AM-150 TRMS
AM-150 TRMS
    AMPROBE(安博)
    DMM TRMS W/PC CONN
AM-150 TRMS 数据手册
AM-120 TRMS, AM-130 TRMS & AM-150 TRMS TRMS Digital Multimeters w/ PC Connection Professional grade and quality performance mark these digital multimeters as a "must have." Don’t miss the download capability and optional accessories that make these value testers versatile. • True RMS (TRMS) • Optical isolated PC interface capability • Auto and manual ranging • Auto power off • Data hold • Peak Hold • Auto & Manual Ranging • Backlight display • Large, easy to read LCD display • Auto Compensation of the test leads resistance • Diode Test • Audible continuity • Safety: CAT III 1000V, CAT IV 600V CAT CAT 1000V 600V IV TRUE R M S z “Patent Pending” FEATURES AM-120 AC Voltage 50.00 / 500.0 Ohms 5.000 / 50.00 / 500.0 kOhms 5.000 / 50.00 MOhms Resistance Frequency Capacitance Temperature Data recording Relative Zero mode 50.00 / 500.0 mV 5.000 / 50.00 / 500.0 / 1000V AM-150 50.00 / 500.0 mV 5.000 / 50.00 / 500.0 / 1000V DC Voltage AC/DC Current AM-130 500.0 / 5000 uA 50.00 / 500.0 mA 5.000 / 10.00 A 6Hz to 125 kHz for all setups except: 6Hz to 1kHz for 500V and 1000V ranges 6Hz to 20kHz for 50V range 50.00 / 500.0 nF 5.000 / 50.00 / 500.0 / 9999uF N/A N/A N/A -58 F to 1832 F -50 C to 1000 C Records PEAK, MAX, 5400 Points MIN, MAX-MIN Yes N/A ACCURACY ± (0.5% Rdg + 3 LSD) @ 50 and 60Hz ± (0.08% Rdg + 2 LSD) @ 5V to 1000V ranges ** ± (0.2% Rdg + 6 LSD) @ 50Ohms to 500 kOhms ranges ** DC: ± (0.2% Rdg + 4 LSD) AC: ± (1.0% Rdg + 4 LSD) ± (0.01% Rdg + 2 LSD) ± (2.0% Rdg + 3 LSD) @ 50 nF to 50uF ranges** ± (0.3% Rdg + 5 LSD) www.AMPROBE.com AM-120 TRMS, AM-130 TRMS & AM-150 TRMS TRMS Digital Multimeters w/ PC Connection “Patent Pending” AM-120 TRMS CAT CAT 1000V 600V IV R M S z OPTIONAL ACCESSORIES 3000A AC Flexible Clamp-on Attachment PART NUMBER ACF-3000 AK 600A AC/DC Clamp-on Attachment CT-600 AC/DC 1000A TRMS AC/DC Clamp-on Attachment 400A AC Clamp-on Attachment Milli-Amps to 30A AC/DC Clamp-on Attachment Dual input Thermocouple adapter with two thermocouples -50˚F to 600˚F (AM-130TRMS and AM-150TRMS Only) Single Input Thermocouple Temperature Attachment (Recommended for AM-120 TRMS) Alligator Clips (For test leads) AM-130 TRMS TRUE PC Interface kit (PC connection cable with software) Software USB to RS-232 Adapter Carrying Case A-1000 A400 CT-30 DKTA-620 and two of TPK-56 TMA-K VRC-320 RS-232 KIT1 www.AMPROBE.com RS-USB CC-ACDC REPLACEMENT PARTS (supplied with product) Thermocouple (AM-130TRMS and AM-150TRMS Only) Test leads with set of alligator clips (alligator clips are not supplied with product) PART NUMBER TPK-59 MTL-90B Fuse 0.63A/500V IR 200kA for mA/uA terminal (AM-120 TRMS and AM-130 TRMS) FA-6x32/.63 Fuse 12.5A/500V IR 20kA for Amp terminal (AM-120 TRMS and AM-130 TRMS) AM-150 TRMS Fuse 1A/1000V IR 10kA for mA/uA terminal (AM-150 TRMS) FA-12.5A/500V FA-1A/1000V Fuse 15A/1000V IR 10KA or 11A/1000V IR 20kA for Amp terminal (AM-150 TRMS) FA-15A/1000V Instruction Manual www.AMPROBE.com Miramar, FL 33025 • Toll Free: 800-327-5060 • Phone: 954-499-5400 • Fax: 954-499-5418 • www.Amprobe.com www.AMPROBE.com
AM-150 TRMS 价格&库存
很抱歉,暂时无法提供与“AM-150 TRMS”相匹配的价格&库存,您可以联系我们找货
