KL446440
KL446440
    AMERICANELECTRICAL(美国电气)
    CONN TERM BLK END PLATE BEIGE
KL446440 数据手册
American Electrical, Inc. Industrial Electrical Components 456 Southlake Blvd. • Richmond, VA 23236 • (804) 379-2899 • Fax: (804) 379-8935 Safe Circuits *Includes screwdriver and jumper* SC- AVK SC- PYK SC-MVK *Terminal block assembly only* SC-AVK-T SC-PYK-T SC- MVK-T Our new SAFE CIRCUITS product line is the innovative answer for safe, quality, wiring connections for up to 20 Amps (UL) per circuit. Forget open terminal barrier strips! SAFE CIRCUITS provide a finger safe, high quality connection that guarantees personnel safety and protects the assembly from outside objects that can interfere. SAFE CIRCUITS include a 10 pole terminal block assembly, a 10 pole jumper, and a screwdriver (also available with terminals only, see above). Available in the three following types 1. A standard size screw clamp version p/n SC-AVK 2. A standard size tension clamp version p/n SC-PYK 3. A miniature size screw clamp version p/n SC-MVK The circuits can handle 20 Amps each and are UL approved and recognized. If you need to have a common distribution of voltage or signals, the 10 pole jumper can easily be cut down to any size. The screwdriver has an ergonomic design so that the proper torque can be applied as well as fitting easily in your hand. All terminals are situated on a 5" piece of slotted DIN Rail for easy mounting. American Electrical, Inc. Industrial Electrical Components 456 Southlake Blvd. • Richmond, VA 23236 • (804) 379-2899 • Fax: (804) 379-8935
KL446440 价格&库存
很抱歉,暂时无法提供与“KL446440”相匹配的价格&库存,您可以联系我们找货
