M3881 BK002
M3881 BK002
    ALPHAWIRE(阿尔法电线)
    CABLE 30COND 12AWG BLACK 500'
M3881 BK002 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. M3881 Construction Diameters (In) 1) Component 1 30 X 1 COND a) Conductor 12 (7/.0305) AWG BC 0.092 b) Insulation 0.016" Wall, Nom. PVC/ 0.005" Wall NYLON 0.134 (1) Color Code Alpha Wire Color Code J Cond Color Cond Color Cond Color 1 BLACK 11 BROWN/BLACK 21 BROWN/BLUE 2 RED 12 BLACK/RED 22 BLACK/ORANGE 3 BLUE 13 BLUE/RED 23 RED/ORANGE 4 ORANGE 14 ORANGE/RED 24 BLUE/ORANGE 5 YELLOW 15 YELLOW/RED 25 YELLOW/ORANGE 6 BROWN 16 BROWN/RED 26 BROWN/ORANGE 7 RED/BLACK 17 BLACK/BLUE 27 BLACK/YELLOW 8 BLUE/BLACK 18 RED/BLUE 28 RED/YELLOW 9 ORANGE/BLACK 19 ORANGE/BLUE 29 BLUE/YELLOW 10 YELLOW/BLACK 20 YELLOW/BLUE 30 ORANGE/YELLOW 2) Cable Assembly 30 Components Cabled a) Twists: 0.9 Twists/foot (min) b) Core Wrap Clear Mylar Tape, 25% Overlap, Min. 3) Jacket 0.083" Wall, Nom.,PVC a) Color(s) BLACK b) Print ALPHA WIRE-* P/N M3881 30C 12 AWG EXXXXXX (UL) TYPE TC 600V 90C DRY 75C WET SUN RES DIR BUR CE ROHS * = Factory Code 1.029 (1.071 Max.) Applicable Specifications 1) UL TC SUN RES DIRECT BURIAL 2) CE: Environmental EU Low Voltage Directive 2006/95/EC 90°C / 600 VRMS 1) CE: EU Directive 2011/65/EU(RoHS2): This product complies with European Directive 2011/65/EU (RoHS Directive) of the European Parliament and of the Council of 8 June 2011. No Exemptions are required for RoHS Compliance on this item. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. 3) California Proposition 65: The outer surface materials used in the manufacture of this part meet the requirements of California Proposition 65. Properties Physical & Mechanical Properties 1) Temperature Range -25 to 90°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 1534 Lbs, Maximum 4) Sunlight Resistance Yes 5) Direct Burial Yes Electrical Properties (For Engineering purposes only) 1) Voltage Rating 600 VRMS 2) Capacitance 34 pf/ft @1 kHz, Nominal Conductor to Conductor 3) Inductance 0.16 µH/ft, Nominal 4) Conductor DCR 1.65 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 1000 FT 48 x 26 x 18 Continuous length b) 500 FT 36 x 14 x 12 Continuous length c) 100 FT 24 x 14 x 12 Continuous length d) Bulk(Made-to-order) [Spool dimensions may vary slightly] www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time.  By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE.  In the case of conflicting contractual provisions, this notice shall govern the status of this document.  ©2013 ALPHA WIRE - all rights reserved.
M3881 BK002 价格&库存
很抱歉,暂时无法提供与“M3881 BK002”相匹配的价格&库存,您可以联系我们找货
