Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207
Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com
Customer Specification
PART NO. M33879
Construction
Diameters (In)
1) Component 1
19 X 1 COND
a) Conductor
12 (7/.0305) AWG BC
0.092
b) Insulation
0.016" Wall, Nom. PVC/ 0.005" Wall NYLON
0.134
(1) Color Code
Alpha Wire Color Code J
Cond
Color
Cond
Color
Cond
Color
1
BLACK
8
BLUE/BLACK
15
YELLOW/RED
2
RED
9
ORANGE/BLACK
16
BROWN/RED
3
BLUE
10
YELLOW/BLACK
17
BLACK/BLUE
4
ORANGE
11
BROWN/BLACK
18
RED/BLUE
5
YELLOW
12
BLACK/RED
19
ORANGE/BLUE
6
BROWN
13
BLUE/RED
7
RED/BLACK
14
ORANGE/RED
2) Cable Assembly
19 Components Cabled
a) Twists:
1.2 Twists/foot (min)
b) Core Wrap
Clear Mylar Tape, 25% Overlap, Min.
3) Shield:
Alum/Mylar Tape, 25% Overlap, Min.
a) Foil Direction
Foil Facing In
b) Drain Wire
14 (7/.0242) AWG TC
4) Jacket
0.063" Wall, Nom.,PVC
a) Color(s)
BLACK
b) Print
ALPHA WIRE-* P/N M33879 19C 12 AWG
EXXXXXX (UL) TYPE TC 600V 90C DRY 75C WET
SUN RES DIR BUR CE ROHS
* = Factory Code
0.804 (0.838 Max.)
Applicable Specifications
1) UL
TC
SUN RES
DIRECT BURIAL
2) CE:
Environmental
EU Low Voltage Directive 2006/95/EC
90°C / 600 VRMS
1) CE: EU Directive 2011/65/EU(RoHS2):
This product complies with European Directive 2011/65/EU (RoHS Directive) of the European
Parliament and of the Council of 8 June 2011. No Exemptions are required for RoHS
Compliance on this item. Consult Alpha Wire's web site for RoHS C of C.
2) REACH Regulation (EC 1907/2006):
This product does not contain Substances of Very High Concern (SVHC) listed on the European
Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information,
please see Alpha's REACH SVHC Declaration.
3) California Proposition 65:
The outer surface materials used in the manufacture of this part meet the requirements of
California Proposition 65.
Properties
Physical & Mechanical Properties
1) Temperature Range
-25 to 90°C
2) Bend Radius
10X Cable Diameter
3) Pull Tension
1004 Lbs, Maximum
Electrical Properties
(For Engineering purposes only)
1) Voltage Rating
600 VRMS
2) Capacitance
55 pf/ft @1 kHz, Nominal Conductor to Conductor
3) Ground Capacitance
99 pf/ft @1 kHz, Nominal
4) Inductance
0.16 µH/ft, Nominal
5) Conductor DCR
1.64 Ω/1000ft @20°C, Nominal
6) OA Shield DCR
2.28 Ω/1000ft @20°C, Nominal
Other
Packaging
Flange x Traverse x Barrel (inches)
a) 1000 FT
36 x 14 x 12 Continuous length
b) 500 FT
30 x 14 x 12 Continuous length
c) 100 FT
24 x 14 x 12 Continuous length
d) Bulk(Made-to-order)
[Spool dimensions may vary slightly]
www.alphawire.com
Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications
described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not
ensure product availability.
Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or
implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever,
even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out
of or in connection with the use, or inability to use, the information or specifications described herein.
ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY
Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE,
and is merely on loan and subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges and
agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be
copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In the case of conflicting contractual provisions, this notice shall
govern the status of this document. ©2013 ALPHA WIRE - all rights reserved.
很抱歉,暂时无法提供与“M33879 BK002”相匹配的价格&库存,您可以联系我们找货
