B4844-R
B4844-R
    ANTENOVA(安诺亚)
    ANT RUBB DUCK 2.4G MALE REV SMA
B4844-R 数据手册
Titanis 2.4 GHz Swivel SMA Antenna Part No. B4844 / B4844-R gigaNOVA® Product Specification 1 Features • • • • • Designed for 2.4 GHz applications: Bluetooth®, Wi-Fi® (802.11a/b/g/n), ZigBee®, etc. Antenna with a SMA male connector Also available as SMA reverse thread to meet FCC regulations, part 15 High efficiency Supplied in bulk 2 Description Titanis is intended for use with all 2.4 GHz applications. The antenna is fitted with a SMA male connector and a blade made of flexible material that can be rotated 360 degree. No external matching network required. 3 Applications • Development tools • Test equipment • Access points, routers, etc • Printers Antennas for Wireless M2M Applications 1 Product Specification Titanis B4844 PS-1.2 Titanis 2.4 GHz Swivel SMA Antenna Part No. B4844 / B4844-R 4 Part number Standard SMA – male: B4844 Reverse thread SMA – male: B4844-R 5 General data Product name Part Number Titanis 2.4 GHz B4844 (Standard SMA – male) B4844-R (Reverse thread SMA – male) Frequency 2.4 – 2.5 GHz Polarization Linear Operating temperature -40 ºC to +85 ºC Impedance 50 Ω Weight 7.1 g Antenna type 1 Dimensions 20 x 19.5 x 62.5 [mm] Swivel external 1 The blade of the antenna is the only part that swivels. DO NOT twist the plastic housing of the antenna blade. The housing is NOT designed to twist or turn and any attempt to do so will likely result in permanent damage to the antenna and its performance and will not be covered by warranty. Installation and removal of the antenna should only be done by turning the metal SMA connector. Titanis is not suitable for outdoor use or applications. 6 Electrical characteristics Typical performance Peak gain 2.2 dBi Average gain -1.0 dBi Average efficiency Maximum Return Loss Maximum VSWR 80% Conditions Data given for the 2.4 – 2.5 GHz frequency range -13 dB 1.6:1 Antennas for Wireless M2M Applications 2 Product Specification Titanis B4844 PS-1.2 Titanis 2.4 GHz Swivel SMA Antenna Part No. B4844 / B4844-R 7 Electrical performance 7-1 Return Loss 7-2 VSWR Antennas for Wireless M2M Applications 3 Product Specification Titanis B4844 PS-1.2 Titanis 2.4 GHz Swivel SMA Antenna Part No. B4844 / B4844-R 7-3 Antenna patterns Z X XY plane Y XZ plane ZY plane Patterns show combined polarisations Antennas for Wireless M2M Applications 4 Product Specification Titanis B4844 PS-1.2 Titanis 2.4 GHz Swivel SMA Antenna Part No. B4844 / B4844-R 8 Antenna dimensions A 7 ± 0.2 B 12.5 ± 0.5 H1 H2 H3 W1 W2 Height Height Height Width Width 62.5 ± 0.5 48.3 ± 0.5 9.5 ± 0.5 20 ± 0.3 19.5 ± 0.3 Dimensions in mm Warning: The blade of the antenna is the only part that swivels. DO NOT twist the plastic housing of the antenna blade. The housing is NOT designed to twist or turn and any attempt to do so will likely result in permanent damage to the antenna and its performance and is not covered by warranty. Installation and removal of the antenna should only be done by turning the metal SMA connector. 9 Hazardous material regulation conformance The antenna has been tested to conform to RoHS requirements. A certificate of conformance is available from Antenova M2M’s website. Antennas for Wireless M2M Applications 5 Product Specification Titanis B4844 PS-1.2 Titanis 2.4 GHz Swivel SMA Antenna Part No. B4844 / B4844-R 10 Packaging 10-1 Optimal storage conditions Temperature -10ºC to 40ºC Humidity Less than 75% RH Shelf Life 48 Months Storage place Away from corrosive gas and direct sunlight 10-2 Packaging information The antennas are delivered in bulk, enclosed in plastic bags. 10-3 Bag label information Dimensions in mm Antennas for Wireless M2M Applications 6 Product Specification Titanis B4844 PS-1.2 Titanis 2.4 GHz Swivel SMA Antenna Part No. B4844 / B4844-R www.antenova-m2m.com Corporate Headquarters North America Headquarters Asia Headquarters Antenova Ltd. nd 2 Floor Titan Court 3 Bishop Square Hatfield AL10 9NA Antenova Ltd. 100 Brush Creek Road, Suite 103 Santa Rosa California, 95404 USA Antenova Asia Ltd. 4F, No. 324, Sec. 1, Nei-Hu Road Nei-Hu District Taipei 11493 Taiwan, ROC Tel: +44 1223 810600 Email: sales@antenova-m2m.com Tel: +1 707 890 5202 Email: sales@antenova-m2m.com Tel: +886 (0) 2 8797 8630 Fax: +886 (0) 2 8797 6890 Email: sales@antenova-m2m.com ® ® ® ® Copyright Antenova Ltd. All Rights Reserved. Antenova , Antenova M2M , gigaNOVA , the Antenova product family names, and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks of Antenova Ltd. Any other names and/or trademarks belong to their respective companies. The materials provided herein are believed to be reliable and correct at the time of print. Antenova does not warrant the accuracy or completeness of the information, text, graphics or other items contained within these information. Antenova further assumes no responsibility for the use of this information, and all such information shall be entirely at the user’s risk. Antennas for Wireless M2M Applications 7 Product Specification Titanis B4844 PS-1.2 Revised March 2016
B4844-R 价格&库存
很抱歉,暂时无法提供与“B4844-R”相匹配的价格&库存,您可以联系我们找货
