KL444420
KL444420
    AMERICANELECTRICAL(美国电气)
    CONN TERM BLK END PLATE BEIGE
KL444420 数据手册
MVK Series MVK 2.5 Width 5 mm 304 429 Mini Terminal Blocks for use with MVK type terminals are manu- 15mm wide DIN Rail MR 15 33.75 factured from thermoplastic raw material. Grey being the main color. 27.0 torque: 1.2 Nm Colors Terminals End Plate Part Number Part Number GREY BEIGE MVK 2.5 304 429 304 420 NPP 444 429 444 420 GREY BEIGE MVK 4 304 439 304 430 NPP 444 429 444 420 Electrical Ratings TSE / CE (EN 60947-7-1 / EN60947-7-2) UL atex Connection Data Solid Strand, Screw Con. - Fine Strand, Screw Con. AWG Conductor / Fine Strand with Ferrule Insulation Stripping Length / Torque Ordering Data Polyamide 66 grey yellow-Green End Bracket Thickness 8mm grey KD 5 End Plate - Disconnect Plate Width 1.5 mm Polyamide 66 grey yellow-Green Voltage/Current/Cross-section 400 V ~ / 24 A / 2.5 mm² 300 V ~ / 20 A / AWG 26-12 400 V ~ / 23 A 0.5 - 4 mm² / 0.5 - 4 mm² 16 - 8 / 0.5 - 2.5 mm² 12 mm / 1.2 Nm Type Part. No. MVK 2.5 304 429 Qty. 100 KD 5 495 069 100 NPP MVK 444 429 100 AD1 467 919 100 UK 2.5/2 UK 2.5/3 UK 2.5/4 UK 2.5/10 476 222 476 223 476 224 476 229 25 20 15 5 TF (Ø2) 493 020 5 IP 2 S IP 2 498 130 498 140 25 25 ge ge 2 496 119 496 250 50 25 Small Partition grey Cross Connection Test Plug-Soc. / Ins. Test Soc. TF itk Warning Label IP t5k with symbol without symbol Group Marking grey ge ge2 Technical Data • Max.clamping range / Max. technical data • Rated Impulse Voltage / Pollution severity • Insulation material group / Gauge pin code according to IEC 60947-1 • Protection class / Protection conductor type Marking Tags See pages 104 & 105 for further detail 20 0.2 - 4 mm² / 4 mm² / 32 A 6 kV / 3 1 / B3 IP 20 / - American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com
KL444420
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光隔离型光电开关。
2. 器件简介:EL817是一种采用光电子技术实现电信号隔离的光电开关,具有高隔离电压、低功耗、响应速度快等特点。
3. 引脚分配:EL817共有6个引脚,分别为VCC、OUT、GND、A、B和C。
4. 参数特性:工作电压为5V,工作电流为10mA,隔离电压为2.5kV,响应时间为1ms。
5. 功能详解:EL817通过光电转换实现电信号隔离,提高系统的抗干扰能力。
6. 应用信息:EL817广泛应用于工业自动化、电力系统、通信设备等领域。
7. 封装信息:EL817采用DIP6封装,尺寸为9.1mm x 9.1mm x 4.8mm。
KL444420 价格&库存
很抱歉,暂时无法提供与“KL444420”相匹配的价格&库存,您可以联系我们找货
KL444420
    • 1+8.04600
    • 200+3.20760
    • 500+3.09960
    • 1000+3.05640
