BLC-L01D-U2
BLC-L01D-U2
    ALLSENSORS
    6-SMD,鸥翼,顶部端口
    压力计 压力 压力传感器±0.04PSI(±0.25kPa) 公型 - 0.12"(3mm)管 0mV ~ 8mV 6-SMD,鸥翼,顶部端口
BLC-L01D-U2 数据手册
Signed Original On F www.allsensors.com Features • 0 to 1 inH2O to 0 to 30 inH2O and 15 PSIA Pressure Ranges • uPower Low Supply Voltage (0.9V to 1.8V) • 0.1% Linearity Typical • Improved Front to Back Linearity • Less Position Sensitivity • Improved Warm-Up Shift Distribution • Parylene Coating Available Upon Request equivalent basic sensing elements. This lower supply voltage gives rise to improved warm-up shift while the CoBeam2 Technology itself reduces package stress susceptibility resulting in improved overall long term stability. The technology also vastly improves position sensitivity compared to conventional single die devices. This series is intended for use with non-corrosive, non-ionic working fluids such as air, dry gases and the like. The output is also ratio- ±1 inH2O (250 Pa) 100 inH2O (25 KPa) 150 inH2O (37 KPa) BLC-L05D ±5 inH2O (1,250 Pa) 200 inH2O (50 KPa) 300 inH2O (75 KPa) BLC-L10D ±10 inH2O (2,500 Pa) 200 inH2O (50 KPa) 300 inH2O (75 KPa) BLC-L20D ±20 inH2O (5,000 Pa) 200 inH2O (50 KPa) 500 inH2O (125 KPa) BLC-L30D ±30 inH2O (7,500 Pa) 200 inH2O (50 KPa) 800 inH2O (200 KPa) 60 PSI (4 barA) 120 PSI (8 barA) BLC-015A 0 to 15 PSIA (1 barA) Pressure Sensor Maximum Ratings Environmental Specifications Supply Voltage (Vs) 3 Vdc Common Mode Pressure 5 psig Lead Temperature (soldering 2-4 sec.) 270 °C All Sensors Temperature Ranges Operating Storage Humidity Limits all sensors p 408 225 4314 Signed Original On File BLC-L01D -25 to 85 °C -40 to 125 °C 0 to 95% RH (non condensing) DS-0353 Rev F Page 1 R Original On File www.allsensors.com Burst Pressure Signed Original O R Proof Pressure www.allsensors.com ors.com Operating Range R Device Signed Original On File R Standard Pressure Ranges www.allsensors.com f 408 225 2079 metric to the supply voltage and is operable from 0.9 to 1.8 volts DC. e www.allsensors.com signal at a low operating voltage and reduces the overall supply voltage while maintaining comparable output levels to traditional a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Signed Original On File R The BLC Series Basic Low Pressure Compact Sensor is based on All Sensors’ CoBeam2 TM Technology. The device provides a high output R www.allsensors.com General Description Signed Original On File • Medical Instrumentation • Environmental Controls • HVAC • Portable / Hand Held Devices www.allsensors.com Applications R R w.allsensors.com Signed Original On File BLC Series Low Pressure Compact Sensors Signed Original On File - - - ±30.0 ±30.0 ±20.0 0.10 100 ±10.0 mV ±10.0 mV - μ V/°C 1 - μ V 2, 6 - μ V ±0.50 %FSS 3 - μ S - Front to Back Linearity - 0.25 - %FSS 5 Temperature Effect on Resistance (0°C-70°C) - 2800 - ppm/°C - Temperature Effect on Span (0°C-70°C) - -2000 - ppm/°C - Input Resistance - 3.4 - k Ω - Output Resistance - 3.4 - k Ω - Specification Notes note 1: Shift is relative to 25°C. note 2: Shift is within the first hour of excitation applied to the device. note 3: Measured at one-half full scale rated pressure using best straight line curve fit. note 4: The span is the algebraic difference between full scale output voltage and the offset voltage.  Span PortB  Lin FB  − 1 ⋅100% 5: Front-Back Linerity computed as:  Span PortA  note 6: Typical warm up of characteristics as shown below. note BLC Warmup Shift (Typical) 0.050 0.030 0.010 -0.010 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 -0.030 BLC Series Low Pressure Compact Sensors R Page 2 Signed Original O Soldering Recommendations 1) Solder parts as a second operation only. 2) Post reflow, wait for 36 hrs before performing any calibration operations. 3) Perform spot cleaning as necessary only by hand. DO NOT wash or submerge device in cleaning liquid. www.allsensors.com Hrs R Signed Original On File 4 Signed Original On File Original On File Notes - - - - - - - OS Normalized to first Reading (mV) Signed Original On F R www.allsensors.com R Units R www.allsensors.com Max www.allsensors.com R Typ L01D, L05D, L10D, L20D, L30D (@ Zero Diff. Pressure) 015A (@ 0 PSIA) Offset Temperature Shift (0°C-70°C) Offset Warm-up Shift Offset Position Sensitivity (1g) Linearity, Hysteresis Error Response Time (10% to 90% Pressure Response) -0.050 ors.com Min Output Span (FSS) L01D 4.5 8.0 11.5 mV L05D 13.5 24.0 34.5 mV L10D 18.0 32.0 46.0 mV L20D 22.0 38.0 55.0 mV L30D 25.0 42.0 60.0 mV 015A 70.0 95.0 120.0 mV Offset Voltage Signed Original On File R Parameter R All parameters are measured at 1.8V excitation and room temperature unless otherwise specified. Pressure measurements are with positive pressure applied to Port B (the only port for the single port configuration.) www.allsensors.com www.allsensors.com w.allsensors.com Signed Original On File Performance Characteristics for BLC Series .551 14 .512 13 3 2 1 .572 14.5 -GND all sensors -Vout 6 .145 3.7 Port B .217 5.5 .100 2.6 .062 1.6 .100 2.5 .018 0.5 TYP .157 4 Port A TYP .528 13.4 .200 5.1 All Sensors TITLE: SIZE A D-Series Package FILE NAME D1 Package .640 16.25 .320 8.125 .581 14.75 .512 13 .216 5.50 .364 9.25 .581 14.75 Port B 12 3 4 5 6 .100 2.54 TYP .255 6.48 .446 11.32 Port A Definition 1 +GND 2 +Vout 3 Vs 4 N/C 5 -Vout 6 -GND .220 5.59 .500 12.7 2X .118 3 .062 1.57 .256 6.5 .059 1.5 Original On File A D-Series Package FILE NAME D3 Package DS-0353 Rev F Page 3 R ors.com All Sensors SIZE Signed Original O NOTES 1) Dimensions are in inches [mm]. 2) For suggested pad layout, see drawing: PAD-21. 3) Pins 1 and 6 must be connected for Gnd. www.allsensors.com R All Sensors TITLE: R .226 5.74 .025 0.64 SQUARE TYP Pin p 408 225 4314 NOTES 1) Dimensions are in inches [mm]. 2) For suggested pad layout, see drawing: PAD-20. 3) Pins 1 and 6 must be connected for Gnd. Signed Original On File Signed Original On File 5 www.allsensors.com R N/C .040 [1] TYP D3 Package www.allsensors.com Vs 4 e www.allsensors.com .381 9.7 +Vout f 408 225 2079 .045 1.1 2 3 R Signed Original On File .066 1.7 .088 2.2 +GND Signed Original On File www.allsensors.com .374 9.5 Definition 1 www.allsensors.com R 4 5 6 Pin a 16035 Vineyard Blvd. Morgan Hill, CA 95037 R Signed Original On F D1 Package R www.allsensors.com w.allsensors.com Signed Original On File Package Drawings R Signed Original On F D4 Package .104 2.6 .102 2.6 .050 1.3 9 8 .350 8.9 .016 0.4 .039 1 .118 3 .098 2.5 .296 7.5 .197 5 .008 0.2 TYP .087 2.2 .142 3.6 .032 0.8 .407 10.3 N/C 3 N/C 4 N/C 5 GND 6 N/C 7 N/C 8 N/C 9 N/C 10 N/C 11 N/C 12 N/C 13 +Vout 14 N/C 15 N/C 16 Vs All Sensors .093 2.4 TITLE: NOTES 1) Dimensions are in inches [mm]. 2) For suggested pad layout, see drawing: PAD-22. -Vout 2 SIZE A D-Series Package FILE NAME D4 Package Original On File www.allsensors.com R R Signed Original O Page 4 www.allsensors.com BLC Series Low Pressure Compact Sensors R Signed Original On File Signed Original On File www.allsensors.com ors.com R Signed Original On File PIN 1 Definition 1 Signed Original On File www.allsensors.com 16 Pin www.allsensors.com R .209 5.3 R TYP R www.allsensors.com w.allsensors.com Signed Original On File Package Drawings (Cont’d) Pin .043 1.1 .024 0.6 .406 10.3 .031 0.8 TYP .200 5.1 .118 3 .020 0.5 .236 6 .010 0.3 .010 0.3 All Sensors TITLE: NOTES 1) Dimensions are in inches [mm]. 2) For suggested pad layout, see drawing: PAD-24 3) Pins 1 and 6 must be connected for Gnd. SIZE A U-Series Package FILE NAME U2 Package .283 7.2 Pin .039 1 1 2 3 MAX .323 8.2 .283 7.2 .374 9.5 6 5 4 .098 2.5 .197 5 Port B .010 0.3 N/C 2 -Vout 3 -GND 4 +GND 5 +Vout 6 Vs 4 TYP .138 3.5 .020 0.5 TYP .100 2.5 .200 5.1 Original On File R A U-Series Package FILE NAME U3 Package DS-0353 Rev F Page 5 R ors.com All Sensors SIZE Signed Original O NOTES 1) Dimensions are in inches [mm]. 2) For suggested pad layout, see drawing: PAD-25 3) Pins 3 and 4 must be connected for Gnd. www.allsensors.com All Sensors TITLE: R .157 4 Definition 1 p 408 225 4314 .138 3.5 Signed Original On File Signed Original On File -GND www.allsensors.com R -Vout 6 TYP U3 Package www.allsensors.com 5 all sensors .100 2.5 .276 7 N/C R Signed Original On File Port B Vs 4 Signed Original On File www.allsensors.com 6 5 4 3 www.allsensors.com R .024 0.6 +Vout e www.allsensors.com .276 7 +GND 2 f 408 225 2079 1 2 3 Definition 1 a 16035 Vineyard Blvd. Morgan Hill, CA 95037 R Signed Original On F U2 Package R www.allsensors.com w.allsensors.com Signed Original On File Package Drawings (Cont’d) R Signed Original On F U4 Package .160 4.1 Signed Original On File R +GND 5 -GND 6 -Vout 7 N/C 8 Vs 4 TYP .100 2.5 8 .010 0.3 .028 0.7 .240 6.1 .050 1.3 TYP .150 3.8 All Sensors NOTES 1) Dimensions are in mm [inches]. 2) Offered for 015A only. 3) For suggested pad layout, see drawing: PAD-26 4) Pins 4 and 5 must be connected for Gnd. TITLE: SIZE A U-Series Package FILE NAME U4 Package How To Order Refer to Table 1 for configuring a standard base part number which includes the pressure range and package. Example P/N with options: BLC-L01D-D1 Table 1 - How to Configure a Part Number BLC - L01D Product Series Code Pressure Range - D1 Package: Pressure Type Dependent BLC Series Low Pressure Compact Sensors R Page 6 Signed Original O (Consult with factory for parylene coating) www.allsensors.com Where: Pressure Range (D1, D3, D4 Packages — Differential Only): L01D, L05D, L10D, L20D, L30D Pressure Range (U2, U3 Package — Gage Only): L01D, L05D, L10D, L20D, L30D Pressure Range (U4 Package — Absolute Only): 015A R Signed Original On File N/C 4 Signed Original On File Original On File 3 R www.allsensors.com .070 1.8 +Vout www.allsensors.com R .016 0.4 N/C 2 Signed Original On File www.allsensors.com 8 7 6 5 Definition 1 www.allsensors.com R .030 0.8 1 2 3 4 .200 5.1 ors.com Pin R www.allsensors.com w.allsensors.com Signed Original On File Package Drawings (Cont’d) Lot Number all sensors Example shown above. Pressure Tubing Recommendations Part Number ABX00002 ABX00004 Package D1 D3 D4 U2 U3 U4 Tubing Number 1 2 1 2 1 N/A Description Versilic SPX-50, 1/16" I.D. x 1/8" O.D. x 1/32" Wall Versilic SPX-50, 3/32" I.D. x 5/32" O.D. x 1/32" Wall e www.allsensors.com Tubing Number 1 2 Original On File p 408 225 4314 a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Signed Original On File R www.allsensors.com R ors.com R Page 7 Signed Original O DS-0353 Rev F www.allsensors.com All Sensors R ALL PRODUCTS FOUND IN THIS DATASHEET ARE PACKAGED IN TUBES WITH PIN 1 ORIENTED TOWARDS THE WHITE STOPPER. Signed Original On File TUBE www.allsensors.com Packaging R Signed Original On File Wafer Number f 408 225 2079 Signed Original On F R www.allsensors.com Part Number Signed Original On File R Company R All Sensors BLC-L01D-D1 B12399-09 R16A24-14 www.allsensors.com www.allsensors.com w.allsensors.com Signed Original On File Product Identification (on backside of device) 0.05 [ 1.27] ( TYP) 0.37 [ 9.4] 0.100 [2.54] PAD-21 PAD-20 0.1 [2.54] 0.047 [1.2] diam, 2 plcs 0.071 [ 1.8] 0.1 [2.54] 0.1 [2.54] 0.05 [ 1.27] ( TYP) PAD-25 PAD-26 Original On File Page 8 R ors.com BLC Series Low Pressure Compact Sensors Signed Original O All Sensors reserves the right to make changes to any products herein. All Sensors does not assume any liability arising out of the application or use of any product or circuit described herein, neither does it convey any license under its patent rights nor the rights of others. www.allsensors.com R www.allsensors.com Dimensions are in inches [mm]. R Signed Original On File PAD-24 0.236 [ 6.0] 0.032 [0.8] [8.5] 0.335 0.127 [3.23] 0.06 [1.5] 0.4 [10.2] 0.127 [3.23] 0.024 [ 0.6] 0.127 [3.23] www.allsensors.com Signed Original On File PAD-22 0.039 [1.0] 0.1 [2.54] 0.127 [3.23] R 0.024 [ 0.6] R Signed Original On File 0.10 [2.54] Signed Original On File www.allsensors.com 0.100 (Typ) [2.54] www.allsensors.com R 0.551 [14.0] 0.040 [1.0] (Typ) 0.079 [ 2.0] 0.094 [1.0] [2.4] Signed Original On F www.allsensors.com 0.039 R R w.allsensors.com Signed Original On File Suggested Pad Layout
BLC-L01D-U2 价格&库存
很抱歉,暂时无法提供与“BLC-L01D-U2”相匹配的价格&库存,您可以联系我们找货
