75.A73CG.G010C
75.A73CG.G010C
    APACERMEMORYAMERICA(宇瞻科技)
    SODIMM204
    2GB DDR3-1333 INDUS. SO-DIMM 128
75.A73CG.G010C 数据手册
Apacer Memory Product Specification 2GB DDR3 SDRAM SODIMM with SPD Ordering Information Part Number Bandwidth Speed Grade Max Frequency 75.A73CG.G010C 10.6GB/sec 1333Mbps 666MHz CAS Latency CL9 Density Organization 2GB 256Mx64 Component Composition Number of Rank 128Mx8*16EA 2 Specifications Features • On Dimm Thermal Sensor: No • Density: 2GB • Organization  128M words × 64 bits, 2 rank • Mounting 8 pieces of 2G bits DDR3 SDRAM sealed in FBGA • Package: 204-pin socket type small outline dual in line memory module (SO-DIMM)  PCB height: 30.0mm  Lead pitch: 0.6mm (pin)  Lead-free (RoHS compliant) • Power supply: VDD = 1.5V ± 0.075V • Double-data-rate architecture; two data transfers per clock cycle • The high-speed data transfer is realized by the 8 bits prefetch pipelined architecture • Bi-directional differential data strobe (DQS and /DQS) is transmitted/received with data for capturing data at the receiver • DQS is edge-aligned with data for READs; centeraligned with data for WRITEs • Differential clock inputs (CK and /CK) • DLL aligns DQ and DQS transitions with CK transitions • Commands entered on each positive CK edge; data and data mask referenced to both edges of DQS • Data mask (DM) for write data • Posted /CAS by programmable additive latency for better command and data bus efficiency • On-Die-Termination (ODT) for better signal quality  Synchronous ODT  Dynamic ODT  Asynchronous ODT • Multi Purpose Register (MPR) for temperature read out • ZQ calibration for DQ drive and ODT • Programmable Partial Array Self-Refresh (PASR) • /RESET pin for Power-up sequence and reset function • SRT range:  Normal/extended  Auto/manual self-refresh • Programmable Output driver impedance control • Eight internal banks for concurrent operation (components) • Interface: SSTL_15 • Burst lengths (BL): 8 and 4 with Burst Chop (BC) • /CAS Latency (CL): 6, 7, 8, 9 • /CAS write latency (CWL): 5, 6, 7 • Precharge: auto precharge option for each burst access • Refresh: auto-refresh, self-refresh • Refresh cycles  Average refresh period 7.8µs at 0°C ≤ TC ≤ +85°C 3.9µs at +85°C < TC ≤ +95°C • Operation Temperature Rang:  Industrial (-40 °C ≤ TC ≤ +95°C) Industrial Temperature The industrial temperature device requires that the case temperature not exceed – 40°C or +95°C. JEDEC specifications require the refresh rate to double when TC exceeds +85°C; this also requires use of the high-temperature self refresh option. Notes: operating case temperature. T is measured in the center of the package. ‧ MAX thermal solution must be designed to ensure the DRAM device does not exceed the ‧ Amaximum T during operation. Device functionality ‧ ing operation. is not guaranteed if the DRAM device exceeds the maximum T durT exceeds +85°C, the DRAM must be refreshed externally at 2X refresh, which is a ‧ If3.9µs interval refresh rate. C C C C Apacer Memory Product Specification Pin Configurations Front side 1 pin 71 pin 73 pin 203 pin 2 pin 72 pin 74 pin 204 pin Back side Front side Back side Pin No. Pin name Pin No. Pin name Pin No. Pin name Pin No. Pin name 1 VREFDQ 103 /CK0 2 VSS 104 /CK1 3 VSS 105 VDD 4 DQ4 106 VDD 5 DQ0 107 A10 (AP) 6 DQ5 108 BA1 7 DQ1 109 BA0 8 VSS 110 /RAS 9 VSS 111 VDD 10 /DQS0 112 VDD 11 DM0 113 /WE 12 DQS0 114 /CS0 13 VSS 115 /CAS 14 VSS 116 ODT0 15 DQ2 117 VDD 16 DQ6 118 VDD 17 DQ3 119 A13 18 DQ7 120 ODT1 19 VSS 121 /CS1 20 VSS 122 NC 21 DQ8 123 VDD 22 DQ12 124 VDD 23 DQ9 125 NC 24 DQ13 126 VREFCA 25 VSS 127 VSS 26 VSS 128 VSS 27 /DQS1 129 DQ32 28 DM1 130 DQ36 29 DQS1 131 DQ33 30 /RESET 132 DQ37 31 VSS 133 VSS 32 VSS 134 VSS 33 DQ10 135 /DQS4 34 DQ14 136 DM4 35 DQ11 137 DQS4 36 DQ15 138 VSS 37 VSS 139 VSS 38 VSS 140 DQ38 39 DQ16 141 DQ34 40 DQ20 142 DQ39 41 DQ17 143 DQ35 42 DQ21 144 VSS 43 VSS 145 VSS 44 VSS 146 DQ44 45 /DQS2 147 DQ40 46 DM2 148 DQ45 47 DQS2 149 DQ41 48 VSS 150 VSS 49 VSS 151 VSS 50 DQ22 152 /DQS5 51 DQ18 153 DM5 52 DQ23 154 DQS5 53 DQ19 155 VSS 54 VSS 156 VSS 55 VSS 157 DQ42 56 DQ28 158 DQ46 57 DQ24 159 DQ43 58 DQ29 160 DQ47 59 DQ25 161 VSS 60 VSS 162 VSS 61 VSS 163 DQ48 62 /DQS3 164 DQ52 63 DM3 165 DQ49 64 DQS3 166 DQ53 65 VSS 167 VSS 66 VSS 168 VSS 67 DQ26 169 /DQS6 68 DQ30 170 DM6 Apacer Memory Product Specification Front side Back side Pin No. Pin name Pin No. Pin name Pin No. Pin name Pin No. Pin name 69 DQ27 171 DQS6 70 DQ31 172 VSS 71 VSS 173 VSS 72 VSS 174 DQ54 73 CKE0 175 DQ50 74 CKE1 176 DQ55 75 VDD 177 DQ51 76 VDD 178 VSS 77 NC 179 VSS 78 NC 180 DQ60 79 BA2 181 DQ56 80 NC 182 DQ61 81 VDD 183 DQ57 82 VDD 184 VSS 83 A12 (/BC) 185 VSS 84 A11 186 /DQS7 85 A9 187 DM7 86 A7 188 DQS7 87 VDD 189 VSS 88 VDD 190 VSS 89 A8 191 DQ58 90 A6 192 DQ62 91 A5 193 DQ59 92 A4 194 DQ63 93 VDD 195 VSS 94 VDD 196 VSS 95 A3 197 SA0 96 A2 198 /EVENT 97 A1 199 VDDSPD 98 A0 200 SDA 99 VDD 201 SA1 100 VDD 202 SCL 101 CK0 203 VTT 102 CK1 204 VTT Apacer Memory Product Specification Pin Description Pin name Function A0 to A13 Address input Row address Column address A10 (AP) Auto precharge A0 to A13 A0 to A9 A12 (/BC) Burst chop BA0, BA1, BA2 Bank select address DQ0 to DQ63 Data input/output /RAS Row address strobe command /CAS Column address strobe command /WE Write enable /CS0, /CS1 Chip select CKE0, CKE1 Clock enable CK0, CK1 Clock input /CK0, /CK1 Differential clock input DQS0 to DQS7, /DQS0 to /DQS7 Input and output data strobe DM0 to DM7 Input mask SCL Clock input for serial PD SDA Data input/output for serial PD SA0, SA1 Serial address input VDD Power for internal circuit VDDSPD Power for serial EEPROM VREFCA Reference voltage for CA VREFDQ Reference voltage for DQ VSS Ground VTT I/O termination supply for SDRAM /RESET Set DRAM to known state ODT0, ODT1 ODT control /EVENT Temperature event pin NC No connection Apacer Memory Product Specification Block Diagram /RESET VTT VDDSPD VREFCA VREFDQ VDD VSS "    Rs3 Rs1  Rs1             " Serial PD SDRAMs (D0 to D15), SPD D2 Notes : 1. DQ wiring may be changed within a byte. 2. DQ, DQS, /DQS, ODT, DM, CKE, /CS relationships must be maintained as shown. V2 D8 D7 V8 V3 D14 V7 V4 V5 D3 D12 V6 D13 SCL SCL SA0 A0 SA1 A1 A2 SDA U1 /EVENT /EVENT D10 V4 D9 V5 D11 D4 V6 VTT V3 * D0 to D15: 1G bits DDR3 SDRAM Address, BA: A0 to A13, BA0 to BA2 Command: /RAS, /CAS, /WE U1: 256 bytes EEPROM Rs1: 159 Rs2: 369 Rs3: 309 Rs4: 2409 V1V9 V2 D0 V1 V9 D5 V7 D15 V8 D6 Address and Control lines Rs4   " "         Rs1 " /RESET:SDRAMs (D0 to D15) D1 Rs4          ! "         !    Rs1  Rs4     Rs1 SPD SDRAMs (D0 to D15) SDRAMs (D0 to D15) SDRAMs (D0 to D15) Rs4          ! Rs4 Rs4 Rs3 Rs2 Rs2 Rs2 Rs2 Rs2 Rs3           Rs4          ! "   Rs1  "        !  Rs1          ! Rs4          ! Rs4      Rs1  "    Rs1 " SDA Rs4                      "        !  Rs1   Rs1    Rs1   Rs4  Rs1        Rs1 " Rs1 Rs3 Rs2 Rs2 Rs2             ! Rs1     Rs1        !      Rs4 Rs1      Rs4 Rs1  "         Rs1     Rs1   Rs1 "        !     "  Rs1           ! Rs1  Rs4          Rs4 Rs1  Rs4  Rs1   Rs1 "       Rs1      Rs1        !              !  Rs1         !  Rs1        ! Rs1     Rs2 Rs2          !       Apacer Memory Product Specification Unit: mm Front side 21.15 2.00 Min 9.00 3.80 Max (DATUM -A-) 4x Full R 1 203 6.00 4.00 Min Component area (Front) A B 21.00 2.15 2.45 39.00 D 1.00 ± 0.10 67.60 Back side 63.60 2.45 2.15 Component area (Back) 20.00 30.00 4.00 204 2 C (DATUM -A-) Detail A Detail B 0.45 ± 0.03 Detail C FULL R 1.65 3.00 4.00 ± 0.10 0.35 Max 2.55 Min 0.60 1.00 ± 0.10 Detail D Contact pad 1.35 0.2 Max 0.35 Max 3.00 (All dimensions are in millimeters with ±0.15mm tolerance unless specified otherwise.)
75.A73CG.G010C 价格&库存
很抱歉,暂时无法提供与“75.A73CG.G010C”相匹配的价格&库存,您可以联系我们找货
