75.073AR.G070C
75.073AR.G070C
    APACERMEMORYAMERICA(宇瞻科技)
    SODIMM200
    DDR2-667 INDUS. SO-DIMM 128X8 1
75.073AR.G070C 数据手册
RoHS Compliant 1GB DDR2 SDRAM SO-DIMM Industrial Product Specifications January 11, 2016 Version 1.1 Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Table of Contents General Description ....................................................................................................... 2 Ordering Information ..................................................................................................... 2 Key Parameters .............................................................................................................. 2 Specifications: ................................................................................................................ 3 Pin Assignments ............................................................................................................. 4 Pin Descriptions ............................................................................................................. 6 Functional Block Diagram ............................................................................................. 7 Absolute Maximum Ratings .......................................................................................... 8 DRAM Component Operating Temperature Range....................................................... 9 Operating Conditions ................................................................................................... 10 IDD Specifications ....................................................................................................... 11 Mechanical Drawing .................................................................................................... 13 ©Apacer Technology Inc. 1 General Description Apacer 75.073AR.G070C is a 128M x 64 Double Data Rate SDRAM high density memory modules based on first generation of 1GB DDR2 SDRAM respectively. It consists of 8 pieces 128M x 8 bit with 8banks Double Data Rate SDRAMs in 60Ball FBGA packages mounted on a 200pin glass-epoxy substrate. Decoupling capacitors are mounted on the printed circuit board in parallel for each DDR2 SDRAM. Synchronous design allows precise cycle control with the use of system clock. Data I/O transactions are possible on both edges of DQS. Range of operating frequencies, programmable latencies and burst lengths allow the same device to be useful for a variety of high bandwidth, high performance memory system applications. Ordering Information Part Number Bandwidth Speed Grade Max Frequency CAS Latency 75.073AR.G070C 5.3 GB/sec 667 Mbps 333 MHz CL5 Density Organization Component Rank 1GB 128M x 64 128M x8*8 1 Key Parameters MT/s DDR2-667 DDR2-800 DDR2-800 Grade -CL5 -CL5 -CL6 tCK (min) 3 2.5 2.5 ns CAS latency 5 5 6 tCK tRCD (min) 15 12.5 15 ns tRP (min) 15 12.5 15 ns tRAS (min) 45 45 45 ns tRC (min) 60 57.5 60 ns CL-tRCD-tRP 5-5-5 5-5-5 6-6-6 tCK ©Apacer Technology Inc. 2 Unit Specifications: ♦ JEDEC standard 1.8V ± 0.1V ♦ Power Supply VDDQ = 1.8V± 0.1V ♦ Interface: SSTL_18 ♦ Posted CAS ♦ Programmable CAS Latency: 3, 4, 5 ♦ Programmable Additive Latency: 0, 1 , 2 , 3 and 4 ♦ Write Latency(WL) = Read Latency(RL) -1 ♦ Burst Length: 4 , 8(Interleave/nibble sequential) ♦ Programmable Sequential / Interleave Burst Mode ♦ On Die Termination ♦ Refresh and Self Refresh ♦ Average Refresh Period 7.8us ♦ Serial presence detect with EEPROM ♦ Compliance with RoHS ♦ Compliance with CE ♦ Supports auto-refresh/self-refresh ♦ Operating Temperature Range: Industrial -40°C ≦ TC ≦ 95°C -40°C ≦ TA ≦ 85°C ♦ Average refresh period 7.8us at 0°C ≦ TC ≦ 85°C 3.9us at 85°C ≦ TC ≦ 95°C ♦ PCB: 30µ gold finger ©Apacer Technology Inc. 3 Pin Assignments Pin No. Pin name Pin No. Pin name Pin No. Pin name Pin No. Pin name 1 VREF 51 DQS2 101 A1 151 DQ42 3 VSS 53 VSS 103 VDD 153 DQ43 5 DQ0 55 DQ18 105 A10 155 VSS 7 DQ1 57 DQ19 107 BA0 157 DQ48 9 VSS 59 VSS 109 WE 159 DQ49 11 DQS0 61 DQ24 111 VDD 161 VSS 13 DQS0 63 DQ25 113 CAS# 163 NC 15 VSS 65 VSS 115 S1# 165 VSS 17 DQ2 67 DM3 117 VDD 167 DQS6 19 DQ3 69 NC 119 ODT1 169 DQS6 21 VSS 71 VSS 121 VSS 171 VSS 23 DQ8 73 DQ26 123 DQ32 173 DQ50 25 DQ9 75 DQ27 125 DQ33 175 DQ51 27 VSS 77 VSS 127 VSS 177 VSS 29 DQS1 79 CKE0 129 DQS4 179 DQ56 31 DQS1 81 VDD 131 DQS4 181 DQ57 33 VSS 83 NC 133 VSS 183 VSS 35 DQ10 85 NC/BA2 135 DQ34 185 DM7 37 DQ11 87 VDD 137 DQ35 187 VSS 39 VSS 89 A12 139 VSS 189 DQ58 41 VSS 91 A9 141 DQ40 191 DQ59 43 DQ16 93 A8 143 DQ41 193 VSS 45 DQ17 95 VDD 145 VSS 195 SDA 47 VSS 97 A5 147 DM5 197 SCL 49 DQS2 99 A3 149 VSS 199 VDDSPD ©Apacer Technology Inc. 4 Pin No. Pin name Pin No. Pin name Pin No. Pin name Pin No. Pin name 2 VSS 52 DM2 102 A0 152 DQ46 4 DQ4 54 VSS 104 VDD 154 DQ47 6 DQ5 56 DQ22 106 BA1 156 VSS 8 VSS 58 DQ23 108 RAS 158 DQ52 10 DM0 60 VSS 110 S0 160 DQ53 12 VSS 62 DQ28 112 VDD 162 VSS 14 DQ6 64 DQ29 114 ODT0 164 CK1 16 DQ7 66 VSS 116 NC 166 CK1 18 VSS 68 DQS3 118 VDD 168 VSS 20 DQ12 70 DQS3 120 NC 170 DM6 22 DQ13 72 VSS 122 VSS 172 VSS 24 VSS 74 DQ30 124 DQ36 174 DQ54 26 DM1 76 DQ31 126 DQ37 176 DQ55 28 VSS 78 VSS 128 VSS 178 VSS 30 CK0 80 NC/CKE1 130 DM4 180 DQ60 32 CK0 82 VDD 132 VSS 182 DQ61 34 VSS 84 NC 134 DQ38 184 VSS 36 DQ14 86 NC 136 DQ39 186 DQS7 38 DQ15 88 VDD 138 VSS 188 DQS7 40 VSS 90 A11 140 DQ44 190 VSS 42 VSS 92 A7 142 DQ45 192 DQ62 44 DQ20 94 A6 144 VSS 194 DQ63 46 DQ21 96 VDD 146 DQS5 196 VSS 48 VSS 98 A4 148 DQS5 198 SA0 50 NC 100 A2 150 VSS 200 SA1 *Pin 85 is NC for 512MB and BA2 for 1GB ©Apacer Technology Inc. 5 Pin Descriptions Pin Name Description Ax SDRAM address bus BAx SDRAM bank select RAS SDRAM row address strobe CAS SDRAM column address strobe WE SDRAM write enable Sx DIMM Rank Select Lines CKEx SDRAM clock enable lines ODTx On-die termination control lines DQx DIMM memory data bus DQSx SDRAM data strobes(positive line of differential pair) DQSx SDRAM data strobes(negative line of differential pair) DMx SDRAM data masks high data strobes(x8-based X72 DIMMs) CKx SDRAM clocks(positive line of differential pair) CKx SDRAM clocks(negative line of differential pair) SCL I2C serial bus clock for EEPROM SDA I2C serial bus data line for EEPROM SAx I2C slave address select for EEPROM VDD SDRAM core power supply VDDQ SDRAM I/0 Driver power supply VREF SDRAM I/O reference supply VSS Power supply return(ground) VDDSPD NC ©Apacer Technology Inc. Serial EEPROM positive power supply Spare pins(no connect) 6 Functional Block Diagram S0 DQS0 DQS0 DM0 DQS4 DQS4 DM4 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 CS I/O 0 I/O 1 I/O 2 I/O 3 I/O 4 I/O 5 I/O 6 I/O 7 DQS DQS DM DQ32 DQ33 DQ34 DQ35 DQ36 DQ37 DQ38 DQ39 D0 DQS1 DQS1 DM1 CS DQS DQS I/O 0 I/O 1 I/O 2 I/O 3 I/O 4 I/O 5 I/O 6 I/O 7 D4 DQS5 DQS5 DM5 DM DQ8 DQ9 DQ10 DQ11 DQ12 DQ13 DQ14 DQ15 CS I/O 0 I/O 1 I/O 2 I/O 3 I/O 4 I/O 5 I/O 6 I/O 7 DQS DQS DM DQ40 DQ41 DQ42 DQ43 DQ44 DQ45 DQ46 DQ47 D1 DQS2 DQS2 DM2 CS DQS DQS I/O 0 I/O 1 I/O 2 I/O 3 I/O 4 I/O 5 I/O 6 I/O 7 D5 DQS6 DQS6 DM6 DM DQ16 DQ17 DQ18 DQ19 DQ20 DQ21 DQ22 DQ23 CS I/O 0 I/O 1 I/O 2 I/O 3 I/O 4 I/O 5 I/O 6 I/O 7 DQS DQS DM DQ48 DQ49 DQ50 DQ51 DQ52 DQ53 DQ54 DQ55 D2 DQS3 DQS3 DM3 CS DQS DQS I/O 0 I/O 1 I/O 2 I/O 3 I/O 4 I/O 5 I/O 6 I/O 7 D6 DQS7 DQS7 DM7 DM DQ24 DQ25 DQ26 DQ27 DQ28 DQ29 DQ30 DQ31 NU/ CS I/O 0 I/O 1 I/O 2 I/O 3 I/O 4 I/O 5 I/O 6 I/O 7 DQS DQS D3 Serial PD SCL SDA WP BA0 - BA2 A0 - A13 DM DQ56 DQ57 DQ58 DQ59 DQ60 DQ61 DQ62 DQ63 A0 A1 A2 SA0 SA1 SA2 VDDSPD Serial PD VDD/VDDQ D0 - D7 VREF D0 - D7 VSS D0 - D7 CS DQS DQS I/O 0 I/O 1 I/O 2 I/O 3 I/O 4 I/O 5 I/O 6 I/O 7 D7 * Clock Wiring Clock Input DDR2 SDRAMs *CK0/CK0 *CK1/CK1 *CK2/CK2 2 DDR2 SDRAMs 3 DDR2 SDRAMs 3 DDR2 SDRAMs BA0-BA2 : DDR2 SDRAMs D0 - D7 *Wire per Clock Loading Table/Wiring Diagrams A0-A13 : DDR2 SDRAMs D0 - D7 RAS RAS : DDR2 SDRAMs D0 - D7 CAS CAS : DDR2 SDRAMs D0 - D7 CKE0 CKE : DDR2 SDRAMs D0 - D7 WE ODT0 WE : DDR2 SDRAMs D0 - D7 ODT : DDR2 SDRAMs D0 - D7 ©Apacer Technology Inc. Notes : 1. DQ,DM, DQS/DQS resistors : 22 Ohms " 5%. 2. BAx, Ax, RAS, CAS, WE resistors : 10 Ohms " 5%. 7 Absolute Maximum Ratings Parameter Symbol Description Units Voltage on VDD pin relative to Vss VDD - 0.5 V ~ 2.3 V V Voltage on VDDQ pin relative to Vss VDDQ - 0.5 V ~ 2.3 V V Voltage on any pin relative to Vss VIN, VOUT - 0.5 V ~ 2.3 V V Storage Temperature TSTG -55 to +100 ℃ Notes: 1. Stress greater than those listed may cause permanent damage to the device. This is a stress rating only and device functional operation at or above the conditions indicated is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. ©Apacer Technology Inc. 8 DRAM Component Operating Temperature Range Symbol Parameter Rating Units Notes Operating case Temperature (TC) -40 to 95 ℃ 1,2,3 Operating ambient temperature (TA) -40 to 85 ℃ 3,4 TOPER Notes: 1. Operating case temperature TC is measured in the center/top side of the DRAM. 2. Device functionality is not guaranteed if the device exceeds maximum TC during operation. 3. Both temperature TA and TC specifications must be satisfied. 4. Operating ambient temperature surrounding the package. Industrial Temperature The industrial temperature (IT) option, if offered, has two simultaneous requirements: ambient temperature(TA) surrounding the device cannot be less than –40°C or greater than+85°C, and the case temperature(TC) cannot be less than –40°C or greater than +95°C. ©Apacer Technology Inc. 9 Operating Conditions Recommended DC Operating Conditions – DDR2 (1.8V) operation Rating Symbol VDD Parameter Units Supply Voltage VDDQ Supply Voltage for Output Min. Typ. Max. 1.7 1.8 1.9 V 1.7 1.8 1.9 V Notes: 1. Under all conditions VDDQ must be less than or equal to VDD.. 2. VDDQ tracks with VDD. AC parameters are measured with VDD and VDDQ tied together. ©Apacer Technology Inc. 10 IDD Specifications Conditions Operating one bank active-precharge current: Symbol MICRON-M Unit IDD0* 480 mA IDD1* 560 mA IDD2P 80 mA IDD2N** 192 mA IDD2Q** 192 mA IDD3P-F 224 mA IDD3P-S 160 IDD3N** 240 tCK = tCK (IDD); tRC = tRC (IDD); tRAS = tRAS MIN (IDD); CKE is HIGH, CS# is HIGH between valid commands; Address bus inputs are SWITCHING; Data bus inputs are SWITCHING Operating one bank active-read-precharge current: IOUT = 0 mA; BL = 8; CL = CL (IDD);, AL = 0;, tCK = tCK (IDD); tRC = tRC (IDD); tRAS = tRAS MIN (IDD); tRCD = tRCD (IDD); CKE is HIGH, CS# is HIGH between valid commands; Address bus inputs are SWITCHING; Data pattern is same as IDD4W Precharge power-down current: All device banks idle; tCK = tCK (IDD); CKE is LOW; Other control and address bus inputs are STABLE; Data bus inputs are FLOATING Precharge standby current; All device banks idle: tCK = tCK (IDD); CKE is HIGH; CS# is HIGH; Other control and address bus inputs are SWITCHING; Data bus inputs are SWITCHING Precharge quiet standby current: All device banks idle; tCK = tCK (IDD); CKE is HIGH; CS# is HIGH; Other control and address bus inputs are STABLE; Data bus inputs are FLOATING Active power-down current: All device banks open; tCK = tCK (IDD); CKE is LOW; Other control and address bus inputs are STABLE; Data bus inputs are FLOATING Active standby current: All device banks open; tCK = tCK (IDD); tRP = tRP (IDD); tRAS = tRAS MAX (IDD); CKE is HIGH, CS# is HIGH between valid commands; Other control and address bus inputs are SWITCHING; Data bus inputs are SWITCHING ©Apacer Technology Inc. 11 mA Operating burst read current: IDD4R* 880 mA IDD4W* 920 mA IDD5** 1200 mA IDD6** 56 mA IDD7* 1480 mA All device banks open; Continuous burst reads; IOUT = 0 mA; BL = 8; CL = CL (IDD); AL = 0; tCK = tCK (IDD); tRAS = tRAS MAX (IDD); tRP = tRP (IDD); CKE is HIGH, CS# is HIGH between valid commands; Address bus inputs are SWITCHING; Data patter is same as IDD4W Operating burst write current: All device banks open; Continuous burst writes; BL = 8; CL = CL(IDD);AL = 0; tCK= tCK(IDD); tRAS= tRAS MAX(IDD); tRP= tRP(IDD); CKE is HIGH, CS# is HIGH between valid commands; Address bus inputs are SWITCHING; Data bus inputs are SWITCHING. Burst refresh current: tCK=tCK(IDD); Refresh command at every tRFC(IDD) interval; CKE is HIGH; CS# is HIGH between valid commands; Other control and address bus inputs are SWITCHING; Data bus inputs are SWITCHING. Self refresh current: CK and CK# at 0V; CKE < 0.2V; Other control and address bus inputs are FLOATING; Data bus inputs are FLOATING. Operating bank interleave read current: All bank interleaving reads; IOUT = 0mA; BL = 8; CL = CL(IDD); AL = tRCD(IDD) - 1*tCK(IDD); tCK= tCK(IDD); tRC= tRC(IDD); tRRD = tRRD(IDD); tRCD = 1*tCK(IDD) ; CKE is HIGH; CS# is HIGH between valid commands; Address bus inputs are STABLE during DESELECTs; Data pattern is same as IDD4R. Notes: *Value calculated as one module rank in this operating condition, and all other module ranks in IDD2P (CKE LOW) mode. **Value calculated reflects all module ranks in this operating condition. ©Apacer Technology Inc. 12 Mechanical Drawing 3.8 mm max 20.00 mm 30 mm 67.60 mm SPD 1.1mm max 1.8 mm 2.7 mm 4.0 mm 0.60 mm 1.00 mm Left key position : Reserved Right key position : VDD = VDDQ = 1.8 V 30µ gold finger Unit: mm Tolerances:+-0.15mm unless otherwise specified ©Apacer Technology Inc. 13 Revision History Revision Date Description 0.9 08/28/2012 Official release 1.0 08/29/2012 release 1.1 07/23/2013 Changed headquarters address ©Apacer Technology Inc. Remark 14 Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: +886-2-2267-8000 Fax: +886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9568 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-290-0686 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd. Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD , Shanghai , 200051, China Tel: 86-21-6228-9939 Fax:86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd. Unit No.201, "Brigade Corner", 7th Block Jayanagar, Yediyur Circle, Bangalore – 560082, India Tel: 91-80-4152-9061 Fax: 91-80-4170-0215 sales_india@apacer.com ©Apacer Technology Inc. 15
75.073AR.G070C 价格&库存
很抱歉,暂时无法提供与“75.073AR.G070C”相匹配的价格&库存,您可以联系我们找货
