AB-FC01265-19712-8A1 数据手册
13815-C MAGNOLIA AVE., CHINO, CA 91710
TOLL-FREE: 888-LED-0800 TEL: 909-628-5050
FAX: 909-628-5006
w w w . a m e r i c a n b r i g h t l e d . c o m
AB-FC Flexible Tape Light Series
IP65 flexible tape light in 12V/24V DC - single color, RGB, and RGBW options
Features:
Applications:
• UL listed
• Conference/meeting rooms
• IP65 waterproof rating
• Commercial/ residential buildings
• Top emitting, wide viewing angle 120°
• Entertainment lighting
• Hospitals
• Storage temperature 0°C~60°C
• Hotels
• Operating temperature -20°C~80°C
• Environment humidity 40-70%RH
1
Copyright © 2019 American Bright Optoelectronics Corp. All right reserved.Version: 2 Date: 4/25/2019
Part number naming system:
AB–FCVVVKK–LLLWL–XA1
V V V – Voltage (volt) (012=12V, 024=24V)
K K – Color/CCT (27 – 2700K, 30 – 3000K, 40 – 4000K, 50 – 5000K, 63 – 6300K, 65 – 6500K CCT, RD – Red, GR –
Green, BL – Blue, AM – Amber, 06 – RGB, 08 – RGBW)
L L L – Light strip length (unit: inch);
Length selection of the strip:
12V
24V
Single Color Multiple of 25mm Multiple of 50mm
RGB/RGBW Multiple of 50mm Multiple of 100mm
W L – Wire lead length (unit: inch); standard length is 12 inches; 00- No wire, no end cap
X – CRI (8 – 80, 9 – 90, X – not applicable)
Ax – Version (Internal Code)
For example, part number below calls out a flexible tape light with IP65 rating, 24VDC in 3000K CCT, CRI 80,
197 inches long with 12 inches wire lead.
AB–FC02430–19712–8A1
2
Outline Dimension:
Single Color:
DC 12V
DC 24V
RGB Color:
DC 12V:
3
DC 24V:
RGBW Color:
12V:
24V:
1,2,3
Cutting Mark is imprinted on the strip:
12V
24V
Single Color
Every 25mm
Every 50mm
RGB/RGBW
Every 50mm
Every 100mm
1
Heat shrink on the end of both sides.
Light strip comes with rear adhesive, 3M 300LSE.
3 Silicon coating: durometer, shore A 60~65 or equivalent. Color: Clear
2
4
Schematic Diagram:
Single Color:
DC 12V:
DC 24V:
RGB Color:
DC 12V:
5
DC 24V:
RGBW Color:
DC 12V:
6
DC 24V:
Characteristics:
Table 1. Configurations for AB-FC Flexible Tape Light Series.
OPERATING
VOLTAGE (V)
12
24
4
CURRENT (A/m)
POWER
LENGTH4
(W/m)
m (inch)
White/Green/Blue: 0.66
8
Red/Amber: 0.83
RGB: 0.84
RGBW: 1.18
White/Green/Blue: 0.33
Red/Amber: 0.41
RGB: 0.42
10
10.1
14.2
8
10
10.1
RGBW: 0.59
14.2
LED COUNT/m
120
5 (197)
60
120
5 (197)
60
Standard unit length: 5m or 10m/roll, for custom length, please contact aboc@americanbrightled.com.
7
Table 2. Product performance of AB-FC Flexible Tape Light Series at T=25 degree C.
PART NUMBER
AB-FC012KK-19712-XA16
AB-FC024KK-19712-XA1
AB-FC01206-19712-XA2
AB-FC02406-19712-XA2
AB-FC01208-19712-8Ax7
AB-FC02408-19712-8Ax
CCT/
WAVELENGTH
30: 3000K
40: 4000K
63: 6300K
RD: Red 620-630nm
LUMINOUS
FLUX5
(lm/m)
LUMINOUS
EFFICACY (lm/W)
CRI
720
90
>80
250
25
GR: Green 520-535nm
BL: Blue 465-475nm
AM: Amber 600-610nm
RD: Red 625-635nm
GR: Green 520-535nm
BL: Blue 465-475nm
560
168
190
90
248
56
70
21
19
25
18
58
RD: Red 620-630nm
GR: Green 520-535nm
BL: Blue 465-475nm
27: 2700K
30: 3000K
40: 4000K
50: 5000K
65: 6500K
81
223
50.2
334
>80
5
Luminous flux ±10% is allowed.
KK - Color/CCT (27 – 2700K, 30 – 3000K, 40 – 4000K, 50 – 5000K, 65 – 6500K CCT, 06 – RGB, 08 – RGBW)
7
x – 1- 3000K CCT, 2 - 4000K CCT, for other color temperature, please contact aboc@americanbrightled.com.
6
8
Optional Mounting Accessories:
Table 3. Mounting Accessories
Size (mm)
Description
Compatible to
AB-M-SS-10-12L20
20x10x13
Stainless mounting bracket
AB-FF series
AB-M-SI-RBLL-06
18.3x6x6
Silicon mounting bracket
AB-FA series
AB-FC series
AB-FD series
AB-M-AL-20-091000
5000x15x10
Aluminum groove
AB-FB series
AB-M-SS-18-09L20
20x18x10
AB-FB series
AB-M-SS-7-9-L7
7x6x12
AB-FH series
Item#
9
Installation Instructions:
Maximum flexibility precaution:
10
Packaging:
Table 4. Packaging information
8
Model
QTY8
AB-FA series
AB-FC series
AB-FD series
1 roll/per ESD bag
10 bags/carton
AB-FB series
AB-FF series
AB-FH series
1 roll/per tray
10 trays/carton
Standard unit length: 5m or 10m/roll, 1 roll/bag. QTY/bag varies per different unit lengths.
11
AB-FC01265-19712-8A1 价格&库存
很抱歉,暂时无法提供与“AB-FC01265-19712-8A1”相匹配的价格&库存,您可以联系我们找货
