DATASHEET
Fera
SRFI068 •
flexiiANT®
Features
Antenna for all 915MHz ISM applications
Maintains high performance within device: DFI (Designed For Integration)
1.13mm diameter RF cable with I-PEX MHF connector
Self-adhesive mounted
Quick integration minimizes design cycle
High performance
100mm or 150mm cable – (other lengths available, MOQs apply)
a n t e n ova.com
DATASHEET: FERA
SRFI068-PS-1.01
Contents
1.
Description
2
2.
Applications
2
3.
General data
2
4.
Part number
3
5.
RF characteristics
3
6.
RF performance
4
6 . 1. Return loss
4
6 . 2. VSWR4
6 . 3. Antenna pattern
Antenna dimensions
7.
5
6
7 . 1. Dimensions FPC section
6
7 . 2. Dimensions assembled
6
7 . 3. I-PEX connector MHF1 (20278-112R-13)
7
7 . 4. Assembly7
Electrical interface
8.
8
8 . 1. Host interface
8
8 . 2. Transmission line
8
Mechanical fixing
8
9.
10.
Antenna integration guide
1 0 .1. Antenna placement
1 0 .2. Orientation of FPC
9
9
10
11.
Hazardous material regulation conformance
11
12.
Packaging
11
1 2 .1. Optimal storage conditions
12
1 2 .2. Label information
12
a n t e n ova.com
1
DATASHEET: FERA
1.
SRFI068-PS-1.01
Description
Fera is intended for use for all ISM 915MHz applications. A flexible antenna
with cable enables direct connection to the host PCB giving easy integration
with plug and play simplicity.
2.
3.
Applications
Remote monitoring
LoRa and Sigfox networks
915 MHz ISM band systems
Smart meters
Home automation
Medical devices
General data
FREQUEN CY
902-928MHz
POLARIZA TION
Linear
OPERATING TEM PERATURE
-40°C to +85°C
E N V I RONMENTAL CO NDITION TEST
ISO16750-4 5.1.1./5.1.2
IMPEDAN CE
50 Ω
WEIGHT
36%
MAXIMUM RETURN LOSS
-15dB
MAXIMUM VSWR
1.4:1
All data measured on SRFI068V-100 in a loaded
condition adhered to a plastic carrier in free space.
a n t e n ova.com
3
DATASHEET: FERA
6.
SRFI068-PS-1.01
RF performance
6.1.
Return loss
6.2.
VSWR
a n t e n ova.com
4
DATASHEET: FERA
6.3.
SRFI068-PS-1.01
Antenna pattern
6.3.1.
902 MHz – 928 MHz
3D pattern at 915MHz
a n t e n ova.com
5
DATASHEET: FERA
7.
SRFI068-PS-1.01
Antenna dimensions
7.1.
SRFI068H
SRFI068V
L
W
T
Length
Width
Thickness
33.0 ±0.2
13.0 ±0.2
0.15 (nominal)
All dimensions in (mm)
7.2.
SRFI068V
SRFI068H
S R F I068H-100
SRFI068H-150
SRFI068V - 1 0 0
SRFI068V-150
Length
Length
Length
Length
115 ±2.0
165 ±2.0
101.3 ±2.0
151.3 ±2.0
Standard cable lengths for this antenna are 100mm and 150mm
a n t e n ova.com
6
DATASHEET: FERA
7.3.
SRFI068-PS-1.01
Front
Side
Back
5.0mm
MATING HEIGHT: 2.5mm MAX
2.0mm
I-PEX
M ATERIAL
Copper Alloy
P LATING
Ag
7.4.
Assembly
I-PEX Connector
SRFI068H
SRFI068V
1.13mm ø Cable
FPC
FPC
1.13mm ø Cable
I-PEX Connector
a n t e n ova.com
7
DATASHEET: FERA
8.
SRFI068-PS-1.01
8.1.
Host interface
The host PCB requires the mating connector which is the I-PEX MHF (UFL)
receptacle. The location should be close to the chip/modules pin for the RF.
Any feed from this receptacle should be maintained at 50Ω impedance.
8.2.
Transmission line
• Must have a characteristic impedance of 50Ω.
• Length should be kept to a minimum.
• Is recommended to be a co-planar waveguide: log on to Antenova.com
and try our Transmission line calculator to easily calculate the dimensions
most suited to your requirements.
• Should have DC blocking capacitor (e.g. 220pF) placed in line to protect
the RF front end.
9.
Mechanical fixing
The antenna uses 3M 468MP adhesive on the reverse side of the FPC. The
antenna has an easy access split line to peel off to reveal the adhesive side. It
is designed for a one time fix to a clean smooth surface. The antenna is keyed
with two 1mm locating holes for easy positioning.
FPC back side
a n t e n ova.com
Split line for easy peel
8
DATASHEET: FERA
10.
SRFI068-PS-1.01
We recommend the following during the design phase to maximise antenna
performance and minimize noise:
Minimum 4 layer PCB
Route signals and power internally where possible
Flood all layers with ground
Knit ground on all layers together with plenty of vias
Follow placement guidance carefully, in addition Antenova provide technical
support to help you through all stages of your design. Register for an account
on https://ask.antenova.com/ to access technical support.
10.1.
Antenna placement
For FPC antennas the host PCB size is not critical to performance, however
consideration must be given to placement. Using six spatial directions,
as shown below, the antenna should ideally maintain a minimum of three
directions free from obstruction in order to radiate effectively. Where there are
obstructions (e.g. PCB, metal parts, battery etc.) a minimum clearance should
still be maintained. These minimum clearances are described later in this
section.
Six spatial directions relative to FPC
Example with 5 spatial directions clear
1
6
4
3
5
2
a n t e n ova.com
9
DATASHEET: FERA
10.2.
SRFI068-PS-1.01
Orientation of FPC
The orientation of the FPC with respect to the host PCB should be defined
depending on the unit. The proximity of the GND will have an influence on the
antenna so the PCB location relative to the antenna should be considered.
The FPC will normally be placed in one of the three following options
for orientation. In each option a distance (d) is the critical dimension to
consider. The diagram below shows the minimum value of (d) for each. Other
obstructions may increase this dimension.
Vertical mounted
FPC
Cable + Connector
d ≥ 3mm
PCB
Co-planar to PCB
d ≥ 15mm
Planar to PCB (Same plane)
d ≥ 3mm
a n t e n ova.com
10
DATASHEET: FERA
11.
SRFI068-PS-1.01
The antenna has been tested to conform to RoHS and REACH requirements. A
certificate of conformance is available from Antenova’s website.
12.
Packaging
The antennas are stored within an anti-static bag of 100 pcs.
100 units per bag (Labelled)
a n t e n ova.com
11
DATASHEET: FERA
12.1.
SRFI068-PS-1.01
TEMPERATURE
-10ºC to 40ºC
HUMIDITY
Less than 75% RH
SHELF LIFE
18 Months
STORAGE PLACE
Away from corrosive gas and direct sunlight
PACKAGING
MSL LEVEL
Antennas should be stored in unopened sealed
manufacturer’s plastic packaging.
1
Note: The shelf life of the antenna is 18 months, provided the bag of 100
pieces remains factory- sealed.
12.2.
Label information
Quality statements
Antenova’s products conform to REACH and RoHS legislation. For our
statements regarding these and other quality standards, please see
antenova.com.
Antenova reserves all rights to the contents of this document. Antenova
gives no warranties based solely on the accuracy or completeness of the
contents of this document and reserves the right to make changes to the
specifications of the products described herein at any time and without
notice.
a n t e n ova.com
12
DATASHEET: FERA
SRFI068-PS-1.01
Antenna design,
integration and test
resources
Product designers – the details contained in this datasheet will help you to
complete your embedded antenna design. Please follow our technical advice
carefully to obtain optimum antenna performance.
We aim to support our customers to create high performance wireless products.
You will find a wealth of design resources, calculators and case studies to aid
your design on our website.
Antenova’s design laboratories are equipped with the latest antenna design tools
and test chambers. We provide antenna design, test and technical integration
services to help you complete your design and obtain the required certifications.
If you cannot find the antenna you require in our product range, please contact us
to discuss creating a custom antenna to meet your exact requirements.
Share knowledge with RF experts around the world.
Visit antenova.com
ask.antenova is a global forum for
designers and engineers working
with wireless technology.
Order antenna samples and
evaluation boards, and read our
antenna resources
VISI T A S K . A N T E N O V A
VISIT ANTENOVA.COM
Request a volume quotation for antennas:
Global headquarters
sales@antenova.com
Antenova Ltd, 2nd Floor Titan Court, 3 Bishop
Square, Hatfield, AL10 9NA
+44 (0) 1707 927589
Copyright® Antenova Ltd. All Rights Reserved. Antenova®, gigaNOVA®, RADIONOVA®, the Antenova product family names and the Antenova logos
are trademarks and/or registered trademarks of Antenova Ltd. Any other names and/or trademarks belong to their respective companies. The
materials provided herein are believed to be reliable and correct at the time of printing. Antenova does not warrant the accuracy or completeness
of the information, text, graphics or other items contained within this information. Antenova further assumes no responsibility for the use of this
information, and all such information shall be entirely at the user’s risk.
a n t e n ova.com
13
很抱歉,暂时无法提供与“SRFI068V-100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+29.358041+3.79998
