RS1D-A
RS1D-A
    ANBON(安邦)
    SMA(DO-214AC)
    二极管 200 V 1A 表面贴装型 SMA/DO-214AC
RS1D-A 数据手册
RS1A-A THRU RS1M-A Recovery Rectifiers-50-1000V 1.0A Surface Mount Fast Package outline Features The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications Fast switching for high efficiency Low reverse leakage Built-in strain relief,ideal for automated placement High forward surge current capability High temperature soldering guaranteed: 250 C/10 seconds at terminals Glass passivated chip junction Compliant to RoHS Directive 2011/65/EU Compliant to Halogen-free SMA/DO-214AC 0.108(2.75) 0.096(2.45) 0.067 (1.70) 0.051 (1.30) 0.177(4.50) 0.157(3.99) 0.012(0.305) 0.006(0.152) 0.096(2.42) 0.078(1.98) Mechanical data 0.060(1.52) 0.030(0.76) Case: JEDEC DO-214AC molded plastic body Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any 0.008(0.203)MAX. 0.208(5.28) 0.188(4.80) Dimensions in inches and (millimeters) Maximum ratings and Electrical Characteristics (AT T A=25 oC unless otherwise noted) MAX. UNIT Forward rectified current See Fig.2 IO 1.0 A Forward surge current 8.3ms single half sine-wave (JEDEC methode) I FSM 30 A PARAMETER CONDITIONS V R = V RRM T A = 25 OC Reverse current Symbol MIN. TYP. 5.0 IR O V R = V RRM T A = 100 C Thermal resistance Junction to ambient NOTE 1 R θJA 50 Diode junction capacitance f=1MHz and applied 4V DC reverse voltage CJ 15 Storage temperature T STG *1 V RRM (V) V RMS*2 (V) *3 VR (V) RS1A-A 50 35 50 RS1B-A 100 70 100 SYMBOLS RS1D-A 200 140 200 RS1G-A 400 280 400 RS1J-A 600 420 600 RS1K-A 800 560 800 RS1M-A 1000 700 1000 *4 VF (V) *5 t rr (ns) Operating temperature T J, ( OC) μA 50 O pF O +150 -65 C/W C *1 Repetitive peak reverse voltage *2 RMS voltage 150 *3 Continuous reverse voltage 1.30 -55 to +150 250 *4 Maximum forward voltage@I F=1.0A *5 Maximum Reverse recovery time, note 2 500 Note: 1.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas 2. Reverse recovery time test condition, I F =0.5A, I R =1.0A, I RR =0.25A http://www.anbonsemi.com TEL:+86-755-23776891 FAX:+86-755-81482182 Page 1 Document ID Issued Date Revised Date AS-3020004 2003/03/08 2022/05/16 Revision E Page. 3 RS1A-A THRU RS1M-A Recovery Rectifiers-50-1000V 1.0A Surface Mount Fast Rating and characteristic curves AVERAGE FORWARD RECTIFIED CURRENT, AMPERES FIG. 1- FORWARD CURRENT DERATING CURVE 0.8 0.6 Single Phase Half Wave 60Hz Resistive or inductive Load 0.4 0.2 0 0 25 50 30 £PEAK FORWARD SURGE CURRENT, AMPERES 1.0 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 75 100 125 150 25 20 15 10 175 5.0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 LEAD TEMPERATURE, C FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS FIG. 4-TYPICAL REVERSE CHARACTERISTICS 1,000 10 1 TJ=25 C PULSE WIDTH=300 ms 1%DUTY CYCLE 0.1 0.01 0.6 0.8 1.0 1.2 1.4 1.5 INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES 20 100 10 TJ=100 C 1 0.1 TJ=25 C 0.01 INSTANTANEOUS FORWARD VOLEAGE, VOLTS 20 40 60 80 100 FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE TRANSIENT THERMAL IMPEDANCE, C/W FIG. 5-TYPICAL JUNCTION CAPACITANCE TJ=25 C 100 0 PERCENT OF PEAK REVERSE VOLTAGE,% 200 JUNCTION CAPACITANCE, pF 100 NUMBER OF CYCLES AT 60 Hz 10 100 10 1 0.1 0.01 0.1 1 10 100 1 0.1 1.0 10 100 REVERSE VOLTAGE,VOLTS http://www.anbonsemi.com TEL:+86-755-23776891 FAX:+86-755-81482182 t,PULSE DURATION,sec. Page 2 Document ID Issued Date Revised Date AS-3020004 2003/03/08 2022/05/16 Revision E Page. 3 RS1A-A THRU RS1M-A Recovery Rectifiers-50-1000V 1.0A Surface Mount Fast Pinning information Pin Pin1 Pin2 Simplified outline cathode anode 1 Symbol 2 1 2 Marking Type number Marking code RS1A-A RS1B-A RS1D-A RS1G-A RS1J-A RS1K-A RS1M-A RS1A RS1B RS1D RS1G RS1J RS1K RS1M Suggested solder pad layout C A B Dimensions in inches and (millimeters) PACKAGE A B C SMA 0.110 (2.80) 0.063 (1.60) 0.087 (2.20) http://www.anbonsemi.com TEL:+86-755-23776891 FAX:+86-755-81482182 Page 3 Document ID Issued Date Revised Date AS-3020004 2003/03/08 2022/05/16 Revision E Page. 3
RS1D-A 价格&库存
很抱歉,暂时无法提供与“RS1D-A”相匹配的价格&库存,您可以联系我们找货
