PPM1030 BL002
PPM1030 BL002
    ALPHAWIRE(阿尔法电线)
    10 AWG 电子线 电线 105/30 蓝色 600V 500.0'(152.4m)
PPM1030 BL002 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. PPM1030 Construction Diameters (In) 1) Component 1 1 X 1 HOOKUP a) Conductor 10 (105/30) AWG TC 0.118 b) Insulation 0.032" Wall, Nom. PVC 0.184+/- 0.004 (1) Print ALPHA WIRE-* 10 AWG EXXXXXX (UL) BOAT CABLE 105C DRY 75C WET BC-5W2 OIL RES I 600V OR AWM 1015/1230 VW-1 -- SAE J378/1128 TYPE GPT 50V DC LL XXXXXX CSA AWM I A/B 105C 600V FT1 OR TEW 105C 600V FT1 ROHS * = Factory Code [Note: Product may have c(UL) or CSA markings depending upon plant of manufacture.] (2) Color(s) WHITE, BLACK, RED, GREEN, YELLOW, BLUE, BROWN ORANGE, SLATE, VIOLET Applicable Specifications 1) UL AWM/STYLE 1015 105°C / 600 VRMS AWM/STYLE 1230 105°C / 600 VRMS VW-1 OIL RES I Boat Cable (BC-5W2) 2) CSA International AWM I A/B 105°C / 600 VRMS FT1 TEW-105 3) Other SAE, J1128 Type GPT SAE, J378B ABYC and Coast Guard Requirments Environmental 105°C / 600 VRMS 1) EU Directive 2011/65/EU(RoHS2): All materials used in the manufacture of this part are in compliance with European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. Properties Physical & Mechanical Properties 1) Temperature Range -20 to 105°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 82 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 600 VRMS 2) Inductance 0.04 µH/ft, Nominal 3) Conductor DCR 1.08 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 1000 FT 12 x 6 x 3.5 Continuous length b) 500 FT 12 x 4.5 x 3.5 Continuous length c) 100 FT 6.5 x 2 x 1.9 Continuous length d) Bulk(Made-to-order) [Spool dimensions may vary slightly] www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time.  By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE.  In the case of conflicting contractual provisions, this notice shall govern the status of this document.  ©2013 ALPHA WIRE - all rights reserved. EU/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: PPM1030 PPM1030 , RoHS-Compliant Commencing With 7/1/2005 Production This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope.  Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire Company: Dave Watson, Director of Engineering & QA 5/15/2013
PPM1030 BL002
物料型号:PPM1030
器件简介:Alpha Wire公司生产的电线,具有多种颜色选择,包括白色、黑色、红色、绿色、黄色、蓝色、棕色、橙色、板岩色和紫色。
引脚分配:文档中未提及引脚分配,因为这是电线而非电子元件。
参数特性: - 导体规格:10(105/30) AWG TC,直径0.118英寸。 - 绝缘材料:0.032英寸壁厚,标称PVC,总厚度0.184英寸。 - 温度范围:-20至105摄氏度。 - 弯曲半径:10倍电缆直径。 - 拉力:最大82磅。 - 电压等级:600V RMS。 - 电感:0.04 H/ft(标称)。 - 导体直流电阻:在20摄氏度下,每1000英尺1.08欧姆(标称)。
功能详解:该电线适用于多种环境,包括干燥和湿润条件,具有油抵抗性,并且符合多个安全标准,如UL、CSA等。
应用信息:电线可用于多种应用,包括但不限于电气和电子设备。
封装信息:提供不同的包装尺寸,包括1000英尺、500英尺和100英尺的连续长度卷轴,以及定制的散装包装。
环境信息:该产品符合欧洲RoHS指令和REACH法规,限制了某些有害物质的使用,并在生产过程中不包含超过0.1%质量分数的高度关注物质(SVHC)。
PPM1030 BL002 价格&库存
很抱歉,暂时无法提供与“PPM1030 BL002”相匹配的价格&库存,您可以联系我们找货
PPM1030 BL002
    • 10+2921.1687410+376.83824
