DLC-L05G-U2
DLC-L05G-U2
    ALLSENSORS
    6-SMD,鸥翼,顶部端口
    压力计 压力 压力传感器±0.18PSI(±1.25kPa) 公型 - 0.12"(3mm)管 16 b 6-SMD,鸥翼,顶部端口
DLC-L05G-U2 数据手册
Environmental Specifications . . . . . . . . . . . . . . . . . . . . . . 2 Equivalent Circuit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Standard Pressure Ranges . . . . . . . . . . . . . . . . . . . . . . . . 3 Performance Characteristics. . . . . . . . . . . . . . . . . . . . . 4 Soldering Recommendations. . . . . . . . . . . . . . . . . . . . 4 I2C Electrical Parameters. . . . . . . . . . . . . . . . . . . . . . . . . 5 Operation Overview .. . . . . . . . . . . . . . . . . . . . . . . . . 6-7 Digital Interface Command & Data Formats. . . 7-8 I2C Interface ................................ . . . . ...8-10 How to Order Guide........................ . . . . . . . . 11 Standard Part Number Configurations.... . . . . . . . . 11 Product Identification Guide............... . . . . . . . . 12 Dimensional Package Drawings Differential SMT, SML and SOIC...13-14 The low supply voltage allows for integration of the sensors into a wide range of process control and measurement systems, as well as direct connection to I2C serial communications channels. The DLC series offers 16 bit digital resolution. The digital interface options ease integration of the sensors into a wide range of process control and measurement systems, allowing direct connection to serial communications channels. For battery-powered systems, the sensors can enter very low-power modes between readings to minimize load on the power supply. These calibrated and compensated sensors provide accurate, stable output over a wide temperature range. This series is intended for use with non-corrosive, non-ionic working fluids such as air and dry gases. Gage DIP and SMT . . . . . . . . . . . . . . . . . . . . . . . 15 A bsolute SMT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Packing Options................................16 Pressure Tubing Recommendations.......17 Suggested Pad Layouts .......................17 All Sensors DS-0365 Rev A Page 1 f 408 225 2079 Pressure Sensor Maximum Ratings . . . . . . . . . . . . . . . 2 p 408 225 4314 Features & Applications . . . . . . . . . . . . . . . . . . . . . . . . . . 2 The DLC Series Compact High Resolution Sensor is based on All Sensors’ CoBeam2 TM Technology. This reduces package stress susceptibility, resulting in improved overall long term stability. This technology breakthrough advances the state of the art for piezoresistive pressure sensors beyond what has been achieved for low pressure sensing using silicon based strain technology. Design engineers will find exceptional space savings with optimal performance for various compact applications. a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Introduction Table of Contents e www.allsensors.com all sensors DLC - Compact High Resolution Pressure Sensors Series DLC — Compact High-Resolution Pressure Sensors all sensors Features • Pressure Ranges from 1 inH2O to 150 psi • High Resolution 16 bit Output • Digital I2C Interface • 1.8V to 3.6V Supply Voltage Range • Compact Package Sizes As Small As 7mm x 7mm Supply Voltage (Vs) Common Mode Pressure 3.63 Vdc 10 psig Environmental Specifications Temperature Ranges Compensated Operating Storage -25°C to 85 °C -40°C to 85 °C -40°C to 125 °C a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Humidity Limits (non condensing) 0 to 95% RH Equivalent Circuit Vs SCL I2C SDA EOC Gnd See package drawings for pinouts All Sensors Table of Contents p 408 225 4314 Pressure Sensor Maximum Ratings f 408 225 2079 e www.allsensors.com Applications • Medical Breathing • Industrial Controls • HVAC • Environmental Controls • Portable Equipment DS-0365 Rev A Page 2 Standard Pressure Ranges Low Pressure Products Device Operating Range A Proof Pressure Burst Pressure DLC-L01D ± 1 inH2O 248.84 Pa 100 inH2O 24.88 kPa 300 inH2O 74.65 kPa DLC-L02D ± 2 inH2O 497.68 Pa 100 inH2O 24.88 kPa 300 inH2O 74.65 kPa DLC-L05D ± 5 inH2O 1,244.20 Pa 200 inH2O 49.77 kPa 300 inH2O 74.65 kPa DLC-L10D ± 10 inH2O 2,488.40 Pa 200 inH2O 49.77 kPa 300 inH2O 74.65 kPa DLC-L20D ± 20 inH2O 4,976.80 Pa 200 inH2O 49.77 kPa 500 inH2O 124.42 kPa DLC-L30D ± 30 inH2O 7,465.20 Pa 200 inH2O 49.77 kPa 500 inH2O 124.42 kPa DLC-L60D ± 60 inH2O 14,930.4 Pa 200 inH2O 49.77 kPa 800 inH2O 199.01 kPa DLC-L01G 0 to 1 inH2O 248.84 Pa 100 inH2O 24.88 kPa 300 inH2O 74.65 kPa DLC-L02G 0 to 2 inH2O 497.68 Pa 100 inH2O 24.88 kPa 300 inH2O 74.65 kPa DLC-L05G 0 to 5 inH2O 1,244.20 Pa 200 inH2O 49.77 kPa 300 inH2O 74.65 kPa DLC-L10G 0 to 10 inH2O 2,488.40 Pa 200 inH2O 49.77 kPa 300 inH2O 74.65 kPa DLC-L20G 0 to 20 inH2O 4,976.80 Pa 200 inH2O 49.77 kPa 500 inH2O 124.42 kPa DLC-L30G 0 to 30 inH2O 7,465.20 Pa 200 inH2O 49.77 kPa 500 inH2O 124.42 kPa DLC-L60G 0 to 60 inH2O 14,930.4 Pa 200 inH2O 49.77 kPa 800 inH2O 199.01 kPa High Pressure Products Device Operating Range A Proof Pressure Burst Pressure DLC-005D ± 5 psi 34.47 kPa 10 psi 68.95 kPa 15 psi 103.42 kPa DLC-015D ± 15 psi 103.42 kPa 30 psi 206.84 kPa 45 psi 310.26 kPa DLC-030D ± 30 psi 206.84 kPa 60 psi 413.69 kPa 90 psi 620.53 kPa DLC-100D ± 100 psi 689.48 kPa 200 psi 1,378.95 kPa 225 psi 1,551.32 kPa DLC-150D ± 150 psi 1,034.20 kPa 225 psi 1,551.32 kPa 225 psi 1,551.32 kPa DLC-005G 0 to 5 psi 34.47 kPa 10 psi 68.95 kPa 15 psi 103.42 kPa DLC-015G 0 to 15 psi 103.42 kPa 30 psi 206.84 kPa 45 psi 310.26 kPa DLC-030G 0 to 30 psi 206.84 kPa 60 psi 413.69 kPa 90 psi 620.53 kPa DLC-100G 0 to 100 psi 689.48 kPa 200 psi 1,378.95 kPa 225 psi 1,551.32 kPa DLC-150G 0 to 150 psi 1,034.20 kPa 225 psi 1,551.32 kPa 225 psi 1,551.32 kPa DLC-015A 0 to 15 psia 1.03 barA 30 psi 2.06 barA 45 psi 3.10 barA DLC-030A 0 to 30 psia 2.06 barA 60 psi 4.14 barA 90 psi 6.20 barA DLC-100A 0 to 100 psia 6.89 barA 200 psi 13.79 barA 225 psi 15.51 barA DLC-150A 0 to 150 psia 10.34 barA 225 psi 15.51 barA 225 psi 15.51 barA Note A: Operating range in Pa is expressed as an approximate value. DLC — Compact High Resolution Pressure Sensors Table of Contents Page 3 Performance Characteristics for DLC Series All parameters are measured at 3.3V ±5% excitation and 25C unless otherwise specified (Note 6). Pressure measurements are with positive pressure applied to PORT B. Output Span (FSS) LxxD (All Packages) - ±0.4 * 224 - Dec Counts LxxG (U2 Package) - 0.4 * 224 - Dec Counts LxxG (All Other Packages) - 0.8 * 224 - Dec Counts 0xxD (All Packages) - - Dec Counts 24 24 ±0.4 * 2 0xxG (All Packages) - 0.8 * 2 - Dec Counts 0xxA (U5 Package) - 0.8 * 224 - Dec Counts Specification Notes 1 Offset Output @ Zero Diff. Pressure (Osdig) 24 LxxD (All Packages) - 0.5 * 2 - Dec Counts LxxG (U2 Package) - 0.5 * 224 - Dec Counts LxxG (All Other Packages) - 24 - Dec Counts 24 - Dec Counts 24 - Dec Counts 24 0.1 * 2 0xxD (All Packages) - 0.5 * 2 0xxG (All Packages) - 0.1 * 2 0xxA (U5 Package) - 0.1 * 2 - Dec Counts - - ±3.00 ±2.00 ±1.25 ±1.00 ±1.00 %FSS %FSS %FSS %FSS %FSS 15.3 15.5 - bit Temperature Output Resolution Overall Accuracy - 16 2 - bit °C Supply Current Requirement During Active State (ICCActive) During Idle State (ICCIdle) - 2.0 100 2.5 250 mA nA Power On Delay - - 2.5 ms 3 ms 3, 4 Total Error Band L01G L01D, L02G L02D, L05G, L05D, L10G, L10D, L20G L20D, L30G, L30D, L60G, L60D All Higher Pressure 2 Pressure Digital Resolution - No Missing Codes 16-bit Option - 3, 4, 5 Data Update time (tDU) Calibrated Resolution 16 bit (see table below) Single Typ 3.70 Max 4.1 Average2 Typ Max 7.20 8.0 Measurement Command Average4 Average8 Typ Max Typ Max 14.20 15.7 28.20 31.1 Average16 Typ Max 56.20 61.9 Units ms Soldering Recommendations 1) Solder parts as a second operation only. 2) Post reflow, wait for 48 hrs before performing any calibration operations. 3) Perform spot cleaning as necessary only by hand. DO NOT wash or submerge device in cleaning liquid. All Sensors Table of Contents DS-0365 Rev A Page 4 all sensors Units e www.allsensors.com Maximum f 408 225 2079 Typical p 408 225 4314 Minimum a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Parameter I2C Electrical Parameters for DLC Series Parameter Symbol Min Typ Max Units Notes Input High Level - 80.0 - 100 % of Vs 5 Input Low Level - 0 - 20.0 % of Vs 5 Output Low Level - - - 10.0 % of Vs 5 I2C Pull-up Resistor - 1000 - - I2C Load Capacitance on SDA, @ 400 kHz CSDA I2C Input Capacitance (each pin) Ω 5 - - 200 pF 5 CI2C_IN - - 10.0 pF 5 I2C Address 41 decimal Pressure Output Transfer Function 𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑑𝑑𝑑𝑑𝑑𝑑 − 𝑂𝑂𝑂𝑂𝑑𝑑𝑑𝑑𝑑𝑑 𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃(𝑖𝑖𝑖𝑖𝐻𝐻2 𝑂𝑂) = 1.25 × � � × 𝐹𝐹𝐹𝐹𝐹𝐹(𝑖𝑖𝑖𝑖𝐻𝐻2 𝑂𝑂) 224 Where: 𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑑𝑑𝑑𝑑𝑑𝑑 Is the sensor 24-bit digital output. 𝑂𝑂𝑂𝑂𝑑𝑑𝑑𝑑𝑑𝑑 Is the specified digital offset output. (see Performance Characteristics Table) 𝐹𝐹𝐹𝐹𝐹𝐹(𝑖𝑖𝑖𝑖𝐻𝐻2 𝑂𝑂) The sensor Full Scale Span in inches H2O For Gage Operating Range sensors: Full Scale Pressure For Differential Operating Range sensors: 2 x Full Scale Pressure. Temperature Output Transfer Function 𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇 (℃) = � Where: 𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑑𝑑𝑑𝑑𝑑𝑑 𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑑𝑑𝑑𝑑𝑑𝑑 ∗ 150 � − 40 224 The sensor 24-bit digital temperature output. (Note that only the upper 16 bits are significant) Specification Notes note 1: THE SPAN IS THE ALGEBRAIC DIFFERENCE BETWEEN FULL SCALE DECIMAL COUNTS AND THE OFFSET DECIMAL COUNTS. THE FULL SCALE PRESSURE IS THE note 2: TOTAL ERROR BAND CONSISTS OF OFFSET AND SPAN TEMPERATURE AND CALIBRATION ERRORS, LINEARITY AND PRESSURE HYSTERESIS ERRORS, OFFSET note 3: PARAMETER IS CHARACTERIZED AND NOT 100% TESTED. note 4: DATA UPDATE TIME IS EXCLUSIVE OF COMMUNICATIONS, FROM COMMAND RECEIVED TO END OF BUSY STATUS. THIS CAN BE OBSERVED AS EOC PIN note 5: AVERAGE CURRENT CAN BE ESTIMATED AS : ICCIdle + ((tDU / Reading Interval) * ICCActive)). REFER TO FIGURE 2 FOR ACTIVE AND IDLE CONDITIONS OF THE note 6: THE SENSOR IS CALIBRATED WITH A 3.3V SUPPLY HOWEVER, AN INTERNAL REGULATOR ALLOWS A SUPPLY VOLTAGE OF 1.8V TO 3.6V TO BE USED WITH- MAXIMUM POSITIVE CALIBRATED PRESSURE. WARM-UP SHIFT AND OFFSET POSITION SENSITIVITY ERRORS. LOW- STATE DURATION. SENSOR (THE ACTIVE STATE IS WHILE EOC PIN IS LOW). OUT AFFECTING THE OVERALL SPECIFICATIONS. THIS ALLOWS DIRECT OPERATION FROM A BATTERY SUPPLY. Note 7: CALIBRATED WITH CONTINOUS READS. DLC — Compact High Resolution Pressure Sensors Table of Contents Page 5 Device Ordering Options Operation Overview The DLC is a digital sensor with a signal path that includes a sensing element, a variable- bit analog to digital converter, a DSP and an IO block that supports an I2C interface (see Figure 1 below). The sensor also includes an internal temperature reference and associated control logic to support the configured operating mode. Since there is a single ADC, there is also a multiplexer at the front end of the ADC that selects the signal source for the ADC. Sensor Commands: Five Measurement commands are supported, returning values of either a single pressure / temperature reading or an average of 2, 4, 8, or 16 readings. Each of these commands wakes the sensor from Idle state into Active state, and starts a measurement cycle. For the Start-Average commands, this cycle is repeated the appropriate numper of times, while the Start-Single command performs a single iteration. When the DSP has completed calculations and the new values have been made available to the I/O block, the sensor returns to Idle state. The sensor remains in this low-power state until another Measurement command is received. After completion of the measurement, the result may then be read using the Data Read command. The ADC and DSP remain in Idle state, and the I/O block returns the 7 bytes of status and measurement data. See Figure 2, following. At any time, the host may request current device status with the Status Read command. See Table 1 for a summary of all commands. For optimum sensor performance, All Sensors recommends that Measurement commands be issued at a fixed interval by the host system. Irregular request intervals may increase overall noise on the output. Furthermore, if reading intervals are much slower than the Device Update Time, using the Averaging commands is suggested to reduce offset shift. This shift is constant with respect to time interval, and may be removed by the application. For longer fixed reading intervals, this shift may be removed by the factory on special request. All Sensors Table of Contents DS-0365 Rev A Page 6 p 408 225 4314 The DSP receives the converted pressure and temperature information and applies a multi-order transfer function to compensate the pressure output. This transfer function includes compensation for span, offset, temperature effects on span, temperature effects on offset and second order temperature effects on both span and offset. There is also linearity compensation for gage devices and front to back linearity compensation for differential devices. a 16035 Vineyard Blvd. Morgan Hill, CA 95037 The ADC performs conversions on the raw sensor signal (P), the temperature reference (T) and a zero reference (Z) during the ADC measurement cycle. f 408 225 2079 e www.allsensors.com Figure 1 - DLC Essential Model all sensors Output Resolution Calibrated output resolution of 16 bits. See the Data Update Time in the Performance Characteristics table. Operation Overview Figure 2 - DLC Communication Model Start-Single Command Command Start-Single Internal State Idle Interal Operation Idle Data Read Active ADC (Temp, Zero, Pressure) Start-Single Active Idle DSP Idle ADC (Temp, Zero, Pressure) Idle Idle DSP New Data Available EOC Start-Average2 / 4 / 8 / 16 Commands (Auto Averaging) Command Data Read Start-Average2/4/8/16 Internal State Idle Interal Operation Idle Active ADC (Temp, Zero, Pressure)1 ADC (Temp, Zero, Pressure)n DSP Start-Average2/4/8/16 Idle Active Idle ADC (T, Z, P)… New Data Available EOC Digital Interface Command Formats When requesting sensor status over I2C, the host simply performs a 1-byte read transfer. When reading sensor data over I2C, the host simply performs a 7-byte read transfer. See Table 1 below for Measurement Commands, Sensor Data read and Sensor Status read details. Table 1 - DLC Sensor Command Set Measurement Commands Description I2C Start-Single Start-Average2 0xAA Start-Average4 0xAD Start-Average8 0xAE Start-Average16 0xAF 0xAC Read Sensor Data I2C Read of 7 bytes from device Read Sensor Status I2C Read of 1 byte from device. DLC — Compact High Resolution Pressure Sensors Table of Contents Page 7 Digital Interface Data Format all sensors For either type of digital interface, the format of data returned from the sensor is the same. The first byte consists of the Status Byte followed by a 24-bit unsigned pressure value and a 24-bit unsigned temperature value. Unused bits beyond the calibrated bit width are undefined, and may have any value. See the Pressure Output Transfer Function and Temperature Output Transfer Function definitions on page 3 for converting to pressure and temperature. Refer to Table 2 for the overall data format of the sensor. Table 3 shows the Status Byte definition. Note that a completed reading without error will return status 0x40. Table 2 - Output Data Format S[7:0] Status Byte P[23:16] Pressure MSB P[15:8] Pressure Byte 1 P[7:0] Pressure LSB T[23:16] Temperature MSB T[15:8] Temperature Byte 1 T[7:0] Temperature LSB Table 3- Status Byte Definition I2C Interface I2C Command Sequence The part enters Idle state after power-up, and waits for a command from the bus master. Any of the five Measurement commands may be sent, as shown in Table 1. Following receipt of one of these commands, the EOC pin is set to Low level, and the sensor Busy bit is set in the Status Byte. After completion of measurement and calculation in the Active state, compensated data is written to the output registers, the EOC pin is set high, and the processing core goes back to Idle state. The host processor can then perform the Data Read operation, which for I2C is simply a 7-byte Device Read. If the EOC pin is not monitored, the host can poll the Status Byte by repeating the Status Read command, which for I2C is a one-byte Device Read. When the Busy bit in the Status byte is zero, this indicate that valid data is ready, and a full Data Read of all 7 bytes may be performed. All Sensors Table of Contents DS-0365 Rev A Page 8 p 408 225 4314 f 408 225 2079 e www.allsensors.com Description [Always = 0] Power : [1 = Power On] Busy: [ 1 = Processing Command, 0 = Ready] Mode: [00 = Normal Operation ] Memory Error [ 1 = EEPROM Checksum Fail] Sensor Configuration [ always = 0] ALU Error [1 = Error] a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Bit Bit 7 [MSB] 6 5 4:3 2 1 Bit 0 [LSB] I2C Interface (Cont’d) I2C Bus Communications Overview The I2C interface uses a set of signal sequences for communication. The following is a description of the supported sequences and their associated mnemonics. Refer to Figure 3 for the associated usage of the following signal sequences. Bus not Busy (I): During idle periods both data line (SDA) and clock line (SCL) remain HIGH. START condition (ST): A HIGH to LOW transition of SDA line while the clock (SCL) is HIGH is interpreted as START condition. START conditions are always set by the master. Each initial request for a pressure value has to begin with a START condition. Slave address (An): The I²C-bus requires a unique address for each device. The DLC sensor has a preconfigured slave address (see specification table on Page 3). After setting a START condition the master sends the address byte containing the 7 bit sensor address followed by a data direction bit (R/W). A “0” indicates a transmission from master to slave (WRITE), a “1” indicates a device-to master request (READ). Acknowledge (A or N): Data is transferred in units of 8 bits (1 byte) at a time, MSB first. Each data-receiving device, whether master or slave, is required to pull the data line LOW to acknowledge receipt of the data. The Master must generate an extra clock pulse for this purpose. If the receiver does not pull the data line down, a NACK condition exists, and the slave transmitter becomes inactive. The master determines whether to send the last command again or to set the STOP condition, ending the transfer. DATA valid (Dn): State of data line represents valid data when, after a START condition, data line is stable for duration of HIGH period of clock signal. Data on line must be changed during LOW period of clock signal. There is one clock pulse per data bit. STOP condition (P): LOW to HIGH transition of the SDA line while clock (SCL) is HIGH indicates a STOP condition. STOP conditions are always generated by the master. Figure 3 - I2C Communication Diagram 1. Measurement Commands: Start-Single ( to start reading of single sample): Start-Single C7…C0: 0xAA Start-Average2 C7…C0: 0xAC Start-Average4 C7…C0: 0xAD Start-Average8 C7…C0: 0xAE Start-Average16 C7…C0: 0xAF Set by bus master: Set by sensor: I ST A6 A5 A4 A3 A2 A1 A0 W I ST A6 A5 A4 A3 A2 A1 A0 R I ST A6 A5 A4 A3 A2 A1 A0 R A C7 … C0 N SP I SP I 2. Status Read: Set by bus master: Set by sensor: A S7 … S0 N 3. Data Read: Set by bus master: Set by sensor: Bus states: Idle: Start: Stop: Ack: Nack: “Read” bit (1): “Write” bit (0): I ST SP A N R W Sensor Address: A6 … A0 Default: 0x78 A S7 … S0 A A P23 … P16 A P15 … P8 A P7 … P0 A T23 … T16 A T15 … T8 N SP I T7 … T0 Data bits: Status: Pressure data: Temperature data: S7 … S0 P23 … P0 T23 … T0 Command Bits: C7 … C0 DLC — Compact High Resolution Pressure Sensors Table of Contents Page 9 Interface Timing Diagram Figure 4 - I2C Timing Diagram tH STA tHIGH tLOW all sensors SCL SDA MIN 100 1.3 0.6 0.6 0.6 0.1 0 0.6 2.0 tSUS TP TYP - tIDLE MAX 400 - UNITS KHz us us us us us us us us e www.allsensors.com SYMBOL fSCL tLOW tHIGH tSUSTA tHSTA tSUDAT tHDAT tSUSTP tIDLE tH DAT a 16035 Vineyard Blvd. Morgan Hill, CA 95037 p 408 225 4314 PARAMETER SCL frequency SCL low width SCL high width Start condition setup Start condition hold Data setup to clock Data hold to clock Stop condition setup Bus idle time tSUDAT f 408 225 2079 tSUS TA All Sensors Table of Contents DS-0365 Rev A Page 10 How to Order Refer to Table 5 for standard part numbers offered which includes the pressure range and package. Example P/N with options: DLC-L05D-D4 Table 4 - Part Numbering Scheme: DLC - L05 D - D4 Package: Output Mode: Output Mode D — Differential Dependent G — Gage A — Absolute Package Dependent Product Pressure Series Code Range Where: Pressure Range (D1, D3, D4 Package): All Differential Pressure Ranges Pressure Range (U1, U2 Package): All Gage Pressure Ranges Pressure Range (U5 Package): All Absolute Pressure Ranges Low Pressure Products DLC DLC DLC DLC DLC DLC DLC - L01 L02 L05 L10 L20 L30 L60 D D D D D D D - D1 D1 D1 D1 D1 D1 D1 DLC DLC DLC DLC DLC DLC DLC - L01 L02 L05 L10 L20 L30 L60 D D D D D D D - D3 D3 D3 D3 D3 D3 D3 DLC DLC DLC DLC DLC DLC DLC - L01 L02 L05 L10 L20 L30 L60 D D D D D D D - D4 D4 D4 D4 D4 D4 D4 High Pressure Products DLC DLC DLC DLC DLC - 005 015 030 100 150 D D D D D - D1 D1 D1 D1 D1 DLC DLC DLC DLC DLC - 005 015 030 100 150 D D D D D - D3 D3 D3 D3 D3 DLC DLC DLC DLC DLC - 005 015 030 100 150 D D D D D - D4 D4 D4 D4 D4 Low Pressure Products DLC DLC DLC DLC DLC DLC DLC - L01 L02 L05 L10 L20 L30 L60 G G G G G G G - U1 U1 U1 U1 U1 U1 U1 DLC DLC DLC DLC DLC DLC DLC - L01 L02 L05 L10 L20 L30 L60 G G G G G G G - U2 U2 U2 U2 U2 U2 U2 High Pressure Products U Packages D Packages Table 5 - Standard Part Number Configurations DLC DLC DLC DLC DLC - 005 015 030 100 150 G G G G G - U1 U1 U1 U1 U1 DLC DLC DLC DLC DLC - 005 015 030 100 150 G G G G G - U2 U2 U2 U2 U2 DLC DLC DLC DLC - 015 030 100 150 A A A A - U5 U5 U5 U5 DLC — Compact High Resolution Pressure Sensors Table of Contents Page 11 Product Identification on backside of device All products are labeled via laser marking as seen in Figure 5. Figure 6 details how to interpret the part marking code. Low pressure ranges from 1 to 60 inH2O are specified with code “L” and 5 to 150 psi high pressure products with code “H”. all sensors The pressure range will be indicated on the same line as the wafer number before the starting character “B”. Example: DLC-L05D-D4 Pressure Range Identifier 5 i nH2O 10 i nH2O 20 i nH2O 30 i nH2O Company Part Marking e www.allsensors.com 2 i nH2O All Sensors DLC-L-D4 5-B12399-09 R16A24-14 Wafer Number Lot Number f 408 225 2079 1 i nH2O DLC - L - D4 Figure 6: Part Marking Series Op�on Pressure Range Identifier Option 1 Pressure Type Identifier Option L 2 5 10 20 30 60 5 15 30 100 150 L L L L L L H H H H H All Sensors Table of Contents Pressure Type Identifier Pressure Range 1 inH2O 2 inH2O 5 inH2O 10 inH2O 20 inH2O 30 inH2O 60 inH2O 5 PSI 15 PSI 30 PSI 100 PSI 150 PSI p 408 225 4314 DLC Package Op�on Descrip�on U1 DIP, Single Top Port, Gage pressure U2 SMT, Single Top Port, Gage pressure U5 D1 SMT, No Port, Absolute pressure Jogged SMT Leads, Dual Port, Same Side, Differen�al pressure D3 SML Leads, Dual Port, Opposite Side, Differen�al pressure D4 SOIC, Differen�al pressure DS-0365 Rev A Page 12 a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Figure 5: Product Labeling n Des cri p on Package Drawings D1 Package Pin .551 14 .512 13 3 21 .572 14.5 4 56 .374 9.5 .066 1.7 .088 2.2 .045 1.1 .381 9.7 Definition 1 N/C 2 SCL 3 SDA 4 EOC 5 VDD 6 VSS .040 [1] TYP Port B .145 3.7 .217 5.5 .100 2.6 .062 1.6 .100 2.5 TYP Port A .018 0.5 TYP .528 13.4 .157 4 .200 5.1 All Sensors TITLE: NOTES 1) Dimensions are in inches [mm]. 2) For suggested pad layout, see drawing: PAD-20. SIZE A D-Series Package FILE NAME D1 Package D3 Package Pin .640 16.25 .320 8.125 .581 14.75 .512 13 .216 5.50 .364 9.25 .581 14.75 Port B 12 345 6 .226 5.74 .100 2.54 TYP .255 6.48 .446 11.32 .025 0.64 SQUARE TYP Port A Definition 1 N/C 2 SCL 3 SDA 4 EOC 5 VDD 6 VSS .220 5.59 .500 12.7 2X .118 3 .062 1.57 .256 6.5 .059 1.5 All Sensors TITLE: NOTES 1) Dimensions are in inches [mm]. 2) For suggested pad layout, see drawing: PAD-21. SIZE A D-Series Package FILE NAME D3 Package DLC — Compact High Resolution Pressure Sensors Table of Contents Page 13 Package Drawings (Cont’d) D4 Package 13 8 VDDB .350 8.9 .209 5.3 SCL 5 4 SDA 6 EOC 16 10 .039 1 PIN 1 16 .016 0.4 TYP .118 3 .098 2.5 .296 7.5 .197 5 .008 0.2 Gnd .087 2.2 .142 3.6 .032 0.8 .407 10.3 Pin Definition 1 INP 2 N/C 3 VSSB 4 SDA 5 SCL 6 EOC 7 N/C 8 N/C 9 N/C 10 VSS 11 VDD 12 N/C 13 VDDB 14 INN 15 N/C 16 VDDB .093 2.4 All Sensors TITLE: SIZE A D-Series Package FILE NAME D4 Package a 16035 Vineyard Blvd. Morgan Hill, CA 95037 p 408 225 4314 NOTES 1) Dimensions are in inches [mm]. 2) For suggested pad layout, see drawing: PAD-22 3) Sensors in this package require handling in accordance with MSL3. 4) Do not connect any signal to Pins 1, 3 & 14. 5) PCB must connect Pin 13 to Pin 16. all sensors 9 Vs 11 e www.allsensors.com .102 2.6 .050 1.3 TYP f 408 225 2079 .104 2.6 All Sensors Table of Contents DS-0365 Rev A Page 14 Package Drawings (Cont’d) U1 Package Pin .335 8.5 3 2 1 4 5 6 .335 8.5 .118 3 Definition 1 N/C 2 SCL 3 SDA 4 EOC 5 VDD 6 VSS .039 1 .236 6 Port B .008 0.2 TYP .122 3.1 2-5 .020 0.5 TYP .100 2.5 TYP .378 9.6 .200 5.1 All Sensors TITLE: NOTES 1) Dimensions are in inches [mm]. 2) For suggested pad layout, see drawing: PAD-23. SIZE A U-Series Package FILE NAME U1 Package U2 Package 1 2 3 .043 1.1 .276 7 Pin .024 0.6 .406 10.3 .024 0.6 6 5 4 Port B .276 7 .118 3 .100 2.5 TYP .031 0.8 TYP Definition 1 N/C 2 SCL 3 SDA 4 EOC 5 VDD 6 VSS .200 5.1 .020 0.5 .236 6 .010 0.3 .010 0.3 .138 3.5 All Sensors TITLE: NOTES 1) Dimensions are in inches [mm]. 2) For suggested pad layout, see drawing: PAD-24. SIZE A U-Series Package FILE NAME U2 Package DLC — Compact High Resolution Pressure Sensors Table of Contents Page 15 Package Drawings (Cont’d) Pin 7 .276 0.8 .031 TYP 10.3 .406 Definition 1 N/C 2 SCL 3 SDA 4 EOC 5 VDD 6 VSS 3.5 .138 0.25 .010 0.25 .010 e www.allsensors.com 0.5 .020 5.8 .228 All Sensors 5.8 .228 NOTES 1) Dimensions are in inches [mm]. 2) For suggested pad layout, see drawing: PAD-24. 3) Absolute pressure only. TITLE: SIZE A all sensors 7 .276 U-Series Package FILE NAME U5 Package Packing Options a 16035 Vineyard Blvd. Morgan Hill, CA 95037 p 408 225 4314 TUBE f 408 225 2079 2.54 .100 TYP U5 Package ALL PRODUCTS FOUND IN THIS DATASHEET ARE PACKAGED IN TUBES. (Consult with factory for the option to ship in trays) All Sensors Table of Contents DS-0365 Rev A Page 16 Pressure Tubing Recommendations Tubing Number 1 2 Recommended Tubing Sizes 1/16" I.D. x 1/8" O.D. x 1/32" Wall 3/32" I.D. x 5/32" O.D. x 1/32" Wall Package D1 D3 D4 U1 U2 U5 Tubing Number 1 2 2 2 2 N/A Suggested Pad Layouts [1.0] 0.100 (Typ) [2.54] 0.10 [2.54] 0.37 [ 9.4] 0.551 [14.0] 0.040 [1.0] (Typ) 0.079 [ 2.0] 0.05 [ 1.27] ( TYP) [2.4] 0.094 0.039 0.024 [ 0.6] 0.100 [2.54] PAD-21 PAD-20 PAD-22 0.1 [2.54] 0.1 [2.54] 0.1 [2.54] 0.127 [3.23] 0.06 [1.5] 0.127 [3.23] 0.4 [10.2] 0.4 [10.2] 0.032 [0.8] 0.127 [3.23] 0.039 [1.0] 0.047 [1.2] diam, 2 plcs 0.1 [2.54] 0.127 [3.23] PAD-23 PAD-24 Dimensions are in inches [mm]. All Sensors reserves the right to make changes to any products herein. All Sensors does not assume any liability arising out of the application or use of any product or circuit described herein, neither does it convey any license under its patent rights nor the rights of others. DLC — Compact High Resolution Pressure Sensors Table of Contents Page 17
DLC-L05G-U2 价格&库存
很抱歉,暂时无法提供与“DLC-L05G-U2”相匹配的价格&库存,您可以联系我们找货
DLC-L05G-U2
  • 1+284.639221+37.00218
  • 5+260.818145+33.90552
  • 10+251.9441610+32.75193
  • 25+241.3342125+31.37267
  • 50+234.0746250+30.42895
  • 100+227.41337100+29.56301
库存:1
