KL444120
KL444120
    AMERICANELECTRICAL(美国电气)
    连接器 端板 用于 AVK 系列
KL444120 数据手册
AVK RD Series AVK 2.5 rd Feed-Through Terminal Blocks and Accessories Width 5 mm 304 200 Colors Terminals End Plate Partition Part Number Part Number Part Number GREY BLUE GREEN YELLOW RED BEIGE AVK 2.5 RD 304 200 304 201 304 202 304 203 304 204 304 209 NPP 444 120 444 121 444 122 444 123 444 124 444 129 APP 462 120 462 121 462 122 462 123 462 124 462 129 GREY BLUE GREEN YELLOW RED BEIGE AVK 4 RD 304 210 304 211 304 212 304 213 304 214 304 219 NPP 444 120 444 121 444 122 444 123 444 124 444 129 APP 462 120 462 121 462 122 462 123 462 124 462 129 GREY BEIGE AVK 25 CC 324 909 304 900 NPP 444 130 444 139 GREY BEIGE AVK 4 C 325 109 325 100 NPP 450 170 450 179 GREY BEIGE AVK 4 GD 304 279 304 270 NPP 444 140 444 149 TS 35 44.4 AVK type terminals are manufactured from thermoplastic raw material. Grey being the main color, five different colors give users additional choices for visual separation of control circuits and/or voltage levels. 42.7 torque: 0.4 Nm Electrical Ratings CE (EN 60947-7-1) VDE (IEC 60947-7-1) UL / CSA ATEX Connection Data Solid Strand, Screw Con. - Fine Strand, Screw Con. AWG Conductor / Fine Strand with Ferrule Insulation Stripping Length / Torque Ordering Data Polyamide 66 Grey Mounting Rails TS 35x7.5 solid TS 35x15 solid TS 35x7.5 slotted TS 35x15 slotted steel slot dim. 25mm on 36mm center 5.2mm slot width End Bracket Thickness 8mm KD 3 aluminum slot dim. 13mm on 26mm center 5mm slot width grey End Plate - Disconnect Plate Width 1.5 mm Polyamide 66 NPP APP Voltage/Current/Cross-section 750 V ~ / 24 A / 2.5 mm² 750 V ~ / 24 A / 2.5 mm² 600 V ~ / 20 A / AWG 26-12 630 V ~ / 23 A 0.5 - 4 mm² / 0.5 - 4 mm² 26 - 12 / 0.5 - 2.5 mm² 10 mm / 0.4 Nm Type Part. No. AVK 2.5 rd 304 200 Type Part. No. slotted 35x7.5 TS3575SL 35x7.5 TS3575SL1 35x7.5 TS3575SL1-A 35x15 TS3515SL solid 35x7.5 TS3575SOL 35x15 TS3515SOL Qty. 100 std. pk. 2m 1m 1m 2m 2m 2m KD 3 495 049 100 NPP 2.5-10 444 120 100 APP 2.5-10 462 120 25 UK 2.5/2 UK 2.5/3 UK 2.5/4 UK 2.5/10 476 222 476 223 476 224 476 229 25 20 15 5 TF (Ø4) 493 040 5 TSK 8 (Ø4) 490 080 5 ITK 32 (Ø4) 492 020 5 IP 2 S IP 2 498 130 498 140 25 25 ge ge 2 496 119 496 250 50 25 NPP avk 2.5 cc Small Partition grey Cross Connection 480 ... 476 ... Test Plug-Soc. / Ins. Test Soc. TF itk Warning Label IP t5k with symbol without symbol Group Marking grey ge ge2 Technical Data • Max.clamping range / Max. technical data • Rated Impulse Voltage / Pollution severity • Insulation material group / Gauge pin code according to IEC 60947-1 • Protection class / Protection conductor type Marking Tags See pages 104 & 105 for further detail 16 0.2 - 4 mm² / 4 mm² - 32 A 8 kV / 3 1 / B3 IP 20 / - American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com
KL444120 价格&库存
很抱歉,暂时无法提供与“KL444120”相匹配的价格&库存,您可以联系我们找货
KL444120
  • 1+5.195131+0.67424
  • 10+4.3679510+0.56688
  • 25+4.0952125+0.53149
  • 50+3.9003950+0.50620
  • 100+3.71398100+0.48201
  • 300+3.43645300+0.44599
  • 500+3.31473500+0.43019
  • 1000+3.156421000+0.40965
  • 2500+2.958692500+0.38399
库存:861
