PPM1430 PK005
PPM1430 PK005
    ALPHAWIRE(阿尔法电线)
    14 AWG 电子线 电线 41/30 粉色 600V 100.0'(30.5m)
PPM1430 PK005 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. PPM1430 Construction Diameters (In) 1) Component 1 1 X 1 HOOKUP a) Conductor 14 (41/30) AWG TC 0.074 b) Insulation 0.0315" Wall, Nom. PVC 0.136+/- 0.004 (1) Print ALPHA WIRE-* 14 AWG EXXXXXX (UL) BOAT CABLE 105C DRY 75C WET BC-5W2 OIL RES I 600V OR AWM 1015/1230 VW-1 -- SAE J378/1128 TYPE GPT 50V DC LL XXXXXX CSA AWM I A/B 105C 600V FT1 OR TEW 105C 600V FT1 ROHS * = Factory Code [Note: Product may have c(UL) or CSA markings depending upon plant of manufacture.] (2) Color(s) WHITE, BLACK, RED, GREEN, YELLOW, BLUE, BROWN ORANGE, SLATE, VIOLET Applicable Specifications 1) UL AWM/STYLE 1015 105°C / 600 VRMS AWM/STYLE 1230 105°C / 600 VRMS VW-1 OIL RES I Boat Cable (BC-5W2) 2) CSA International AWM I A/B 105°C / 600 VRMS FT1 TEW-105 3) Other SAE, J1128 Type GPT SAE, J378B ABYC and Coast Guard Requirments Environmental 105°C / 600 VRMS 1) EU Directive 2011/65/EU(RoHS2): All materials used in the manufacture of this part are in compliance with European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. Properties Physical & Mechanical Properties 1) Temperature Range -20 to 105°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 32 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 600 VRMS 2) Inductance 0.05 µH/ft, Nominal 3) Conductor DCR 2.8 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 1000 FT 12 x 4.5 x 3.5 Continuous length b) 500 FT 6.5 x 6 x 1.9 Continuous length c) 100 FT 6.5 x 2 x 1.9 Continuous length d) Bulk(Made-to-order) [Spool dimensions may vary slightly] www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time.  By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE.  In the case of conflicting contractual provisions, this notice shall govern the status of this document.  ©2013 ALPHA WIRE - all rights reserved. EU/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: PPM1430 PPM1430 , RoHS-Compliant Commencing With 7/1/2005 Production This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope.  Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire Company: Dave Watson, Director of Engineering & QA 5/15/2013
PPM1430 PK005
物料型号:PPM1430
器件简介:Alpha Wire生产的电线,具有多种颜色选择,包括白色、黑色、红色、绿色、黄色、蓝色、棕色、橙色、板岩色和紫色。
引脚分配:文档中没有提供引脚分配信息,因为这是一个电线产品,而不是电子元件。
参数特性: - 导体规格:14(41/30) AWG TC,直径0.074英寸。 - 绝缘材料:0.0315英寸壁厚,标称PVC,总厚度0.136英寸。 - 温度范围:-20至105摄氏度。 - 弯曲半径:10倍电缆直径。 - 拉力:最大32磅。
功能详解: - 电线符合多个安全标准,包括UL AWM/STYLE1015、UL AWM/STYLE1230、VW-1、OIL RESI、Boat Cable (BC-5W2)、CSA AWM I A/B、FT1、TEW-105等。 - 符合欧盟RoHS指令2011/65/EU,限制使用某些有害物质。 - 不含REACH候选清单上的高关注物质(SVHC),超过0.1%的质量百分比。
应用信息:适用于多种环境和应用场景,包括需要耐油、耐水和耐高温的场合。
封装信息: - 包装方式:法兰x横向x桶装(英寸)。 - 1000英尺:12x4.5x3.5英寸连续长度。 - 500英尺:6.5x6x1.9英寸连续长度。 - 100英尺:6.5x2x1.9英寸连续长度。 - 散装(按订单制作):卷轴尺寸可能略有变化。
PPM1430 PK005 价格&库存
很抱歉,暂时无法提供与“PPM1430 PK005”相匹配的价格&库存,您可以联系我们找货
