LPT141
LPT141
    AMERICANELECTRICAL(美国电气)
    LIGHTPOLE POWER TAP - UNTERMINAT
LPT141 数据手册
LPT-140 TEL: 804-379-2899 The Lightpole Power Tap (LPT-140), manufactured by Solis Energy, is an industrial-grade device that attaches to a photocell receptacle and reliably outputs power off of a streetlight or light pole. The LPT-140 features integrated surge protection, a UV-resistant enclosure built to withstand extreme weather conditions and temperature variations, a locking quick-connect adapter for easy cable changes in the field, and a rubber gasket underneath to protect the light pole’s socket from weather. It is a rugged, utility grade component designed for reliable, long term use. The LPT-140 is fully compatible with both ANSI C136.10 three conductor twist-lock photocell receptacles and ANSI C136.41 seven conductor twist-lock dimming photocell receptacles, and will not interfere with the functionality of photocell controllers. Voltage Range 0 – 305 VAC Input; 10 A Max Operating Temperature -40°C to 70°C Surge Protection Clamping Voltage: 1025 VAC Joule Rating: 380 J Host Connector ANSI C136.41: 7-Pin Dimming Photocell Connector Load Connector IP67 Twist-Lock Physical UV-Resistant Enclosure - 4” x 3.75” x 3.2” LPT-140 No Cable Included, Base Unit Only LPT-141 Includes Base Unit & 10’ Unterminated Cable LPT-142 Includes Base Unit & 25’ Unterminated Cable
LPT141 价格&库存
很抱歉,暂时无法提供与“LPT141”相匹配的价格&库存,您可以联系我们找货
