LPF04025350LTT
LPF04025350LTT
    ATC
    0402 (1005公制)
    RF FILTER LOW PASS 4.242GHZ 0402
LPF04025350LTT 数据手册
ATC 0402 LPF SERIES THIN FILM LOW PASS FILTER ATC 0402 LPF Series LGA Thin Film Low Pass Filters Features: • Cut-Off Frequency (typ): 2484 MHz to 6000 MHz • Characteristic Impedance: 50Ω • Low Insertion Loss: 0.35 dB typ. • Operating Temp: -40˚C to +85˚C • Low Profile LGA/SMT EIA Package • Pb Free / RoHS Compliant Applications: • Wireless communications • WLAN’s (802.11) ATC’s 0402 LPF Series Thin Film SMT Low Pass Filters offer superb high frequency performance in a low profile LGA style EIA package. The LPF Series is offered in a broad range of selected cut-off frequencies making them well suited for wireless frequency applications. Their superb performance provides an excellent drop-in solution for the most critical filter applications. The LPF Series exhibits excellent passband insertion loss, stop-band rejection and matching characteristics. The LPF 0402 filter Series is fully tested to meet or exceed electrical, environmental and mechanical specifications. They are supplied in tape and reel making them fully compatible with high speed automated pick-and-place manufacturing. • Public Safety Radio (P25) • LTE • ISM • Global Navigation Satellite Systems (GNSS Part Number Passband (MHz) LPF04022484LT DC to 2484 LPF04022740LT DC to 2740 LPF04023600LT DC to 3600 LPF04025350LT DC to 5350 LPF04025650LT DC to 5650 LPF04026000LT DC to 6000 ATC # 001-1185 Rev. A, 6/18 ATC 0402 LPF SERIES THIN FILM LOW PASS FILTER Dimensions Size (EIA) Mechanical Configurations Length (L) .040 ±.002 (1.00 ±0.05) 0402 Width (W) .023 ±.002 (0.58 ±0.04) Thickness (T) .014 ±.002 (0.35 ±0.50) S B A inches (mm) A .008 ±.002 (0.20 ±0.06) B .007 ±.002 (0.18 ±0.05) L S .002 ±.002 (0.05 ±0.05) T inches (mm) W Top View Recommended Pad Layout 0.006 (0.15) IN GND IN GND OUT GND OUT GND 0.020 (0.51) 0.012 (0.30) 0.008 (0.20) ATC Part Number Code LPF 0402 2484 L T T Packaging T = Tape and Reel, std. Low Pass Filter Case Size: 4 digits Termination T = Tin Termination Passband: 4 digits Style: L = LGA, C = Chip The above part number refers to a Low Pass Filter, (EIA case size 0402), Passband DC to 2484 MHz, Land Grid Array (LGA) Style, Tin Termination ATC accepts orders for our parts using designations with or without the “ATC” prefix. Both methods of defining the part number are equivalent, i.e., part numbers referenced with the “ATC” prefix are interchangeable to parts referenced without the “ATC” prefix. Customers are free to use either in specifying or procuring parts from American Technical Ceramics. For additional information and catalogs contact your ATC representative or call direct at +1-631-622-4700. Consult factory for additional performance data. Sales of ATC products are subject to the terms and conditions contained in American Technical Ceramics Corp. Terms and Conditions of Sale (ATC document #001-992). Copies of these terms and conditions will be provided upon request. They may also be viewed on ATC’s website at www.atceramics.com/productfinder/default.asp. Click on the link for Terms and Conditions of Sale. ATC has made every effort to have this information as accurate as possible. However, no responsibility is assumed by ATC for its use, nor for any infringements of rights of third parties which may result from its use. ATC reserves the right to revise the content or modify its product line without prior notice. © 2016 American Technical Ceramics Corp. All Rights Reserved. ATC # 001-1185, Rev. A, 5/18 ATC 0402 LPF SERIES THIN FILM LOW PASS FILTER ATC LPF04022484L Passband 0 to 2484 MHz 0 -5 0 S(11) -10 -5 S(21) -15 -10 Magnitude (dB) Magnitude (dB) ATC LPF04022740L Passband 0 to 2740 MHz -20 -25 -30 -35 -40 -20 -25 -30 -35 S(11) -40 S(21) -45 -45 -50 -15 0 2 4 6 8 10 -50 12 0 2 4 6 ATC LPF04023600L Passband 0 to 3600 MHz 0 S(11) S(11) -15 -20 -25 -30 -35 -40 14 16 18 20 -20 -30 -40 S(11) S(21) -50 -45 -60 0 2 4 6 8 10 12 14 0 2 4 Frequency (GHz) ATC LPF04025650L Passband 0 to 5650 MHz 0 6 8 10 12 Frequency (GHz) ATC LPF04026000L Passband 0 to 6000 MHz 0 -5 -10 -10 -15 Magnitude (dB) Magnitude (dB) 12 -10 S(21) S(21) Magnitude (dB) Magnitude (dB) -10 -20 -25 S(11) -30 S(21) -35 -40 -45 -50 10 ATC LPF04025350L Passband 0 to 5350 MHz 0 -5 -50 8 Frequency (GHz) Frequency (GHz) 0 2 4 6 8 Frequency (GHz) 10 12 14 -20 -30 S(11) -40 S(21) -50 -60 0 2 4 6 8 10 12 14 Frequency (GHz) 16 18 20 14
LPF04025350LTT 价格&库存
很抱歉,暂时无法提供与“LPF04025350LTT”相匹配的价格&库存,您可以联系我们找货
