WIRE MANAGEMENT PRODUCTS
SPIRAL WRAP TUBING
SW
RoHS COMPLIANT
SPIRAL WRAP TUBING APPLICATIONS:
Wire Harness Breakouts
Cable Bundling
CHARACTERISTICS
OPERATING TEMPERATURE:
■ Polyethylene: –20°C to 80°C
■ Nylon: –40°C to 120°C
■ Teflon*: –70°C to 250°C
■ PVC: –20°C to 80°C
COLOR DESCRIPTION:
■ SW-1 to 6, SW-20 to 25 and SW-30 to 35: Natural
■ SW-10 to 14: White
■ SW-40 to 45 and SW-50 to 53: Black
SPIRAL CUT FOR HARNESS BREAKOUTS:
Wire harnessing, cabling and bundling work is simplified with the use of
Alpha’s SW series spiral wrap tubing. SW tubing wraps tightly to the wire
and cable being bundled, yet is flexible and simple to apply. All types
maintain flexibility even when bent around sharp edges. Breakouts or
tapoff connections may be made through the openings of the wrap. SW
spiral wrap is constructed from several semi-rigid tubing materials and
then cut on a continual spiral.
Standard
Put-Up
Ft.
Max.
Oper.
Temp.
Min.
Oper.
Temp.
Nom.
O.D.
Inches
Nominal Max. Diam.
Wall
Inner Wire
Thickness
Bundle
FlammaInches
Inches
bility
Alpha
Part No.
Size
In.
SW-1
SW-2
SW-3
SW-4
SW-5
SW-6
1/8
1/4
3/8
1/2
3/4
1
CLEAR POLYETHYLENE
Ideal for general indoor
applications. This costeffective material is extremely
abrasion resistant and is
unaffected by most solvents.
25, 100, 500
25, 100, 500
25, 100
25, 100
25, 100, 500
25, 100, 500
80°C
(176°F)
–20°C
(–4°F)
0.125
0.250
0.375
0.500
0.750
1.000
0.031
0.046
0.052
0.062
0.065
0.095
1/2
2
3
4
5
6
Not
Flame
Retardant.
SW-10
SW-11
SW-12
SW-13
SW-14
1/8
1/4
3/8
1/2
3/4
FIRE RESISTANT
POLYETHYLENE
A cost-effective alternative to
Nylon or Teflon*. This special
material is self-extinguishing.
25, 100, 500
25, 100, 500
25, 100
25, 100
25, 100
80°C
(176°F)
–20°C
(–4°F)
0.125
0.250
0.375
0.500
0.750
0.031
0.046
0.052
0.062
0.065
1/2
2
3
4
5
94V-0
SW-20
SW-21
SW-22
SW-23
SW-24
SW-25
1/8
1/4
3/8
1/2
3/4
1
NYLON
Highly specialized product
that is tough, durable, selfextinguishing, abrasion resistant, lightweight. Operates
over a wide temp. range.
25, 100, 500
25, 100, 500
25, 100
25, 100
25, 100
25, 100
120°C
(176°F)
–40°C
(–40°F)
0.125
0.250
0.375
0.500
0.750
1.000
0.016
0.025
0.035
0.035
0.032
0.032
1/2
2
3
4
5
6
94V-2
SW-30
SW-31
SW-32
SW-33
SW-34
SW-35
1/8
1/4
3/8
1/2
3/4
1
TEFLON*
Self extinguishing, fluorocarbon,
resin material. Possesses
greatest min. & max. temp.
range of any spiral wrap
material. Suitable for use in a
number of industrial applications.
250°C
(482°F)
–70°C
(–94°F)
0.125
0.250
0.375
0.500
0.750
1.000
0.030
0.030
0.030
0.030
0.032
0.040
1/2
2
2-1/2
3
3-1/2
4
Self
Extinguishing.
SW-40
SW-41
SW-42
SW-43
SW-44
SW-45
1/8
1/4
3/8
1/2
3/4
1
ULTRAVIOLET-RESISTANT
BLACK POLYETHYLENE
Recommended for outdoor use.
Same properties as clear
polyethylene but contains extra
additive for moisture resistance
ultraviolet light and rain.
80°C
(176°F)
–20°C
(–4°F)
0.125
0.250
0.375
0.500
0.750
1.000
0.030
0.045
0.050
0.060
0.065
0.095
1/2
2
3
4
5
6
Not
Flame
Retardant.
SW-50
SW-51
SW-52
SW-53
1/8
1/4
3/8
1/2
PVC
Superior taber abrasion
resistance, tensile strength,
thermal, mechanical & electrical
properties. Self-extinguishing
flexible product.
80°C
(176°F)
–20°C
(–4°F)
0.125
0.250
0.375
0.500
0.032
0.045
0.052
0.062
1/2
2
2-1/2
3
Self
Extinguishing.
Standard Materials
25,
25,
25,
25,
25,
25,
100
100
100
100
100
100
25, 100, 500
25, 100, 500
25, 100
25, 100
25, 100, 500
25, 100, 500
25,
25,
25,
25,
100
100
100
100
*Registered trademark of E.I. DuPont Co.
Web Site: www.alphawire.com
Email: info@alphawire.com
Toll Free: 1-800-52 ALPHA • Telephone: 908-925-8000 • Fax: 908-925-6923
Europe/UK Telephone: +44 (0) 1932 772422 • Europe/UK Fax: +44 (0) 1932 772433
157
