AP-UM256MR31CG-2MSNRT
    APACERMEMORYAMERICA(宇瞻科技)
    USB DISK MODULE SLC 90D MOUNTING
AP-UM256MR31CG-2MSNRT 数据手册
RoHS Recast Compliant 86%'LVN0RGXOH҈Plus Product Specifications June 10th, 2014 9HUVLRQ Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan Tel: +886-2-2267-8000 Fax: +886-2-2267-2261 www.apacer.com USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT )($785(6 • • – – • • • USB2.0 High-Speed and USB1.1 FullSpeed compatible interface Capacity 256, 512 MB 1, 2, 4, 8, 16, 32 GB Intelligent USB Module Advanced wear-leveling algorithms to substantially increase longevity of flash media – BCH (24 bit) Error Detection Code/Error Correction Code (EDC/ECC) – – – – Temperature ranges 0°C to 70°C for operation (standard) 1 -40°C to 85°C for operation (ET ) -40°C to 85°C for storage • – – – • Extended Data Protection (Optional) – Write protection setting by jumper for prevention of data overwrites. • Support boot-up function for OS Windows XP Embedded Windows CE Linux Windows 7 • Performance – Sustained read: up to 34 MB/s – Sustained write: up to 22 MB/s – • – – – – – MTBF 6 Approximately greater than 4.20 x 10 hours Power consumption (typical) Active mode: 181 mA Idle mode: 68 mA Operating voltage: 5V (with a certain percentage of tolerance) Connector 10-pin (2x5) female header • NAND Flash type: SLC • Supports Ready Boost for Vista • RoHS Recast Compliant (2011/65/EU) • Support Non-Removable Setting 1. Extended Temperature Notes: the results for performance and power consumption addressed here may vary in real world platforms. 1 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 7$%/(2)&217(176 *HQHUDO'HVFULSWLRQ  1.1 Performance-optimized Controller....................................................................................................... 3 1.1.1 Error Correction Code (ECC) ........................................................................................................................3 1.1.2 Wear-Leveling ...............................................................................................................................................3 1.1.3 Write Protection Mode (Optional) ..................................................................................................................3 )XQFWLRQDO%ORFN'LDJUDP 3LQ$VVLJQPHQW ϐ ϑ ϐ ϑ 3.1 Type A, Type B, and Type C ............................................................................................................... 5 3.2 Type D STD ................................................................................................................................... 6 3.3 Type D LP ..................................................................................................................................... 7 3.4 Type E (LP) ......................................................................................................................................... 8 3HUIRUPDQFH 5HOLDELOLW\6SHFLILFDWLRQV  4.1 Capacity Specifications ....................................................................................................................... 9 4.2 Performance Specifications................................................................................................................. 9 4.3 Environmental Specifications .............................................................................................................. 9 4.4 MTBF ................................................................................................................................................. 10 (OHFWULFDO6SHFLILFDWLRQ  5.1 AC Characteristics............................................................................................................................. 11 3K\VLFDO'LPHQVLRQ  6.1 Horizontal Design .............................................................................................................................. 12 6.1.1 Type A (STD 90D)......................................................................................................................................12 6.1.2 Type B (STD 90D-MH) ...............................................................................................................................13 6.1.3 Type C (STD 90D-MS) ...............................................................................................................................14 6.2 Vertical Design .................................................................................................................................. 15 6.2.1 Type D (STD 180D)....................................................................................................................................15 6.3 Low Profile Design............................................................................................................................. 16 6.3.1 Type D (LP 180D) .......................................................................................................................................16 6.3.1 Type E (LP 90D) .........................................................................................................................................17 3URGXFW2UGHULQJ,QIRUPDWLRQ 7.1 Product Code Designation ................................................................................................................ 18 7.2 Valid Combinations ........................................................................................................................... 19 2 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT *HQHUDO'HVFULSWLRQ Apacer’s USB-Disk Module (UDM) is a high performance, embedded solid state drive (SSD) designed to replace a conventional IDE hard disk drive. UDM SSD can be plugged into a standard Embedded USB connector commonly found in desktops, portable PC systems and industrial PC systems. This product is well suited for embedded flash storage applications offering new and expanded functionality as well as more cost-effective designs, better performance and increased reliability. 1.1 Performance-optimized Controller The heart of an UDM is the USB controller, which translates standard USB signals into the data and controls of the flash media. This proprietary USB controller is specifically designed to attain high data throughput from host to flash. 1.1.1 Error Correction Code (ECC) The UDM uses BCH Error Detection Code (EDC) and Error Correction Code (ECC) algorithms which correct up to 24 random single-bit errors for each 1024-byte block of data depending on spare area of flash memory. High performance is achieved through hardware-based error detection and correction. 1.1.2 Wear-Leveling Flash memory can be erased a limited number of times, This number is called the erase cycle limit, or write endurance limit, The erase cycle limit applies to each individual erase block in the flash device. In a typical application, and especially if a file system is used, specific pages are constantly updated (e.g., the page that contains the FAT, registry, etc.). Without any special handling, these pages would wear out more rapidly than other pages, reducing the lifetime of the entire flash. To overcome this inherent deficiency, Apacer’s USB-Disk Module (UDM) uses wear-leveling algorithm. This wear-leveling algorithm ensures that consecutive writes of a specific sector are not written physically to the same page in the flash. This spreads flash media usage evenly across all pages, thereby maximizing flash lifetime. The wear-leveling mechanism provides write/erase cycles for reliable data storage over an extended period. 1.1.3 Write Protection Mode (Optional) When the device is configured to the Write-Protection mode, it enhances the data security and protection. This feature prevents the stored data from inadvertent system writes or erases, and viruses. 3 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT )XQFWLRQDO%ORFN'LDJUDP The USB-Disk Module (UDM) contains a controller, embedded firmware, and Flash Media with a female connector. The UDM interfaces with the host system allowing data to be written to and read from the Flash Media. Flash Media Host USB Interface Flash Management Controller Flash Media Figure 2-1: Functional block diagram 4 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 3LQ$VVLJQPHQW This chapter provides the information on the pin assignments and signal descriptions. 3.1 Type A, Type B, and Type C Table 3-1: Pin Assignment of the 10-pin configuration in Type A, Type B, Type C, and Type E Pin Signal Pin Signal 1 +5V 2 N.C 3 USB D- 4 N.C 5 USB D+ 6 N.C 7 GND 8 N.C 9 Key (Blocked) 10 N.C 5 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 3.2 Type Dϐ ϐSTDϑ ϑ Table 3-2: Pin Assignment of the 10-pin configuration in Type D (STD) Pin Signal Pin Signal 1 +5V 2 +5V 3 USB D- 4 N.C 5 USB D+ 6 N.C 7 GND 8 GND 9 Key (Blocked) 10 GND 6 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 3.3 Type Dϐ ϐLPϑ ϑ Table 3-3: Pin Assignment of the 10-pin configuration in Type D (LP) Pin Signal Pin Signal 1 +5V 2 N.C 3 USB D- 4 N.C 5 USB D+ 6 N.C 7 GND 8 N.C 9 Key (Blocked) 10 N.C 7 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 3.4 Type E (LP) Table 3-4: Pin Assignment of the 10-pin configuration in Type A, Type B, Type C, and Type E Pin Signal Pin Signal 1 +5V 2 N.C 3 USB D- 4 N.C 5 USB D+ 6 N.C 7 GND 8 N.C 9 Key (Blocked) 10 N.C 8 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 3HUIRUPDQFH 5HOLDELOLW\6SHFLILFDWLRQV 4.1 Capacity Specifications The USB-Disk Module product family is available as below table matrix. Table 4-1: Capacity Specification Density Total Bytes 256MB 254,509,056 512 MB 512,458,752 1GB 1,029,406,720 2GB 2,061,205,504 4GB 4,120,920,064 8GB 8,248,131,584 16GB 16,030,662,656 32GB 32,061,292,544 Notes: the number of total bytes may vary depending on the file system in use. 4.2 Performance Specifications Table 4-2: Performance Specifications Capacity 256 MB 512 MB 1 GB 2 GB 4 GB 8 GB 16 GB 32 GB Sustained read (MB/s) 31 31 32 34 28 32 34 31 Sustained write (MB/s) 10 15 19 19 21 15 22 21 Performance Note: results may vary in real world platforms or flash configurations. 4.3 Environmental Specifications Environmental specification of the USB-Disk Module (UDM) product family which follows the MIL-STD810F standards is available as shown in Table 4-3. Table 4-3: Environmental Specifications Temperature Operation Storage 0°C to 70°C (Std.); -40°C to 85°C (Ext. Temp.) -40°C to 85°C Vibration Sine wave 10 Hz to 500 Hz, 50 m/s , 3 axes (IEC 68-2-6, non-operating) Shock Half sine wave 50G, 6 axes, 18 times (IEC 68-2-27, non-operating) EMC FCC, CE 2 9 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 4.4 MTBF Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in this device. The measurement assumes that device failure rate can be generated by the sum of failure rates in each component and a steady state failure rate can be predicated as equal to or greater than 6 4.20 x 10 hours. Notes about the MTBF: The MTBF is predicated and calculated based on “Bellcore Analysis Method 1”. 10 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT (OHFWULFDO6SHFLILFDWLRQ Caution: Absolute Maximum Stress Ratings – Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability. Table 5-1: Operating Range Range Ambient Temperature Voltage Standard Extended Temperature 0°C to 70°C -40°C to 85°C 4.5-5.5V Table 5-2: Absolute maximum power pin stress ratings Parameter Power Supply Input Voltage on any pin except VDD with respect to GND Symbol Min Max Unit VDD- VSS VIN -0.3 –ss – 0.3 5.5 VDD +0.3 V V 5.1 AC Characteristics Table 5-3: AC Characteristics Full Speed Parameter Symbol Min Rise Time TFR 4 Fall Time TFF 4 Differential Rise and Fall Time Matching TFRFM 90 Driver Output Resistance ZDRV 28 Typ Max Unit 20 ns 20 ns 111.11 % 44 Ө Typ Max Unit ѧ ѧ ѧ ѧ ѧ ѧ ѧ ѧ Table 5-4: AC Characteristics High Speed Parameter Symbol Min Rise Time (10%~90%) THSR 500 Fall Time (10%~90%) THSF 500 Driver Output Resistance ZHSDRV 40.5 49.5 ps ps Ө 11 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 3K\VLFDO'LPHQVLRQ 6.1 Horizontal Design 6.1.1 Type A (STD 90D) Standard 90 degree Length 28.8mm Width 26.65mm Height (Max) 10.5 mm Unit: mm Tolerance: ̈́0.2 12 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 6.1.2 Type B (STD 90D-MH) Standard 90 Degree Mounting Header Length 37.8mm Width 26.65mm Height (Max) 10.5 mm Unit: mm Tolerance: ̈́0.2 13 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 6.1.3 Type C (STD 90D-MS) Standard 90 Degree Mounting Screw Length 37.8mm Width 26.65mm Height (Max) 10.5 mm     Unit: mm Tolerance: ̈́0.2 14 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 6.2 Vertical Design 6.2.1 Type D (STD 180D) Standard 180 Degree Length 37.3mm Width 26.65mm Height (Max) 8.5 mm Unit: mm Tolerance: ̈́0.2 15 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 6.3 Low Profile Design 6.3.1 Type D (LP 180D) Low Profile 180 Degree Length 31.50mm Width 24mm Height (Max) 5 mm Unit: mm Tolerance: ̈́0.2 16 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 6.3.1 Type E (LP 90D) Low Profile 90 Degree Length                                       36.80mm Width Write Protect 26.50mm Height (Max) 7.10 mm Read/Write Write Protect Switch Unit: mm Tolerance: ̈́0.2 17 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 3URGXFW2UGHULQJ,QIRUPDWLRQ 7.1 Product Code Designation AP – UM xxxx X X X X X – X XX XX T Toshiba SLC Option: RB: Ready Boost WP: Write Protection NR: Non-Removable MS: Mounting Screw MH: Mounting Header FW Version S: Halogen-free Compliant G: RoHS Compliant Temperature: C: Commercial Temperature E: Extended Temperature PCB version Dimension 1 = 90D STD 2 = 180D STD 3 = 90D Low Profile 4 = 180D Low Profile Solution version Capacities: 256M = 256MB 512M = 512MB 001G = 1GB 002G = 2GB 004G = 4GB 008G = 8GB 016G = 16GB 032G = 32GB Model Name Apacer Product Code 18 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 7.2 Valid Combinations 7.2.1 Type A (STD 90D) Standard 90 degree Capacity ʳ ʳ ʳ Standard 256MB 512MB 1GB AP-UM256MR13CS-2T ʳ AP-UM512MR13CS-2T ʳ AP-UM001GR13CS-2T ʳ 2GB 4GB ʳ ʳ AP-UM008GR13CS-2T ʳ AP-UM016GR13CS-2T ʳ AP-UM032GR13CS-2T ʳ 8GB 16GB 32GB Extended Temperature AP-UM256MT13ES-2T AP-UM512MT13ES-2T AP-UM001GT13ES-2T AP-UM002GT13ES-2T AP-UM004GT13ES-2T AP-UM008GT13ES-2T AP-UM016GT13ES-2T AP-UM002GR13CS-2T AP-UM004GR13CS-2T AP-UM032GT13ES-2T 7.2.2 Type B (STD 90D-MH) Standard 90 degree Mounting Header Capacity ʳ ʳ ʳ Standard Extended Temperature 256MB AP-UM256MR13CS-2MHT ʳ AP-UM256MT13ES-2MHT 512MB 1GB 2GB AP-UM512MR13CS-2MHT ʳ AP-UM001GR13CS-2MHT ʳ AP-UM002GR13CS-2MHT ʳ AP-UM512MT13ES-2MHT AP-UM001GT13ES-2MHT AP-UM002GT13ES-2MHT 4GB 8GB AP-UM004GR13CS-2MHT ʳ AP-UM008GR13CS-2MHT ʳ 16GB 32GB AP-UM016GR13CS-2MHT ʳ AP-UM032GR13CS-2MHT ʳ AP-UM004GT13ES-2MHT AP-UM008GT13ES-2MHT AP-UM016GT13ES-2MHT AP-UM032GT13ES-2MHT 7.2.3 Type C (STD 90D-MS) Standard 90 degree Mounting Screw Capacity ʳ ʳ ʳ Standard Extended Temperature 256MB AP-UM256MR13CS-2MST ʳ AP-UM256MT13ES-2MST 512MB 1GB AP-UM512MR13CS-2MST ʳ AP-UM001GR13CS-2MST ʳ AP-UM512MT13ES-2MST AP-UM001GT13ES-2MST 2GB 4GB AP-UM002GR13CS-2MST ʳ AP-UM004GR13CS-2MST ʳ 8GB 16GB AP-UM008GR13CS-2MST ʳ AP-UM016GR13CS-2MST ʳ AP-UM002GT13ES-2MST AP-UM004GT13ES-2MST AP-UM008GT13ES-2MST AP-UM016GT13ES-2MST 32GB AP-UM032GR13CS-2MST ʳ AP-UM032GT13ES-2MST 19 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 7.2.4 Type D (STD 180D) Standard 180 degree Capacity ʳ ʳ ʳ Standard Extended Temperature 256MB AP-UM256MR23CS-2T ʳ AP-UM256MT23ES-2T 512MB 1GB AP-UM512MR23CS-2T ʳ AP-UM001GR23CS-2T ʳ AP-UM512MT23ES-2T AP-UM001GT23ES-2T 2GB 4GB ʳ ʳ AP-UM008GR23CS-2T ʳ AP-UM016GR23CS-2T ʳ AP-UM032GR23CS-2T ʳ AP-UM002GT23ES-2T AP-UM004GT23ES-2T 8GB 16GB 32GB AP-UM002GR23CS-2T AP-UM004GR23CS-2T AP-UM008GT23ES-2T AP-UM016GT23ES-2T AP-UM032GT23ES-2T 7.2.5 Type D (LP 180D) Low Profile 180 Degree Capacity ʳ ʳ 256MB 512MB 1GB 2GB 4GB 8GB ʳ Standard Extended Temperature ʳ ʳ ʳ ʳ AP-UM004GR40CG-2T ʳ AP-UM008GR40CG-2T ʳ AP-UM256MR40CG-2T AP-UM512MR40CG-2T AP-UM001GR40CG-2T AP-UM002GR40CG-2T AP-UM256MT40EG-2T AP-UM512MT40EG-2T AP-UM001GT40EG-2T AP-UM002GT40EG-2T AP-UM004GT40EG-2T AP-UM008GT40EG-2T 7.2.6 Type E (LP 90D-MS) Low Profile 90 Degree Mounting Screw Capacity ʳ ʳ 256MB 512MB 1GB 2GB 4GB 8GB ʳ Standard ʳ ʳ ʳ ʳ AP-UM004GR31CG-2MST ʳ AP-UM008GR31CG-2MST ʳ AP-UM256MR31CG-2MST AP-UM512MR31CG-2MST AP-UM001GR31CG-2MST AP-UM002GR31CG-2MST Extended Temperature AP-UM256MT31EG-2MST AP-UM512MT31EG-2MST AP-UM001GT31EG-2MST AP-UM002GT31EG-2MST AP-UM004GT31EG-2MST AP-UM008GT31EG-2MST 20 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 7.2.7 Type A (STD 90D) - NR Standard 90 degree Capacity ʳ ʳ ʳ Standard Extended Temperature 256MB AP-UM256MR13CS-2NRT ʳ AP-UM256MT13ES-2NRT 512MB 1GB AP-UM512MR13CS-2NRT ʳ AP-UM001GR13CS-2NRT ʳ AP-UM512MT13ES-2NRT AP-UM001GT13ES-2NRT 2GB 4GB AP-UM002GR13CS-2NRT ʳ AP-UM004GR13CS-2NRT ʳ AP-UM002GT13ES-2NRT AP-UM004GT13ES-2NRT 8GB 16GB AP-UM008GR13CS-2NRT ʳ AP-UM016GR13CS-2NRT ʳ AP-UM008GT13ES-2NRT AP-UM016GT13ES-2NRT 32GB AP-UM032GR13CS-2NRT ʳ AP-UM032GT13ES-2NRT 7.2.8 Type B (STD 90D-MH) - NR Standard 90 degree Mounting Header Capacity ʳ ʳ ʳ Standard 256MB 512MB 1GB AP-UM256MR13CS-2MHNRT ʳ AP-UM512MR13CS-2MHNRT ʳ AP-UM001GR13CS-2MHNRT ʳ 2GB 4GB AP-UM002GR13CS-2MHNRT ʳ AP-UM004GR13CS-2MHNRT ʳ 8GB 16GB AP-UM008GR13CS-2MHNRT ʳ AP-UM016GR13CS-2MHNRT ʳ 32GB AP-UM032GR13CS-2MHNRT ʳ Extended Temperature AP-UM256MT13ES-2MHNRT AP-UM512MT13ES-2MHNRT AP-UM001GT13ES-2MHNRT AP-UM002GT13ES-2MHNRT AP-UM004GT13ES-2MHNRT AP-UM008GT13ES-2MHNRT AP-UM016GT13ES-2MHNRT AP-UM032GT13ES-2MHNRT 7.2.9 Type C (STD 90D-MS) - NR Standard 90 degree Mounting Screw Capacity ʳ ʳ ʳ Standard Extended Temperature 256MB AP-UM256MR13CS-2MSNRT ʳ AP-UM256MT13ES-2MSNRT 512MB 1GB AP-UM512MR13CS-2MSNRT ʳ AP-UM001GR13CS-2MSNRT ʳ 2GB 4GB AP-UM002GR13CS-2MSNRT ʳ AP-UM004GR13CS-2MSNRT ʳ AP-UM512MT13ES-2MSNRT AP-UM001GT13ES-2MSNRT AP-UM002GT13ES-2MSNRT AP-UM004GT13ES-2MSNRT 8GB 16GB AP-UM008GR13CS-2MSNRT ʳ AP-UM016GR13CS-2MSNRT ʳ AP-UM008GT13ES-2MSNRT AP-UM016GT13ES-2MSNRT 32GB AP-UM032GR13CS-2MSNRT ʳ AP-UM032GT13ES-2MSNRT 21 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 7.2.10 Type D (STD 180D) - NR Standard 180 degree Capacity ʳ ʳ ʳ Standard Extended Temperature 256MB AP-UM256MR23CS-2NRT ʳ AP-UM256MT23ES-2NRT 512MB 1GB AP-UM512MR23CS-2NRT ʳ AP-UM001GR23CS-2NRT ʳ AP-UM512MT23ES-2NRT AP-UM001GT23ES-2NRT 2GB 4GB AP-UM002GR23CS-2NRT ʳ AP-UM004GR23CS-2NRT ʳ AP-UM002GT23ES-2NRT AP-UM004GT23ES-2NRT 8GB 16GB AP-UM008GR23CS-2NRT ʳ AP-UM016GR23CS-2NRT ʳ AP-UM008GT23ES-2NRT AP-UM016GT23ES-2NRT 32GB AP-UM032GR23CS-2NRT ʳ AP-UM032GT23ES-2NRT 7.2.11 Type D (LP 180D) - NR Low Profile 180 Degree Capacity ʳ ʳ 256MB 512MB 1GB 2GB 4GB 8GB ʳ Standard Extended Temperature ʳ ʳ ʳ ʳ AP-UM004GR40CG-2NRT ʳ AP-UM008GR40CG-2NRT ʳ AP-UM256MR40CG-2NRT AP-UM512MR40CG-2NRT AP-UM001GR40CG-2NRT AP-UM002GR40CG-2NRT AP-UM256MT40EG-2NRT AP-UM512MT40EG-2NRT AP-UM001GT40EG-2NRT AP-UM002GT40EG-2NRT AP-UM004GT40EG-2NRT AP-UM008GT40EG-2NRT 7.2.12 Type E (LP 90D-MS) - NR Low Profile 90 Degree Mounting Screw Capacity ʳ ʳ ʳ Standard Extended Temperature 256MB AP-UM256MR31CG-2MSNRT ʳ AP-UM256MT31EG-2MSNRT 512MB 1GB AP-UM512MR31CG-2MSNRT ʳ AP-UM001GR31CG-2MSNRT ʳ 2GB 4GB AP-UM002GR31CG-2MSNRT ʳ AP-UM004GR31CG-2MSNRT ʳ 8GB AP-UM008GR31CG-2MSNRT ʳ AP-UM512MT31EG-2MSNRT AP-UM001GT31EG-2MSNRT AP-UM002GT31EG-2MSNRT AP-UM004GT31EG-2MSNRT AP-UM008GT31EG-2MSNRT Note: Please consult with our sales representatives for availabilities. 22 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT 5HYLVLRQ+LVWRU\ Revision Description Date 1.0 Official Release May 16, 2011 1.1 Revised Capacity Specifications May 24, 2011 1.2 Revised Product Ordering Information Updated address for our branch in Europe th April 10 , 2012 th 1.3 Added MTBF section May 10 , 2012 1.4 Added Non-removable model types into Product Ordering th June 20 , 2012 Information 1.5 Added 16GB & 32GB models June 29 , 2012 1.6 Updated Type-E mechanical diagram July 18 , 2012 1.7 Updated contact phone number of Apacer office in America August 30 , 2012 1.8 Added Write Protect switch to Type E mechanical drawing February 20 , 2013 1.9 Added Write Protect for 180D low profile and non-removable type th March 4 , 2013 in Product Ordering Information 2.0 Revised wear-leveling contents: from dynamic to advanced due to th April 11 , 2013 firmware upgrade 2.1 Updated performance due to change of NAND flash use July 26 , 2013 2.2 Revised Type D –LP mechanical drawing June 10 , 2014 th th th th th th 23 © 2014 Apacer Technology, Inc. Rev. 2.2 USB-Disk Module҈Plus AP-UMxxxxXXXXX-XXXXXT *OREDO3UHVHQFH Taiwan (Headquarters) Apacer Technology Inc. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt. Ltd. # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore – 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 24 © 2014 Apacer Technology, Inc. Rev. 2.2
物料型号:USB-Disk Module Plus AP-UMxxxxXXXXX-XXXXXT
器件简介: - 这是Apacer公司生产的USB-Disk Module (UDM),一种高性能的嵌入式固态硬盘(SSD),设计用来替代传统的IDE硬盘驱动器。UDM SSD可以插入桌面、便携式PC系统和工业PC系统中常见的标准嵌入式USB连接器。该产品非常适合嵌入式闪存存储应用,提供新的和扩展的功能,以及更具成本效益的设计、更好的性能和更高的可靠性。
引脚分配: - 引脚分配表详细列出了10针配置的信号定义,例如+5V电源、USB D-和D+数据线路、GND地线以及被阻塞的KEY信号。
参数特性: - 支持USB2.0高速和USB1.1全速兼容接口。 - 提供256MB至32GB不等的容量选项。 - 持续读取速度高达34MB/s,持续写入速度高达22MB/s。 - 采用先进的磨损均衡算法显著提高闪存媒体的寿命。 - 支持BCH(24位)错误检测代码/错误校正代码(EDC/ECC)。 - 可选的数据保护扩展功能,如通过跳线设置写保护以防止数据被覆盖。 - 平均无故障时间(MTBF)预计大于4.20 x 10^6小时。
功能详解: - 包括错误校正码(ECC)、磨损均衡、可选的写保护模式等,以确保数据的可靠性和存储的长期稳定性。
应用信息: - 支持多种操作系统启动功能,包括Windows XP Embedded、Windows CE、Linux、Windows 7等。 - 工作温度范围从0°C至70°C(标准),扩展温度范围可达-40°C至85°C。 - 支持Ready Boost for Vista。
封装信息: - 提供多种物理尺寸设计,包括水平和垂直设计,以及低剖面设计,以适应不同的应用需求。
产品订购信息: - 根据容量、温度范围、是否支持Ready Boost、是否具备写保护功能、是否为不可拆卸设计等因素,提供了详细的产品代码命名规则和有效组合选项。
AP-UM256MR31CG-2MSNRT 价格&库存
很抱歉,暂时无法提供与“AP-UM256MR31CG-2MSNRT”相匹配的价格&库存,您可以联系我们找货
