M4204 BK001
M4204 BK001
    ALPHAWIRE(阿尔法电线)
    同轴 缆线 21 AWG(0.41mm²) RG-6 1000.0'(304.80m) 75 Ohms
M4204 BK001 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. M4204 Construction Diameters (In) 1) Component 1 1 X 1 COAX a) Conductor 21 (SOLID) AWG BCW 0.028 b) Insulation 0.0785" Wall, Nom. Polyethylene(PE) 0.185 Cond Cond (1) Color(s) Cond Color 1 NATURAL Color c) Cabling 1 COAX Cabled d) Shield BC BRAID Shield,95% Coverage, Min. 2) Shield BC BRAID Shield,95% Coverage, Min. 3) Jacket 0.045" Wall, Nom.,Polyethylene (PE) a) Color(s) BLACK b) Print ALPHA WIRE-* P/N M4204 RG 6A/U TYPE * = Factory Code Color 0.332+/- 0.004 Applicable Specifications 1) Military Mil-C-17/RG-6A/U Type 80°C / 2000 VRMS Environmental 1) EU Directive 2011/65/EU(RoHS2): All materials used in the manufacture of this part are in compliance with European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. 3) California Proposition 65: Properties The outer surface materials used in the manufacture of this part meet the requirements of California Proposition 65. Physical & Mechanical Properties 1) Temperature Range -40 to 80°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 25 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 2000 VRMS 2) Characteristic Impedance 75 Ω +/- 3 3) Inductance 0.115 µH/ft, Nominal 4) Ground Capacitance 20.5 pf/ft @1 kHz, Nominal 5) Velocity of Propagation 66 % 6) Conductor DCR 32 Ω/1000ft @20°C, Nominal 7) OA Shield DCR 1.1 Ω/1000ft @20°C, Nominal 8) Voltage Withstanding 7 kV, Minimum 9) Corona Extinction 2.7 kV, Minimum 10) Attenuation, Nom dB/100ft 0.4 @ 1 MHz 0.8 @ 10 MHz 1.9 @ 50 MHz 2.7 @ 100 MHz 4.1 @ 200 MHz 5.9 @ 400 MHz 8.1 @ 700 MHz 9.4 @ 900 MHz 9.8 @ 1 GHz Other Packaging www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Flange x Traverse x Barrel (inches) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time.  By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE.  In the case of conflicting contractual provisions, this notice shall govern the status of this document.  ©2013 ALPHA WIRE - all rights reserved. EU/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: M4204 M4204 , RoHS-Compliant Commencing With 2/1/2006 Production This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope.  Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire Company: Dave Watson, Director of Engineering & QA 5/14/2013
M4204 BK001
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
M4204 BK001 价格&库存
很抱歉,暂时无法提供与“M4204 BK001”相匹配的价格&库存,您可以联系我们找货
