BLCR-L01D-U2
BLCR-L01D-U2
    ALLSENSORS
    6-SMD,鸥翼,顶部端口
    压力计 压力 压力传感器±0.04PSI(±0.25kPa) 公型 - 0.12"(3mm)管 0mV ~ 8mV 6-SMD,鸥翼,顶部端口
BLCR-L01D-U2 数据手册
Technology itself reduces package stress susceptibility resulting in improved overall long term stability. The technology also vastly improves position sensitivity to nearly unmeasurable levels. This series is intended for use with non-corrosive, non-ionic working fluids such as air, dry gases and the like. The output is also ratiometric to the supply voltage and is operable from 1.8 to 3.3 volts DC. Signed Original On File R ±1 inH2O (249 Pa) 100 inH2O (25 KPa) 150 inH2O (37 KPa) BLCR-L05D ±5 inH2O (1,245 Pa) 200 inH2O (50 KPa) 300 inH2O (75 KPa) BLCR-L10D ±10 inH2O (2,491 Pa) 200 inH2O (50 KPa) 300 inH2O (75 KPa) BLCR-L20D ±20 inH2O (4,982 Pa) 200 inH2O (50 KPa) 500 inH2O (125 KPa) BLCR-L30D ±30 inH2O (7,472 Pa) 200 inH2O (50 KPa) 800 inH2O (200 KPa) Pressure Sensor Maximum Ratings Environmental Specifications Supply Voltage (Vs) 5 Vdc Common Mode Pressure 5 psig Lead Temperature (soldering 2-4 sec.) 270 °C All Sensors Temperature Ranges Operating Storage Humidity Limits DS-0354 Rev E -25 to 85 °C -40 to 125 °C 0 to 95% RH (non condensing) R Page 1 Signed Original O Original On File www.allsensors.com BLCR-L01D www.allsensors.com R Burst Pressure R Proof Pressure Signed Original On File Operating Range www.allsensors.com Device all sensors f 408 225 2079 traditional equivalent basic sensing elements. This lower supply voltage gives rise to improved warm-up shift while the CoBeam2 e www.allsensors.com incorporates All Sensors CoBeam2 Technology to reduce the overall supply voltage while maintaining comparable output levels to p 408 225 4314 Signed Original On File The BLCR Series Basic Sensor is based on a Dual Die Reference technology to reduce all output offset or common mode errors. It also a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Signed Original On F R www.allsensors.com General Description R R • Medical Instrumentation • Environmental Controls • HVAC Signed Original On File Applications www.allsensors.com www.allsensors.com • 0 to 1 inH2O to 0 to 30 inH2O Pressure Ranges • Low Supply Voltage (1.8V to 3.3V) • 0.1% Linearity Typical • Improved Front to Back Linearity • Intrinsically No Position Sensitivity • Improved Warm-Up Shift Distribution • Parylene Coating Available Upon Request • Reduced TCO R Features Standard Pressure Ranges ors.com w.allsensors.com Signed Original On File BLCR Series Low Voltage Pressure Sensors Signed Original On F R ±10.0 ±0.2 0.1 100.0 - - ±0.5 - μV μV %FSS μS 2, 6 3 - Front to Back Linearity Temperature Effect on Resistance (0°C-70°C) - - 0.25 2800 - - %FSS ppm/°C 5 - Temperature Effect on Span (0°C-70°C) Input Resistance Output Resistance - - - -2000 1.7 1.7 - - - ppm/°C k Ω k Ω - Specification Notes note 1: Shift is relative to 25°C. note 2: Shift is within the first hour of excitation applied to the device. note 3: Measured at one-half full scale rated pressure using best straight line curve fit. note 4: The span is the algebraic difference between full scale output voltage and the offset voltage. Lin  Span PortB  − 1 ⋅100%  BLCR Warmup Shift (Typical) OS Normalized to first Reading (mV) 0.025 0.015 0.005 -0.005 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 -0.015 -0.025 R Signed Original On File 1 Hrs BLCR Series Low Pressure Compact Sensors R Page 2 Signed Original O Soldering Recommendations 1) Solder parts as a second operation only. 2) Post reflow, wait for 36 hrs before performing any calibration operations. 3) Perform spot cleaning as necessary only by hand. DO NOT wash or submerge device in cleaning liquid. www.allsensors.com Original On File 4 Signed Original On File R Notes www.allsensors.com www.allsensors.com Units - - - - FB  5: Front-Back Linerity computed as:  Span PortA note 6: Typical warm up characteristics as shown below. R Max Offset Warm-up Shift Offset Position Sensitivity (1g) Linearity, Hysteresis Error Response Time (10% to 90% Pressure Response) note ors.com Typ R Signed Original On File www.allsensors.com Min Output Span (FSS) L01D 4.5 8.0 11.5 mV L05D 13.5 24.0 34.5 mV L10D 18.0 32.0 46.0 mV L20D 22.0 38.0 55.0 mV L30D 25.0 42.0 60.0 mV Offset Voltage @ Zero Diff. Pressure - - ±10.0 mV Offset Temperature Shift (0°C-70°C) - ±4.0 - μV/ °C Signed Original On File R Parameter R All parameters are measured at 3.3 volt excitation and room temperature unless otherwise specified. Pressure measurements are with positive pressure applied to PORT B (the only port for the single port configuration). www.allsensors.com www.allsensors.com w.allsensors.com Signed Original On File Performance Characteristics for BLCR Series Pin .551 14 .512 13 3 2 1 .572 14.5 5 TITLE: SIZE A D-Series Package FILE NAME D1 Package Pin .581 14.75 .512 13 .216 5.50 .364 9.25 .581 14.75 Port B 12 3 4 5 6 .226 5.74 TYP .255 6.48 .446 11.32 .025 0.64 SQUARE TYP Port A Definition 1 VsA 2 -Vout 3 VsR 4 -VoutR 5 GND 6 +VoutA .220 5.59 Vs -Vout .500 12.7 2X all sensors All Sensors NOTES 1) Dimensions are in inches [mm]. 2) Pins 1 & 3 must be connected for Vs input. 3) Pins 4 & 6 must be connected for +Vout output. 4) For suggested pad layout, see drawing: PAD-20. .118 3 2 1 6 3 A R 4 .062 1.57 .256 6.5 5 .059 1.5 All Sensors DS-0354 Rev E +Vout All Sensors TITLE: SIZE A D-Series Package FILE NAME D3 Package R Page 3 Signed Original O NOTES 1) Dimensions are in inches [mm]. 2) Pins 1 & 3 must be connected for Vs input. 3) Pins 4 & 6 must be connected for +Vout output. 4) For suggested pad layout, see drawing: PAD-21. GND R Signed Original On File +Vout www.allsensors.com Original On File GND f 408 225 2079 .200 5.1 e www.allsensors.com .528 13.4 p 408 225 4314 Signed Original On File www.allsensors.com Port A TYP .157 4 .640 16.25 .320 8.125 4 R R R 3 Signed Original On File www.allsensors.com +VoutA www.allsensors.com R GND 6 A D3 Package ors.com 5 2 1 Port B 6 .100 2.6 .100 2.54 -VoutR -Vout .040 [1] TYP .145 3.7 .018 0.5 TYP VsR 4 Vs .217 5.5 .100 2.5 3 Signed Original On File .045 1.1 .062 1.6 -Vout .374 9.5 .066 1.7 .088 2.2 .381 9.7 VsA 2 www.allsensors.com R 4 5 6 Definition 1 a 16035 Vineyard Blvd. Morgan Hill, CA 95037 R Signed Original On F D1 Package R www.allsensors.com w.allsensors.com Signed Original On File Package Drawings R Signed Original On F D4 Package .104 2.6 .102 2.6 .050 1.3 9 .197 5 .008 0.2 7 GND +Vout .118 3 .098 2.5 .296 7.5 TYP 6 R .087 2.2 .142 3.6 .032 0.8 .407 10.3 -OutA 2 N/C 3 N/C 4 N/C 5 GndA 6 -OutR 7 GndR 8 N/C 9 N/C 10 +OutR 11 N/C 12 +VsR 13 +OutA 14 N/C 15 N/C 16 +VsA .093 2.4 NOTES 1) Dimensions are in inches [mm]. 2) Pins 12 and 16 must be connected for Vs input. 3) Pins 5 and 7 must be connected for Gnd. 4) Pins 1 and 10 must be connected for -Vout. 5) Pins 6 and 13 must be connected for +Vout. 6) For suggested pad layout, see drawing: PAD-22. All Sensors TITLE: SIZE A D-Series Package FILE NAME D4 Package Original On File www.allsensors.com R R Signed Original O Page 4 www.allsensors.com BLCR Series Low Pressure Compact Sensors R Signed Original On File Signed Original On File www.allsensors.com ors.com R Signed Original On File .016 0.4 .039 1 A 5 PIN 1 12 10 Definition 1 Signed Original On File R 13 1 Pin www.allsensors.com www.allsensors.com 16 .350 8.9 .209 5.3 Vs -Vout 8 16 R TYP R www.allsensors.com w.allsensors.com Signed Original On File Package Drawings (Cont’d) 2 1 6 5 .200 5.1 GND +Vout All Sensors NOTES 1) Dimensions are in inches [mm]. 2) Pins 1 & 3 must be connected for Vs input. 3) Pins 4 & 6 must be connected for +Vout output. 4) For suggested pad layout, see drawing: PAD-23. TITLE: SIZE A U-Series Package FILE NAME U1 Package U2 Package 1 2 3 .043 1.1 .276 7 Pin Definition 1 VsA 2 -Vout .024 0.6 .406 10.3 .024 0.6 .276 7 .100 2.5 TYP .031 0.8 TYP VsR 4 -VoutR 5 GND 6 +VoutA Vs .200 5.1 -Vout .118 3 2 1 3 .020 0.5 6 .236 6 A R 4 .010 0.3 5 DS-0354 Rev E All Sensors TITLE: SIZE A U-Series Package FILE NAME U2 Package R Page 5 Signed Original O All Sensors +Vout www.allsensors.com NOTES 1) Dimensions are in inches [mm]. 2) Pins 1 & 3 must be connected for Vs input. 3) Pins 4 & 6 must be connected for +Vout output. 4) For suggested pad layout, see drawing: PAD-24 GND R 6 5 4 Port B 3 e www.allsensors.com .020 0.5 TYP .100 2.5 TYP Signed Original On File Original On File 4 R .122 3.1 .138 3.5 R 3 A .010 0.3 ors.com +VoutA all sensors Port B .378 9.6 GND 6 -Vout .236 6 2-5 -VoutR 5 Vs .039 1 .008 0.2 TYP 4 f 408 225 2079 .118 3 VsR p 408 225 4314 Signed Original On File .335 8.5 3 www.allsensors.com Signed Original On File 4 5 6 -Vout a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Signed Original On F R www.allsensors.com R 3 2 1 VsA 2 R www.allsensors.com .335 8.5 Definition 1 Signed Original On File R Pin R U1 Package www.allsensors.com www.allsensors.com w.allsensors.com Signed Original On File Package Drawings (Cont’d) Signed Original On F R Signed Original On File www.allsensors.com Where: Pressure Range (D1, D3, D4 Packages — Differential Only): L01D, L05D, L10D, L20D, L30D Pressure Range (U1, U2 Package — Gage Only): L01D, L05D, L10D, L20D, L30D (Consult with factory for parylene coating) Packaging TUBE Original On File ors.com R Page 6 Signed Original O BLCR Series Low Pressure Compact Sensors www.allsensors.com R www.allsensors.com ALL PRODUCTS FOUND IN THIS DATASHEET ARE PACKAGED IN TUBES WITH PIN 1 ORIENTED TOWARDS THE WHITE STOPPER. R Signed Original On File www.allsensors.com Signed Original On File Package: Pressure Type Dependent R R Pressure Range Signed Original On File www.allsensors.com Product Series Code - D1 R BLCR - L01D www.allsensors.com R w.allsensors.com Signed Original On File How To Order all sensors Example shown above. Pressure Tubing Recommendations Tubing Number 1 2 Part Number ABX00002 ABX00004 Package D1 D3 D4 U1 U2 Tubing Number 1 2 1 2 2 Description Versilic SPX-50, 1/16" I.D. x 1/8" O.D. x 1/32" Wall Versilic SPX-50, 3/32" I.D. x 5/32" O.D. x 1/32" Wall e www.allsensors.com Signed Original On File Lot Number p 408 225 4314 Signed Original On File a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Original On File www.allsensors.com R R ors.com R Signed Original O Page 7 www.allsensors.com DS-0354 Rev E Signed Original On File All Sensors www.allsensors.com f 408 225 2079 Signed Original On F R www.allsensors.com Wafer Number R R Part Number Signed Original On File www.allsensors.com Company R All Sensors BLCR-L01D-D1 B12399-09 R16A24-14 www.allsensors.com R w.allsensors.com Signed Original On File Product Identification (on backside of device) [1.0] 0.37 [ 9.4] 0.024 [0.6] 0.100 [2.54] PAD-21 PAD-20 PAD-22 0.1 [2.54] 0.1 [2.54] 0.1 [2.54] 0.127 [3.23] 0.06 [1.5] 0.127 [3.23] 0.4 [10.2] 0.4 [10.2] 0.032 [0.8] 0.127 [3.23] 0.039 [1.0] 0.047 [1.2] diam, 2 plcs R Signed Original On File 0.10 [2.54] Signed Original On File www.allsensors.com 0.100 (Typ) [2.54] www.allsensors.com R 0.551 [14.0] 0.040 [1.0] (Typ) 0.079 [ 2.0] 0.05 [1.27] (TYP) [2.4] 0.094 R Signed Original On F 0.039 R www.allsensors.com w.allsensors.com Signed Original On File Suggested Pad Layout PAD-24 Original On File Page 8 R ors.com BLCR Series Low Pressure Compact Sensors Signed Original O All Sensors reserves the right to make changes to any products herein. All Sensors does not assume any liability arising out of the application or use of any product or circuit described herein, neither does it convey any license under its patent rights nor the rights of others. www.allsensors.com R www.allsensors.com Dimensions are in inches [mm]. R Signed Original On File Signed Original On File PAD-23 www.allsensors.com R 0.1 [2.54] 0.127 [3.23]
BLCR-L01D-U2 价格&库存
很抱歉,暂时无法提供与“BLCR-L01D-U2”相匹配的价格&库存,您可以联系我们找货
