Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207
Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com
Customer Specification
PART NO. M9240082
Construction
Diameters (In)
1) Component 1
8 X 1 PAIR
a)Conductor 1
20 (SOLID) AWG FE
0.032
b)Conductor 2
20 (SOLID) AWG CONSTANTAN
0.032
c)Insulation
0.016" Wall, Nom. PVC
0.064
(1) Print
ALPHANUMERIC NUMBERS - 1-ONE
ALTERNATING AND
INVERTED
(2) Color(s)
FE: BLACK, CONSTANTAN: RED
Pair number printed on Black conductors
d)Pair
2/Cond Cabled Together
(1) Twists:
6.9 Twists/foot (min)
Individually Applied:
e) Shield:
Foil Free Alum/Mylar Tape, 25% Overlap, Min.
(1) Foil Direction
Foil Facing In
(2) Drain Wire
20 (7/28) AWG TC
2)Cable Assembly
8 Components Cabled
a) Twists:
1.3 Twists/foot (min)
b) Core Wrap
Clear Mylar Tape, 25% Overlap, Min.
3)Shield:
a) Foil Direction
Foil Facing In
b) Drain Wire
20 (7/28) AWG TC
5)Jacket
0.055" Wall, Nom.,PVC
a) Color(s)
YELLOW
b) Ripcord
1 End 810 Denier Nylon
c)Print
ALPHA WIRE-* P/N M9240082
EXXXXX 105C 20 AWG (UL) PLTC/ITC
THCPL EXTN TYPE JX --- ROHSCE
* = Factory Code
Applicable Specifications
0.506 (0.528 Max.)
1) UL:
PLTC
105°C
ITC
105°C
CL3
2) Other
ANSI MC96.1 Type JX
Environmental
1)CE:EU Directive 2011/65/EU(RoHS2):
This product complies with European Directive 2011/65/EU (RoHS Directive) of the
European Parliament and of the Council of 8 June 2011. No Exemptions are
required for RoHS Compliance on this item. Consult Alpha Wire's web site for
RoHS C of C.
2) REACH Regulation (EC 1907/2006):
This product does not contain Substances of Very High Concern (SVHC) listed on the European
Union's REACH candidate list in excess of 0.1% mass of the item. Forup-to-date information,
please see Alpha's REACH SVHC Declaration.
3) California Proposition 65:
The outer surface materials used in the manufacture of this part meet the requirements of
California Proposition 65.
Properties
Physical & Mechanical Properties
1)Temperature Range
-20 to 105°C
2)Bend Radius
10X Cable Diameter
3)Pull Tension
207 Lbs, Maximum
4)Sunlight Resistance
Yes
Electrical Properties
(For Engineering purposes only)
1) Voltage Rating300 VRMS
2) Component 1
a)Inductance
0.2 µH/ft, Nominal
b)Conductor 1 DCR
78 Ω/1000ft @20°C, Nominal
c)Conductor 2 DCR
293 Ω/1000ft @20°C, Nominal
d)Component Shield DCR
9.2 Ω/1000ft @20°C, Nominal
e)OA Shield DCR
Other
6.9 Ω/1000ft @20°C, Nominal
Packaging
Flange x Traverse x Barrel (inches)
a)1000 FT
36 x 14 x 12 Continuous length
b)500 FT
30 x 14 x 12 Continuous length
c)100 FT
16 x 11 x 8 Continuous length
d)Bulk(Made-to-order)
[Spool dimensions may vary slightly]
www.alphawire.com
Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications
described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not
ensure product availability.
Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or
implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever,
even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out
of or in connection with the use, or inability to use, the information or specifications described herein.
ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY
Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE,
and is merely on loan and subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges and
agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be
copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In the case of conflicting contractual provisions, this notice shall
govern the status of this document. ©2013 ALPHA WIRE - all rights reserved.
EU/China ROHS CERTIFICATE OF COMPLIANCE
To Whom It May Concern:
Alpha Wire Part Number: M9240082
M9240082 , RoHS-Compliant Commencing With 1/1/2006 Production
This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European
Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of
electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions
are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this
Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope. Additionally, Alpha certifies that
the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006.
Substance
Maximum Control Value
Lead
0.1% by weight (1000 ppm)
Mercury
Cadmium
0.01% by weight (100 ppm)
Hexavalent Chromium
0.1% by weight (1000 ppm )
Polybrominated Biphenyls (PBB)
Polybrominated Diphenyl Ethers (PBDE) ,
Including Deca-BDE
The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its
release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or
the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is
for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual
usage of the product.
Authorized Signatory for the Alpha Wire Company:
Dave Watson, Director of Engineering & QA
5/14/2013
