AP-FD25C23E0128GS-5TM
    APACERMEMORYAMERICA(宇瞻科技)
    PATA 2.5 FLASH DRIVE MLC 128GB
AP-FD25C23E0128GS-5TM 数据手册
RoHS Compliant ATA Flash Drive 257-M Product Specifications (Toshiba 15nm) December 2, 2016 Version 1.4 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX Features:  Standard ATA/IDE Bus Interface – ATA command set compatible – ATA operating mode supports up to: PIO Mode-4 Multiword DMA Mode-2 Ultra DMA Mode-6  Capacity – 32, 64, 128, 256 GB  Performance* – Sustained read: Up to 100 MB/sec – Sustained write: Up to 90 MB/sec   Flash Management – Advanced wear-leveling algorithms – S.M.A.R.T. – Built-in hardware ECC: 72bit/1KB – Flash Block Management – Power Failure Management – ATA Secure Erase  Temperature Range – Operation: Standard: 0°C to 70°C Extended: -40°C to 85°C – Storage: -40°C to 100°C  Power Consumption* – Supply voltage: 5V – Active mode: 400 mA – Idle mode: 20 mA  Connector Type – 44-pin male  Master/Slave Jumper Setting  RoHS Compliant NAND Flash Type: MLC *Varies from capacities. The values presented in Performance and Power consumption are typical and may vary depending on various settings and platforms. 1 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX Table of Contents 1. General Description .............................................................................. 3 2. Functional Block ................................................................................... 3 3. Pin Assignments .................................................................................... 4 3.1 Pin Definitions ...................................................................................................................................... 4 3.2 Jumper Setting .................................................................................................................................... 5 4. Product Specifications.......................................................................... 6 4.1 Capacity Specifications ....................................................................................................................... 6 4.2 Performance Specifications ................................................................................................................. 6 4.3 Environmental Specifications .............................................................................................................. 6 5. Flash Management ................................................................................ 7 5.1 Advanced Wear-Leveling Algorithms .................................................................................................. 7 5.2 S.M.A.R.T. ........................................................................................................................................... 7 5.3 Built-in Hardware ECC ........................................................................................................................ 7 5.4 Flash Block Management .................................................................................................................... 7 5.5 Power Failure Management ................................................................................................................ 8 6. Software Interface ................................................................................ 9 6.1 Command Set ...................................................................................................................................... 9 6.2 ATA Secure Erase ............................................................................................................................... 9 7. Electrical Specifications .................................................................... 10 8. Physical Characteristics ..................................................................... 11 9. Product Ordering Information ............................................................. 12 9.1 Product Code Designations ............................................................................................................... 12 9.2 Valid Combinations ............................................................................................................................ 13 9.2.1 Standard Temperature ................................................................................................................ 13 9.2.2 Extended Temperature ............................................................................................................... 13 2 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX 1. General Description Apacer’s ATA-Flash Drive (AFD) is a high-performance, solid state drive (SSD) designed to replace a conventional IDE hard disk drive. AFD supports standard ATA/IDE protocol and can be plugged into a standard IDE connector commonly found in desktop or portable PCs. It is more rugged, reliable and power-efficient compared to the mechanical hard drive and is designed for use in rugged laptops, military devices, thin clients, Point of Sale (POS) terminals, telecom, medical instruments, surveillance systems and industrials PCs. AFD also offers users selectable Master/Slave operation through an external jumper setting. Apacer AFD Series is the best instant replacement for high-maintenance HDD where reliability is a major concern. AFD includes a built-in microcontroller and file management firmware that communicates through with the ATA standard interfaces. AFD is designed to work at 5 Volts, support the standard ATA/IDE protocol up to PIO Mode-4, Multiword DMA Mode-2, and Ultra DMA Mode-6 interfaces, and use a standard ATA driver that fits to most of the mainstream operating systems. Featuring technologies as Advanced Wear-leveling algorithms, S.M.A.R.T, Enhanced Data Integrity, Power Failure Management, and ATA Secure Erase, the AFD device assures users of security in storage applications. 2. Functional Block The ATA-Flash Drive (AFD) includes the ATA controller and flash media, as well as the ATA standard interface. Figure 2-1 shows the functional block diagram. Figure 2-1 Functional Block Diagram 3 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX 3. Pin Assignments 3.1 Pin Definitions Table 3-1 lists the pin assignments with respective signal names for the 44-pin configuration. A “#” suffix indicates the active low signal. The pin type can be input, output or input/output. Figure 3-1 44-pin Connector Pin 43 Pin 1 Table 3-1 Pin Assignments for the 44-Pin Configuration Pin No. Signal Name Pin Type Pin No. Signal Name Pin Type 1 3 5 7 9 11 13 15 17 19 21 23 RESET# D7 D6 D5 D4 D3 D2 D1 D0 GND DMARQ IOWR# IORD# HDMARDY# HSTROBE# IORDY DDMARDY# DSTROBE DMACK# INTRQ A1 A0 CS1FX# DASP# VDD GND I I/O I/O I/O I/O I/O I/O I/O I/O O I 2 4 6 8 10 12 14 16 18 20 22 24 GND D8 D9 D10 D11 D12 D13 D14 D15 NC GND GND I/O I/O I/O I/O I/O I/O I/O I/O - I 26 GND - O 28 CSEL I I O I I I I/O - 30 32 34 36 38 40 42 44 GND IOCS16# PDIAG# A2 CS3FX# GND VDD NC O I/O I I - 25 27 29 31 33 35 37 39 41 43 - 4 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX 3.2 Jumper Setting 5 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX 4. Product Specifications 4.1 Capacity Specifications Capacity specifications of the ATA-Flash Drive (AFD) list out unformatted, out-of-box capacity information. Table 4-1 Capacity Specifications Capacity Total bytes* Cylinders** Heads Sectors Max LBA 32 GB 32,017,047,552 16383 16 63 62,533,296 64 GB 64,023,257,088 16383 16 63 125,045,424 128 GB 128,035,676,160 16383 16 63 250,069,680 256 GB 256,060,514,304 16383 16 63 500,118,192 *Display of total bytes varies from file systems. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Specifications Performance of the ATA-Flash Drive is listed in Table 4-2. Table 4-2 Performance Specifications Capacity 32 GB 64 GB 128 GB 256 GB Sustained Read (MB/s) 100 100 100 100 Sustained Write (MB/s) 40 75 75 90 Performance Note: Performance varies from flash configurations or host system configurations. 4.3 Environmental Specifications Environmental specifications of the ATA-Flash Drive follow the standards of MIL-STD-810F. Table 4-3 Environmental Specifications Item Criteria Non-Operating Temperature -40°C to 100°C Operating Temperature 0°C to 70°C (Standard); -40°C to 85°C (Extended) Non-Operating Vibration Sine wave: 15(G), 10~2000(Hz); X, Y, Z axis Non-Operating Shock 1,500(G), 0.5(ms), ±X, ±Y, ±Z axis 6 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX 5. Flash Management 5.1 Advanced Wear-Leveling Algorithms Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. On the other hand, NAND flash storage adopt flash as their primary media. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term earlier. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 5.2 S.M.A.R.T. S.M.A.R.T. is an acronym for Self-Monitoring, Analysis and Reporting Technology, an open standard allowing disk drives to automatically monitor their own health and report potential problems. It protects the user from unscheduled downtime by monitoring and storing critical drive performance and attributes parameters. Ideally, this should allow taking proactive actions to prevent impending drive failure. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our SMART feature that complies with the ATA/ATAPI specifications. Based on the SFF-8035i Rev. 2.0 specifications, SMART Attribute IDs shall include Initial bad block count, Bad block count, Spare block count, Maximum erase count, Average erase count and Power cycle. When the SMART Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. 5.3 Built-in Hardware ECC The properties of NAND flash memory make it ideal for applications that require high integrity while operating in challenging environments. The integrity of data to NAND flash memory is generally maintained through ECC algorithms. This ATA-Flash Drive is programmed with a hardware ECC engine which correct up to 72 bits per 1KB. 5.4 Flash Block Management Current process technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a highly minimal number of initial bad block during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. On the other hand, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 7 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX 5.5 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 8 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX 6. Software Interface 6.1 Command Set Table 6-1 Command Set Code Command Code Command E5h Check Power Mode F6h Security Disable Password 92h Download Microcode F3h Security Erase Prepare 90h Execute Device Diagnostic F4h Security Erase Unit E7h Flush Cache F5h Security Freeze Lock EAh Flush Cache EXT F1h Security Set Password ECh Identify Device F2h Security Unlock A1h Identify Packet Device 70h Seek E3h Idle EFh Set Features E1h Idle Immediate F9h Set Max* 91h Initialize Device Parameters 37h Set Max Address EXT 00h NOP C6h Set Multiple Mode E4h Read Buffer E6h Sleep C8h Read DMA B0h SMART 25h Read DMA EXT E2h Standby C4h Read Multiple E0h Standby Immediate 29h Read Multiple EXT E8h Write Buffer F8h Read Native Max Address CAh Write DMA 27h Read Native Max Address EXT 35h Write DMA EXT 20h Read Sector C5h Write Multiple 24h Read Sector EXT 39h Write Multiple EXT 40h Read Verify Sectors 30h Write Sector 42h Read Verify Sectors EXT 34h Write Sector EXT 10h Recalibrate *The command can be configured as “Set Max Lock”, “Set Max Address”, “Set Max Set Password”, “Set Max Unlock” and “Set Max Freeze Lock”, depending on the transfer mode in operation. 6.2 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 9 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX 7. Electrical Specifications Table 7-1 Operating Voltage & Temperature Standard Extended Operating Voltage Ambient Temperature 0°C to 70°C -40°C to 85°C 5V± 5% (4.75-5.25V) Table 7-2 Power Consumption Capacity 32 GB 64 GB 128 GB 256 GB Active (mA) 265 270 265 400 Idle (mA) 20 20 20 20 Modes Note: Power consumption varies from flash configurations or host system configurations. 10 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX 8. Physical Characteristics 11 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX 9. Product Ordering Information 9.1 Product Code Designations AP – FD25 C 2 3 E xxxxG S – X X XX Flash Type FW Version Temperature Blank: Standard Temperature W: Wide Temperature Environmental Specifications S: RoHS + Halogen free Compliant Capacity 0032G = 32GB 0064G = 64GB 0128G = 128GB 0256G = 256GB Product Type E = 2.5 inched/180D with STD function PCB Version Outline 180D Degree Controller Version 2.5 inch ATA Flash Drive Apacer Product Code 12 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX 9.2 Valid Combinations 9.2.1 Standard Temperature Capacity 32GB 64GB 128GB 256GB Model Number AP-FD25C23E0032GS-5TM AP-FD25C23E0064GS-5TM AP-FD25C23E0128GS-5TM AP-FD25C23E0256GS-5TM 9.2.2 Extended Temperature Capacity 32GB 64GB 128GB 256GB Model Number AP-FD25C23E0032GS-W5TM AP-FD25C23E0064GS-W5TM AP-FD25C23E0128GS-W5TM AP-FD25C23E0256GS-W5TM Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 13 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX Revision History Revision Date Description Remark 1.0 1/6/2016 Official release 1.1 2/25/2016 Revised power consumption values 1.2 3/29/2016 Revised product ordering information 1.3 6/17/2016 Revised the code for the Set Max Address EXT command 1.4 12/2/2016 Updated product ordering information 14 © 2016 Apacer Technology Inc. Rev. 1.4 ATA Flash Drive 257- M AP-FD25C23ExxxxGS-XXXX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9551 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, th Unit No.201, “Brigade Corner”, 7 Block Jayanagar, Yediyur Circle, Bangalore – 560082, India Tel: 91-80-4152-9061 Fax: 91-80-4170-0215 sales_india@apacer.com 15 © 2016 Apacer Technology Inc. Rev. 1.4
AP-FD25C23E0128GS-5TM 价格&库存
很抱歉,暂时无法提供与“AP-FD25C23E0128GS-5TM”相匹配的价格&库存,您可以联系我们找货
