VFD Cable
25' AND 50' PUT-UPS IN STOCK AND READY TO SHIP
A
lpha Wire’s Variable Frequency Drive (VFD) cables can increase the reliability and
life of your VFD systems by combating performance issues and signal disruptions.
Specially manufactured with a cross-linked polyethylene (XLPE) insulation, Alpha Wire VFD
cables minimize EMI/RFI interference, provide excellent corona resistance, and exceptional
performance even in low-temperatures and across longer transmission distances.
XLPE Insulation
Series V and V-Flex Cables
For high-performance in
VFD applications
Lower Capacitance | Excellent
Corona Resistance | Longer
Transmission Distances
Round Geometry
Enhances Uniform Electrical
Properties | Allows IP67/NEMA 6
Liquid-Tight Sealing
Double Shielding
EMI Protection
MAXIMIZE UP TIME
WITH THE VFD LENGTHS YOU NEED, WHEN YOU NEED THEM.
V
SERIES CABLES
ENHANCED DESIGN FOR
SUPERIOR PERFORMANCE
I N VF D A P P L I CAT I O N S
Size: 16AWG - 8AWG
Temperature Range: -40°C – +90°C
Construction: PVC Jacket with XLPE Insulation
Shielding: Foil/Braid
Bend Radius: 10x Cable Diameter
Approvals: UL TC-ER (600 V) | UL Motor Supply (1000 V)
UL SUN RES | CSA AWM I/II A/B | CSA FT4
Alpha Wire P/N
Color
Put-up
Description*
V16008 BK007
Black
50 ft
8AWG 4C VFD CABLE
V16008 BK008
Black
25 ft
8AWG 4C VFD CABLE
V16010 BK007
Black
50 ft
10AWG 4C VFD CABLE
V16010 BK008
Black
25 ft
10AWG 4C VFD CABLE
V16012 BK007
Black
50 ft
12AWG 4C VFD CABLE
V16012 BK008
Black
25 ft
12AWG 4C VFD CABLE
V16014 BK007
Black
50 ft
14AWG 4C VFD CABLE
V16014 BK008
Black
25 ft
14AWG 4C VFD CABLE
V16016 BK007
Black
50 ft
16AWG 4C VFD CABLE
V16016 BK008
Black
25 ft
16AWG 4C VFD CABLE
*Available in conductor plus full size insulated ground.
V-Flex
SERIES CABLES
S U P E R I O R F L E XI B I L I T Y
F O R E A S I E R R O UT I N G
AND HANDLING
Size: 16AWG - 8AWG
Construction: TPE Jacket with XLPE Insulation
Bend Radius: 5x Cable Diameter
UL SUN RES | UL OIL RES I/II | CSA FT4
Alpha Wire P/N
Color
Put-up
Description
VF16008 BK008
Black
25 ft
8AWG 4C VFD CABLE TPE
VF16010 BK007
Black
50 ft
10AWG 4C VFD CABLE TPE
VF16010 BK008
Black
25 ft
VF16012 BK007
Black
50 ft
12AWG 4C VFD CABLE TPE
VF16012 BK008
Black
25 ft
VF16014 BK007
Black
50 ft
14AWG 4C VFD CABLE TPE
VF16014 BK008
Black
25 ft
VF16016 BK007
Black
50 ft
16AWG 4C VFD CABLE TPE
VF16016 BK008
Black
25 ft
© 2019 Alpha Wire. All rights reserved.
Specifications subject to change. Consult Alpha Wire for latest specifications.
很抱歉,暂时无法提供与“VF16014 BK007”相匹配的价格&库存,您可以联系我们找货
