SRFI065-100
SRFI065-100
    ANTENOVA(安诺亚)
    RF 天线
SRFI065-100 数据手册
DATASHEET Lama SRFI065 • flexiiANT® Features • • • • • • • Antenna for ISM and LoRa® bands (863 – 870MHz and 902 - 928MHz) 1.13mm diameter RF cable with I-PEX MHF connector Self-adhesive mounted Quick integration minimizes design cycle High efficiency within a small area 100mm cable – (other lengths available) Maintains high performance within device: DFI (Designed For Integration) a n t e n ova.com DATASHEET: LAMA SRFI065-PS-1.01 Contents 1. Description 2 2. Applications 2 3. General data 2 4. Part number 3 5. RF characteristics 3 6. RF performance 4 6 . 1. Return loss 4 6 . 2. VSWR4 6 . 3. Efficiency 5 6 . 4. Antenna pattern 6 Antenna dimensions 7. 8 7 . 1. Dimensions FPC section 8 7 . 2. Dimensions assembled 8 7 . 3. I-PEX connector MHF1 (20278-112R-13) 9 7 . 4. Assembly 9 Electrical interface 8. 10 8 . 1. Host interface 10 8 . 2. Transmission line 10 Mechanical fixing 10 9. 10. Antenna integration guide 11 1 0 .1. Antenna placement 11 1 0 .2. Orientation of FPC 12 11. Hazardous material regulation conformance 13 12. Packaging 13 1 2 .1. Optimal storage conditions 14 1 2 .2. Label information 14 a n t e n ova.com 1 DATASHEET: LAMA 1. SRFI065-PS-1.01 Description Lama is a flexible PCB antenna with a cable that connects to the host PCB giving easy integration. The antenna covers both ISM bands (863 – 870MHz and 902 - 928MHz). Dimensions of Lama are 35*10*0.15mm. 2. Applications • • • • • • • LoRa® wireless nodes LoRa® Gateway/Routers Smart meters Home automation Monitoring equipment Smart Grids Remote sensors 3. General data FREQUEN CY 863-870MHz 902-928MHz POLARIZA TION Linear OPERATING TEM PERATURE -40°C to +85°C E N V I RONMENTAL CO NDITION TEST ISO16750-4 5.1.1./5.1.2 IMPEDAN CE 50 Ω WEIGHT
SRFI065-100 价格&库存
很抱歉,暂时无法提供与“SRFI065-100”相匹配的价格&库存,您可以联系我们找货
SRFI065-100
  • 1+24.30336
  • 10+22.29106
  • 25+21.08128
  • 100+19.05700
  • 200+17.60766
  • 600+16.46975
  • 800+15.42766
库存:175
