R1A06031000G5AR
R1A06031000G5AR
    TTM(迅达)
    100 Ohms ±2% 0.25W,1/4W 芯片电阻 0201(0603 公制) 射频,高频率 厚膜
R1A06031000G5AR 数据手册
Model R1A06031000G5AR Anaren High Frequency Chip Resistor Electrical Specifications: Room (25 ºC) Min. 98 -300 Resistance (Ω) TCR (ppm / ºC) Power (W) Features:  RF Performance up to 20 GHz Typ. 100 Max. 102 +300 0.25 Operating Temperature (º C) -55 150 Frequency Range (GHz) Return Loss (dB) DC 20 10 Specifications subject to change with out notice.  100 Ω  10 mil 96 % Alumina  Non-Nichrome Resistive Element  Terminals: Au/Sn Solder over Gold Description  Thick Film chip resistor with Au/Sn solder terminals.  Base Material is 10 mil 96% Alumina.  Other values available.  Solder Attach  Tolerance 2% Outline Drawing .006 Dimensions shown in inches ±0.002 unless otherwise shown .010 .024 .011 .012 R1A06031000G5AR (097) Rev A Available on Tape and Reel For Pick and Place Manufacturing. USA/Canada: Toll Free: Europe: (315) 432-8909 (800) 544-2414 +44 2392-232392 Model R1A06031000G5AR Performance Specifications: Power De-rating: Suggested Mounting: Solder mount using Au/Sn solder with resistive side down. Description of Standard Tests as specified by options in Part Number Change in Resistance Parameter Test Method Limit Typical Resistance ± 2% 100 Ω T.C.R (ppm / ºC) ± 300 Overload (Short Time) ±2% ±0.5% Rated V ltage x 2.5 for 5 seconds ±0.5% ±0.3% -55°C (30 minutes), +125°C (30 minutes), 100 cycles Life Test ±3% ±1% 70°C ± 2°C, 1000 hours, 1.5 hr ON, 0.5 hr OFF cycle High Temperature Exposure ±1% ±0.3% Thermal Shock Measurement at 25°C Measurement at +25°C to-55°C and +25°C to +125°C +125°C for 1000 hours, +155°C for 1000 hours R1A06031000G5AR (097) Rev A USA/Canada: Toll Free: Europe: (315) 432-8909 (800) 544-2414 +44 2392-232392 Available on Tape and Reel For Pick and Place Manufacturing.
R1A06031000G5AR 价格&库存
很抱歉,暂时无法提供与“R1A06031000G5AR”相匹配的价格&库存,您可以联系我们找货
R1A06031000G5AR
  • 500+240.07652500+31.18473
R1A06031000G5AR
  • 1+277.507921+36.04687
  • 10+242.4522210+31.49332
  • 25+238.3307125+30.95795
库存:3
