AB-GES-R08136W501N2
AB-GES-R08136W501N2
    AMERICANBRIGHT
    INGENI-AC 120VAC RECTANGULAR 80*
AB-GES-R08136W501N2 数据手册
AB-GES-L15110Wxx1-C2 13815-C MAGNOLIA AVE., CHINO, CA 91710 TOLL-FREE: 888-LED-0800 TEL: 909-628-5050 FAX: 909-628-5006 w w w . a m e r i c a n b r i g h t l e d . c o m AB-GES-R08136Wxx1N2 Features & Applications Features:        3000lm Square AC LED light engine SimpleDrive® - 120V AC drive technology Driver on Board structure Phillips Lumileds LED Long life - No Electrolytic capacitors Easily to be integrated UL Compliance Applications:  Down light (Diffused type) AB-GES-R08136Wxx1N2 Copyright © 2015 American Bright Optoelectronics Corp. All right reserved. The information in this document is subject to change without notice 1 AB-GES-L15110Wxx1-C2 13815-C MAGNOLIA AVE., CHINO, CA 91710 TOLL-FREE: 888-LED-0800 TEL: 909-628-5050 FAX: 909-628-5006 w w w . a m e r i c a n b r i g h t l e d . c o m Outline Dimensions 46 (LES) Units: mm Notes: 1. Terminal block is used and No wire connected. 2. Thickness of PCB is 1.0mm 3. Tolerance of dimension is 0.15mm 4. There’s no thermal tape in the back side of the module. AB-GES-R08136Wxx1N2 Copyright © 2015 American Bright Optoelectronics Corp. All right reserved. The information in this document is subject to change without notice 2 13815-C MAGNOLIA AVE., CHINO, CA 91710 TOLL-FREE: 888-LED-0800 TEL: 909-628-5050 AB-GES-L15110Wxx1-C2 FAX: 909-628-5006 w w w . a m e r i c a n b r i g h t l e d . c o m Characteristics ■ Absolute Maximum Ratings  Parameter Symbol Rating Unit Input Voltage Vin 130 Vac LED Junction Temperature TJ 115 oC Storage Temperature Tstg -40 ~ 100 oC Operation Temperature Topr -40 ~ 85 oC oC oC Proper current rating must be observed to maintain junction temperature below maximum at all time. For this product, we suggest to keep the Temperature of TC point under 75 oC, and the temperature of Top IC surface under 115oC. After passing the maximum temperature of IC, the rating current will be lower automatically for protecting the whole circuit. ■ Electrical Characteristics, Ta=25ºC Parameter Symbol Min. Max. Unit Input Voltage Vin 110 130 Vac Input Frequency Freq. Power Factor PF Action Junction Temperature of 50/60 0.9 Tact,OTP OTP (Over temperature protection) Hz 0.95 oC 140 ■ Optical Characteristics (Vin=120V), Ta=25ºC AC Power Color Temp Model name Luminous Flux(lm) CRI Min Typ. Max (K) Min Typ AB-GES-R08136W301N2 32.4 36.0 39.6 3000K 3300 3600 >80 AB-GES-R08136W401N2 32.4 36.0 39.6 4000K 3300 3600 >80 AB-GES-R08136W501N2 32.4 36.0 39.6 5000K 3300 3600 >80  Correlated color Temperature is derived from the CIE 1931Chromaticity diagram.  The luminous flux tolerance is ± 10%.  This CRI value tolerance is ± 2.  Calibration accuracy of CIEx and CIEy : 0.007 ;  Calibration error CCT 3000K 175K ; 4000K 300K ; 6500K 400K AB-GES-R08136Wxx1N2 Copyright © 2015 American Bright Optoelectronics Corp. All right reserved. The information in this document is subject to change without notice 3 AB-GES-L15110Wxx1-C2 13815-C MAGNOLIA AVE., CHINO, CA 91710 TOLL-FREE: 888-LED-0800 TEL: 909-628-5050 FAX: 909-628-5006 w w w . a m e r i c a n b r i g h t l e d . c o m ■ Relative Spectrum of Emission (Ta=25ºC) ■ Radiation Pattern AB-GES-R08136Wxx1N2 Copyright © 2015 American Bright Optoelectronics Corp. All right reserved. The information in this document is subject to change without notice 4 AB-GES-L15110Wxx1-C2 13815-C MAGNOLIA AVE., CHINO, CA 91710 TOLL-FREE: 888-LED-0800 TEL: 909-628-5050 FAX: 909-628-5006 w w w . a m e r i c a n b r i g h t l e d . c o m Packing 1 Box = 100 PCS (about 14 Kgs(Net Weight) / 15kg(Gross weight) Box size (L x W x H) = (470x340x350 mm) AB-GES-R08136Wxx1N2 Copyright © 2015 American Bright Optoelectronics Corp. All right reserved. The information in this document is subject to change without notice 5 AB-GES-L15110Wxx1-C2 13815-C MAGNOLIA AVE., CHINO, CA 91710 TOLL-FREE: 888-LED-0800 TEL: 909-628-5050 FAX: 909-628-5006 w w w . a m e r i c a n b r i g h t l e d . c o m Color Bin Code Color region stays within Macadam "3-Step" ellipse from the chromaticity center. The chromaticity center refers to ANSI C78.377:2008. Please refer to ANSI C78.377 for the chromaticity center. CCT Steps Cx Cy a b theta 2700K 3 0.4578 0.4101 0.00810 0.00420 53.70 3000K 3 0.4338 0.4030 0.00834 0.00408 53.22 3500K 3 0.4073 0.3917 0.00927 0.00414 54.00 4000K 3 0.3818 0.3797 0.00939 0.00402 53.72 5000K 3 0.3447 0.3553 0.00822 0.00354 59.62 5700K 3 0.3287 0.3417 0.00746 0.00320 59.09 6500K 3 0.3123 0.3282 0.00669 0.00285 58.57 AB-GES-R08136Wxx1N2 Copyright © 2015 American Bright Optoelectronics Corp. All right reserved. The information in this document is subject to change without notice 6 AB-GES-L15110Wxx1-C2 13815-C MAGNOLIA AVE., CHINO, CA 91710 TOLL-FREE: 888-LED-0800 TEL: 909-628-5050 FAX: 909-628-5006 w w w . a m e r i c a n b r i g h t l e d . c o m AB-GES-R08136Wxx1N2 Copyright © 2015 American Bright Optoelectronics Corp. All right reserved. The information in this document is subject to change without notice 7
AB-GES-R08136W501N2 价格&库存
很抱歉,暂时无法提供与“AB-GES-R08136W501N2”相匹配的价格&库存,您可以联系我们找货
