PBM0430 OR005
PBM0430 OR005
    ALPHAWIRE(阿尔法电线)
    4 AWG 电子线 电线 420/30 橙色 600V 100.0'(30.5m)
PBM0430 OR005 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. PBM0430 Construction Diameters (In) 1) Component 1 1 X 1 HOOKUP a) Conductor 4 (420(7x60)/30) AWG TC 0.268 b) Insulation 0.062" Wall, Nom. PVC 0.392+/- 0.004 (1) Print ALPHA WIRE-* 4 AWG PREMIER EXXXXX (UL) BOAT CABLE 105C DRY 75C WET BC-5W2 OIL RES I 600V OR AWM STYLE 1283 VW-1 --- SAE J378/1127 TYPE SGT 50V DC --- LLXXXXX CSA AWM IA/B 105C 600V FT1 OR TEW 105C 600V FT1 * = Factory Code [Note: Product may have c(UL) or CSA markings depending upon plant of manufacture.] (2) Color(s) WHITE, BLACK, RED, GREEN, YELLOW, BLUE, BROWN ORANGE, SLATE, VIOLET Applicable Specifications 1) UL VW-1 AWM/STYLE 1283 105°C / 600 VRMS Boat Cable (BC-5W2) OIL RES I 2) CSA International FT1 AWM I A/B 105°C / 600 VRMS TEW-105 3) Other ABYC and Coast Guard Requirments SAE, J1127 TYPE SGT SAE, J378B Environmental 50 VDC 1) EU Directive 2011/65/EU(RoHS2): All materials used in the manufacture of this part are in compliance with European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. 3) California Proposition 65: The outer surface materials used in the manufacture of this part meet the requirements of California Proposition 65. Properties Physical & Mechanical Properties 1) Temperature Range -40 to 105°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 330 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 600 VRMS 2) Inductance 0.04 µH/ft, Nominal 3) Conductor DCR 0.28 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 1000 FT 20 x 11 x 8 Continuous length b) 500 FT 16 x 11 x 8 Continuous length c) 250 FT 12 x 10 x 5 Continuous length d) 100 FT 12 x 10 x 5 Continuous length e) 25 FT 12 x 10 x 5 Continuous length f) Bulk(Made-to-order) [Spool dimensions may vary slightly] www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time.  By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE.  In the case of conflicting contractual provisions, this notice shall govern the status of this document.  ©2013 ALPHA WIRE - all rights reserved. EU/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: PBM0430 PBM0430 , RoHS-Compliant Commencing With 7/1/2005 Production This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope.  Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire Company: Dave Watson, Director of Engineering & QA 5/15/2013
PBM0430 OR005
1. 物料型号:PBM0430 2. 器件简介:文档描述了一种由Alpha Wire生产的电线,具有多种颜色选择,包括白色、黑色、红色、绿色、黄色、蓝色、棕色、橙色、板岩色和紫罗兰色。 3. 引脚分配:文档中没有明确提到引脚分配,因为它是关于电线而非集成电路或连接器。 4. 参数特性: - 导体:4(420(7x60)/30) AWG TC,直径为0.268英寸 - 绝缘:0.062英寸壁厚,标称PVC,总直径为0.392英寸 - 温度范围:-40至105°C - 弯曲半径:10倍电缆直径 - 拉力:最大330磅 - 电压等级:600 VRMS 5. 功能详解:电线符合多个标准,包括UL VW-1、AWM/STYLE1283、Boat Cable (BC-5W2)、OIL RESI等,适用于多种环境和应用。 6. 应用信息:电线符合欧盟RoHS指令、REACH法规和加州65号提案,表明其材料不含某些有害物质,适合环保要求。 7. 封装信息:提供了不同长度电线的包装信息,包括1000英尺、500英尺、250英尺、100英尺、25英尺的连续长度,以及定制的散装包装。
PBM0430 OR005 价格&库存
很抱歉,暂时无法提供与“PBM0430 OR005”相匹配的价格&库存,您可以联系我们找货
PBM0430 OR005
    • 50+2158.0859750+279.18137
