Model BD60120N50100AHF
Preliminary
PRELIMINARY
Ultra Low Profile 0404 Balun
50Ω to 100Ω Balanced
Description
The BD60120N50100AHF is a low cost, low profile sub-miniature unbalanced
to balanced transformer designed for differential inputs and output locations on
modern chipsets in an easy to use surface mount package for applications including
point-to-point radio and wideband GaN. The BD60120N50100AHF is ideal for high
volume manufacturing and delivers higher performance than traditional ceramic
baluns. The BD60120N50100AHF has an unbalanced port impedance of 50 and a
100 balanced port impedance. This transformation enables single ended signals to
be applied to differential ports on modern integrated chipsets. The output ports have
equal amplitude (-3dB) with 180 degree phase differential. The
BD60120N50100AHF is available on tape and reel for pick and place high volume
manufacturing.
Detailed Electrical Specifications: Specifications subject to change without notice.
ROOM (25˚C)
Features:
Frequency
(GHz)
5.9 – 11.7 GHz
Thin Height
Profile
Port
Impedance
Return
loss (dB)
Insertion
loss (dB)
Unbal.
Bal.
Typ.
Min.
Typ.
5.9-8.5
50
100
22
15
0.4
10.0-11.7
50
100
25
15
0.6
Max.
Amplitude
Balance
(dB)
Phase
Balance
(deg)
CMRR
(dB)
Power
Handling
(watts)
Typ.
Min
Typ.
Max
Typ.
Max.
0.6
0.8
1.2
9
11
21
TBD
0.8
0.9
1.5
7
12
24
TBD
Ultra Low
Insertion Loss
Surface
Mountable
Tape & Reel
RoHS Compliant
Halogen Free
-55°C to 85°C
* Insertion Loss stated at room temperature (Insertion Loss is approximately 0.1 dB higher at +85 ºC)
Outline Drawing
Top View (Near-side)
Side View
Bottom View (Far-side)
.24
±.06
TBD
.56
1.04±.10
3x .27
1
2
.24
3x .27
.30
.30
1.04±.10
.50
3x .25
3
4
3x .25
Pin Designation
GND / DC Feed
1
+ RF GND
Dimensions are in Millimeters
Mechanical Outline
2 Unbalanced Port
3 Balanced Port
4 Balanced Port
Visit us at
www.anaren.com
.50
Tolerances are Non-Cumulative
USA/Canada:
Toll Free:
Europe:
Asia:
(315) 432-8909
(800) 411-6596
+44 2392-232392
+86 512-62749282
Preliminary
Preliminary Typical Performance: 6.0 GHz. to 12.0 GHz.
Differential insertion loss
-0.3
-6
-0.6
-9
-0.9
-12
-1.2
-15
-1.5
[dB]
[dB]
Return Loss
-1.8
-21
-2.1
-24
-2.4
-27
-2.7
-30
-3
-33
-3.3
-36
5.5
6.5
7.5
8.5
9.5
10.5
11.5
12.5
-3.6
5.5
6.5
7.5
Freq [GHz]
1.5
15
1
10
0.5
5
-1.5
-15
8.5
9.5
11.5
12.5
10.5
11.5
12.5
-5
-10
7.5
10.5
6.5
9.5
Phase balance
[degree]
[dB]
Amplitude Balance
2
-2
5.5
8.5
Freq [GHz]
10.5
11.5
12.5
Freq [GHz]
CMRR
-20
5.5
6.5
7.5
8.5
9.5
Freq [GHz]
-10
-15
[dB]
-20
-25
-30
-35
-40
-45
-50
5.5
6.5
7.5
8.5
9.5
10.5
11.5
12.5
Freq [GHz]
Visit us at
www.anaren.com
USA/Canada:
Toll Free:
Europe:
Asia:
(315) 432-8909
(800) 411-6596
+44 2392-232392
+86 512-62749282
Preliminary
PRELIMINARY
Preliminary Wide Band Performance: 4.0 GHz. to 14.0 GHz.
-0.3
-6
-0.6
-9
-0.9
-12
-1.2
-15
-1.5
[dB]
[dB]
Return Loss
-1.8
-21
-2.1
-24
-2.4
-27
-2.7
-30
-3
-33
-3.3
-36
4
5
6
7
8
9
10
11
12
13
14
-3.6
4
5
6
7
Freq [GHz]
1.5
15
1
10
0.5
5
-1.5
-15
6
7
8
9
10
11
12
13
14
11
12
13
14
-5
-10
5
10
4
9
Phase balance
[degree]
[dB]
Amplitude Balance
2
-2
8
Freq [GHz]
11
12
13
14
-20
Freq [GHz]
CMRR
4
5
6
7
8
9
10
Freq [GHz]
-10
-15
[dB]
-20
-25
-30
-35
-40
-45
-50
4
5
6
7
8
9
10
11
12
13
14
Freq [GHz]
Visit us at
www.anaren.com
USA/Canada:
Toll Free:
Europe:
Asia:
(315) 432-8909
(800) 411-6596
+44 2392-232392
+86 512-62749282
Preliminary
Mounting Configuration:
In order for Xinger surface mount components to work optimally, the proper impedance transmission lines must be
used to connect to the RF ports. If this condition is not satisfied, insertion loss, Isolation and VSWR may not meet
published specifications.
All of the Xinger components are constructed from organic PTFE based composites which possess excellent
electrical and mechanical stability. Xinger components are compliant to a variety of ROHS and Green standards and
ready for Pb-free soldering processes. Pads are Gold plated with a Nickel barrier.
An example of the PCB footprint used in the testing of these parts is shown below. In specific designs, the
transmission line widths need to be adjusted to the unique dielectric coefficients and thicknesses as well as varying
pick and place equipment tolerances.
With No DC Bias
3x Transmission
Line
3x .29
With DC Bias
Plated thru
hole to
ground
Plated thru
hole to
ground
.33
3x Transmission
Line
3x .29
.33
3x .29
.33
3x .29
.22
.50
.22
.50
.22
.22
.50
.50
Circuit Pattern
Circuit Pattern
Footprint Pad (s)
Footprint Pad (s)
Solder Resist
Mounting Footprint
Visit us at
www.anaren.com
Solder Resist
Mounting Footprint
USA/Canada:
Toll Free:
Europe:
Asia:
(315) 432-8909
(800) 411-6596
+44 2392-232392
+86 512-62749282
Preliminary
PRELIMINARY
Packaging and Ordering Information
Parts are available in reel and are packaged per EIA 481-D. Parts are oriented in tape and reel as shown below.
Minimum order quantities are 4000 per reel.
Visit us at
www.anaren.com
USA/Canada:
Toll Free:
Europe:
Asia:
(315) 432-8909
(800) 411-6596
+44 2392-232392
+86 512-62749282
很抱歉,暂时无法提供与“BD60120N50100AHF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11.164071+1.45016
- 10+10.1477110+1.31814
- 25+9.7507425+1.26657
- 50+9.4601950+1.22883
- 100+9.17572100+1.19188
- 250+8.81087250+1.14449
- 500+8.54270500+1.10966
- 1000+8.281051000+1.07567
- 国内价格 香港价格
- 4000+5.150594000+0.66904
