AM-160 TRMS
AM-160 TRMS
    AMPROBE(安博)
    DMM TRMS W/PC CONN
AM-160 TRMS 数据手册
AM-140 TRMS & AM-160 TRMS Precission TRMS Digital Multimeters w/ PC Connection These "top of the line" digital multimeters are affordable without sacrificing an array of features and functions. From true RMS to PC Connectivity Amprobe’s Precision DMMs excel in the professional environment. • True RMS (TRMS) • Optical isolated PC interface capability • MAX, MIN MAX-MIN recording • Peak hold • Auto and manual ranging • Intelligent auto power off • Data hold • Relative zero mode • Audible and visual warning against improper plug-in • DC Loop Current 4-20mA • dBm reading with 20 selectable impedance values • Backlight display • Large, easy to read LCD display • Diode Test • Audible continuity • Safety: CAT III 1000V, CAT IV 600V “Patent Pending” FEATURES AC Voltage AM-140 AM-160 CAT 1000V 600V IV TRUE R M S z ACCURACY 500.00 mV AM-140: ± (0.8% Rdg + 60 LSD) @ 45 to 300 Hz** 5.0000 / 50.000 / 500.00 / 1000.0 V AM-160: ± (0.8% Rdg + 20 LSD) @ 45 to 300 Hz** 500.00 mV 5.0000 / 50.000 / 500.00 / 1000.0 V Resistance 500.00 Ohms 5.0000 / 50.000 / 500.00 kOhms 5.0000 / 50.00 0MOhms AC Current 500.00 / 5000.0 uA 50.000 / 500.00 mA 5.0000 / 10.000 A DC Current 500.00 / 5000.0 uA 50.000 / 500.00 mA 5.0000 / 10.000 A Frequency 5.0000 Hz to 200.000kHz Capacitance 50.00 / 500.0 nF 5.000 / 50.00 / 500.0 / 9999uF Temperature N/A Dual thermocouple -58 F to 1832 F -50 C to 1000 C Duty Cycle 0.1% to 99.99% DC Voltage CAT AM-140: ± (0.10% Rdg + 2 LSD) AM-160: ± (0.05% Rdg + 2 LSD) AM-140: ± (0.10% Rdg + 6 LSD) @ 500 Ohms to 500 kOhms ranges ** AM-160: ± (0.07% Rdg + 2 LSD) @ 500 Ohms to 500 kOhms ranges ** AM-140: ± (1.0% Rdg + 40 LSD) @ 50 and 60 Hz** AM-160: ± (0.5% Rdg + 50 LSD) @ 50 and 60 Hz** ± (0.5% Rdg + 20 LSD) ± (0.002% Rdg + 4 LSD) ± (2.0% Rdg + 3 LSD) @ 50 nF to 50uF ranges** ± (0.3% Rdg + 2 F) ± (0.3% Rdg + 1 C) ± (3 LSD / kHz + 2 LSD) www.AMPROBE.com AM-140 TRMS & AM-160 TRMS Precission TRMS Digital Multimeters w/ PC Connection “Patent Pending” AM-140 TRMS CAT CAT 1000V 600V IV TRUE R M S z OPTIONAL ACCESSORIES 3000A AC Flexible Clamp-on Attachment PART NUMBER 1000A TRMS AC/DC Clamp-on Attachment 600A AC/DC Clamp-on Attachment A-1000 CT-600 AC/DC 400A AC Clamp-on Attachment Milli-Amps to 30A AC/DC Clamp-on Attachment ACF-3000 AK A400 CT-30 Dual input Thermocouple adapter with two thermocouples -50˚F to 600˚F DKTA-620 and two of (AM-160 TRMS Only) TPK-56 Single Input Thermocouple Temperature Attachment (Recommended for AM-140 TRMS) TMA-K PC Interface kit (PC connection cable with software) RS-232 KIT1 Alligator Clips (For test leads) VRC-320 Software www.AMPROBE.com USB to RS-232 Adapter Carrying Case AM-160 TRMS RS-USB CC-ACDC REPLACEMENT PARTS (supplied with product) Thermocouple (AM-160 TRMS Only) Test leads with set of alligator clips (alligator clips are not supplied with product) Fuse 0.63A/500V IR 200kA for mA/uA terminal (AM-140 TRMS) Fuse 12.5A/500V IR 20kA for Amp terminal (AM-140 TRMS) Fuse 1A/1000V IR 10kA for mA/uA terminal (AM-160 TRMS) Fuse 15A/1000V IR 10KA or 11A/1000V IR 20kA for Amp terminal (AM-160 TRMS) Instruction Manual PART NUMBER TPK-59 MTL-90B FA-6x32/.63 FA-12.5A/500V FA-1A/1000V FA-15A/1000V www.AMPROBE.com Miramar, FL 33025 • Toll Free: 800-327-5060 • Phone: 954-499-5400 • Fax: 954-499-5418 • www.Amprobe.com www.AMPROBE.com
AM-160 TRMS 价格&库存
很抱歉,暂时无法提供与“AM-160 TRMS”相匹配的价格&库存,您可以联系我们找货
