AB-FA01208-19700-8A1 数据手册
AMERICAN BRIGHT
OPTOELECTRONICS CORP.
13815-C MAGNOLIA AVE., CHINO, CA 91710
TOLL-FREE: 888-LED-0800
TEL: 909-628-5050
FAX: 909-628-5006
w w w . a m e r i c a n b r i g h t l e d . c o m
Application:
Features:
UL listed (#E353753)
IP20 waterproof rating
Conference/Meeting rooms
Top emitting, wide viewing angle 120°
Commercial Purposes
Storage temperature -20°C~+80°C
Operating temperature -20°C~+45°C
Residential/Institution Buildings
Schools
Environment humidity 40-70%RH
Hospitals
Factories and Offices
Hotels
Product performance parameter:
Serial
number
1
Part Number
AB-FA0120819700-8A1
CCT/nm
CRI
3000±150K
>80
Red
620630nm
Green
520535nm
Blue
460470nm
QTY/M Luminous
(39.3in) per meter
60LED
60LED
lm/W
working
voltage
(12V)/IF(A)
Rated
power
(W/M)
361lm
95/W
12V/0.31A
3.8
72lm
20/W
12V/0.30A
3.6
233lm
73/W
12V/0.26A
3.2
55lm
18/W
12V/0.25A
3.1
Notes:
1. Luminous flux plus or minus 10% is allowed in the floating.
2. Maximum length current attenuation 15%.
3. Photometric standards are based on CIE eye sensitivity curve diagram test.
1|Page
AMERICAN BRIGHT
TEL: 909-628-5050
FAX: 909-628-5006
Schematic diagram:
Schematic:
(DC12V)
B
B
B
G
G
G
R
R
R
W
W
W
B
B
B
B
G
G
G
G
R
W
R
R
R
12V+
W
W
W
Product size chart:
LLL
50mm
12V+
12V+
10mm
12V+
12V+
12V+
12V+
12V+
12V+
R
R
R
R
R
R
R
R
G
G
G
G
G
G
G
G
B
B
B
B
B
B
B
B
W
W
W
W
W
W
W
W
16.66mm
LED
PCB
LLL
NOTE:
1. UNIT:MM(IN)
2. COLOR:WHITE
3. 3M 9495 double-sided tape on the back
2|Page
AMERICAN BRIGHT
TEL: 909-628-5050
FAX: 909-628-5006
Installation method:
LED Strip Installation
a
b
C
LED Chip
Angle≥90°
Angle≥60°
Angle≥60°
Correct
a≥60°
Incorrect
Incorrect
a: use an angle greater or equal to 90 degrees when there is an LED chip on the corner while
placing the strip in a concave position (Angle≥90degree)
b: use an angle greater or equal to 60 degrees when there is an LED chip on the corner while
placing the strip in a concave position (Angle≥60degree)
c:use an angle greater or equal to 60 degrees when there is an LED chip on the corner while
placing the strip in a concave position (Angle≥60degree) In the convex position the angle
should not reach 90 degrees .See above diagram.
3|Page
AMERICAN BRIGHT
TEL: 909-628-5050
FAX: 909-628-5006
Maximum Flexibility Precaution
R15
LESS THAN8
NOTE: DO NOT BEND TO A
RADIUS OF LESS THAN 0.59 INCH
NOTE: SHARP BENDING ISN'T
ALLOWABLE
NOTE: DO NOT AXIAL BEND TO
THE HEIGHT OF MORE THAN 19.8mm
WITHIN 0.78 INCH SEGMENT
R11.8
NOTE: DO NOT HORIZONTAL
BEND TO A RADIUS OF LESS THAN
18 INCH
AXIS
NOTE: DO NOT TWIST MORE THAN 90°
OVER THE LENGTH OF ONE 24v SEGMENT/ TWO 12V
SEGMENTS (4" TOTAL LENGTH)
Product packaging
Model
1
Part number
box(pcs)
Net Weight/box
Gross Weight/box
4|Page
AB-FA01208-19700-8A1 价格&库存
很抱歉,暂时无法提供与“AB-FA01208-19700-8A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.54040
- 200+2.21400
- 500+2.13840
- 1000+2.10600
- 国内价格 香港价格
- 100+8.35882100+1.08662
- 200+7.79305200+1.01308
- 300+7.50243300+0.97529
- 500+7.17342500+0.93252
- 700+6.97749700+0.90705
- 1000+6.786221000+0.88219
- 国内价格 香港价格
- 1+15.518801+2.01740
- 10+11.0423510+1.43547
