E150N50X4E
E150N50X4E
    TTM(迅达)
    SMD,6.4x6.4mm
    RES SMD 50 OHM 2% 150W
E150N50X4E 数据手册
Model E150N50X4E Flangeless Mount Termination 150 Watts, 50: Description The E150N50X4E is high performance Aluminum Nitride (AlN) termination intended as a cost competitive alternative to Beryllium Oxide (BeO). The termination is well suited to all cellular frequency bands such as; AMPS, GSM, DCS, PCS, PHS and UMTS. The high power handling makes the part ideal for terminating circulators and for use in power combiners. The termination is also RoHS compliant! General Specifications Features: x RoHS Compliant x 200 Watts x DC – 3.0 GHz x AlN Ceramic x Non-Nichrome Resistive Element x Low VSWR x 100% Tested Resistive Element Substrate Terminal Finish Operating Temperature Thick film AlN Ceramic Matte Tin over Nickel Barrier -50 to +200qC (see de rating chart) Tolerance is r0.010”, unless otherwise specified. Designed to meet of exceed applicable portions of MIL-E-5400. All dimensions in inches. Electrical Specifications Resistance Value: Power: Frequency Range: Return Loss 50 Ohms, r 2% 150 Watts DC – 3.0 GHz 25dB DC – 2.0 GHz 20dB DC – 3.0 GHz Specification based on unit properly installed using suggested mounting instructions and a 50 ohm nominal impedance. Specifications subject to change. Outline Drawing UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES 1 of 2 USA/Canada: Toll Free: Europe: (315) 432-8909 (800) 544-2414 +44 2392-232392 Model E150N50X4E Typical Performance: E150N50X4E E150N50X4E 110 100 90 70 60 0.50 130 0.00 80 1.00 120 50 140 40 150 -5.00 -10.00 160 -15.00 30 0.20 20 Return Loss (dB) 170 -20.00 180 10 0.50 1.00 2.00 -0.20 0 0.00 -25.00 -0.50 -170 -10 -30.00 -1.00 -160 -35.00 -20 -150 -40.00 -30 -140 -45.00 -40 -130 -50.00 0.00 0.50 1.00 1.50 2.00 F [GHz] 2.50 3.00 -120 3.50 Power De-rating: -50 -60 -110 -100 -90 -80 -70 Mounting Footprint and Procedure: *Actual performance could be limited by the solder properties of the application 2 of 2 USA/Canada: Toll Free: Europe: (315) 432-8909 (800) 544-2414 +44 2392-232392
E150N50X4E 价格&库存
很抱歉,暂时无法提供与“E150N50X4E”相匹配的价格&库存,您可以联系我们找货
