QB1111A40ESTD
QB1111A40ESTD
    ATC
    THERMAL CONDUCTOR Q-BRIDGE
QB1111A40ESTD 数据手册
ATC Q-BRIDGE THERMAL CONDUCTOR ATC Q-Bridge Thermal Conductor ATC’s new Q-Bridge Thermal Conductor is manufactured with the highest quality materials for reliable and repeatable performance providing a cost effective thermal management solution. These devices are constructed with Aluminum Nitride (AlN) or Beryllium Oxide (BeO) and are available in standard EIA form factors. Q-Bridge provides the designer with the ability to manage thermal conditions by directing heat to a thermal ground plane, heat sink or any other specific thermal point of interest. The inherently low capacitance makes this device virtually transparent at RF / microwave frequencies. This device has the added benefit of offering additional layers of protection to adjacent components from hot spot thermal loads. Q-Bridge provides the benefit of increased overall circuit reliability. ATC’s Q-Bridge is manufactured using one-piece construction, providing a RoHS compliant SMT package that is fully compatible with high speed automated pick-and-place processing. It is available in various EIA case sizes. Custom configurations are also available. Applications: • GaN Power Amplifiers • High RF Power Amplifiers • Filters • Synthesizers • Industrial Computers • Switch Mode Power Supplies • Pin & Laser Diodes Features: • High Thermal Conductivity Functional Applications: • Low Thermal Resistance • Between active device and adjacent ground planes • Low Capacitance • Specific contact pad to case • Increases Circuit Reliability • Contact pad to contact pad • RoHS Compliant • Direct component contact to via pad or trace • More efficient thermal management • Edges fully metalized Termination Materials ATC Termination Code Termination Materials Y Silver Platinum Non-Magnetic Termination S Silver over Magnetic Termination Note: Non-edge wrapped style in all case sizes is supplied with S termination Edge wrapped style in case sizes 0302 through 1111 is supplied with Y termination Edge wrapped style in case sizes 2010 through 3737 are supplied with S termination ATC # 001-1143 Rev. H, 7/17 ATC Q-BRIDGE THERMAL CONDUCTOR t t Mechanical Configurations W L W L T T Edge Wrapped No Wrap Typical Characteristics Case Size Length (L) Width (W) Thickness (T) Terminal (t) 20 (0.51 ±.05) 10 (0.25) Thermal Thermal Resistance (°C/W) Conductivity (mW/°C) Available Configurations Termination Y 0302 19 12 53 81 S Y .040 ±.002 .020 ±.002 20 10 0402 25 16 40 61 (1.02 ±.051) (0.51 ±.051) (0.51 ±.05) (0.25) S Y .050 ±.002 .050 ±.002 25 15 0505 10 7 100 153 (1.27 ± .051) (1.27 ±.051) (0.64 ±.05) (0.38) S Y .060 ±.002 .030 ±.002 25 15 0603 20 13 50 76 (1.52 ±.051) (.76 ±.051) (0.64 ±.05) (0.38) S Y .080 ±.002 .050 ±.002 40 20 0805 10 7 100 153 (2.03 ±.051) (1.27 ±.051) (1.02 ±.05) (0.51) S Y .100 ±.002 .050 ±.002 40 20 1005 13 8 77 122 (2.54 ±.051) (1.27 ±.051) (1.02 ±.05) (0.51) S Y .100 ±.002 .200 ±.002 40 20 3 2 320 508 1020 (2.54 ±.051) (5.08 ±.051) (1.02 ±.05) (0.51) S Y .110 ±.002 .110 ±.002 40 20 7 4 153 240 1111 (2.79 ±.051) (2.79 ±.051) (1.02 ±.05) (0.51) S S .195 ±.010 .095 ±.010 60 30 2010 10 6 100 159 (4.95 ±.254) (2.41 ±.254) (1.52 ±.05) (0.77) S S .240 ±.010 .250 ±.010 60 40 2525 4 3 240 380 (6.10 ±.254) (6.35 ±.254) (1.52 ±.05) (1.02) S S .370 ±.010 .245 ±.010 60 50 3725 6 4 160 254 (9.40 ±.254) (6.22 ±.254) (1.52 ±.05) (1.27) S S .365 ±.010 .375 ±.010 60 50 3737 4 3 240 380 (9.27 ±.254) (9.53 ±.254) (1.52 ±.05) (1.27) S inches (mm) Note: Thermal conductivity is normalized to chip size. All values are approximate. Consult factory for extended thermal conductivity options. .030 ±.002 (.77 ±.051) .020 ±.002 (0.51 ±.051) AlN BeO AlN BeO Style W E W E W E W E W E W E W E W E W E W E W E W E ATC Q-BRIDGE THERMAL CONDUCTOR ATC Part Number Code QB 0603 A 25 W Y T Packaging T = Tape and Reel, std. 1000 pc., 7” Reel 500 pc., 7” Reel C = ATC Matrix Tray Q-Bridge Case Size Substrate A = AlN; B = BeO Termination Y = Silver Platinum Non-Magnetic Termination S = Silver over Magnetic Termination Thickness (mils) Style: W = Edge Wrap; E = No Wrap The above part number refers to a Q-Bridge, (EIA case size 0603), Aluminum Nitride (AlN) substrate, Thickness 25 mils., Style W, Y Termination (Silver Platinum Non-Magnetic Termination), with Tape and Reel Packaging. ATC accepts orders for our parts using designations with or without the “ATC” prefix. Both methods of defining the part number are equivalent, i.e., part numbers referenced with the “ATC” prefix are interchangeable to parts referenced without the “ATC” prefix. Customers are free to use either in specifying or procuring parts from American Technical Ceramics. For additional information and catalogs contact your ATC representative or call direct at +1-631-622-4700. Consult factory for additional performance data. Sales of ATC products are subject to the terms and conditions contained in American Technical Ceramics Corp. Terms and Conditions of Sale (ATC document #001-992). Copies of these terms and conditions will be provided upon request. They may also be viewed on ATC’s website at www.atceramics.com/productfinder/default.asp. Click on the link for Terms and Conditions of Sale. ATC has made every effort to have this information as accurate as possible. However, no responsibility is assumed by ATC for its use, nor for any infringements of rights of third parties which may result from its use. ATC reserves the right to revise the content or modify its product line without prior notice. © 2015 American Technical Ceramics Corp. All Rights Reserved. ATC # 001-1143, Rev. H, 7/17
QB1111A40ESTD 价格&库存
很抱歉,暂时无法提供与“QB1111A40ESTD”相匹配的价格&库存,您可以联系我们找货
