550U104MCAT
550U104MCAT
    ATC
    0.1 µF ±20% 6.3V 陶瓷电容器 0301(0803 公制)
550U104MCAT 数据手册
A T C 5 5 0 U S e r i e s u b C TM C A P A C I T O R S ATC 550U Series UBC Ultra-Broadband Capacitor TM Features: • 0301 Case Size • Capacitance: 100 nF • Operating Frequency: 16 KHz (-3 dB roll-off) to 40+ GHz* • Insertion Loss: 0.4 dB typical • One Piece Construction • Voltage Rating: 6.3 WVDC • RoHS Compliant Terminations • Gold Terminations Available Advantages ATC’s new 550U Ultra-Broadband Capacitor is manufactured with highest quality materials to provide reliable and repeatable Ultra-Broadband performance from 16 KHz through 40+ GHz. It exhibits ultra-low insertion loss, flat frequency response and excellent return loss, and is ideal for D.C. Blocking, Coupling, Bypassing and Feedback applications requiring Ultra-Broadband performance. The 550U is a one-piece 0301 SMT package, fully compatible with high speed automated pick-and-place manufacturing. It is designed to meet the most stringent requirements of Ultra-Broadband applications. • Transimpedance amplifiers • ROSA/TOSA† • Flat Frequency Response • SONET†† • Excellent Return Loss • Broadband Test Equipment • Unit-to-Unit Performance Repeatability • Broadband Microwave/ millimeter-wave • Rugged Ceramic Construction †Receive and Transmit Optical Sub-Assembly ††Synchronous Optical Network *25 °C, no bias applied ATC 550U Series Return Loss (S11) 0 -10 -0.5 -20 Magnitude (dB) Magnitude (dB) • Optoelectronics/High Speed Data • Ultra-Low Insertion Loss ATC 550U Series Insertion Loss (S21) 0.0 Applications: • Ultra-Broadband performance -1.0 -1.5 -2.0 0 5 10 15 20 25 -40 -50 (Typical) -2.5 -30 (Typical) 30 35 40 -60 0 5 10 15 20 25 30 35 40 Frequency (GHz) Frequency (GHz) ATC 550U Data Sheet Test Condition Description ATC testing to 40 GHz performed on 10-mil-thick Rogers RO3006 microstrip board, with the device under test subtending a 10 mil gap in a 13.4-mil-wide center trace (nominal 50-ohm characteristic impedance). ATC # 001-1127 Rev. E; 5/14 A T C 5 5 0 U S e r i e s u b c TM C A P A C I T O R S Mechanical Dimensions Electrical Specifications: • Capacitance: 100 nF • Rated Voltage: 6.3 WVDC • Dielectric Withstanding Voltage (DWV): 250% of rated WVDC for 5 secs. 0.005 in. ± 0.002 in. (0.13 mm ± 0.05 mm) 0.013 in. ± 0.002 in. (0.33 mm ± 0.05 mm) • Operating Temperature Range: -55°C to +85°C • Temperature Coefficient of Capacitance (TCC): ±15% • Insulation Resistance: 1010 Ω min. @ +25°C @ rated WVDC 109 Ω min. @ +85°C @ rated WVDC 0.015 in. ± 0.002 in. (0.38 mm ± 0.05 mm) 0.034 in. ± 0.002 in. (0.86 mm ± 0.05 mm) ATC PART NUMBER CODE ATC 550 U 104 M T T Series Tape and Reel: 500, 1000 and 4000 pieces on 3’’ reel. Case Size: (0301) Capacitance Code: Termination Code First 2 significant digits for capacitance T = Tin Plated over Nickel Barrier R=Decimal Point (Standard) CA = Gold Plated over Nickel Barrier Capacitance Tolerance M = 20% The above part number refers to a 550 Series (case size U) 100 nF capacitor, M tolerance (±20%), with T termination (Tin Plated over Nickel Barrier), tape and reel packaging. ATC accepts orders for our parts using designations with or without the “ATC” prefix. Both methods of defining the part number are equivalent, i.e., part numbers referenced with the “ATC” prefix are interchangeable to parts referenced without the “ATC” prefix. Customers are free to use either in specifying or procuring parts from American Technical Ceramics. For additional information and catalogs contact your ATC representative or call direct at (+1-631) 622-4700. Consult factory for additional performance data. Sales of ATC products are subject to the terms and conditions contained in American Technical Ceramics Corp. Terms and Conditions of Sale (ATC document #001-992 Rev. A 10/03). Copies of these terms and conditions will be provided upon request. They may also be viewed on ATC’s website at www.atceramics. com/productfinder/default.asp. Click on the link for Terms and Conditions of Sale. ATC has made every effort to have this information as accurate as possible. However, no responsibility is assumed by ATC for its use, nor for any infringements of rights of third parties which may result from its use. ATC reserves the right to revise the content or modify its product line without prior notice. © 2009 American Technical Ceramics Corp. All Rights Reserved. ATC # 001-1127 Rev. E; 5/14
550U104MCAT 价格&库存
很抱歉,暂时无法提供与“550U104MCAT”相匹配的价格&库存,您可以联系我们找货
