranded silver-plated copper conductors • PTFE insulation • Silver-plated copper braid shield, 90% coverage • White PTFE tape jacket Part No. Conductors 2824 2824/2 2824/3 2824/4 2824/5 2824/6 1 2 3 4 5 6 Availability Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 20 AWG (0.62 mm2) 100 ft (30.5 m) 1000 ft (305 m)* Stranding: 19/32 (19 x 0.20 mm) Insulation thickness: 0.009 (0.23 mm) *May contain multiple lengths 334 Nominal Diameter Inch mm 0.092 2.34 0.146 3.71 0.154 3.91 0.167 4.24 0.182 4.62 0.193 4.90 Part No. Conductors 2827 2827/2 2827/3 2827/4 2827/5 2827/6 1 2 3 4 5 6 Nominal Diameter Inch mm 0.100 2.54 0.158 4.01 0.171 4.34 0.186 4.72 0.203 5.16 0.221 5.61 Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Braid Shield > 600 V Communication and Control 600 V Multiconductor, PTFE, PTFE Tape Braid Shield 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) MIL-DTL-16878/4 (Type E) NEMA HP3-EXBEE Part No. Conductors 2829/2 2829/3 2829/4 2 3 4 Stranding: 19/29 (19 x 0.29 mm) Insulation thickness: 0.012 (0.30 mm) • -55°C to +200°C • Chart G (page 532) Materials • S  tranded silver-plated copper conductors • PTFE insulation • Silver-plated copper braid shield, 90% coverage • White PTFE tape jacket Jacket Thickness Inch mm 0.012 0.30 0.012 0.30 0.012 0.30 16 AWG (1.23 mm2) Operating Temperature Conductor Color Coding Nominal Diameter Inch mm 0.186 4.72 0.197 5.00 0.215 5.46 Part No. Conductors 2826 2826/2 2826/3 2826/4 1 2 3 4 Nominal Diameter Inch mm 0.122 3.10 0.206 5.23 0.219 5.56 0.240 6.10 Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 Availability 100 ft (30.5 m) 1000 ft (305 m)* *May contain multiple lengths Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 335 Cable > Communication, Control and Industrial > Multiconductor > Foil/Braid Shield > 300 V Communication and Control 300 V Multiconductor, SR-PVC, PVC Foil/Braid Shield 28 AWG (0.08 mm2) Stranding: 7/36 (7 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2464 VW-1 UL CL2 CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CL2) • -20°C to +60°C (CMG) Conductor Color Coding Part No. Conductors 3463* 3464C 3465C 3466C 3467C 3468C 3469C 3470C 3470/15C 3470/25C 3470/37C 3470/50C 3 4 5 6 7 8 9 10 15 25 37 50 Nominal Diameter Inch mm 0.171 4.34 0.181 4.60 0.191 4.85 0.202 5.13 0.202 5.13 0.212 5.38 0.223 5.66 0.236 5.99 0.267 6.78 0.312 7.92 0.347 8.81 0.397 10.08 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 *UL AWM 2464/CSA CMG only. • Chart D (page 531) Materials • S  tranded tinned copper conductors • Semirigid PVC insulation • Foil + braid shield Aluminum/polyester/aluminum foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to the conductor • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 336 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Foil/Braid Shield > 300 V Low Capacitance Data Cable 300 V Multiconductor, FPP, PVC Foil/Braid Shield 28 AWG (0.08 mm2) Stranding: 7/36 (7 x 0.13 mm) Insulation thickness: 0.013 (0.33 mm) UL AWM 2919 (30 V) VW-1 UL CL2 CSA CMG FT4 Operating Temperature Part No.* Conductors 3483 3484C 3488C 3489C 3490/25C 3 4 8 9 25 Nominal Diameter Inch mm 0.184 4.67 0.195 4.95 0.232 5.89 0.245 6.22 0.348 8.84 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 Mutual capacitance: 12 pF/ft (39.4 pF/m) Ground capacitance: 20 pF/ft (65.6 pF/m) *C suffix part no. are CL2 approved. • -20°C to +80°C (AWM) • -20°C to +75°C (CL2) • -20°C to +60°C (CMG) Conductor Color Coding • C  hart D (page 531) for 3-conductor to 9-conductor cables • Chart F (page 532) for 25-conductor cables Materials • S  tranded tinned copper conductors • Foam polypropylene insulation • Foil + braid shield Aluminum/polyester/aluminum foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid shield, 65% coverage • Slate PVC jacket Availability 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 337 Cable > Communication, Control and Industrial > Multiconductor > Overall Foil/Braid Shield > 300 V Communication and Control 300 V Multiconductor, SR-PVC, PVC Overall Foil/Braid Shield 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2464 VW-1 UL CM CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Part No. Conductors 6327 6328 6329 6330 6331 6332 6333 6334 6335 6336 6337 6338 3 4 5 6 7 8 9 10 15 25 37 50 • C  hart F (page 532) for 15-conductor through 50-condcutor cables • See table below for 3-conductor through 10-conductor cables • S  tranded tinned copper conductors • Semirigid PVC insulation • Foil + braid shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire, 24 AWG (0.22 mm2), 7/32 (7 x 0.22 mm) Tinned copper braid, 65% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 338 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 Mutual capacitance: 32 pF/ft (105 pF/m) Ground capacitance: 58 pF/ft (190 pF/m) Conductor Color Coding Materials Nominal Diameter Inch mm 0.185 4.70 0.196 4.98 0.209 5.31 0.223 5.66 0.223 5.66 0.236 5.99 0.250 6.35 0.266 6.76 0.292 7.42 0.354 8.99 0.398 10.11 0.449 11.40 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors 6339 6340 6341 6342 6343 6344 6345 6346 6347 6348 6349 6350 3 4 5 6 7 8 9 10 15 25 37 50 Nominal Diameter Inch mm 0.198 5.03 0.211 5.36 0.226 5.74 0.241 6.12 0.241 6.12 0.256 6.50 0.272 6.91 0.290 7.37 0.320 8.13 0.390 9.91 0.440 11.18 0.540 13.72 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.053 1.35 Mutual capacitance: 36 pF/ft (118 pF/m) Ground capacitance: 65 pF/ft (213 pF/m) Color Coding: 3 through 10 Conductors 1 Black 2 White 3 Red 4 Green 5 Brown 6 Blue 7 Orange 8 Yellow 9 Violet 10 Slate Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Foil/Braid Shield > 300 V Communication and Control 300 V Foil/Braid Shield, Multiconductor, FPE, PVC Low Capacitance Data Cable 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.016 (0.41 mm) UL AWM 2919 (30 V) VW-1 UL CM CSA CMH FT1 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMH) Part No. Conductors 6351 6352 6353 6354 6355 6356 6357 6358 6359 6360 6361 3 4 5 6 7 8 9 10 15 25 37 Materials Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.048 1.22 Mutual capacitance: 12 pF/ft (39.4 pF/m) Ground capacitance: 22 pF/ft (72.2 pF/m) Conductor Color Coding • C  hart F (page 532) for 15 through 37 conductors. Other parts, see table at right. Nominal Diameter Inch mm 0.217 5.51 0.231 5.87 0.248 6.30 0.265 6.73 0.265 6.73 0.282 7.16 0.300 7.62 0.320 8.13 0.353 8.97 0.432 10.97 0.514 13.06 Color Coding 1 Black 2 White 3 Red 4 Green 5 Brown 6 Blue 7 Orange 8 Yellow 9 Violet 10 Slate • S  tranded tinned copper conductors • Foam polyethylene insulation • Foil + braid shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 65% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 339 Cable > Communication, Control and Industrial > Multipair > Unshielded > 300 V Communication and Control 300 V Unshielded, Multipair, PVC, PVC 22 AWG (0.32 mm2) Stranding: Solid Insulation thickness: 0.010 (0.25 mm) UL AWM 2464, 2576 VW-1 UL CM CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Conductor Color Coding Part No. Pairs 1300C 1302C 1304C 1305C 1306C 1307C 1308/11C 1309C 1310C 1313C 1 2 3 4 5 6 11 13 16 27 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Materials • S  tranded tinned copper conductors • PVC insulation • Slate PVC jacket 1000 ft (305 m) Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.040 1.02 UL AWM 2576 • Chart A (page 528) Availability Nominal Diameter Inch mm 0.157 3.99 0.215 5.46 0.226 5.74 0.246 6.25 0.267 6.78 0.289 7.34 0.362 9.19 0.382 9.70 0.414 10.52 0.537 13.64 Part No. Pairs 1317C 1318C 1319C 1320C 1322C 1323C 1324C 1325C 1327C 1327/19C 2 3 4 5 6 9 11 12 15 19 Nominal Diameter Inch mm 0.231 5.87 0.244 6.20 0.265 6.73 0.289 7.34 0.320 8.13 0.371 9.42 0.401 10.19 0.414 10.52 0.460 11.68 0.493 12.52 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.040 1.02 0.040 1.02 UL AWM 2464 18AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) 340 Part No. Pairs 1131C 1132C 1133C 1134C 1135C 1136C 1138C 1139C 1149C 1 2 3 4 5 6 8 9 19 Nominal Diameter Inch mm 0.225 5.72 0.332 8.43 0.356 9.04 0.396 10.06 0.444 11.28 0.484 12.29 0.534 13.56 0.584 14.83 0.791 20.09 Jacket Thickness Inch mm 0.032 0.81 0.035 0.89 0.037 0.94 0.040 1.02 0.045 1.14 0.045 1.14 0.050 1.27 0.055 1.40 0.070 1.78 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Overall Foil Shield > 300 V Communication and Control 300 V Overall Foil Shield, Multipair, SR-PVC, PVC 24 AWG (0.23 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2464 UL CM CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Conductor Color Coding Part No. Pairs 5471C 5472C 5473C 5474C 5475C 5476C 5477C 5478C 5479C 5480C 5480/15C 5480/19C 5480/25C 5480/50C * 1 2 3 4 5 6 7 8 9 10 15 19 25 50 Nominal Diameter Inch mm 0.156 3.96 0.212 5.38 0.224 5.69 0.243 6.17 0.270 6.86 0.292 7.42 0.292 7.42 0.316 8.03 0.343 8.71 0.373 9.47 0.415 10.54 0.445 11.30 0.527 13.39 0.699 17.75 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.037 0.83 0.040 1.02 0.040 1.02 0.040 1.02 0.045 1.14 0.053 1.35 • Chart K (page 529) *Color code chart C. Materials Individually Shielded, 22 AWG (0.35 mm2), 7/30 (7 x .025) Tinned Copper Drain Wire UL VW-1 • S  tranded tinned copper conductors • Semirigid PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.33 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Pairs 6416 2 Nominal Diameter Inch mm 0.295 7.49 Jacket Thickness Inch mm 0.041 1.04 Mutual capacitance: 55 pF/ft (180 pF/m) Ground capacitance: 95 pF/ft (312 pF/m) Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 341 Cable > Communication, Control and Industrial > Multipair > Overall Foil Shield > 300 V Communication and Control 300 V Overall Foil Shield, Multipair, PVC, PVC 22 AWG (0.32 mm2) Stranding: Solid Insulation thickness: 0.013 (0.33 mm) UL AWM 2464 VW-1 UL CM CSA CMG FT4 Part No. Pairs 5902C 5905C 5906C 5909C 5909/15C 5909/19C 2 4 6 9 15 19 Nominal Diameter Inch mm 0.238 6.05 0.273 6.93 0.329 8.36 0.385 9.78 0.471 11.96 0.506 12.85 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.035 0.89 0.037 0.94 0.040 1.02 0.040 1.02 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Conductor Color Coding • Chart K (page 529) Materials • Solid tinned copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 342 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Overall Foil Shield > 150 and 300 V Communication and Control 150 and 300 V Overall Foil Shield, Multipair, PVC, PVC 150 V, AWM 2576 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2576 VW-1 (150 V) UL AWM 2464 VW-1 (300 V) UL CM CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Conductor Color Coding • Chart A (page 528) Part No. Pairs 2211C 2212C 2213C 2214C 2215C 2216C 2219C 2219/12C 2219/15C 2219/19C 2219/23C 2219/27C 1 2 3 4 5 6 9 12 15 19 23 27 Availability Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.035 0.89 0.035 0.89 0.035 0.89 0.040 1.02 0.040 1.02 0.040 1.02 300 V, AWM 2464 18 AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Materials • S  tranded tinned copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Nominal Diameter Inch mm 0.168 4.27 0.232 5.89 0.245 6.22 0.266 6.76 0.290 7.37 0.315 8.00 0.372 9.45 0.415 10.54 0.451 11.46 0.494 12.55 0.545 13.84 0.589 14.96 Part No. Pairs 2241C 2242C 2243C 2244C 2245C 2246C 2249C 2249/12C 2249/19C 1 2 3 4 5 6 9 12 19 Nominal Diameter Inch mm 0.226 5.74 0.333 8.46 0.357 9.07 0.397 10.08 0.445 11.30 0.485 12.32 0.585 14.86 0.652 16.56 0.792 20.12 Jacket Thickness Inch mm 0.032 0.81 0.035 0.89 0.037 0.94 0.040 1.02 0.045 1.14 0.045 1.14 0.055 1.40 0.055 1.40 0.070 1.78 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 343 Cable > Communication, Control and Industrial > Multipair > Overall Foil Shield > 300 V Communication and Control 300 V Overall Foil Shield, Multipair, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.013 (0.33 mm) UL PLTC/CM UL VW-1 UL Sunlight Resistant CSA CMG FT4 Operating Temperature • -20°C to +105°C (CM) • -20°C to +60°C (CMG) Part No. Pairs 6417 6418 6419 6420 6421 6422 6423 6424 6425 6426 2 3 4 6 9 11 15 19 27 51 Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) • Black and red pairs, numbered • S  tranded tinned copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire, 24 AWG (0.22 mm2), 7/32 (7 x 0.20) • Slate PVC jacket Jacket Thickness Inch mm 0.038 0.97 0.043 1.09 0.043 1.09 0.043 1.09 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 0.075 1.91 18 AWG (0.96 mm2) Conductor Color Coding Materials Nominal Diameter Inch mm 0.267 6.78 0.291 7.39 0.315 8.00 0.370 9.40 0.447 11.35 0.480 12.19 0.545 13.84 0.593 15.06 0.698 17.73 0.914 23.22 Part No. Pairs 6427 6428 6429 6430 6431 6432 6433 2 3 4 6 9 11 15 Nominal Diameter Inch mm 0.362 9.19 0.403 10.24 0.438 11.13 0.518 13.16 0.622 15.80 0.671 17.04 0.751 19.08 Jacket Thickness Inch mm 0.043 1.09 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 0.063 1.60 Availability 500 ft (152 m) 1000 ft (305 m) 344 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Overall Foil Shield > 300 V Communication and Control 300 V Overall Foil Shield, Multipair, HDPE, PVC Low Capacitance, Extended Distance Cable 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2919 (30 V) VW-1 UL CM CSA CMG FT4 Part No. Pairs 6083C 6084C 6087C 6089C 6089/18C 3 4 7 9 18 Operating Temperature Nominal Diameter Inch mm 0.235 5.97 0.254 6.45 0.297 7.54 0.342 8.69 0.440 11.18 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 Characteristic impedance: 100 ohms Mutual capacitance: 15 pF/ft (49.2 pF/m) Ground capacitance: 27 pF/ft (88.6 pF/m) • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Conductor Color Coding • Chart M (page 530) Materials • S  tranded tinned copper conductors • High-density polyethylene insulation • Aluminum/polyester/aluminum foil shield, 25% overlap min. Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 345 Cable > Communication, Control and Industrial > Multipair > Overall Foil Shield > 300 V Communication and Control 300 V Overall Foil Shield, Multipair, PE, PVC Low Capacitance Data Cable 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.016 (0.41 mm) UL AWM 2919 (30 V) VW-1 UL CM CSA CMH FT1 Part No. Pairs 6301 6304 6 12.5 Nominal Diameter Inch mm 0.351 8.92 0.455 11.56 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 Characteristic impedance: 120 ohms Mutual capacitance: 12.8 pF/ft (42 pF/m) Ground capacitance: 23 pF/ft (75.4 pF/m) Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMH) Conductor Color Coding • Chart M (page 530) Materials • S  tranded tinned copper conductors • Polyethylene insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 346 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Overall Foil Shield > 300 V Communication and Control 300 V Overall Foil Shield, Multipair, FPP, PVC Low Capacitance Data Cable 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.016 (0.41 mm) UL AWM 2919 (30 V) VW-1 UL CM CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Conductor Color Coding Part No. Pairs 6202C 6203C 6204C 6205C 6206C 6207C 6208C 6209C 6210C 6210/12C 6210/15C 6210/18C 6210/25C 2 3 4.5* 5 6 7 8 9 10 12.5* 15 18.5* 25 Characteristic impedance: 105 ohms Mutual capacitance: 12.5 pF/ft (41 pF/m) Ground capacitance: 22 pF/ft (72 pF/m) Materials Availability 500 ft (152 m) 1000 ft (305 m) Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.050 1.27 0.050 1.27 *Single conductor colors: 4.5 = black, 12.5 = red, 18.5 = white • Chart A (page 528) • S  tranded tinned copper conductors • Foam polypropylene insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Nominal Diameter Inch mm 0.258 6.55 0.272 6.91 0.304 7.72 0.323 8.20 0.351 8.92 0.351 8.92 0.379 9.63 0.408 10.36 0.441 11.20 0.455 11.56 0.496 12.60 0.554 14.07 0.655 16.64 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) Part No. Pairs 6212C 6213C 6216C 6217C 6218C 6220C 6220/12C 6220/15C 6220/18C 6220/25C 2 3 6 7 8 10 12.5* 15 18.5* 25 Nominal Diameter Inch mm 0.304 7.72 0.322 8.18 0.420 10.67 0.420 10.67 0.456 11.58 0.563 14.30 0.580 14.73 0.631 16.03 0.667 16.94 0.793 20.14 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 *Single conductor colors: 12.5 = red, 18.5 = white Characteristic impedance: 105 ohms Mutual capacitance: 12.5 pF/ft (41 pF/m) Ground capacitance: 22 pF/ft (72 pF/m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 347 Cable > Communication, Control and Industrial > Multipair > Overall Foil Shield > 600 V Communication and Control 600 V Overall Foil Shield, Multipair, PE, PVC 16 AWG (1.32 mm2) Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.032 (0.81 mm) Part No. Pairs 2471 1 Nominal Diameter Inch mm 0.314 7.98 Jacket Thickness Inch mm 0.035 0.89 Mutual capacitance: 20.5 pF/ft (67.3 pF/m) Ground capacitance: 37 pF/ft (121.4 pF/m) UL AWM 2106 VW-1 14 AWG (1.94 mm2) Operating Temperature Stranding: 19/27 (19 x 0.36 mm) Insulation thickness: 0.032 (0.81 mm) • -20°C to +60°C Conductor Color Coding • Black, clear Part No. Pairs 2472 1 Nominal Diameter Inch mm 0.344 8.74 Jacket Thickness Inch mm 0.035 0.89 Mutual capacitance: 22.7 pF/ft (74.5 pF/m) Ground capacitance: 41 pF/ft (134.5 pF/m) Materials • S  tranded tinned copper conductors • Polyethylene insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire one even AWG size smaller than conductor • Slate PVC jacket 12 AWG (3.08 mm2) Stranding: 19/25 (19 x 0.45 mm) Insulation thickness: 0.037 (0.94 mm) Part No. Pairs 2473 1 Nominal Diameter Inch mm 0.412 10.46 Jacket Thickness Inch mm 0.040 1.02 Mutual capacitance: 23.9 pF/ft (78.4 pF/m) Ground capacitance: 43 pF/ft (141.1 pF/m) Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 348 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor/Multipair > Ind. and Overall Shield > 400 V Communication and Control 400 V Multiconductor, Multipair, PE, PVC Foil Shielded Pairs and Overall Foil Shield 25 AWG (0.18 mm2) Stranding: 3/33 TC +4/33 TCW (3 x 0.18 +4 x 0.18 mm) Insulation thickness: 0.013 (0.33 mm) Part No. Conductors Pairs 2468 2 1 Nominal Diameter Inch mm 0.165 4.19 Jacket Thickness Inch mm 0.020 0.51 Operating Temperature • -20°C to +60°C Conductor Color Coding • C  onductors: 1 White, 2 Green Pair: Black-Red Materials • S  tranded tinned and steelcoated copper conductors • Polyethylene insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire, 25 AWG (0.18 mm2), 7/33 (7 x 0.18 mm) • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 349 Cable > Communication, Control and Industrial > Multipair > Overall Foil/Braid Shield > 300 V Communication and Control 300 V Overall Foil/Braid Shield, Multipair, SR-PVC, PVC 28 AWG (0.09 mm2) Stranding: 7/36 (7 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2464 VW-1 UL CL2 CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CL2) • -20°C to +60°C (CMG) Part No. Pairs 3472C 3474C 3475C 3476C 3477C 3480C 3480/12C 3480/18C 3480/25C 2 4 5 6 7 10 12.5 18 25 Nominal Diameter Inch mm 0.211 5.36 0.235 5.97 0.258 6.55 0.275 6.99 0.275 6.99 0.332 8.43 0.342 8.69 0.389 9.88 0.446 11.33 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 Availability Ft 100 100 100, 1000 100 100 100, 500, 1000 100, 500, 1000 100, 500, 1000 100, 500, 1000 Conductor Color Coding • Chart A (page 528) Materials • S  tranded tinned copper conductors • Semirigid PVC insulation • Foil + braid shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 65% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 350 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Overall Foil/Braid Shield > 300 V Communication and Control 300 V Overall Foil/Braid Shield, Multipair, SR-PVC, PVC 24 AWG (0.23 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2464 VW-1 UL CM CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Part No. Pairs 6362 6363 6364 6365 6366 6367 6368 6369 6370 6371 6372 2 3 4 5 6 7 10 12.5 15 18 25 Nominal Diameter Inch mm 0.234 5.94 0.246 6.25 0.265 6.73 0.286 7.26 0.308 7.82 0.308 7.82 0.379 9.63 0.389 9.62 0.421 10.69 0.451 11.46 0.523 13.28 Conductor Color Coding • S  tranded tinned copper conductors • Semirigid PVC insulation • Foil + braid shield Aluminum/polyester foil, 25% overlap min. Foil facing outward Stranded tinned copper drain wire, 24 AWG (0.23 mm2), 7/32 (7 x 0.20 mm) Tinned copper braid, 65% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Color Code M M M M M M M M M M M 22 AWG (0.35 mm2) • See tables Materials Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 Stranding: 7/30 (7 x 0.25mm) Insulation thickness: 0.010 (0.25 mm) Part No. Pairs 6373 6374 6375 6376 6377 6378 6379 6380 6381 6382 6383 6384 2 3 4 5 6 7 8 10 12.5 15 18 25 Nominal Diameter Inch mm 0.254 6.45 0.267 6.78 0.288 7.32 0.312 7.92 0.337 8.56 0.337 8.56 0.363 9.22 0.418 10.62 0.430 10.92 0.467 11.86 0.500 12.70 0.595 15.11 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 Color Code A A A Chart below A A Chart below A A A A A Color Code Chart (Part No. 6376 and 6379) Pair No. Color Pair No. Color 1 2 3 4 Black, Red Black, White Black, Green Black, Blue 5 6 7 8 Black, Yellow Black, Brown Black, Orange Red, White Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 351 Cable > Communication, Control and Industrial > Multipair > Overall Foil/Braid Shield > 300 V Communication and Control 300 V Overall Foil/Braid Shield, Multipair, PE, PVC Low Capacitance Data Cable 28 AWG (0.089 mm2) Stranding: 7/36 (7 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2960 VW-1 UL CL2 CSA CMH FT1 Operating Temperature • -20°C to +75°C (CL2) • -20°C to +60°C (AWM, CMH) Conductor Color Coding • Chart K (page 529) Part No. Pairs 6390 6391 6392 6393 6394 6395 6396 6397 6398 6399 6400 2 3 4 5 7 9 12 13 18 25 31 Nominal Diameter Inch mm 0.211 5.36 0.220 5.59 0.235 5.97 0.252 6.40 0.269 6.83 0.305 7.75 0.335 8.51 0.341 8.66 0.383 9.73 0.440 11.18 0.470 11.94 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 Characteristic impedance: 100 ohms Mutual capacitance: 15.5 pF/ft (50.9 pF/m) Ground capacitance: 27.5 pF/ft (90.2 pF/m) Materials • S  tranded tinned copper conductors • Polyethylene insulation • Foil + braid shielding Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 90% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 352 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Overall Foil/Braid Shield > 300 V Communication and Control 300 V Overall Foil/Braid Shield, Multipair, PE, PVC Low Capacitance Data Cable 24 AWG (0.23 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.016 (0.41 mm) 65% braid coverage UL AWM 2919 VW-1 UL CM CSA CM FT1 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) Conductor Color Coding Part No. Pairs 6401 6402 6403 6404 6405 6406 6407 6408 6409 6410 6411 2 3 4 5 6 7 9 10 12 18 25 Nominal Diameter Inch mm 0.280 7.11 0.294 7.47 0.318 8.08 0.345 8.76 0.373 9.47 0.373 9.47 0.430 10.92 0.463 11.76 0.478 12.14 0.580 14.73 0.671 17.04 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.047 1.19 0.047 1.19 Characteristic impedance: 100 ohms Mutual capacitance: 15.5 pF/ft (50.9 pF/m) Ground capacitance: 27.5 pF/ft (90.2 pF/m) • Chart M (page 530) Materials • S  tranded tinned copper conductors • Polyethylene insulation • Foil + braid shielding Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 65% or 90% coverage • Slate PVC jacket 24 AWG (0.23 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.016 (0.41 mm) 90% braid coverage Part No. Pairs 6412 6413 6414 6415 1 2 3 4 Nominal Diameter Inch mm 0.208 5.28 0.280 7.11 0.294 7.47 0.318 8.08 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 Characteristic impedance: 120 ohms Mutual capacitance: 12.8 pF/ft (42 pF/m) Ground capacitance: 23 pF/ft (75.5 pF/m) Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 353 Cable > Communication, Control and Industrial > Multipair > Overall Foil/Braid Shield > 300 V Communication and Control 300 V Overall Foil/Braid Shield, Multipair, FPP, PVC Low Capacitance Data Cable 28 AWG (0.089 mm2) Stranding: 7/36 (7 x 0.13 mm) Insulation thickness: 0.013 (0.33 mm) UL AWM 2919 (30 V) VW-1 UL CL2 CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CL2) • -20°C to +60°C (CMG) Part No. Pairs 3492C 3493C 3494C 3495C 3496C 3498C 3500/12C 3500/18C 3500/25C 2 3 4 5 6 8 12.5 18 25 Nominal Diameter Inch mm 0.230 5.84 0.241 6.12 0.265 6.73 0.284 7.21 0.305 7.75 0.326 8.28 0.381 9.67 0.439 11.15 0.531 13.49 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.048 1.22 Mutual capacitance: 12 pF/ft (39.3 pF/m) Ground capacitance: 20 pF/ft (65.5 pF/m) Conductor Color Coding • Chart M (page 530) Materials • S  tranded tinned copper conductors • Foam polypropylene insulation • Foil + braid shielding Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 65% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 354 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Overall Foil/Braid Shield > 300 V Communication and Control 300 V Overall Foil/Braid Shield, Multipair, FPP, PVC Low Capacitance Data Cable 24 AWG (0.23 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.016 (0.41 mm) UL AWM 2919 (30 V) VW-1 UL CM CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Part No. Pairs 6222C 6223C 6224C 6225C 6226C 6227C 6228C 6230C 6230/12C 6230/15C 6230/18C 6230/25C 2 3 4 5 6 7 8 10 12.5 15 18 25 Conductor Color Coding • Chart M (page 530) Nominal Diameter Inch mm 0.280 7.11 0.294 7.47 0.318 8.08 0.345 8.76 0.373 9.47 0.373 9.47 0.401 10.19 0.463 11.76 0.477 12.12 0.518 13.16 0.586 14.88 0.677 17.20 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.050 1.27 0.050 1.27 Characteristic impedance: 105 ohms Mutual capacitance: 12.5 pF/ft (41 pF/m) Ground capacitance: 22 pF/ft (72 pF/m) Materials • S  tranded tinned copper conductors • Foam polypropylene insulation • Foil + braid shielding Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 65% coverage • Slate PVC jacket Availability 500 ft (152 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 355 Cable > Communication, Control and Industrial > Multipair > Individually Foil Shielded Pairs > 300 V Communication and Control 300 V Individually Foil Shielded Pairs, Multipair, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) 22 AWG (0.35 mm2) drain wire UL AWM 2919 (30 V) VW-1 UL CL2 CSA CMG FT4 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Part No. Pairs 6052C 6053C 6054C 6056C 6059C 6059/11C 6059/15C 6059/19C 6059/27C 2 3 4 6 9 11 15 19 27 Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) 20 AWG (0.51 mm2) drain wire • Chart A (page 528) • S  tranded tinned copper conductors • PVC insulation • Individual aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire • PVC jacket Jacket Thickness Inch mm 0.043 1.09 0.043 1.09 0.043 1.09 0.053 1.35 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 18 AWG (0.81 mm2) Conductor Color Coding Materials Nominal Diameter Inch mm 0.316 8.03 0.334 8.48 0.364 9.25 0.451 11.46 0.522 13.26 0.581 14.76 0.644 16.36 0.698 17.73 0.828 21.03 Part No. Pairs 6062C 6063C 6064C 6066C 6069C 6069/15C 2 3 4 6 9 15 Nominal Diameter Inch mm 0.376 9.55 0.418 10.62 0.456 11.58 0.541 13.74 0.650 16.51 0.804 20.42 Jacket Thickness Inch mm 0.043 1.09 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 356 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Individually Foil Shielded Pairs > 300 V Communication and Control 300 V Individually Foil Shielded Pairs, Multipair, PP, PVC 22 AWG (0.32 mm2) Stranding: Solid Insulation thickness: 0.010 (0.25 mm) Part No. Pairs 6000C 6008C 3 15 • Chart A (page 528) Materials • S  olid or stranded tinned copper conductors • Polypropylene insulation • Individual aluminum/polyester foil shield, 25% overlap min. Foil facing inward Solid or stranded tinned copper drain wire, 22 AWG (0.35 mm2), 7/30 (7 x 0.25 mm) • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) UL CM CM 22 AWG (0.35 mm2) Operating Temperature Conductor Color Coding Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 Characteristic impedance: 62 ohms Mutual capacitance: 25 pF/ft (82 pF/m) Ground capacitance: 45 pF/ft (147 pF/m) UL 2493 VW-1 UL CM, CMG CSA CMG FT4 • -20°C to +75°C (CM) • -20°C to +60°C (AWM) • -20°C to +60°C (CMG) Nominal Diameter Inch mm 0.278 7.06 0.492 12.50 Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Pairs 6010C 6012C 6014C 6016C 6017C 6018C 6019C 6020C 6022C 3 6 9 11 12 15 17 19 27 Nominal Diameter Inch mm 0.298 7.57 0.378 9.60 0.436 11.07 0.483 12.27 0.483 12.27 0.565 14.35 0.593 15.06 0.593 15.06 0.698 17.73 Jacket Thickness Inch mm 0.048 1.22 0.048 1.22 0.048 1.22 0.048 1.22 0.048 1.22 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 UL CMG CMG CMG CMG CMG CM CM CM CM Characteristic impedance: 55 ohms Mutual capacitance: 28 pF/ft (91.9 pF/m) Ground capacitance: 50 pF/ft (164 pF/m) 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.33 mm) Insulation thickness: 0.013 (0.33 mm) Part No. Pairs 6032C 6033C 6036C 6039C 6042C 2 3 6 9 12 Nominal Diameter Inch mm 0.331 8.41 0.349 8.86 0.450 11.43 0.555 14.10 0.615 15.62 Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 UL CMG CMG CMG CMG CMG Characteristic impedance: 61 ohms Mutual capacitance: 25 pF/ft (82 pF/m) Ground capacitance: 45 pF/ft (147.6 pF/m) 18 AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Pairs 6023C 6024C 6025C 3 6 9 Nominal Diameter Inch mm 0.406 10.31 0.561 14.25 0.650 16.51 Jacket Thickness Inch mm 0.047 1.19 0.063 1.60 0.063 1.60 UL CM CM CM Characteristic impedance: 59 ohms Mutual capacitance: 26 pF/ft 85.3 pF/m) Ground capacitance: 47 pF/ft (154.2 pF/m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 357 Cable > Communication, Control and Industrial > Multipair > Individually Foil Shielded Pairs > 300 V Communication and Control 300 V Individually Foil Shielded Pairs, Multipair, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.013 (0.33 mm) 24 AWG (0.23 mm2) drain wire UL PLTC UL CM UL VW-1 CSA CMG FT4 Operating Temperature Part No. Pairs 6434 6435 6436 6437 6438 6439 6440 6441 2 3 4 6 9 11 19 51 • -20°C to +105°C (PLTC, CM) • -20°C to +60°C (CMG) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) 20 AWG (0.56 mm2) drain wire • Black and red pairs, numbered • S  tranded tinned copper conductors • PVC insulation • Individual aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire • Slate PVC jacket Jacket Thickness Inch mm 0.043 1.09 0.043 1.09 0.043 1.35 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.075 1.91 18 AWG (0.96 mm2) Conductor Color Coding Materials Nominal Diameter Inch mm 0.295 7.49 0. 311 7.89 0.338 8.58 0.420 10.66 0.484 12.29 0.537 13.63 0.646 16.40 1.020 25.90 Part No. Pairs 6442 6443 6444 6445 6446 6447 6448 2 3 4 6 9 11 15 Nominal Diameter Inch mm 0.406 10.31 0.429 10.90 0.468 11.89 0.557 14.15 0.669 16.99 0.746 18.95 0.829 21.06 Jacket Thickness Inch mm 0.053 1.35 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 0.063 1.60 Availability 500 ft (152 m) 1000 ft (305 m) 358 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Individually Foil Shielded Pairs > 350 V Communication and Control 350 V Individually Foil Shielded Pairs, Multipair, PP, PE Direct Burial 20 AWG (0.51 mm2) Stranding: 10/30 (10 x 0.25 mm) Insulation thickness: 0.008 (0.20 mm) Part No. 6314 6315 Operating Temperature • -20°C to +80°C Nominal Diameter Jacket Thickness Inch mm Inch mm 3 0.291 7.39 0.040 1.02 6 0.385 9.78 0.045 1.14 Characteristic impedance: 48 ohms Mutual capacitance: 31 pF/ft (101.7 pF/m) Ground capacitance: 56 pF/ft (183.7 pF/m) Pairs Conductor Color Coding • Chart A (page 528) Materials • S  tranded tinned copper conductors • Polypropylene insulation • Individual aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire, 22 AWG (0.35 mm2), 7/30 (7 x 0.25 mm) • Black polyethylene jacket Availability 1000 ft (305 m) 500 ft (152 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 359 Cable > Communication, Control and Industrial > Multipair > Individually Foil Shielded Pairs > 300 V Communication and Control 300 V Individually Foil Shielded Pairs, Multipair, PE, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2919 (30 V) VW-1 UL CM CSA CMG FT4 Operating Temperature Part No. Pairs 6385 6386 6387 6388 6389 3 6 9 12 25 Nominal Diameter Inch mm 0.247 6.27 0.317 8.05 0.368 9.35 0.411 10.44 0.599 15.21 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.047 1.19 Characteristic impedance: 60 ohms Mutual capacitance: 25 pF/ft (82 pF/m) Ground capacitance: 47 pF/ft (154.2 pF/m) • -20°C to +80°C (AWM) • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Conductor Color Coding • Chart A (page 528) Materials • S  tranded tinned copper conductors • Polyethylene insulation • Individual aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 360 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Individually Foil Shielded Pairs > 300 V Communication and Control 300 V Individually Foil Shielded Pairs, Multipair, PP, PVC Individually Shielded Pairs 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) 24 AWG (0.22 mm2) drain wire Foil facing outward UL CMG CSA CMG FT4 Operating Temperature • -20°C to +75°C (CM) • -20°C to +60°C (CMG) Part No. Pairs 2466C 2 Nominal Diameter Inch mm 0.170 4.32 Characteristic impedance: 60 ohms Mutual capacitance: 25 pF/ft (82 pF/m) Ground capacitance: 45 pF/ft (147.6 pF/m) Color code: 1 Red-Black, 2 Green-White. Individually Shielded Pairs, UL CM 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.008 (0.20 mm) 24 AWG (0.22 mm2) drain wire Foil facing outward Conductor Color Coding • See tables Materials • S  tranded tinned copper conductors • Polypropylene insulation • Individual aluminum/polyester foil shield, 25% overlap min. Stranded tinned copper drain wire (see tables for sizes) • Slate PVC jacket Part No. Pairs 2463C 4 Nominal Diameter Inch mm 0.230 5.84 Jacket Thickness Inch mm 0.020 0.51 Characteristic impedance: 53 ohms Mutual capacitance: 29 pF/ft (95.1 pF/m) Ground capacitance: 52 pF/ft (170.6 pF/m) Color code: 1 Red-Black, 2 Green-White, 3 White/Red-White/Black, 4 White/Green-White/Yellow. Individually Shielded Pairs 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.015 (0.38 mm) 22 AWG (0.35 mm2) drain wire Foil facing inward Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Jacket Thickness Inch mm 0.020 0.51 Part No. Pairs 2467C 4 Nominal Diameter Inch mm 0.340 8.64 Jacket Thickness Inch mm 0.030 0.76 Characteristic impedance: 66 ohms Mutual capacitance: 23 pF/ft (75.5 pF/m) Ground capacitance: 41 pF/ft (134.5 pF/m) Color code: 1 Red-Black, 2 Green-White, 3 White/Red-White/Black, 4 White/Green-White/Yellow. Individually Shielded Pairs +Overall Shield, AWM 2717 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.009 (0.23 mm) 22 AWG (0.35 mm2) drain wire Foil facing inward Part No. Pairs 1243/2C 2 Nominal Diameter Inch mm 0.245 6.22 Jacket Thickness Inch mm 0.030 0.76 Characteristic impedance: 57 ohms Mutual capacitance: 27 pF/ft (88.6 pF/m) Ground capacitance: 49 pF/ft (160.7 pF/m) Color code: 1 Red-Black, 2 Green-White. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 361 Cable > Communication, Control and Industrial > Multipair > Individual and Overall Shield > 300 V > Low Cap Communication and Control 300 V Individually Foil Shielded Pairs and Overall Foil/Braid, Multipair, FPE, PVC, Low Capacitance Data Cable 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.019 (0.49 mm) UL AWM 2493 VW-1 UL CM CSA CM FT1 Operating Temperature • -20°C to +75°C (CM) • -20°C to +60°C (AWM, CMG) Part No. Pairs 6316 6317 6318 6319* 6320 6321 6322* 6323 6324 6325 6326 2 3 4 5 6 7 8 10 15 18 25 Materials • S  tranded tinned copper conductors • Foam polyethylene insulation • Individual aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire, 24 AWG (0.23 mm2), 7/32 (7 x 0.20 mm) • Overall foil + braid shielding Aluminum/polyester foil, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 65% coverage • Slate PVC jacket Jacket Thickness Inch mm 0.048 1.22 0.048 1.22 0.048 1.22 0.048 1.22 0.048 1.22 0.048 1.22 0.048 1.22 0.063 1.60 0.063 1.60 0.063 1.60 0.085 2.16 Characteristic impedance: 100 ohms Mutual capacitance: 12.5 pF/ft (41 pF/m) Ground capacitance: 22 pF/ft (72.2 pF/m) Conductor Color Coding • Chart A (page 528) • (See table at right for Part No. 6319 and 6322) Nominal Diameter Inch mm 0.349 8.86 0.353 8.97 0.397 10.08 0.430 10.92 0.464 11.79 0.464 11.79 0.499 12.67 0.606 15.39 0.687 17.45 0.721 18.31 0.901 22.89 *Color Code Pair No. Color Pair No. Color 1 2 3 4 Black, Red Black, White Black, Green Black, Blue 5 6 7 8 Black, Yellow Black, Brown Black, Orange Red, White Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 362 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Foil Shield > 300 V Communication and Control 300 V Foil Shield, Multiconductor, PVC, PVC Plenum Rated 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.008 (0.020 mm) 24 AWG (0.22 mm2) drain wire UL CL2P UL CMP CSA CMP FT6 Operating Temperature • -5°C to +75°C Part No. Conductors 58401 57003 57004 57006 57008 57010 57015 58110/25 2 3 4 6 8 10 15 25 Conductor Color Coding Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.008 (0.020 mm) 24 AWG (0.22 mm2) drain wire Materials Availability Jacket Thickness Inch mm 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 22 AWG (0.35 mm2) • Chart D2 (page 531) • S  tranded bare copper conductors • Plenum-rated PVC insulation • Foil shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire (see tables for size) • Slate plenum-rated PVC jacket Nominal Diameter Inch mm 0.120 3.05 0.120 3.05 0.131 3.33 0.154 3.91 0.167 4.24 0.194 4.93 0.217 5.51 0.262 6.65 Part No. Conductors 58411 58113 58114 58116 58117 58118 58119 58120 58120/12 58120/15 58120/25 2 3 4 6 7 8 9 10 12 15 25 500 ft (152 m) 1000 ft (305 m) Nominal Diameter Inch mm 0.126 3.20 0.133 3.38 0.145 3.68 0.172 4.37 0.172 4.37 0.187 4.75 0.201 5.11 0.218 5.54 0.225 5.72 0.245 6.22 0.314 7.98 Jacket Thickness Inch mm 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.017 0.43 20 AWG (0.35 mm2) Stranding: 7/0.0121 (7 x 0.31 mm) Insulation thickness: 0.008 (0.020 mm) 22 AWG (0.35 mm2) drain wire Part No. Conductors 58421 58124 58126 2 4 6 Nominal Diameter Inch mm 0.138 3.51 0.160 4.06 0.191 4.85 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.015 0.39 0.015 0.39 0.015 0.39 363 Cable > Communication, Control and Industrial > Multiconductor > Foil Shield > 300 V Communication and Control 300 V Foil Shield, Multiconductor, PVC, PVC Plenum Rated 18 AWG (0.82 mm2) Stranding: 7/0.0152 (7 x 0.39 mm) Insulation thickness: 0.009 (0.023 mm) 22 AWG (0.35 mm2) drain wire UL CL2P UL CMP CSA CMP FT6 Part No. Conductors 58431 58133 58134 58136 2 3 4 6 Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.009 (0.023 mm) 18 AWG (0.82 mm2) drain wire • -5°C to +75°C • Chart D2 (page 531) Materials Jacket Thickness Inch mm 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 16 AWG (1.31 mm2) Operating Temperature Conductor Color Coding Nominal Diameter Inch mm 0.162 4.11 0.172 4.37 0.189 4.80 0.227 5.77 Part No. Conductors 58142 58144 2 4 Nominal Diameter Inch mm 0.186 4.72 0.218 5.54 Jacket Thickness Inch mm 0.015 0.39 0.015 0.39 • S  tranded bare copper conductors • Plenum-rated PVC insulation • Foil shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire (see tables for size) • Slate plenum-rated PVC jacket Availability 500 ft (152 m) 1000 ft (305 m) 364 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Foil Shield > 300 V Communication and Control 300/150 V Foil Shield, Multipair, PVC, PVC Plenum Rated 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.008 (0.020 mm) 24 AWG (0.22 mm2) drain wire UL CL2P UL CMP CSA CMP FT6 Part No. Pairs 57602 57603 57604 57605 57606 2 3 4 5 6 Operating Temperature Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.008 (0.020 mm) 24 AWG (0.22 mm2) drain wire Conductor Color Coding Materials • S  tranded bare copper conductors • Plenum-rated PVC insulation • Foil shield • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire (see tables for size) • Slate plenum-rated PVC jacket Part No. Pairs 58412 58413 58414 58415 58416 57628 58419 58420/19 2 3 4 5 6 8 9 19 Nominal Diameter Inch mm 0.185 4.70 0.197 5.00 0.217 5.51 0.239 6.07 0.261 6.63 0.285 7.24 0.311 7.90 0.418 10.62 Jacket Thickness Inch mm 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.016 0.41 0.018 0.46 20 AWG (0.35 mm2) Stranding: 7/0.0121 (7 x 0.31 mm) Insulation thickness: 0.008 (0.020 mm) 22 AWG (0.35 mm2) drain wire Availability 500 ft (152 m) 1000 ft (305 m) Jacket Thickness Inch mm 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 0.015 0.39 22 AWG (0.35 mm2) • -5°C to +75°C • Chart A1 (page 528) Nominal Diameter Inch mm 0.165 4.19 0.175 4.45 0.193 4.90 0.212 5.38 0.231 5.87 Part No. Pairs 57632 57634 57636 2 4 6 Nominal Diameter Inch mm 0.205 5.21 0.240 6.10 0.291 7.39 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.015 0.39 0.015 0.39 0.015 0.39 365 Cable > Communication, Control and Industrial > Multipair > Foil Shield > 150 V Communication and Control 150 V Foil Shield, Multipair, FEP, PVDF Plenum Rated, Low- and Mid-Capacitance Individually Shielded Pairs 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.007 (0.18 mm) UL CL2P UL CMP CSA CMP FT6 Part No. Pairs 58602 58603 58604 2 3 4 Nominal Diameter Inch mm 0.164 4.17 0.175 4.45 0.194 4.93 Jacket Thickness Inch mm 0.009 0.23 0.009 0.23 0.009 0.23 Mutual capacitance: 25 pF/ft (82 pF/m) Ground capacitance: 45 pF/ft (147.6 pF/m) Operating Temperature Overall Shield 24 AWG (0.22 mm2) • -25°C to +125°C Conductor Color Coding • Chart A1 (page 528) Materials • S  tranded tinned copper conductors • FEP insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire, 24 AWG (0.22 mm2), 7/32 (7 x 0.20 mm) • Slate PVDF jacket Availability 500 ft (152 m) 1000 ft (305 m)* *May contain multiple lengths Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.007 (0.18 mm) Part No. Pairs 58802 58803 58804 58806 58809 58812 2 3 4 6 9 12.5 Nominal Diameter Inch mm 0.154 3.91 0.163 4.14 0.180 4.57 0.217 5.51 0.256 6.50 0.294 7.47 Jacket Thickness Inch mm 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 Mutual capacitance: 20 pF/ft (65.6 pF/m) Ground capacitance: 36 pF/ft (118.1 pF/m) Overall Shield 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.012 (0.30 mm) Part No. Pairs 58902 58903 58904 58906 58909 58912 2 3 4 6 9 12.5 Nominal Diameter Inch mm 0.186 4.72 0.199 5.05 0.219 5.56 0.266 6.76 0.315 8.00 0.367 9.32 Jacket Thickness Inch mm 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 Mutual capacitance: 12.5 pF/ft (41 pF/m) Ground capacitance: 23 pF/ft (75.5 pF/m) 366 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multipair > Foil Shield > 150 V Communication and Control 150 V Foil Shield, Multipair, FEP, PVDF Plenum Rated, Low- and Mid-Capacitance Overall Foil Shield, Individually Shielded Pairs 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.007 (0.18 mm) UL CL2P UL CMP CSA CMP FT6 Operating Temperature Part No. Pairs 58612 58613 58616 2 3 6 Nominal Diameter Inch mm 0.189 4.80 0.202 5.13 0.272 6.91 Mutual capacitance: 29 pF/ft (95.1 pF/m) Ground capacitance: 51 pF/ft (167.3 pF/m) Individually Shielded Pairs, Overall Shield 18 AWG (0.82 mm2) • -55°C to +125°C Conductor Color Coding • Chart A1 (page 528) Materials • S  tranded tinned copper conductors • FEP insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire, 24 AWG (0.22 mm2), 7/32 (7 x 0.20 mm) • Slate PVDF jacket Jacket Thickness Inch mm 0.009 0.23 0.009 0.23 0.009 0.23 Stranding: 7/0.0152 (7 x 0.39 mm) Insulation thickness: 0.007 (0.18 mm) Part No. Pairs 58632 58633 2 3 Nominal Diameter Inch mm 0.247 6.27 0.264 6.71 Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 Mutual capacitance: 35 pF/ft (114.8 pF/m) Ground capacitance: 63 pF/ft (206.7 pF/m) Individually Shielded Pairs 16 AWG (0.35 mm2) Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.007 (0.18 mm) Part No. Pairs 58642 58643 2 3 Availability Nominal Diameter Inch mm 0.289 7.34 0.309 7.85 Jacket Thickness Inch mm 0.012 0.30 0.012 0.30 Mutual capacitance: 39 pF/ft (128 pF/m) Ground capacitance: 69 pF/ft (226.4 pF/m) 500 ft (152 m) 1000 ft (305 m)* *May contain multiple lengths Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 367 Cable > Communication, Control and Industrial > Multiconductor > Unshielded and Shielded > 200 V Communication and Control 200 V Unshielded and Shielded, Multiconductor PVC, PVC Hi-Fi and Stereo Cable 32 AWG (0.03 mm2) Stranding: 7/40 (7 x 0.08 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors 1101 1102 3 4 Nominal Diameter Inch mm 0.063 1.60 0.072 1.83 Operating Temperature • -20°C to +80°C 30 AWG (0.05 mm2) Stranding: 7/38 (7 x 0.10 mm) Insulation thickness: 0.010 (0.25 mm) Conductor Color Coding • 1 Black, 2 Red, 3 White, 4 Green Materials • S  tranded tinned copper conductors • PVC insulation • Conductors twisted in an extra tight lay Part No. Conductors 1115 1116 2 3 Nominal Diameter Inch mm 0.064 1.63 0.070 1.78 Availability 100 ft (30.5 m) 1000 ft (305 m) Miniature Shielded Cable 28 AWG (0.09 mm2) Stranding: 7/36 (7 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) Conductor Color Coding • 1 Black, 2 Red, 3 White, 4 Green Materials • S  tranded tinned copper conductors • Color-coded PVC insulation • Tinned copper braid shield, 80% coverage • Clear PVC jacket Part No. Conductors 1120 1121 1122 2 3 4 Nominal Diameter Inch mm 0.115 2.92 0.120 3.05 0.130 3.30 Jacket Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 368 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Multiconductor > Unshielded > 150 V Communication and Control 150 V Unshielded Multiconductor PP, PVC Silver Satin Oval Telephone Cable 26 AWG (0.14 mm2) Stranding: 7/34 (7 x 0.16 mm) Insulation thickness: 0.009 (0.23 mm) Temperature Rating • -20°C to +60°C Conductor Color Coding • See table Materials • S  tranded bare copper conductors • Polypropylene insulation • Silver PVC jacket Part No. Conductors 1604 1606 1608 4 6 8 Nominal Outer Dimension Inch mm 0.090 x 0.190 2.28 x 4.83 0.090 x 0.270 2.28 x 6.85 0.090 x 0.350 2.28 x 8.89 Jacket Thickness Inch mm 0.020 0.51 0.024 0.61 0.024 0.61 Conductor Color Coding Conductor No. 1 2 3 4 5 6 7 8 1604 Black Red Green Yellow 1606 White Black Red Green Yellow Blue 1608 Slate Orange Black Red Green Yellow Blue Brown Availability 328 ft (100 m), box 1000 ft (305 m), box Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 369 Cable > Communication, Control and Industrial > Multipair > Individual and Overall Shield > 300 V Communication and Control 300 V Individually Foil Shielded Pairs or Overall Foil Shielded, Multipair, FPP, PVC Individually Foil Shielded Pairs 24 AWG (0.23 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.023 (0.58) Part No. Pairs 6073C 6076C 6079C 6079/11C 6079/12C 6079/15C 6079/27C 3 6 9 11 12 15 27 Nominal Diameter Inch mm 0.374 9.50 0.483 12.27 0.597 15.16 0.643 16.33 0.663 16.84 0.719 18.26 0.962 24.43 Jacket Thickness Inch mm 0.048 1.22 0.048 1.22 0.065 1.65 0.065 1.65 0.065 1.65 0.065 1.65 0.087 2.21 AWM 2493 2493 2493 2493 2493 2493 2490 Characteristic impedance: 115 ohms Mutual capacitance: 12 pF/ft (41 pF/m) UL AWM 2490, 2493, 2668 VW-1 UL CM CSA CMG FT4 Operating Temperature • -20°C to +75°C (CM) • -20°C to +60 (AWM, CMG) Overall Foil Shield 22 AWG (0.32 mm2) Stranding: Solid Insulation thickness: 0.023 (0.58) Part No. Pairs 6072C* 2 Nominal Diameter Inch mm 0.42 9.50 Jacket Thickness Inch mm 0.035 0.89 AWM 2668 Characteristic impedance: 150 ohms Mutual capacitance: 8.8 pF/ft (28.9 pF/m) *Black jacket. Conductor Color Coding • Chart K (page 529) Materials • S  olid or stranded tinned copper conductors • Foam polypropylene insulation • Individual aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire, 24 AWG (0.23 mm2), 7/32 (7 x 0.20 mm) • Slate PVC jacket (unless otherwise noted) Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 370 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Flat Cable > Unshielded > 300 V Communication and Control 300 V Unshielded, Flat Cable, 0.050 (1.27 mm) Centerline 28 AWG (0.09 mm2) Stranding: 7/36 (7 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2651, 20932 VW-1 Operating Temperature • -20°C to +105°C Materials • S  tranded tinned copper conductors • Extruded PVC insulation (slate cable) • Thermally bonded PVC with clear PVC covering (color-coded cable) Part No. Slate Color Coded (AWM 2651) (AWM 20932) 3580/9 3583/9 3580/10 3583/10 3580/14 3583/14 3580/15 3583/15 3580/16 3583/16 3580/20 3583/20 3580/24 3583/24 3580/25 3583/25 3580/26 3583/26 3580/34 3583/34 3580/37 3583/37 3580/40 3583/40 3580/50 3583/50 3580/60 3583/60 3580/64 3583/64 Conductors 9 10 14 15 16 20 24 25 26 34 37 40 50 60 64 Width (W) Span (S) Inch mm Inch mm 0.45 0.50 0.70 0.75 0.80 1.00 1.20 1.25 1.30 1.70 1.85 2.00 2.50 3.00 3.20 11.43 12.70 17.78 19.05 20.32 25.40 30.48 31.75 33.02 43.18 46.99 50.80 63.50 76.20 81.28 0.40 0.45 0.65 0.70 0.75 0.95 1.15 1.20 1.25 1.65 1.80 1.95 2.45 2.95 3.15 10.16 11.43 16.51 17.78 19.05 24.13 29.21 30.48 31.75 41.91 45.72 49.53 62.23 74.93 80.01 Color • A  WM 2651: slate cable, with red polarity stripe on leading edge • AWM 20932: color-coded cable: brown, red, orange, yellow, green, blue, violet, slate, white, black . . . repeats Electrical Characteristics • C  apacitance: 14 pF/ft (45.9 pF/m) nom. at 1 MHz • Propagation delay: 1.4 ns/ft (4.6 ns/m) @ 0.18 ns risetime • Impedance: 105 ohms (G-S-G configuration) • Near-end crosstalk: 3.2% • Far-end crosstalk: 11.5% • Crosstalk measured on adjacent lines, 1 ns risetime, 10 ft (3.05 m) length Availability 100 ft (30.5 m) May contain multiple lengths Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 371 Cable > Communication, Control and Industrial > Round to Flat > Foil + braid Shield > 300 V Communication and Control 300 V Foil + Braid Shield, Round to Flat Flat Cable, 0.050 (1.27 mm) Centerline 28 AWG (0.09 mm2) Stranding: 7/36 (7 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 20381 (300 V) UL CL2 (150 V) Part No. Conductors 3585/25 3585/26 3585/40 3585/50 25 26 40 50 Nominal Diameter Inch mm 0.34 8.64 0.35 8.89 0.40 10.20 0.46 11.70 Nominal Width Inch mm 1.20 30.48 1.65 41.91 1.95 49.53 2.45 62.23 Operating Temperature • -20°C to +105°C Materials • S  tranded tinned copper conductors • PVC insulation • Foil + braid shield Aluminum/polyester Tinned copper braid (90% coverage) • Black PVC jacket, 0.030 (0.08 mm) thick Configuration • F  lat cable termination area is 0.75 (19 mm) long and occurs every 1.5 (38 mm) Electrical Characteristics • C  apacitance: 24 pF/ft (78.7 pF/m) nom at 1 MHz • Impedance: 70 ohms Availability 100 ft (30.5 m) May contain multiple lengths 372 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Communication, Control and Industrial > Flat Cable > Foil Shield > 150 V Communication and Control 150 V, Jacketed, Foil Shield, Flat Cable, 0.050 (1.27 mm) Centerline 28 AWG (0.09 mm2) Part No. 3590/10 3590/14 3590/16 3590/26 Stranding: 7/36 (7 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) Nom. Core Width (A) Nom. Jacket Width (C) Conductors Inch mm Inch mm 10 0.50 12.70 0.57 14.48 14 0.70 17.78 0.77 19.56 16 0.80 20.32 0.87 22.10 26 1.30 33.02 1.37 34.80 UL AWM 2912 UL Type CL2 Operating Temperature • -20°C to +105°C Materials • S  tranded tinned copper conductors • Extruded slate PVC insulation with red polarity stripe • Aluminum/polyester/aluminum foil shield Two 28 AWG (0.09 mm2) stranded tinned copper drain wires • Slate PVC jacket, 0.030 (0.08 mm) thick Electrical Characteristics • C  apacitance: 20 pF/ft (65.6 pF/m) nom. at 1 MHz • Propagation delay: 1.45 ns/ft (4.8 ns/m) at 0.18 ns risetime • Impedance: 70 ohms • Near-end crosstalk: 5.5% • Far-end crosstalk: 1.6% • Crosstalk measured on adjacent lines, 3.5 ns risetime Availability 100 ft (30.5 m) May contain multiple lengths Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 373 Cable > Communication, Control and Industrial > Flat Cable > Unshielded > 150 V Communication and Control 150 V Unshielded, Flat Cable, 0.025 (0.64 mm) Centerline 30 AWG (0.05 mm2) Stranding: Solid Insulation thickness: 0.013 (0.33 mm) Part No. Conductors 3582/26 3582/40 3582/50 3582/60 26 40 50 60 Width (W) Inch 0.65 1.00 1.25 1.50 mm 16.51 25.40 31.75 38.10 Span (S) Inch 0.625 0.975 1.225 1.475 mm 15.88 24.76 31.15 37.46 UL AWM 2678 VW-1 Operating Temperature • -20°C to +105°C Color • S  late, with red polarity stripe on leading edge Materials • Solid bare copper conductors • PVC insulation Electrical Characteristics • C  apacitance: 24.9 pF/ft (82 pF/m) nom. (G-S-G) at 1 kHz 14.3 pF/ft (47 pF/m) nom. (G-S) at 1 kHz • Propagation delay: 1.52 ns/ft (4.9 ns/m) • Impedance: 78 ohms (G-S-G single-ended configuration) 131 ohms nom. (G-S differential configuration) • Skew: 0.036 ns/ft (0.12 ns/m) max Availability 100 ft (30.5 m) May contain multiple lengths 374 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Make AlphaWire.com your destination for all your cabling needs! Easy to use, full of information, and designed to make the selection of wire, cable, tubing, and wire management fast and easy—the Alpha Wire website is the only source you need. • • • • • • • • • Search products by parameters View complete product listing Download specs Read white papers written by our industry experts Request a sample (or two!) Learn about our market-specific solution sets Download literature Look around our “Engineer’s Room” Build your own cable with our powerful Cable Design Center™ Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 375 { Confession } We’ve taken a shine to working down on the farm (Our Solar Solution Set is a 24-hour per day workhorse) Proven Performance, Superior Support Alpha Wire’s solar cables and photovoltaic wire are proven throughout the industry. Better still, we offer the fastest delivery so you can order what you need from our large in-stock inventory today and receive it tomorrow. To find the ideal solar cable and wire for your application, and to download our new Solar Power brochure, visit www.alphawire.com. F or reliable, high-performance solar farms, Alpha Wire’s Solar Solution Set helps engineers and installers create reliable, durable solar systems. Our solar cables and photovoltaic wire are designed for the harsh environments of solar energy applications—the hot and cold of climate extremes, ozone and UV radiation, moisture, oil, and direct burial. Our specially formulated PVC jackets provide years of reliable service by withstanding the potential environments without failing or degrading. Regardless of your panel-to-grid needs, we have the product to satisfy it. With wire and cable in a range of gauges and conductor counts, Alpha has the solar solution. Alpha also has the accessories, from flexible conduit to heat-shrink tubing, to help you manage the system for faster installation, easier maintenance, and reliable operation. A Full Range for Power and Control Solar Power Solution Set • Photovoltaic wire • Multiconductor solar cable • Series M and Series P control cables • Solid bus bar wires • FIT® heat-shrink tubing • Slit-loom and PVC flex tubing Typical Applications • Panel monitoring and control • Panel to junction box • Panel to collector • Collector to inverter • Grounding • Motor supply Toll Free: 1-800-52 ALPHA | www.alphawire.com 376 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com.
3590/26 SL005 价格&库存
很抱歉,暂时无法提供与“3590/26 SL005”相匹配的价格&库存,您可以联系我们找货
3590/26 SL005
  • 1+16663.393011+2159.89299
