AB-FC02440-19700-8A1
    AMERICANBRIGHT
    LIGHT STRIP W IP65 24V 6 LED/SEG
AB-FC02440-19700-8A1 数据手册
13815-C MAGNOLIA AVE., CHINO, CA 91710 TOLL-FREE: 888-LED-0800 TEL: 909-628-5050 FAX: 909-628-5006 w w w . a m e r i c a n b r i g h t l e d . c o m AB-FC Flexible Tape Light Series IP65 flexible tape light in 12V/24V DC - single color, RGB, and RGBW options Features: Applications: • UL listed • Conference/meeting rooms • IP65 waterproof rating • Commercial/ residential buildings • Top emitting, wide viewing angle 120° • Entertainment lighting • Hospitals • Storage temperature 0°C~60°C • Hotels • Operating temperature -20°C~80°C • Environment humidity 40-70%RH 1 AB-FC Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved.Version: 2 Date: 4/25/2019 Part number naming system: AB–FCVVVKK–LLLWL–XA1 V V V – Voltage (volt) (012=12V, 024=24V) K K – Color/CCT (27 – 2700K, 30 – 3000K, 40 – 4000K, 50 – 5000K, 63 – 6300K, 65 – 6500K CCT, RD – Red, GR – Green, BL – Blue, AM – Amber, 06 – RGB, 08 – RGBW) L L L – Light strip length (unit: inch); Length selection of the strip: 12V 24V Single Color Multiple of 25mm Multiple of 50mm RGB/RGBW Multiple of 50mm Multiple of 100mm W L – Wire lead length (unit: inch); standard length is 12 inches; 00- No wire, no end cap X – CRI (8 – 80, 9 – 90, X – not applicable) Ax – Version (Internal Code) For example, part number below calls out a flexible tape light with IP65 rating, 24VDC in 3000K CCT, CRI 80, 197 inches long with 12 inches wire lead. AB–FC02430–19712–8A1 2 AB-FC Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved.Version: 2 Date: 4/25/2019 Outline Dimension: Single Color: DC 12V DC 24V RGB Color: DC 12V: 3 AB-FC Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved.Version: 2 Date: 4/25/2019 DC 24V: RGBW Color: 12V: 24V: 1,2,3 Cutting Mark is imprinted on the strip: 12V 24V Single Color Every 25mm Every 50mm RGB/RGBW Every 50mm Every 100mm 1 Heat shrink on the end of both sides. Light strip comes with rear adhesive, 3M 300LSE. 3 Silicon coating: durometer, shore A 60~65 or equivalent. Color: Clear 2 4 AB-FC Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved.Version: 2 Date: 4/25/2019 Schematic Diagram: Single Color: DC 12V: DC 24V: RGB Color: DC 12V: 5 AB-FC Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved.Version: 2 Date: 4/25/2019 DC 24V: RGBW Color: DC 12V: 6 AB-FC Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved.Version: 2 Date: 4/25/2019 DC 24V: Characteristics: Table 1. Configurations for AB-FC Flexible Tape Light Series. OPERATING VOLTAGE (V) 12 24 4 CURRENT (A/m) POWER LENGTH4 (W/m) m (inch) White/Green/Blue: 0.66 8 Red/Amber: 0.83 RGB: 0.84 RGBW: 1.18 White/Green/Blue: 0.33 Red/Amber: 0.41 RGB: 0.42 10 10.1 14.2 8 10 10.1 RGBW: 0.59 14.2 LED COUNT/m 120 5 (197) 60 120 5 (197) 60 Standard unit length: 5m or 10m/roll, for custom length, please contact aboc@americanbrightled.com. 7 AB-FC Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved.Version: 2 Date: 4/25/2019 Table 2. Product performance of AB-FC Flexible Tape Light Series at T=25 degree C. PART NUMBER AB-FC012KK-19712-XA16 AB-FC024KK-19712-XA1 AB-FC01206-19712-XA2 AB-FC02406-19712-XA2 AB-FC01208-19712-8Ax7 AB-FC02408-19712-8Ax CCT/ WAVELENGTH 30: 3000K 40: 4000K 63: 6300K RD: Red 620-630nm LUMINOUS FLUX5 (lm/m) LUMINOUS EFFICACY (lm/W) CRI 720 90 >80 250 25 GR: Green 520-535nm BL: Blue 465-475nm AM: Amber 600-610nm RD: Red 625-635nm GR: Green 520-535nm BL: Blue 465-475nm 560 168 190 90 248 56 70 21 19 25 18 58 / / / RD: Red 620-630nm GR: Green 520-535nm BL: Blue 465-475nm 27: 2700K 30: 3000K 40: 4000K 50: 5000K 65: 6500K 81 223 50.2 / / / 334 / / / / / / / / >80 5 Luminous flux ±10% is allowed. KK - Color/CCT (27 – 2700K, 30 – 3000K, 40 – 4000K, 50 – 5000K, 65 – 6500K CCT, 06 – RGB, 08 – RGBW) 7 x – 1- 3000K CCT, 2 - 4000K CCT, for other color temperature, please contact aboc@americanbrightled.com. 6 8 AB-FC Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved.Version: 2 Date: 4/25/2019 Optional Mounting Accessories: Table 3. Mounting Accessories Size (mm) Description Compatible to AB-M-SS-10-12L20 20x10x13 Stainless mounting bracket AB-FF series AB-M-SI-RBLL-06 18.3x6x6 Silicon mounting bracket AB-FA series AB-FC series AB-FD series AB-M-AL-20-091000 5000x15x10 Aluminum groove AB-FB series AB-M-SS-18-09L20 20x18x10 Stainless mounting bracket AB-FB series AB-M-SS-7-9-L7 7x6x12 Stainless mounting bracket AB-FH series Item# Image 9 AB-FC Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved.Version: 2 Date: 4/25/2019 Installation Instructions: Maximum flexibility precaution: 10 AB-FC Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved.Version: 2 Date: 4/25/2019 Packaging: Table 4. Packaging information 8 Model QTY8 AB-FA series AB-FC series AB-FD series 1 roll/per ESD bag 10 bags/carton AB-FB series AB-FF series AB-FH series 1 roll/per tray 10 trays/carton Image Standard unit length: 5m or 10m/roll, 1 roll/bag. QTY/bag varies per different unit lengths. 11 AB-FC Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved.Version: 2 Date: 4/25/2019
AB-FC02440-19700-8A1 价格&库存
很抱歉,暂时无法提供与“AB-FC02440-19700-8A1”相匹配的价格&库存,您可以联系我们找货
